View Full Version : Honda Civic / Del Sol (1992 - 2000)
- My 98 DX Hatch build progress discussion
- Rear driver side wheel locks up
- 99 civic si suspension noise Need Help!
- 96 Civic - Help identify missing blue caps in engine bay
- EX engine into Civic DX - What's needed for this swap?
- boosted eg civic - white smoke and running lean
- Does 94-00 Integra Suspension fit 96-00 Civic??
- 98 hatch mini me swap?
- 99 Civic - Grant Steering Wheel
- Firewall plug numbers ( searched)
- d16z6 misses when accelerating or shifting gear
- Alternatives Other Than Welding Adjustable Test Pipe
- 93 dx 1.5 crank nose damage
- 1993 civic dx AC questions
- Any suggestions for a pair of LCA's for 97 Civic Ex
- JDM B16A Code 21 and 23? HELP!!! T_T
- R134A conversion drier compatability
- 95 del sol won't start after revving engine with battery disconnected
- D16y8 gas leak from fuel rail. Need fuel rail assembly info.
- 92 vx/y8 swap -- Can't find coolant leak on firewall side of engine
- 95 Civic Dx Automatic Intermitent start
- TDC Sensor Code
- Weird problem
- Will it pass or not?
- New guy's first V-tec Eg Civic D16Z6
- head question
- Should I use a P28 or P72 ecu
- 92 Civic - no start and oil pressure, battery, and CEL dimly lit or off
- should i be getting better mpg and what i can do to help my mpg
- Front lower torque (vibration?) mounts necessary?
- Peplaced alternator now runs like crap
- Head gasket/water pump/timing belt advice!
- Power steering pumps...oem/non oem
- Power window goes up to far.
- Another "behind crank shaft pulley leak".
- Car Wont Start
- 97 HX chassis, HX ECU, Y5 block, Y8 head, Y8 IM - Many CEL codes & running problems
- 1997 Civic Ex (D16Y8) Idel Problems
- 1992 vx hatch - front bumper to fender fit
- 92 civic 1.6 dizzy o-ring
- 1992 vx hatch heater only blows warm/hot
- Denji headlights value?
- 95 Ej1 with LS swap low idle, stumbling, stalling, running rich
- b18 ls or d16zc swap 95 eg civic coupe?
- how much should I scrub down my throttle body, can I use I brass brush?
- EG torn lower ball joint boot, energy suspension boot bad fit, how to tell wear?
- 98 Civic auto transmission shifting problem - p0700, p0740, p0730 error codes
- Starting Problem
- Slow 94 Civic Sedan Build Thread:
- Battry drain problem
- EJ2 - D15b2 Swap help
- Will these tail lights fit a 98 dx coupe?
- 97 civic ex won't start, help please
- How do I remove the door off my 97 honda civic
- 95 has weak heat
- honda civic P2A-4 Head
- What OEM radios fit the EG audio console?
- Is there such a thing as door droop?
- Just got a 4 door eg - need opinions - b16 or gsr or lsv or b20v swap?
- clutch/trans issues - clutch engages with pedal near the floor
- civic ej1 catback exhaust
- exhaust system for 92 Civic - i want a roadster sound or a low hum not a buzz
- civic engine harnessplug id
- STRANGE THINGS!!!!!! HELP!! - Problems with battery or alternator?
- 00 Civic with overheating issue
- torque value error
- Head Gasket Blown - To Sell or Repair?
- Is this bearing clearance ok
- Knocking noise(Hopefully not Rod knock)
- Stick shift really loose *need to know the name of this part on shift linkage*
- Fail Emissions
- RTV/Hondabond question.
- 97 Civic HX/D16Y7 swap - iacv (P1509) and o2 sensor (P0135) CEL codes
- overheating d16z
- EG Coupe Bare Shell Weight
- 98 Civic - cluster lights don't work
- EG vibration noise between 2500-3200rpm
- EG sedan - windshield molding removal/replacement
- Intermittent squeaking noise possibly from transmission
- 97 civic - how difficult to obtain and install heater core and components?
