View Full Version : Honda Civic / Del Sol (1992 - 2000)
- 2000 Civic SI rims with tires
- air/fuel gauge
- Speedometer problems...
- Where can I buy momo hub screws?
- Want to swap out HX
- what is this connector/where does it go?
- cat back exauhst?
- LOWERING MORE?
- clue in newbie on terminology
- gauges??
- o2 sensor question...
- Another swap question- b18c1 into 5th gen civic
- Changing auto Tranny Fluid....any tips before this is done?
- Ex, Lx, Hx, Dx, Vx????
- peeling paint
- 99 civic spoiler
- brake problem
- what are the benefits between p30 and a p28?
- Rotor replacement!
- a/c not blowing hard enough with gsr dash????
- fuel rail leaking
- steering column bezel light for EK where can i find one
- turbo not boosting in first gear...help?
- Question regarding Installing a wiring harness
- whine at higher rpms
- Where to get a tranny??
- Biggest tire size that will fit on a stock Del Sol
- del sol fire wall
- Another rough idle thread
- Master cylinder/Brake line Question
- just got a rear lip. wont fit cause of exhaust!!!??
- Lsd trans = tourque steer??? + coolant question
- AC question on swap
- Si,SiR,SiRII Head?
- Where yall get the Del Sol Amber Corner Light????????
- clicking almost "diesel engine" type-sound from under-hood
- Oil Pressure Gauge Install Help
- a couple of questions for the honda masters
- Testing VTEC Solenoid
- Valve Cover Gastket
- can a p06 ecu run a d16z6 5spd man somehow
- Brake light comes on when I take a turn?
- DC Sports 4-1 header on Civic SI-- help please!
- A5D tranny????
- ECU for a D16z6...what do i need?
- Check engine
- Clutch problems...
- power mirror help
- air/fuel guage install
- 98 civic EX problems please HELP anyting any ideas......
- detailed instructions on installing clutch on d16 y8 please, maybe pics
- Retrofitting HID's in Ek's
- Greddy turbo gasket, need help!
- ?:Anyone in SD willing to help me do a climate control conversion?
- I got a problem!
- rally civic
- Shudder While Braking
- anybody
- Blox Racing sway bar....any experience? no luck in suspension forum
- Lugnut stuck with the wheel stud. . . help!
- clueless radio code ????
- Plastic smelll from engine...
- FAQ : How to Install Hondata S300 on virgin p28. 56k noway
- anyone dropped their oil pan down before?
- CTR wheel bearing for rear?!
- Are Omni slip on coilovers any good
- What car are these lowering springs from?
- Need parts for 92 hb, 94 coup ex
- need some advice on where 2 get stuff
- help plz
- Honda civic lx 93 is overheating now dont want to trun on help me
- brakes!!!!!!!!!!!!
- HELP ME OUTT!!! PLZZ
- EG civic front speakers
- V-Tec wiring into EK
- Need Help!! OBD1 GSR Motor Into OBD2 DX DELSOL ?
- exhaust fitment???
- Injector Size
- Wire Harness question for a H series swap in an EK
- Why doesn't it fit
- Acura TL Navi. Monitor in a 96-00 Hatch Back?
- stock tire pressure on 13 inch steelies???????????????
- 5 inch tach
- another a/c swap question
- hood latch alarms
- to those without power steering
- engine lacks power and when in gear it doesnt rev up either
- cel 23
- problem with swap
- Y21 VSS drive gear. Need hAlp!
- Did anyone buy a motor here..
- CEL Code 92
- Megan Race Coilovers.
- questions before i do my swap...
- Clock install in a civic cx
- Compression good enough?
- hey guys anyone know what a sp sensor stands for? 99 civic, its on the same fuse as the alternator
- Has anyone ever installed an aftermarket muffler and it screw up your idle ???
- DIY: Paint windshield cowl
- a/c compressor question~!
- dumb question
- Boostin 00' SI
- about b16 swap in my 95 civic...
- ctr cams vs. itr cams
- ARGH! Bleeding hydraulic clutch!
- Rebuild ?'s !Builders HELP!
- D Tranny Problems
- cousin just bought 97 ex coupe, problems though...
- WTF happened to my cam timing?!!
- 89-91 civic kyb gr2 and coilovers work on 93 hatch???
- d series swap
- Starting Problems
- 99-00 HONDA CIVIC SI SPOON STYLE FRONT LIP SPOILER for sale
- D16Z6 Engine parts?
- Anything Else I Should While I'm Doing This?
- Air condition making whistling noise
- Check out how I pulled my motor!! haha
- skunk2 compatability
- Bad poping noise please help!
- Spark Plug Order
- edelbrock turbo kit for sale!! W/ d16y8 motor
- Where to mount harness?
- ABS side skirts...
- overheating only on the freeway
- HID on EG hatch Thread
- EG & GSR LCAs? Any Difference?
