View Full Version : Honda Civic / Del Sol (1992 - 2000)
- ***Stock harness with JDM P30/ Do they match up to all the pins? ***
- opion: whats the better eg coupe setup?
- Strange noise when shutting off my engine! HELP!
- 92 h22 eg (vx) IM????
- is a skunk2 ecu worth iT??
- EG damper compatability
- clearing out headlight turn signals??
- Underdrive pulley
- will 13's fit on an 98 civic EX?
- Where to add auto tranny fluid?
- Brake rotor and pad upgrade suggestions.
- $6000 to work with!?
- Turbo my civic or get another/different car and turbo?
- b16 map sensor
- My Car Arrived! Finally here! 1992 Civic Hatchback DX with A LOT of STUFF
- H22 swap why is it do this?????
- Transmission removal and questions (56k, screw you!)
- ¿I Need Help on 92 civic vx hatch?
- Header (B16)
- Tranny goes forward and sounds like reverse???
- which camber kit?
- Question about brake line install
- coil, igniter problem?
- WAHOOO new personal best at the track tonight!
- oil pan question
- need help please!!
- replacing parts
- leaking oil
- 96 civic dx hatch with 96 gsr motor
- HELP!!!! my car is knocking very very Loud!!!! PLZ!!! HELP!
- Name that sensor....
- Check this out, Mugen V8????
- Show your 92-95 Civic Optional Audio Console Pics
- My tranny... or My Clutch?
- cam installation
- radio trouble
- GSR sway bar fit on a 97 hatch
- ECU Trouble Code 70: auto trans error
- another b18b swap question
- what happens with $3000 in hand me downs
- about to buy a car.. lots of questions!!!
- Brake Master Cylinder
- CTR pipping..
- Apexi V-AFC version II
- EK climate control
- Installing a clutch
- removing air conditioning?
- lsvtec suggested parts for build
- wilwood big brake kit - different pads?
- Pillar Bar Install
- suspension
- PSI Question
- Metal vibration sounds
- Need some HElp with Swap
- Is this good compression??
- radiator help please for 99-00 d16
- Wiring diagram for VAFC???
- NEED HELP FOR SCHOOL PROJECT
- possible b16b swap
- not sure.. auto-manual swap *parts*
- Tranny upgrades coming soon...need some suggestions
- Stoping distance after GSR brake upgrade?
- HELP SoCal Peeps!!! I need to borrow a D16 CX/DX intake box for a smog check!!!
- cooling problem in a 94 gsr...
- 1/4 times?
- All 96-00 Civic HB owners with custom exhaust piping...
- idle at 200 rpms !?!?!
- break in period for cams?
- Biggest Tire on Stock Del Sol 14" Rims???
- Fuel Pump Install???
- THE SI
- what do you think I am dynoing at?
- Constant power wire !!
- Jspec b18c-r Swap - Harness ?
- please help with b series tarnny code
- compression test resuts for a 99 EX?
- 01 Civic Oil Change?
- Tom's Motorsport Coilovers
- Question about 1994 coupe pasanger mirror
- D16Y8 dyno. 9-30-03
- can you run hr sports with stock shocks?
- biggest shot of nitrous? (did a search)
- still f***ed up....
- Any Boosted 92-95 Civic Hatches????
- Update on my coolant leaking inside the cabin issue...
- auto -> 5spd
- Is this a good or great place to buy from jdmspecperf
- apexi
- 99-00 Si LCAs, forks, swaybar: How much weight savings or gain compared to EX setup?
- d15b vs d16y8 need quick answer please
- does anyone make a traga style top for a 94 ex coupe?
- 97 Civic Backfiring Occaisionally....
- cam and camgear setup for dual stage nitrous!!!!?
- What Brake Pads to use for No Dust?
- Brake Poll Willwood Kit vs. Complete Integra brakes
- idle @ 900/1300rpms
- download honda civic repair manual in .pdf format!
- Pictures of Kaminari Top wing, on 2003 Honda Civic Si (my car)
- Need a Carfax ran...Please help!
- steering wheel causing fuse to short??? need help!!!!
- Yokohama K240
- a6 oil pan same as z6????
- JDM Climate Control Blubs
- HELM's error?
- Looking for more power!!
- JDM EG cluster with SRS LIGHT! my first how-to
- for those who have swapped b into d series cars
- The PROJECT Stories !!
- EK owners listen up! Gsr Brakes?
- Pretty much stumped..
- Finally...a OBD2A/OBD2B to OBD1 conversion chart!
- Chipped ECUs on a B18c
- digital speedometer?
- Type R AEM CAI in a CIVIC
- Damage to CAI in wheel well hole
- B series clutch
- pics of EG
- Pics of Projects EG
- My Hatch Project
- Spoon style EG
- Pistons in a B18C...
- anyone using a versus motorsport cf hood?
- Power Locks and Windows
- Engine swap question...how much for a wiring harness?
- VTEC Pin Layout
- How to Install Cruise Control?
