View Full Version : Honda Civic / Del Sol (1992 - 2000)
- ECU and Injector decisions for boosted del sol
- Car wouldn't start, then magically did?
- Double din in cupholder area
- low fuel light wire up?
- B16a2 Distributor
- Civic VX dies when in gear
- Oil change shenanigans!
- 1994 civic hatch wobble?
- Need help wiring d16y8
- Ek hatch OEM sunroof w/em1 donor?
- del sol a/c bezel removal
- 92 civic lx auto trans issues?
- how interchangable are d16z6 and d16y8 intake parts?
- 92 Hatch? Or 98 Hatch?
- Pear shaped project
- A/C Not Working 95 CIVIC
- radiator fan issues
- EJ8 blew? White smoke? Leaking oil? HELP!
- Disc brake conversion
- Electric window conversion
- why i cant post any topic at Marketplace??
- 00 Ex : brake pedal too low
- gas pedal issue... HELP!
- sportmax fitment?!?!?!
- 1994 civic hatch with b20 turbo swap problems
- CEL light when going around 90+
- EK - Lights/Indicators Worked, no longer work.
- 93 Del sol Targa top Leak Please help
- 97 civic ex passenger door lock problem...
- Main fan resolved, AC fan not working
- 94 del sol, 5 speed, with rough shifting
- D4 flashing, I think tranny took a dump.
- b16 90 vs b16 96 and up
- 92 civic cx - turbo?
- Need help with ECU
- 96 manual iac connector available?
- 93 del sol - pool of oil in cylinder 4 and 1
- Brake light issue
- Help ME Plzz with installing 91 B18 into my 97 Civic!!!
- wiring nightmare need help
- secondary o2 sensor location on 98 civic EX?
- Oil Leak help?
- 95 civic ex with custom turbo - looking for maintence suggestions
- Difference BETWEEN PKJ20CR-M11 vs. PKJ20CR-L11 spark plugs?
- AC compressor clutch
- 17 year old girl needs help rebuilding D Series
- 2000 Coupe vs EM1 Brake Differences
- Function & Form LCA Bushings
- 99 Civic EX Clutch Problem - hydro to cable
- WHAT ENGINE CODE IS THIS FROM? JDM??
- Need Del Sol for test fitting!!!
- 94 Civic: Bouncing Speedo
- Oil Weights in SoCal
- my first swap need some info?
- 94 Civic EX clock reseting with key and lights
- '95 Integra LS being parted out near me - what else do I need?
- Pretty sure my input shaft bearing is toast....
- Is it suppose to shift like this?
- Fitting Spoon seat into ek4
- 99 Civic sedan - D16Y7 in need of a swap
- 1998 Ek 1.4 Door Lock Problems!!
- Obd2a to obd2b conversion 98 civic
- y7 in 93 eg
- Hood Latch Part # Question
- yes or no ?
- jdm d15b into 96 civic
- gsr idles after hg replace and cleaned iacv too
- Overhauling b16 94 del sol vtec Parts?
- gsr trans/clutch problem?
- 00 civic - cabin blower GROWLS
- GSR Motor Idles at 3000RPM
- Civic Offset
- Consensus on front lower tie bar or h brace???
- Will a obd2 gsr dizzy work on my 99 si???
- EG with gsr dash w/ s2000 cluster
- eg hatch/LS swap - just revs up when in gear
- Thinking of buying a del Sol with Turbo
- knock sensor help!!
- Reusable pistons?
- low vtec pressure/oil pump?
- DZ struts, shocks and springs -- are these any good?
- Instrument cluster replacement help
- Car jumps hard between 1500-2000 rpm
- Cluster doesnt light up. Pinout help
- Skunk2 T1 Turbo Cams - B Series
- 93 civic with integra rear dics. can i still fit my 13 inch stock wheels
- 94 Civic EX 5-speed -- what are these plugs and box (see pics)?
- what cabin harness plug is this?
- What trunk lid will fit a 2000ex coupe?
- B16A2 - Solenoid-side Cam Cap - Valve cover off or not?
- Knock Sensor?????????
- Differences between 92-95 hatchback bumpers all trims front & rear?
- 93 DX - Idle will not set below 1000
- Removing 99-00 Civic Under Fuse Box
- need help with b16 eldelbrock victor x intake manifold
- Crank pulley bolt is kicking my....
- Failed Emissions Testing
- 94 civic ex, car wont start
- d16y8 timing off 1/2 tooth?
- No vtec in my poorman type R swapped ej6
- s2000 steering wheel for 2000 honda civic si
- 96 Civic DX/OBD1 conversion - random misfires HELP PLEASE
- 95 d16z6 Engine Dies at idle with ac on?
- Could my alternator be going??
- 92 Si door panels.....no pinstripes???
- loose crank pulley?
- 99-00 civic si to type r and rhd conversion ? s
- B16 All Motor, Help
- Transmission in a 96 Civic
- sputter issue and ecu need help please
- forgot about dust shield on rear hub. 93 sol
- 97 Civic/B16a2 swap acting up - can't figure out idle problems
- 98stock ek sputter and jerk when accelerating
- del sol color opinion
- Build Help
- 92-95 JDM SiR sticking speedometer
- Ignition key stuck... help
- 99-00 Civic SI AEM Short Ram Intake Question
- d15b7.. timing maybe?
- 98 civic ex - need ideas on how to make car look nice
- 1996 Civic Hatch Wiring Issue
- 95 civic ex - best ways to make more power?
- O2 sensor problem, need help.
