View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Bouncing Idle with b18c 00 civic running chipped p28
- 99 Civic Si... No warm up... no Vtec
- How to replace drivers side window?
- Help: Civic EG Si, Blower motor not working
- Eg hatch won't start !!
- brake bleeding question
- Fuel pump cover screws
- AC blowing hot air...
- ZC engine build questions...
- How to clean up wheels?
- HELP D16Z6 Bored/ didn't notch vitara/Eagle setup.
- Paint then assemble parts?
- EG Hatch (of course) build thread
- '93 Del Sol SI D16Z6 Swapped Head and now no VTEC
- Desable Speed Limiter
- 95 civic d16y8, not getting spark
- HELP!! Car cranks but wont start, push pedal down to start
- Check engine light issue
- 96 civic ex clutch entered grinding
- Which rebuild kit to get?
- Confused on wiring during install
- S300 tuning question
- Will the wheels fit eg?
- 90 civic dx what do the black/white & black/silver wires go to from fuel pump?
- rear speaker cover
- 96 Boosted EK Block compatability
- Rear struts
- AFTERMARKET STEERING WHEEL
- d16z6 single cam project
- ls-vtec ECU?????
- Stealing integra parts
- Upgrades
- Rebuilt Motor - Bogs down and dies. HELP!
- Weightloss and Hood latch relocation
- Evoultion of my Civic (so far)
- EK Manual to Power Door Panel Insert
- EM1 Cabin Air Filter
- choosing distributor cap
- 98 CIVIC CX tuning suggestions
- ideas on motor
- What style and where to locate LMA's (Lost motion assemblies)
- $100 to spend at advanced auto on my boring car
- First gen B16A head gasket part #?
- strut bar help!!!
- problems with the horn on my 95 civic
- Soft transmission noise.
- Need OE Wiring Schematics
- Tire Rubbing - Suspension Issue
- Disconnected hose. Where is your home?
- No crank CEL 8
- 1998 civic wind-shield wiper resivor leaking why?
- 1994 civic dx , 5 speed manuel question.
- Problems with LS swap on EJ2
- sol d15b7 engine from auto trans to 5spd
- What is the allen bolt on a 99 EX IACV for?
- 94 civic dx front sway bar install questions
- Please HELP ls-vtec sputter problems
- Safe Turbo Build?
- I need help ! Aftermarket header noob question
- Slightly high Idle on my B20 EM1...Is there a way to adjust???
- srs system in a non srs wheel
- Adjustable end links vs non ajustable
- microsleeves??? grooved crankshaft
- Engine squeak
- internal upgrades
- Ek Fog light wiring question, Broken Relay Tab ?!?!?
- Issue with transmission after swap
- Eh3 hatch rear hub
- 1992 Honda Civic Smell Good
- Beeps, but no power otherwise
- Fool the comp
- Cheep upgrades
- 95 vx d15b7 no map sensor?
- Anyone can tell me if this is normal?
- FJ R Spec I-Beam Rods?
- 97 Civic ex hesitates acceleration
- wiring nos dry kit, silenoids and jet to hondata and
- 2000 Honda Civic si been sitting for 2 years
- d15b7 5sp stock transmission on 93 sol
- 93 b16 swap
- Can we rebuild starter, using Toyota parts?
- 92 Civic SI Hatchback Vibration Sound
- 92 civic vx wiring
- 98 lx uncomfortable seat?
- Urgent Help 95 Civic DX Rattle after timing belt change
- 1995 Honda Civic fuse #15 problems
- h22a eh fuel injectors not working
- iacv code p1509 keeps coming back
- sharing my Koni/GC experience
- d16z6 intake manifold fuel rail missing AEM fuel rail install?????
- Cleaning EGR Plate
- PCV breather filter
- rad cap on 93 del sol si?
- LS B18 Rocker Placement
- Replacing vacuum hoses
- Urgent please help! Crx 92 vtec
- Urgent help , crx 92 vtec
- headlight questions
- 95 Civic Engine Code 9
- Intake or Exhaust
- Speedo problem
- 2000 Civic HX Help
- 1995 eg with d16z6 swap
- Chip key system?
- quick horspower
- Help locating rywire parts
- Acura Instrument Cluster/Wiring Harness in a EG Civic
- Converting Light Grey door panels, to Dark Grey...??
- 1993 delsolt code 43 without code 1
- Is there a OEM black LHD dash?
- 98 civic hatch exhaust fit a 93 civic hatch?
- B-series EG Hasport Shift Linkage?
- accel ignitions
- Honda crx 1992 vtec
- Spark and fuel but no start and over heating
- My car's not pulling!!!
- Recent Valve Adjustment HELPPP (pic of setup)
- rear camber neeed help
- coolant leak issue...
- Exhaust Help? Newbie Question!
- Del sol project help!!
