View Full Version : Honda Civic / Del Sol (1992 - 2000)
- need help with ls tranny
- canister under intake mani
- Steering noise?
- Will civic stock springs fit on a del sol?
- horrible gas milage
- JDM B20 into a 00 Civic SI EM1
- Timing Belt Tensioner
- B16a2 Tranny Swap To B18c1 Tranny Question
- help car not starting
- engine harness for my 1995 honda civic dx
- leaky hatch
- P75 ecu in 93 vx
- need advise on what to do!?!?!?
- anyone use block off plate on bottom of T/B?
- From Steady 32mpg to 27mpg since winter started?
- what harness for ls-vtec?
- CEL #15 Help
- Air/fuel gauge how to ??? Sensor wire??
- which itbs are better?
- Skunk2 Cam Gear
- What have you done to your civic today!!!!!!!
- How can I get more MPG?
- [DIY] - How To - Honda Access Window Visor Installation on an EK
- steering rack opinin questions
- gsr swap into delsol
- Identify these wheels please
- Rim Colour Change (photoshoppers needed)
- ssqv insert on no insert? OPINIONS
- 93 Civic whining noise front right engine compartment
- stock or aftermarket flywheel?????
- GSR shift linkage diagram Help
- D-series timing issue
- Cracked header!
- Creeking and squeeking on the rear
- Wich Comptech Icebox fit EG ? - DC2 or Si ? -
- interior fabric
- eg foglight wiring how to..
- Projector Lenses
- O2 sensor whole........????
- how much could i sell ls/vtec block for?
- cam gear interchangeable?
- look what i found on ebay... (drag civic)
- Will a bad igniter throw a code?
- Need input ASAP!! Water/Methenol Injection
- 99 civic ex radiator fan not working
- Welded differential questions!!!
- integra rear seats in my 2000 civic coupe
- cylinder head?
- My Turbo 2000 White Coupe (Finished)
- mags help?...
- Headlight adjustment
- Unstable RPM
- Knock sensor
- 97 DX Tranny or Clutch???
- Offset?
- 3030 to 3040 Prop valve
- Reasonable Price for D series Engine + Tranny?
- Recaro Rails
- need rare (or is it?) civic pic help please
- question bout B-series engines
- p30 ecu on d16y8
- 00' Si Brakes on my 95' EG
- transmisson took a crap???? clutch???
- which engine best to turbo? sohc zc cs d15b
- tranny help!
- Quick Question: Tokico Shocks on EK
- CAT removal HELP!
- one light wayy brighter then the other
- help with new bearings
- o2 sensor location?
- need help on what dizzy to use
- What door handles fit 94 hatch?
- [DIY] Honda Civic 92-95 "OEM" Rear Fog Lamp Retrofit Install Guide
- Wide open throttle issues
- Wiring troubles, someone please help!
- Transmission is on its last legs.
- Swap help 98 hatch
- d16y8 all motor
- car wont spark or ignite. HELP!
- Shifter broke will this one fit???
- Oil catch can, best place to install?
- Do i need this
- my car is just rurning but not starting?
- 99-00 Depo vs. Honda Access Fogs
- eg6, driving light would flash on, then go back to drl?
- coilovers?
- how do you disable the immobilizer in 00 gsr ecus?
- Apex'i WS2 Question
- will a jdm h22 in a eg pass smog in California?
- EG Auto to Manual
- battery relocation
- B16 wiring problem
- Eg:front end question
- billet mounts for swap
- speedo not working but vtec does?
- Engine Harness OBD1 B17A1 In 93 SI HB
- still not starting
- d15 motor problem...idles rough and dies when given gas????
- motor mounts
- B swap... radiator hose question...
- Was this an option?
- SIR fog lights? wiring
- intro
- chipping ecu does trans matter?
- are sir2 wiper assembly's mirrored to ours?
- but of bumper trouble
- Aluminum radiator, junk or not?
- can u delete a fast idle valve...
- S2k cluster in EK
- question about tire size and ride height.
- Transmission noise car can barely move
- light id
- Let's clear this ref ticket business up
- J's tsuchinoko racing intake
- HELP! 99 Honda Civic Si needs revived
- built ls/vtec bucking problem while cruising
- honda civic v-tec wiring
- Noise from rear 93 del sol
- Lets see and talk about those 4 Door Civics
- What should a b16b head be stamped with? p73, pr3...?
- Ah-Haa! I found the problem to my bad gas mileag woes!!
- rear disc conversion
- Idle problem and low torque.
- Rear Disc Brake Question
- Civic swap
- im finally legal :)
- corner lights take a while to turn on...
- OB2 to JDM OBD1 wiring.