- question: building a z6 turbo right?
- tell me what you think
- 2/3 door front end on 4 door 92-95
- Important for SoCal hybrid honda owners!!!
- JDM tray?
- DENSO vs NGK
- do you need a spring compressor to install coil overs?
- 97 civic power window wont stay in track
- Finished my EG front suspension (pics)
- where did my weeeeee tec go?
- got an engine problem?
- Turn signal question
- can anyone vouch for hardboiled egz
- ZC came standard on canadian dx hatchback (92-95)??
- exhaust smoke question
- Getting married, don't really need shocks?
- how to check timing belt
- Hey! I'm new.. here's a pic of my hatch!
- front brakes off JDM SIR2 same as GSR front brakes?
- Where to buy d-series motors
- intake question?
- J's Racing Wing?
- what do yall think about the Buddy Club 2 kit?
- damn, AC bolts sheered off in block, waht to do?
- how to wire up autometer fuel level gauge?
- obd-1 p30? chipped or not chipped?
- HELP!! What Do I Need??
- 1" type r master cylinder on ek hatch
- Black locking hood pins??
- y8 IM on Z6 head?
- Need Some HELP on Verifying a ZC Tranny PLZ!!!
- Highest Tourque Rating Out Of A Nat. Aspirated B16A2?
- 92-95 eg brake swap? PLEASE CONFIRM
- Storing car for winter...
- port and polishing my y8
- D16Y8 throwing code 14 (IAC)
- Proper way to store a car?
- who knows the part # for a usdm p30?
- Competition engineering Weld In
- sohc turbo opinions
- red VHT wrinkle paint..but where to buy?¿?¿
- cam cap
- B18c1 instal help.
- are 99 - 00 civic front struts the same as 92 civic
- Anybody been through CHP inspection for their SALVAGED vehicle?
- Someone please HELP!!!! D16y8 in 92 hatch dies on freeway and wont start back up.
- HELP!! where do i get instructions to install ebay chip?
- trimming front fender liner?
- another dumb question but hey...
- EGs with CF hatch
- Any unused Pins...ECU
- I need to trade someone
- does anyone have a flame thrower?
- Whats the necessary parts for a 5 lug into a 00 ex hatch?
- ebay???
- what is a good asking price for great shape.....
- differences in ls manifolds........???
- seat options?
- ebrake problem -- help me!!
- cpe front/rear lips on 4dr.
- racing chip??
- compression test results...
- anyone running tein ss on there 92-95 hatch?.....
- where can i get injectors for a 94 ex civic?
- Ek owners! where do you find CF trunks for hatches?
- turbo in an ek civic
- need help!!
- "STR Manifold B18A / B18B Polished" gains 28 hp! yeah sure!
- inlinefour.com carbon fiber products!?!? u got any!?!?
- mini me...best ECU?
- SOHC Valve Cover
- what rpm to launch?
- sohc vtec fully rebuild Jackson racing supercharger or turbo??
- my Piece of Sh*t daily
- B16A Alternator fit???
- 99-00 OEM fog lights... painted or unpainted????
- is the front lca hard to take out??
- breather on heater core?
- Civic suspension?
- goin turbo
- i need an answer
- Kamikaze!!!
- ECU
- where to buy bolts? rear camber.
- how to put an INTEGRA FASTBRAKES 11" KIT on a del sol
- Insurance question
- which ek to get?
- A small list of ecu codes
- Eg8 with Worldsport
- EK Hatchback Suspension Ideas?
- Radiator support welded on?
- '99 GSR windhshield washing system into an '96 civic?
- Springs/Coilovers to pair up with tokico Illuminas
- NPR intercooler on a 99-00 civic si
- JIC exhaust?!
- 93 civic header fit on 2003 civic???
- 5th gen. PS Removal Kits Ready ('96-'00 also available)
- Carbon Fiber CTR Rear Spoiler??? Where to buy?
- Insurance with AllState for a hybird???? How???? In CA
- JDM B16 or Turbo D16z6?? need help deciding.
- Where to buy EK antenna cover?
- Car will Not start !!!
- 99 civic cd player into 95 civic ???? wiring
- Question For 1999 Honda Civic Si Owners
- Funky Idle
- NOT your typical brake swap ???
- Rim/tire question
- any pics of 95 gsr rims painted gunmetal on a 6th gen coupe?
- Anyone try tint on white coupes?
- need help on price-buying an EG
- WORLD SPORT---Should I order Today????
- 92- 95 Coupes w/ GSR, Si, LS Rims.. Pics?
- To be or not to be: VAFC TUNED
- Suspension Techniques Swaybars
- 3.0 CL Engine
- which intake manifold?
- cracked windshield
- 02 sensor compatibility?
- Gauge Cluster?
- Idle Problem
- 18's on an ek hatch?
- STEEL BRAIDED BRAKE LINES: surfing the group buy... which ones?
- Starting problems with a EG6 B16
- Del Sol Question
