View Full Version : Honda Civic / Del Sol (1992 - 2000)
- i have a quick question
- Integra side mirrors on Civic Sedan
- Fog light switch
- Rear Swaybar and aftermarket exaust
- looking for this one guy on here
- Best place to get Magnaflow products?
- My header buying problems continue......
- pictures only
- did my car come with a front swaybar?
- Damn SOMEBODY Robbed Me!
- How to install EG coilovers
- what does Si stand for?
- OEM foglights
- Rotor size
- parts question
- will a dc exhaust fit my eg hatch
- best place to buy B16
- 93 EG SI.. Dash is Black but Climate control Buttons are GREY??
- Where is the best place to buy Slipstreams?
- VA locals check this shite out!
- looking for new ecu?
- true full coilovers vs ground control type PROs and CONs
- SRS light Question
- Can a Oil catch can/over flow can replace radiator coolant reserve tank?
- right-hand drive
- rear Sway bar for 5th gen 2 door....
- good 195/50/15 tires out right now
- biggest bore?
- EG SiR cluster...bad lighting
- What's the valve of my civic
- For all the 93+up coupes.....
- Dart Block for Honda
- ***Resetting SRS Light**
- how much should i pay for this??
- Oil Change. Engine Flush vs Kerosene Vs. Auto Tranny Fluid
- 1995 Hatch OEM body kit needs to go!!!
- GSR Chip
- BAAE meet at Dave and Busters Sept 21. *Bay Area Cali*
- For all the 92-95 hatch owners
- fog lights on a 96-98 pics pleaase??
- Are Nitto NT-450 anygood???
- Someone lookin for 4dr EG JDM tail?
- CRVtec in a 97 Sol?
- JDM Lower Control Arm??
- The OFFICIAL Carbing/Okuyama GB, with new lower pricing!! =)
- No Exhaust for a Del Sol VTec?
- installing n1 tomorrow
- Will a 99-2000 hood fit a 96-98???
- FULL DRAG del sol
- what tire size for 16" rims
- group buy Fiber Images
- Attn: All LS/VTEC + CRVTEC people.
- Redline 3rd, shift into fourth and BOOM....
- "Fine A*s civic, for sale / trade"
- SPOON air filter
- Hondata stage 2 or 3??
- Can a 99 LS axle back exhaust Fit my 94 DX B pipe?
- what do u use to clean ur headers???
- battery (charge) light comes on... ???
- anyone know where to get an EG JDM cluster at a REASONABLE price?
- ITR Cluster in an EK?
- does anyone know the thread on the fuel feed line?or what kinda fitting it is
- opinions on pics and info of my 5th gen civic... coooooool!!!
- how to take off mirrors
- Which gauge wire for radiator switch setup?
- Standard transmission??
- Updated pics of the h22/eg swap...
- Anyone picky on the type of gas they use ?
- jdmhondaparts/inlinefour
- Help me build a custom 2.5" exhaust...
- I hate my EK hatch (vent)
- break pads
- Anyone using exhaust cutouts???
- jdm sidemarkers
- SpeedTrialUSA instructional track day @ GingerMan Raceway
- is this rice ?
- Starting problems!!
- interior paint?
- Help Del SOLS>>>>>>>
- Brake Light Prob
- will these coilovers work on my 92 civic???
- 1997 Civic grill????
- which CAI for EK hatch with B18C1 ?
- 96 civic dx w/ex lower control arms & the suspension techniques bars that i want.....
- replacing drums?
- EG jdm headlights w/city lights, corner lights, side markers
- suspension problem
- Unplug VSS
- Camber Question
- Which strut bar works?
- Would a b16a be a good engine to put in a 1995 civic ex coupe?
- ecu chipping help
- Oem Fog lights
- Anyone w/ LS Throttle Body on B16?
- Apexi Vaf-c
- what else do i need for a b16a2 into my eg?
- Manley valve springs and retainers?
- another mugen strip?
- Bad Luck
- 93 hatch Vs 240???????????
- How do I make a Civic Del Sol handle?
- a/c removal on 92 cx
- North FL Meet...
- Pics of my AEM install in the eg6..Warning..Big pics....
- JDM Civic SiR 18mm rear sway bar.
- how to change oil?
- what will i need for a D16y7 to B16a2 swap on an lx??
- what does honda do in ohio
- Engine Swap From a 94 civic 1.5 non VTECH to a 95 1.6 VTECH
- Any have armrest in their eg hatch? show the pics..
- Have any of you changed out a clutch master cylinder ??? 93 cx hatch
- interchangable midpipe?
- Rims
- Engine swap question
- B16B/B18C longblock?...anyone know where i can buy just the block..?
- Buying car: Would you, buy one with a swap or buy one and drop in a swap?
- power steering rack in a non-ps car
- Steering Wheels shakes like a mofo at 60mph+...
- What color should I paint the inside of my new garage?
- Skunk2 Camber Kit - Ball Joint Information
- EG seats in a EF CRX
- B16A1 advice, turbo kits???
