View Full Version : Honda Civic / Del Sol (1992 - 2000)
- what header with LS into EK swap N1 catback
- messed up control arm?
- What ecu's and wireing harness will work with this motor?
- Bad inside tire wear=camber? toe? alignment?
- AEM fuel rail or Golden Eagle Fuel rail?
- need opinion....how much
- Exhaust Resonator questions
- Brembo Rotor Instalation Question
- did tein full coil overs ever come with red springs?
- help: is typerx.com legit??/finding z3 side skirts
- a whine noise on my civic hatchback
- Del Sol Steering Column Help
- bent valves????
- 97 Civic LX Sedan for $4750 and some questions....
- whats wrong with my car and can anyone help???
- 92-93 brakes vs 94-95
- 96 - 98 civic jdm fog light intall HELP!!
- Know of any site that sells replacement meter needles for the cluster?
- Compensator Arm Poly Bushings for EK HELP!???
- Spoon n1 with rust?
- Civic lip question???
- where can i find a cluster for my civ w/ a tachometer that goes to 10k?
- Skunk 2 catback on a 99 EX. need help
- Confused about paint?
- My idle problem
- 98 civ help dash lights
- lug nut help!
- Front LCAs of CIVICs 96-up fit in 92-95 models?
- Which O2 sim works?
- modifying taillights
- pining vtec harness for mini me
- Piston rings, which are good rings for my app....?
- stupid exhaust question
- this eg worth putting money into
- pic post please ....
- Question about interior color?
- oil temp gauge
- Tighen up the shifter...
- Where to find offset on rota rims?
- 93 VX Shift Linkage Nut/Bolt Size Question, Stock Bolts Rusted, Need New For Short Shifter
- Smoke when i hit vtec?
- shock install
- Can I use a 96-98 Civic LX tranny case with the internals of a D16Z6 tranny??
- clutch chatter
- eg2 swap ?
- no reverse gear HELP
- cv axel going?noo wait gone?
- tranny question
- fender question
- Newbie Introduction
- clutch/tranny problem?
- is it possible to convert sohc to dohc
- Electrical Problems....PLEASE HELP
- 2dr/HB front bumper on 4dr?
- Does anyone know what an EK DX hatch gets for MPGs?
- rear disc brake swap question
- ECU Code!!!!!!!
- what do i need 2 do a 99honda civic frontend on a delsol???
- car storage...this sound RIGHT!?!
- Starting over
- Do high flow cats hurt gas milage??
- head for 94 civic
- looking for a civic hatchback post ??? one piece front end
- 95 Civic CX Tach Installation Help
- Problems with overheating 92 eg Hb DX
- Brakes smoking.... HELP
- HELP ! ! ! Clutch and Gear GRINDING ? ? ?
- CTR Front Clip
- weird shuttering noise......
- Not sure if i have the right knuckles on my car....
- What Chip should I get for a 97 civic EX
- Did my first junk yard run
- AEM V2 intake
- Distributor wont plug in..?
- B16A2 Cruise Control
- B16A into Ek
- insurance question... 94 civic cx vs. crx hf
- EG Airbox on an EK? Will this work?
- need opinion
- how do you remove paint off your moldings?...side moldings
- Fixing window on 95VX hatch
- (eg dach) How do you take off the gray plasic peaice that goes around the climit controles and deck.
- AC wont blow cold. any suggestions?
- Swap Question
- Shift linkage pin
- Is 2500 worth it for theft revoerd EK hatch
- Gauge bezel question...
- OK....someone broke into my hatchie last sat. night...
- getting warm! time to do some maintaince! like fixing passanger side window?
- Weird code
- Leaking Proportioning Valve
- head studs???
- 96-97 civic ecu different from 98?
- pulling fender?
- possible vafc problem, or spark plug problem?
- Oil Pressure Question...
- Running Rich, Sputtering-bogging, but only at startup.
- NEW JERSEY LOCALS! ADVICE NEEDED!
- EG 2 door - brake noises
- short ram gsr swap
- Titling an abandonded vehicle
- Replaced headgasket... now no compression... ideas?
- Will a shift fork from a 96-98 Civic HX work on a D16z6 tranny??
- Vtec head on a d16y7 block
- Vtec Head on a D16y8 block
- Finally buying swap...having dillema..HELP
- eg troubles
- oem glass tinted?
- Gsr Cluster in eg..wit plastic shield?
- H series adapter plate?
- air bubbles in coolant- definately blown headgasket?
- Key out of ignition, radio stays on ??????????
- Is this legal?
- how hard is it to ghetto wire VTEC on a d15b7 computer?
- Wheel spacer size
- Upgrading My brakes
- i have a quick question
- Fixing the door lock wire?
- what's wrong with my moonroof? (already searched)
- 3500 rpm stumble
- SI vs SIG
- Power Window Problems, it only goes 1/2 way down
- b16a oil level?? HELP!!