- WANNA BUY A SWAP!!??? Help Me Out!
- D16Y8 being replaced with a D15B issues
- clutch master cylinder
- What seats will work in an EG?
- My tranny is acting up and my car wont go into gear! Help
- main fuel relay
- Scan tools for obd2 car with obd1 computer
- what happened??
- Loose nuts in oil pan!!!
- *** DO NOT SHOP FROM INLINEFOUR.COM ***
- what would you guys do? sell my h22 and turbo my gsr????????
- 99-00 si rotors repacement
- Secondary emissions code
- 96 Civic Bosal Muffler front pipe to manifold gasket
- VTEC 00 Si
- a little problem but too big for me,maye you can help.
- Where Is The Fuel/Gas Filter Located On A D16y7?
- crankshafts
- How important are the splash guards?
- Intermediate Shaft???
- b16a 96-97 model
- intake question
- SHOW ME THE CLEAN JDM EG'S PIC THREAD
- smelling gas
- cd player
- Civic rear spoiler removed
- Help!...check engine/no vtec
- which oem wheels for silver EK civic hatch
- removing hub to get to the wheel stud????
- Does anyone know weight and size of 99-00 civic OEM hood? I need to find out shipping price.
- Headgasket ?
- onsoku coilovers any good?
- Post up your Spoilers/Wing, whatever you call it on EG coupes
- b16a2 ecu
- ac compressor turns on and off
- I'm Retarded, Name This Exhaust Piece (highly detailed pic inside)
- Wiring up a pivot shift light to a different power source?
- red line at 2.5????
- APEXi WS one exhaust....anyone still sell it?
- oil dipstick is black
- vx rims on coupe
- ECU not relearning idle
- brake and clutch lock
- Newbie with Ticking/Clicking sound question
- will this steering wgell dirextly bolt on?
- question for all h22's
- fuel rail
- are my compression numbers good?
- weird tranny tick?
- Type R Shift Knob
- skunk 2 stage 1 or 2 or zex 59300 cams???
- EK Power Window Problem *Please Help*
- is this a good price?
- car dies when starting then doesnt want to start right away. i doubt its main relay
- Looking for a high-volume oil pump for my D16Z6.
- In Japan - Sourcing Parts Necessary for B18C Swap into Canadian CX Hatchback
- best headlight bulbs for EG?
- wiring my vtec engine swapped
- 1995 Civic 2 door coupe?
- Help with a/c
- STOCK FENDERS FOR 98 civic hatchback
- DEL SOL SEATS
- z6 tranny into 97 coupe
- Please Help!!
- sohc turbo or k20a?????
- The diffreances between a 96 CTR lip and the Rplica CTR 96 lip ?
- New Circuit with fuse box?
- What year/model had no PS?
- 2000 B16a2 into EG
- Sparco Sprint fitment issues...
- Inside: Del Sol Vertical Door Installation Instructions
- distributor help me!!!!!!!
- Bad Gas Mileage
- eg hatch with d15b7 or eg coupe with b16a
- troubled..please help 98 ex
- LS ECU in Manual DX car throwing Code 19
- Help Me ID A Prop Valve!
- diff. between 92-95 and 96-00 turbo kits
- blocks? d16 vs d17
- rebuild/refresh quote for b18b->Socal
- header question
- hey u guys read this
- Mini me, and clutch questions
- grinding tranny
- Oem ek fog light help?
- Eg with an F20C motor, accomplished?
- h22 turbo or b18b turbo
- AC bracket on a 00 civic with a GSR
- will 95 integra dash work in 97 civic H/B
- Where to find a Cusco Roll Cage???
- chasis code on 96-99 coupe?
- keyless entry
- need some serious help
- s2000 seats into ek
- B20 or B18
- Possible ECU Problem
- AC Issue
- need some help with omnipowers on 98 EX
- VTEC solenoid
- VTEC NOT ENGAGING
- Password JDM Intake Which Filter?
- D16Y8
- Check engine problem code 1 Help!!
- power lock wiring help plz
- Did you put skunk2 Cams in your B16?
- suspension question
- Need help with 92 cx hatch
- over heating problem
- short shifter no name vrs name brand
- thinking of getting a quick release hub but...?
- 96-98 front or 99-00? best place to buy OEM body parts?
- Idle @ 4000 rpm
- Thermal 3 4 sale or trade
- Fuel Line Question
- Perch cutting, need help!!
- Baretta 2 Way LCD Pager/ Car Alarm Keyless Entry
- My gf just bought a auto. green 93 del sol, help shed some light on it please.
- what is wrong with this thing??????
- b16 cel codes
- At what mileage did your D16 spin a bearing?
- saving more gas
- vavle springs
- ROCKINGHAM PARK, NH MEET PICS *56k, die*
- Need some guidance.........2000 Civic Si