- ek or ej
- Driveabilty issue
- Taking the power steering and ac off - pros and cons?
- Thermostat housing leaking bad
- Transtop lifting roof removed now windows not workin?
- turn signal, clock & cluster problems 92 civic lx
- Are L and R axles the same?
- e85 on na d15b7
- gsr upgrade suggestions
- If you own a 96-00 Civic please read(help with header O2 sensor)
- delsol ex door handle help?
- Starts, Idles, Cuts off, Won't start now.
- skunk2 cam valve adjustment?
- K20A for 98ek
- z6 vtec pressure switch
- should i use grease on camshaft?
- Free AC bracket for 92-00 Civic for B-Series Engine Swap
- 94 Civic LX passenger side wheel is jerking - What Is This (see pic)?
- My Ek GSR Turbo Build VIDEO
- D16Y8 cam in D15B 3 stage
- do b-series always leak a little be of oil between head and block?
- d16z6 "headgasket"
- 98 Civic/B18b swap dies? while driving.
- Is the '91 Civic EX 4-door Master Cylinder still the best bolt-on MC Upgrade?
- help with noise from driver's side quarter panel - higher speed makes louder noise
- OBD1 code reading question
- help for lower power problem
- is possible that keep cruise control after change racing steeling wheel
- Preventing honda cancer
- FML...blown d16z6 motor :(
- Anyone know where to get just the red lense for a eg fog
- vtec not working help
- lost gsr 5th gear today why
- Car wont move.
- 92 civic si brake pedal sinking in slowly
- 99-00 Si Headlights on a 96 EK hatch?
- d series trannys?
- Disable my EK?
- need help converting fuel filter into inline fuel filer on my EK
- EK owners with k swap and strut bar chime in
- what is this port?
- 97 civic cx with 97 b18c1 swap P/S question
- noob question:13" steelies on a 98 coupe??
- h22 swap for an ej6 coupe? any advice is appreciated
- 92 civic hatch.. no turn signals but have hazards!
- 95 EG6 - Need help with brakes
- looks like many ppl hv problems with swap b16 and b18
- 98 civic dx running like crap after rebuild
- Good tire size for my Del Sol?
- Del Sol Clutch Issues. Need a solution!
- A/C Vents blowing desintegrated foam
- need more help lol swap question
- BBK manifold
- Do I have valve damage?
- Resonator need help!!!!!!
- auto to manny swap NEED HELP
- 92 civic runs like ****, help!!
- will a y8 manifold fit on a d15 motor?
- cracking and popping when i turn left
- ebay exhaust gone wrong!?!?!?!
- Need help with plans for Si: gt3076r on 25-30 psi, methanol injection, 500-600 hp
- Need your input on what do with my car..
- Super New - Never Owned Honda - Is this a good deal?
- Mini me missfire
- why wont a 96 civic DX axle fit into a new tranny (y4f) just installed?
- Good deal or not 2000 Blue Civic Si EM1 for $5000
- New here, trying to figure out price for '93
- Interior Lighting Issue HELP
- CEL wont stop blinking..
- sohc turbo help
- 00 Civic - Questions on front/rear sway bars, subframe brace, and strut tower bar
- K20z3 swap running super rich
- Constant squeaking sound
- D16 not Revving past 5 rpm's....
- mookeeh struts?? sounds like a illiget baby
- B18 transmission help!!(piece broke off and dont know what it is)
- Rpms too high on highway (b16 swapped ej6)
- obd2a motor in obd1 sol... Help?
- h22 civic coupe idle problem
- EG a/c lines into an EM1??
- About to install rear disc brakes on my '93 Hatch - bushings/upgrades before install?
- Some proportioning valve clarifications...
- Disable power steering
- Do i need to get ANOTHER set of new bushings?
- how to identify injectors
- EG Hatch - what suspension for smoothest ride?
- k20 in ek
- EACV HOSES??
- 95 coupe tach incorrect.
- Oil question
- B16A2 - Distributor - How to change rotor?
- Weird Transmission Problem
- AC questions in b18 swap
- 95 Civic coupe - how do I replace the entire suspension?
- ***Power window issues***
- 96 civic hatch rear brake assembly conversion, drums to disc quest???
- Why Does My Steering Wheel Rattles At High Speeds?
- Possible electrical problem?
- D16a SWAP to A D16z6....
- Wheel and tire upgrade
- COMPETITION ENGINEERING ROLL CAGE FOR EK
- Steering Wheel Squeaks
- CIVIC engine management codes
- 99 Civic Sedan: Corrupted Fuel Guage issue
- h22a4 swap
- Weird steering wheel movement
- 92 civic vx build
- d16zc swap-fan not working!
- P1457 Leak in canister area
- ITR or H2B?
- b16 swap won't crank/start and speedo jumps around
- 92 CIVIC HATCH SI NO DASH LIGHTS OR REAR RUNNING LIGHT
- 7th Gen exhaust on Del Sol
- Can ethanol gas cause a clogged filter.....
- fuel pump / relay issue 92 civic vx d16z6 swap
- Have some questions about b series transmissions
- H22 Ek Hatch axle help
- Map sensor wiring help
- Please help me identify this motor mount!!
- 93 del sol power steering leak question.
- head gasket?
- What's the difference with a d15b 3 stage vtec vs. D15b vtec?
- Best ecu for a b20b swap?
- D16A6 Block parts will fit in D16Y7???
- 2000 hx - O2 sensor CEL codes
- Stupid z6 head gasket question.
- how rare are these rims?