- Squeak from DS front (I've searched)
- What shift linkage in a swap
- B20V Problem?????
- how much should i be able to get?
- Fuel rail leaking gas how can I fix this....??
- Wipers not turning off
- what camshaft should i use in my civic
- I have a cel code, but cant tell which code exactly...
- Keeping a quiet exhaust
- obd2 harness adapter question
- Who Knows?
- Short shifter in a hatch wth engine swap.
- no gages work in my car
- d16z6 to d16y8 swap need help.
- EG hatch / 96 tegra steering wheel question
- 2001 honda insight rims will fit a 2000 honda civic?
- 2001 insight rims fit a 2000 civic ??
- CTR Intake and Exhaust Cams Question??
- 1992 civic hb battery drain - argh!
- all motor ls then turbo
- help please: 98 civic hb headlights
- to all the slammed cars out there!
- Swap Question... Please Help...
- 98-00 civic sedan swap...
- CEL 43 Fuel supply system
- any need to tune mini me?
- Interchangeable Parts - D15B7 and D16Z6
- Which 02 to buy?
- Im new to civics
- corner amber indicator light issue
- h22 sol running rich and hesitates
- civic a/c
- b17a1 into eg
- Corner amber indicator light issue(help)
- head gasket Question
- Sexy Engine Bay?
- h23a1 in to 94 civic cupe help
- What to do for Power?
- D16Z6 Rebuild Kit?
- Quick question for all of you (PICS INSIDE)
- rsx dashboard in eg civic
- no power at the fuel pump.. somone helpp!
- dashboard lights dont work?
- right hand drive conversion?
- sensor help on b18b1 swap
- how/where to get dizzy oil seal & bearing
- engine swap... radiator question
- Help please, i get a clicking from behind my glove box, any ideas?
- Driving from Illinois to Alaska...
- 1st time engine swap, and i got two codes help plz
- 1.4i mini me conversion can it be done ??
- Why..why..why..does this happen?
- help!!! new cams
- new cams---need help
- BAR Help!!
- suspension write up?
- help! obd2a to obd2b harness conversion lsvtec distributor wiring problem?
- n00b to brakes and doing rear disc conversion
- Different brand name header?
- what would casue this? rising temperature gauge
- Thinking about buying 2000 hatchback
- dizzY Q...
- The money shot question about new motor
- 92 Civic VX Dyno Testing
- 95 civic tail lights
- 96 Civic Alternator Fuse Keeps Going Out Need Help Please
- motor doesnt warm up when its cold outside
- Weird power loss..... HELP!!!! Honda tech gurus needed
- B18C1 Not engaging VTEC. New Solenoid/Oil Switch. NO CEL. New Harness
- i have a gsr tranny and it makes noises.
- exhaust
- trying to figure out some wiring please help
- What are your exhaust preferences?
- ek auto to man trans swap, what all nec?
- 92 hb rear seat question
- Swaped a 95 jdm obd1 h22a into my 99 civic hb probloms
- backed up; hit muffler real hard!
- del sol- new radio, fuse keeps blowing
- What is the correct way to start up a parked car in 1st gear?
- my eg8 plans(also would like your opinions)
- EG h/b with H22 ?
- bad tps and 02 censor
- stil high NOX
- Is 5th Gen Capert Interchangable?
- Car Starting Troubles (D15B)
- map sensor question.
- can you interchange z6 and y8 cams
- Del Sol Fuel Cell Pic's
- HELP with decision on my car with Major issues!!!!!
- Exhaust question!!!
- Igniter-Coil Interchange?
- Really stupid question??
- Help. GSR swap into EK
- question about coolant temp gauge
- How to lengthen Transmission Gear ratios?
- Engine swap... Assembling correct parts.
- P28 and P72 ecu
- driving down the road, car died, ecu fuse blown.
- cel in upper rpms goes away when i restart car
- ls/Vtec in ek quick questions
- 1998 hatch Cat converter
- Smoggin' time and need a cat now =(
- rims question
- Where do i get leds for my cluster
- picked up a 95 coupe
- Plans for an EM1...
- 1997 honda civic driving braking noise problem NEED HELP
- a/c and power steering in my car with my new swap
- need help w/blitz DTT DCll
- please help with my 97 civic.. radio speedometer problems
- my ej2
- valve cover
- sohc vtec injectors
- what size tires for 16" rims?
- no power to ecu, no power at fuse 18
- Head and Main studs?
- Unknown condition motor - things to do before swap?
- Ek brake conversion with integra one questions???
- My 1992 Hatch build!!
- Everyones Opinion on this setup
- 99 gsr front and rear seats into ek hatch?
- Auto to Manual but not with stock engine!