- Does any one have a B18C1 engine harness I can borrow?
- Brake line tuck help
- BLOWN HEAD GASKET!?! - ANYONE TRIED "BAR'S" or "BlueDevil" Sealant
- Eg hatch fuel pump problems
- p1509 and p0135 97 civic
- Cold weather turn signal issue.
- 95 Civic EX - Another jumping idle
- 95 civic vtec is leaking coolant
- B20EK, Code 6. ECT Sensor
- Rear Rubber grommet wire protector (rear defroster,license plate) EK hatch. leaking !
- Does a p28 ecu work for d15(jdm) vtec swap
- type r b18c header won't fit
- Acura/Honda Wiper switch into a Civic
- Failed emissions 95 Del Sol Si
- problems with civic exhaust and general questions?
- 1999 civic cooling issues
- 99 Civic Si - cruise control sometimes won't engage
- D16y8 - Oil in spark plug holes?
- 1996 Civic Voltage drop issue
- 96 CIVIC DX - radiator shoots out water
- What vehicle's glove box will fit a 93 del sol si?
- Odd RPM jump when gas is released.
- Problems with O2 sensor in 2000 SI
- Will 89 crx mounts for a b18a fit a 95 coupe
- Will EK complete ignition switch fit an EG?
- Should I buy this 98' CX Hatch? (EJ6)?
- Sub Frame Ek9
- Overheating Randomly 97 Civic DX
- 99 CX HB - what would happen if I were to put high compression pistons in the D16Y7?
- Whistling Car :O
- B16 swap into 98 ex auto civic - engine harness question
- Some sort of relay or switch on key cylinder of ignition switch??
- Want more pep in my 98 Civic EX coupe
- 92 Civic CX won't start !!!
- 99-00 civic vs 97-01 integra
- Wont go over 4000 RPMs in any gear
- Estimated Cost For Parts To Be Painted
- interior subtle differences
- 98 civic, bogs down, dies when you give it gas
- 95 Integra coupe front windows in 95 civic coupe?
- Alpine SPS-610 6 1/2" fronts in 2000 EX sedan
- Need 98 civic help, car idles then dies when you give it gas!!!
- 93 Del Sol Turn signals and hazards stopped working
- 1996 civic HX exhaust header cracked. best replacement?
- 1997 Honda Civic Cluster light doesnt work
- Where buy double din optional console and the cup holder for EG?
- HELP!! my Honda civic SI 00 waste a lot of gas.
- anyone got a rock hard brake pedal?
- timing marks on d16z6?
- recaro spg xl driver seat install into a 93 hatchback
- Fuse #24 keeps blowing PGM FI?
- 2000 Honda Civic Radio/Climate Control Issue HELP
- Midpipe Exhaust similarities in EG/EK coupe & HB?
- HEADLIGHT PROBLEM PLEASE HELP !
- Interior trim
- B16 wont heat up
- Couple questions left unanswered about reupholstering
- Passanger window loose
- Front end groaning
- 1999 Civic Si - cruise control, defrost, climate control issues
- 94 Sol vtec backfiring when cold
- Losing power to radio
- Swaps and hood clearance / spacer question
- rpm goes up but not speed in 3rd and 4th gear
- check this out- original mugen spoiler
- 99 civic with 98 engine laggin out
- Welding Catalytic Converter Questions
- Obd2a to obd1 swap, few issues. need some help
- 1998 Acura 1.6EL rear defost light always on!!
- 94 Civic VX stalling/burning oil
- 98 EX(d16y8) rough idle then stall
- swapping jdm b16a from del sol to ek hatch..need some answers pleasee
- Wire tuck in 96 Civic - Are these two capped plugs (pic) needed?
- taping brakes raises idle?
- 99' EM1-oil burning smell
- Civic won't start.
- 94 civic ex issue accelerating
- jdm d16a head work on d16y5?
- 94 civic tranny problems - car doesn't move in gear
- 95 Del Sol Si Build Thread with History
- 1999 Civic Si - P0135 code, 02 sensor help!
- Identify this B16 head!