- Need Some opinion for my d15b7
- 96 civic ex coupe, broken into, know the value of this stuff?
- Suspension 96 GTI springs fit 95 dx hatch?
- 98 coupe suspension fit 95 hatch no prob?
- 1.5l 95 hatch, more power off line?
- where to get 99-00 foglights
- ARP head studs, who's running them, who's not?
- Time for a rebuild, where to buy? (D16z6)
- Can someone resize these pics so I can print out a clearer copy of the diagrams?
- Need help please read...
- Gearbox question
- arp bolts compatable for z6 and y8?
- just did valve adjustment but its still loud
- ~~RHD EG6!! REAL or FAKE?!~~
- speedometer question
- 40A Ignition Fuse keeps on blowing out. WHY?
- Idle Contorl Valve
- boost on an ls
- Need help....NYC&L.I
- BAD MISFIRE!!!! PLEASE HELP!!
- car dies while running
- my skunk2 ss just about fell out of my car today
- not getting fuel
- Opinions needed on building my d16z6
- Approximately how long do aftermarket shocks last on Civics?
- cam and crank seal part numbers
- Help: Can't Get Car to Start
- Rear lower arm replacement question
- how much can i get for my car95 cx hatch
- water temperature problem!!!!!!
- D Series Tranny, Need Info...
- uhmm a lil help plz
- Check Engine Light!!!!!!!!!!!!!!!
- what is the best cam gears?
- 95 civic, suspension. need help please !!
- LS swap into EK questions
- what timing belt for jdm sohc vtec?
- help help help with my b16a
- Non powered Jdm Mirrors? Ek...
- alternator compatability question....
- Flywheel Myths?
- water in corner lights, how to make it stop
- ATT all sohc lovers What headgasket do you use for high compression?
- gauging interest in selling my hatchback
- How can I tell a aftermarket bumper from a OEM bumper? (EG 95)
- y8 head on a z6 block
- Honda Trouble
- wide body for del sol
- 2000 Civic Dx stock noise
- Will the ST sway+tie combo for 94-01 teg fit an eg??
- recaro
- my civic took a shit
- 02 civic 2dr/ 4dr
- how often should i check timing?
- wheel hop makes cat break off form header
- bad idle?
- what ek front end is this?
- Master cylinder question
- bogging down problems....
- mini me swap in 1994 civic cx
- Cf Hood?
- grand national turbo
- Changing gear fluid?
- VTEC activation switch
- Do They Make A Strut Tower Bar That Fits Over The D16y7 ITB?
- Koni Yellows Or Reds??
- need help....fuel rail question....
- D-series Apexi World Sport Review/EG coupe exhaust on EK sedan
- shell made daily driver on a budget? Worth a try
- eg with gsr swap.....need exhaust help
- What did you pay to get your timing belt/water pump replaced?
- more power for b16
- cars in limp mode, please help
- main relay for a 1994 civic dx 4 dr
- cylinder misfire
- wtb 95 gsr TPS
- getting worse mpg. whats wrong?
- Remove Pcv valve and can and replace with greddy catch can?
- Civic hatch with b20 track report
- code 41 after intake install?
- k20 swap
- auto tranny mount same as 5 speed tranny mount
- OBDII to OBDI wiring
- stock honda JACK
- Side Mirrors
- EG coupe vs. hatch exhausts....different?
- broken VSS plug
- Civic Help me head hurts
- Plus 1/2 tire upgrade report
- Hatch ???
- Maximum Wattage
- 96 civic ex d16y7 with p2p code 22 but no vtec?
- degrees for front camber
- anybody have problems with their l-con traction bars rubbing against the tires???
- d16y7 engine question... oil jet?
- moonroof problems
- Paint stripper ( not a question )
- 98 EK, 2000 GSR - Plug and Play engine harness?
- 5-Speed vs. Manual Center Counsil
- stripped?
- RSR non-slip pad
- Bugs with my b18c1 swap. what should i do?
- Ordering LCAs need help!?
- What is this piece??
- Civic Interior
- intercooler kit for my Jackson Racing supercharger???
- Spark Plug Question
- how to make jdm headlight from stock?
- Low oil pressure in d16z6
- Smoke in high rpm!!! HELP! B18C1
- Need help
- Sidemarkers helppppp
- Cable Reel
- Help Remove AC
- why does the 117hp HX engine get better mileage then the 115hp VP engine?
- Replacing windows from manual to automatic
- EK Weight Reduction
- Ball Joint Noise...Upper or lower??
- Power windows in ek hatch, need everything!
- OH great need engine help!!!!!!!!
- Convertion OBD II to OBD I
- *SRS Light on* Horn Stopped.
- Correct model cold air intake
- Tein vs. Neuspeed...for an EK
- ?how to check the check engine light?
- nos on my 04 ex ?
- rear caliper are stuck on rear