- Wanting to buy a B18 Type R
- d15y7?
- s15 conversion?
- H22/F22 Vtec swap into Del Sol, anything I should be aware of?
- B16B spoon stroker kit...opinions!!
- Anybody in Tokyo?
- tiens
- My car has a drinking problem (Head gasket?)
- Dilema on which route to take.. could use some advice!
- which tranny to use
- ok i am looking to run 11's on slicks
- integra shifter in a civic?
- Finished putting my B18C5 back together...
- What happend to my hands free kit
- Steering wheel from Civic
- Free CarFax
- hx or gsr wheels oneg hatch???
- another c/f hood ?
- Can you make a '94 Civic VX fast???
- hey for the guys around Texas
- HELPPPPon civic
- 99 Si exhaust piping... will it fit a 96 dx hatch?
- New York meet and drive down to Import Revolution car show Sept 7 !!!!
- Greddy or DC Sports Header....
- Wiring switch to turn fuel pump or starter on to protect from thieves..???
- Come tuesday morning.....
- new MOTOR, different PROBLEMS
- Side Molding Help!!
- (Supid Question) Whats tread wear???
- What is the correct aem cai for my application?
- SHIFT linkage noise
- Engine swap??
- throttle sensor....which????
- C&R of Fluidyne Radiator? Is one better than the other?
- cheap and quiet exhaust for EG?
- motor advice
- Ferio front clip
- can BFG Drag Radials fit 14" HXwheels?
- Header Q's which one and why?
- CTR rear sway bar upgrade?
- Whats the difference between the hatchback CX/DX/VX/and SI on the 5th gen civics?
- Intake Breather Hose / Sensor on B16A SiRII question....
- 93 Del-Sol Question
- 92-95 civic header?
- Need help QUICK...installing used Gground Control right now! thanks...
- intake manifold ?'s
- just got my 95 civic coupe
- i need help wirin a tach.
- Best place to buy Stainless Steel Brake lines?
- RC injectors will not fit
- what advantages for a p72 ecu over stock
- need help finding a fuse
- is this a good price?
- 1992-95 Civic DX Valve Clearances
- OEM Part number
- Put on your Seat belt when the VTEC turns on....kinda wack but..
- WTF???
- raising COMP. RAT. with a 3ply head gasket MINUS the center ply???????
- cant find price value on my eg
- Just put on an ITR AEM CAI(Pics)
- trailing arm swap = wheel rub???
- Saw this EK on ebay what do you guys think?
- 2002 Civ EX spark plugs and wires
- trade my coupe for your hatch?
- Help PLEASE! Gotta see the Ref...
- Lack of AC
- VTEC smoking problem?
- lookin to buy a b16a3 delsol..whats the problem areas? worries? strong points?
- To All the JDM fans, I have a question??
- which PIAA headlight bulbs to get?
- how do i decompress air condition
- What is up with my car?!
- Tein HA vs Tein SS
- Civic Coupe pics?
- Redneck Rebuild 101.............
- clean headlights?
- ECU Jumper
- s14 headlight conversion
- Tire Wear Problems- NEED SOME HELP and ADVICE
- What speed does CTR tranny top out at?
- Looking for a 1992-1995 Civic on the east coast . . .
- Getting a 72 Mini!!
- 92 Civic Cx hb, lookin for any help to bring in power.
- Replacing tail lights!
- Spring Settling
- JDM Honda Civic Type R brake calipers.
- any meets this sunday??
- stock del sol 1/4 times
- what kind of lugs
- Goodbye to Hondatech!
- ** EMERGENCY ** -- Friend broke down in Seattle -- Needs B16A1 Distributor.
- 95 GSR center caps
- What size Magnaflow oval muffler?
- Continuation of Spade's Thread on D series upgrades since I couldn't reply anymore
- Auto / Hybrid Question
- Shock Question
- i know this is played, but what exhaust, because the ws is on forever backorder!
- exhaust question....?
- Can't get the oil filter off! Is there a wrench for this?
- i neeed help quickly
- si tranny
- need d16z6 manual ecu asap!
- Slightly OT: SpeedPeople.com Sport Compact Open
- those of you with jdm steering wheels.
- did any 5th gen ever come with external ignition coil?
- vtec problems need help
- brake replacement questions
- h22 I.D. ?
- del sol si guage cluster ( a good buy? )
- SRS Light??
- oem parts
- installing new tranny and clutch..taking old one out... help!?
- 98' accord headlights on a 92 civic hatchback..
- 3rd gear grinding after VTEC
- soon to be 00' si owner
- Super Trapp Muffer ? Yay Or Nay ?
- Help ASAP on Spring
- Squeaking clutch...
- How to run oem power door locks and windows in 93 cx
- opinion on the apexi ni vs fireball vs skunk 2??
- best way to build a b16a
- civic parts swap
- Bomz Aluminum spoiler which one look better cheap too
- Performance Muffler for my civic
- EK owners w/ CTR rear lip
- b18b revlimiter
- JDM / Type R LCA ??
- Would U Roll In This To School (please move to members corner)