- GSR crank stuck
- Honda del sol93
- Painting Front and Rear Bumper Covers
- Coilover Decision?
- Melanistic eg (superslow build)
- Installing manual rack into 99 Ex Coupe...issues with steering joint
- need help with identifying a plug
- Ground wire cleaning/replacement
- 98 civic won't start
- 95 Civic Ex-No Brake Lights-Wiring Issues?
- Gasket Maker help
- JDWhat? Hot Rod tech builds a Honda (1994 DX Coupe)
- Transmission issues?
- Ls Sitting wierd on my ek Help
- fuel issue
- Dash lights dont always work
- cold air and a header
- 92 civic h22 code diagnosis question
- 96 Civic LX Rear Passenger Window Problem.
- 1999 Civic EX - no start w/video
- Need help asap fuses blowing
- Cluster swap, what years will fit
- Stretching Steering Wheel?
- Non vtec head (d15Z4) on vtec block ( d15Z8 )
- Got a dirt cheap 98 coupe, want to restore it like it deserves
- innovative mounts?
- adjustable rear camber need help
- No Power in Interior/Headlights *HELP*!!
- Accident Help.
- Where to buy Catalytic Converter direct fit 2.25"
- 00 civic Mounting ecu
- 93 Eg SI fog light switch
- timing set on a rich d15 & bucking and jerking
- D15B7 Misfire
- Annoying 1995 civic lx probelm
- sunroof glass flew off : / What are my options?
- EP3 Civic TypeR Cluster Pinout
- 92 95 civic HOOD dampers
- RSR Exmag Exhaust for EM1 Civic
- HVAC backlight bulbs
- 92-95 service manual
- Shift Linkage Bolt Size ?
- brake noise.
- a few things...
- '93 Sol Si- Taillight Pigtail
- rattling/vibrating by pulleys
- Let go of brake car dies...
- 1999 civic lx exhaust manifold/header/cat problem
- high idle on startup?
- whitecrow rep. front bumper
- 94 hatch rear brack conversion, help!
- b16a2 swap in 92 hatchback civic - no start
- seat belt conversion?
- 1993 - D15B7 - Possible Blown Head Gasket
- clunk
- 16x7 retracks 225/50/16
- What is the different between Honda Civic DX, CX and VX (1993)
- gas pedal spring assembly?
- Bad o2 sensors?
- Brake issue
- D16Y7 cranks, fuel, but no spark
- new to HT
- b16a2 limp mode
- gonna build my d..dont hate please
- Transmission swap help
- Starter motor not kicking in.
- Door locks wont work with remote
- My New Civic Build
- How to: Changing timing belt/water pump when engine is out
- advanced timing for my z6
- 00 civic ex ls/vtec swap help (ht) coolant issues
- EM1 Civic Exhaust question!!
- a/c-heater vent delete?
- Engine cranks slowly, wants to start, then either starts or doesn't
- 1998 Honda Civic driver door won't close
- New quarters for my 93 civic ex sedan
- ATTN i have an irratic idle plz help...
- surging idle 94 civic dx d157b
- fuel door replacement cable replacement
- Blower motor delete: Is there a way to seal up the hole?
- Would these wheels fit on my 93 Civic Dx Hatch?
- 95 civic tachometer stuck above 2k rpm???
- Civic Si 2000 Not Aligning right
- brake problem asap....
- 98 Civic EX Engine Noise 1k-2.5k rpm (Video)
- diy air box help
- Rear Susspension problem
- 2000"civic bogging stalling backfire on cold start ups
- DEI 524n install.
- D15B7 Bad sound No Start
- about d16x8
- antifreeze overflow tank problem.
- Best Iginition Timming for Economy
- Misfire coinciding with RPM
- 99 civic pedal ratio?
- Central locking system problems
- Idea's needed: rebuilt engine won't start
- bad vss or gauge cluster??
- y8 and z6 cam gear/cam caps
- msd external?
- Light weight sunroof options?
- Fuel pump not priming sometimes please help
- TPS help!
- 1993 Del Sol Headache
- Gsr swap front o2 sensor need help!
- OEM Exedy or Stage 1 Clutch
- Bypassing Del Sol ABS
- Clutch problem
- Misfiring/no power under load, oil consumption
- Swap problems, d16y7 to d16y8
- Exhaust Help?
- bad map sensor?
- Recomended Oil for a D16Y8
- Does enyone know if gsr shift linkage fits on a b16a
- 1996 Civic Blower resister keeps blowing.
- 1996 Blower resister keeps blowing.
- idle help!
- d series help! - which engine is this?
- lots of smoke!!
- Severe Oil Leak
- 95 civic/ 93 integra
- Heat Shield Rattle
- My EK build
- Electrical Problem?
- Can i install Arp studs w/out removing head?
- 1997 civic ek with gsr swap car dies.
- help car redlining by it self
- 2000 honda civic si tuner help
- d16y7 compression pressure