- Ebay exhaust kit questions
- NOOB.. help with info on a EK ?? please
- No Customer Service from ChaseBays or RyWire??
- Rear Main Seal Depth???
- Rebuilt carbon synchro trans stuck in 1st!!!
- HX engine harness with b18c1 swap??
- fuse keeps blowing when i step on brake pedal!!
- Max MPG
- Relocating Power Door Locks on EG
- need wiring help- trailer lights!
- 1993 Civic CX hatchback...sway bars
- Anyone ever see this sohc valve cover before ???
- Hydro tranny
- 93 del sol smells rich replace several parts
- top fuel 0-400 special drag and street fighter top fuel
- Low Power Below 2000 RPMs
- Let out the clutch and the whole front end hoping and shaking
- Someone help me find out what kind of ek rear ucas i have
- 93 civic speedo wont work
- 99 Civic DX Hatchback - alarm install - Door Trigger?
- o2 sensor issues. Bank1
- usdm light dimmer: how to connect, eg hatch 92 edm
- wiring/plugs questions 92 eg hatch edm
- 00 Civic Keeps Blowing Wires
- 2000 Si head gasket question
- Leak from around water pump after start in 18 degree weather
- y7 with y8 exhaust manifold??
- CV half shaft re-build/replacement
- After clutch job: Pedal softer, gears stiffer.
- What kinda engine 1.6L L4 DOHC 16V is for a '93 Del Sol?
- 97 Civic HX chassis & ECU/modified engine skipping at 2.5k RPM and many CEL codes
- No Heat,Just Cold Air
- Running aftermarket tapered lug nuts on OEM wheels.
- Hot Spots Using LED Bulbs In Gauge Cluster
- Swapped dash & engine harness, car is acting up.
- 98 Civic/D16Y8 swap - need help hooking up VTEC
- 94 dx d16z6 swap + p28/Now cel 41 - o2 sensor?
- 98 Civic with idle problem - possible causes?
- Rough idle at cold start
- Cooling system and check engine light
- H Powered 95 Honda Civic Hatchback
- 95 civic ex cable tranny swap
- 97 civic dies after a 3hr drive as im getting off freeway
- drive indicator light not working
- 375xxx D15z1 Worth it?
- Water pump and belt
- help with del sol weight
- Locked out of reverse
- 93 VX Hatch D15z1 to D16a6
- b16a2 running rich in 92 cx
- Clutch sticks to floor
- 93 civic eg instrument cluster issue
- 96 Civic No power to Driver Window and Blower Switch?
- front suspension rebuild questions
- 98 civic dx swap issue with map help please
- 92 EG with B18c swap driving issues
- 94 civic Distributor, Can't get the rotor off.
- Color name/code
- build pics 94 civic hatch
- Need input on a UKDM ITR header
- 93 eg hatch/97 B18b1 swap - Engine rebuild questions after two bearings spun
- im an old guy building a ricer....I think?
- EK side marker template
- Window/Door frame issue
- EK Coupe Build Plans
- 99 Civic CX - running rich, emissions code, ECU questions
- Need help with jdm obd0 b16a swap into 00 civic ex
- Floor shifter bulb number
- 97 Civic EX/d16y8 - what are possibilities for this car?
- soft clutch pedal
- Stumble/hesitation if hold throttle at cruising speed under 3k rpm
- Fuel pump bad? *Pictures*
- GSR rear disks
- Troubleshooting VSS & heated O2 circuit: '98 2dr LX 5spd
- How much difference of HP (or WHP) is there on Del Sol regarding year?
- 95 civic loses power in warm weather. Fuel pump?
- civic si 00 stock pipe diameter
- problem with bwr subframe
- EG Sunroof Problem!
- Civic HX CVT Auto Trans into DX
- back at it again...98 ex leaking oil
- Daily Driver build ideas?
- will 92-95 civic sedan power mirrors fit civic coupe
- 95 civic/jdm b18cR swap won't start after distributor rotor screw fell out
- Things to do to my Civic
- 99 civic hatchback - interior repaint
- My Ek9 Project
- ZC/D16 Head info
