View Full Version : Honda Civic / Del Sol (1992 - 2000)
- honda parts
- whats a good price for a gsr rear brake setup with good rotors and pads and ebrake cable
- My Dumb question #5 - Which is more accurate?
- How many miles are you getting out of your clutch?
- CF lip issue
- Skunk 2 Stage 2 Cams
- 97DX gearing
- -------- How to inspect clutch disk for glaze & clutch disk life ?????
- How to remove passenger airbag from EG
- ek JDM side markers
- Does my car ride rough because of my shocks?
- just did bypass still bad idle
- Spoon N1 Exhaust
- Burning more gas
- TAIL LIGHT PROBLEM PELASE HELP
- just bought a ebay ITR front strut bar and it's hollow
- Idle issues
- hoses and electrical
- Quick help
- CTR 5 lug installation questions.....
- Anyone have a sedan? Pics please!
- Eg suspension setup question
- What Kind of Radiator Support is This?
- Side mirror queestion
- is there a such thing as a 10 pound racing seat?
- VSS plug in problem
- Exhaust leak. What else can go wrong
- how do i tell what fittings i have on my fuel cell?
- 94 civic ex coupe rear disk with abs with b20 swap trade
- H22 ek idle problems
- Will an ITR exhaust fit an ek?
- Rotas: 95 Red EG6
- VAFC 2 advantages?
- Civic Hatchback: Replacing Core Support Help!
- *HELP* Rear LCA Problem on Hatch..
- Intake manifold question
- ebrake cables for integra disks (specific question) pic inside
- need answer quick!!!!
- My car runs really cool (temp sensor reading low)
- d15b jdm cams
- Will a Integra Sway bar fit ontio a 2000 Civic ex?
- a question.....
- integra rear brake swap/abs question
- Mufflers (real nice looks w/ great sound) help me pick!
- Throttle Body Issues.
- NEED HELP, MESSED UP DURING OIL CHANGE.
- Eg With swaps.... can you still use a full catback exhaust system without having to ajust the pipein
- P0131 Trouble Code....?
- powder coating rims
- Weird squaeking noise please help
- Suggestions/Opinions Z6 head to Y7 Block
- intake mani.
- Rear windsheild wiper question...
- Firing Order - 2000 Civic LX
- ST rear sway bar install on a 98 civic - shock bolt?
- how come pass. head light wont work??
- differences between obd1 and obd2 distributor?
- Blew a head gasket!!!
- Need Help Finding Wiring for 92-95 civic Si or EX
- Stalled and car acted really weird.
- MSD+NGK+BOSH
- crazy idle jump
- Tranny makes weird sound?
- APC Seat! what rails?
- Baring a car with a JDM motor.
- Weird sound?
- dx coupe question
- How do you determine that a motor is legal?
- f20B?????
- help on strut bar on ej8 (searched)
- UH OH FOR THE HONDA!!! :(
- 99-00 foglight switch harness
- sohc question
- Help! Can you tell the model of this Civic?
- Del Sol Clear Corners
- turbo question
- D16Y6...
- need some obscure info re LSVTEC & S4 trans...i've searched and can't find
- b16a4 sirII
- URGENT HELP PLEASE!
- honda fit in the usa!!!!
- b20 in 00 ex
- Is RPM that important when measuring ignition timing?
- Questions about installing parts on a 96 civic DX...
- Cluster wiring
- B18B w/ Engine, tranny, old air intake, and headers
- NRG carbon fiber hatch woes
- corner light wires...
- How do you? make wholes in ecu.
- Any ideas? Bought 00 Civic Ex
- obd II to obd I and other d - series swap questions
- --How do you take off your steering wheel on a 96 civic?---
- Imput shaft bearing?
- Tie Rod replacement
- Need help......door problem...
- Testing for spark, something went wrong???
- shaving the side moldings
- Weight
- Engine swap question help!
- car will not get into gear!!
- Nology Hotwires?
- Did some one say Delsol
- VTEC-E to regular VTEC
- passenger side door question?
- Crankshafts: differences between B16A (1st gen) and B16A2
- 1997 Civic hood will not pop open. Help please!
- crower valvetrain
- b18c1 pistons
- jumping rpm
- delsol engine swap
- Check engine light codes on a 97 civic
- Opinions needed on new paint!
- Where can I buy a replacement OBD2 B16 for my 2000 Si??
- Project Junkyard H22 EG hatch
- Interior Dress Up
- knocking noise
- I need Help Please...B18c bogging in VTEC
- 94 civic cx sell or restore
- Spark Plug wires installation
- Which Carbon Fiber company is better??
- How to get hood off of an eg?
- E-Brake warning light doesn't come on?
- Help! Brakes dont work!
- del sol weight
- Is a JDMCARBOY.COM Mugen Twin Loop Style Exhaust legit replacement for a Fix-it Ticket?
- code 90 question
- 5gen EX floor wiring harness versus SI wiring harness
- Suspension upper mounts and bump stops...
- Q: Replc. 96 Civic LX head gasket
- how much boost van i get with D16Z6 Tranny?
- Wiring Mini Me With CX Harness
- rear disk brakes on 92 civic 2dr, what ebrake cables to use?
- Old and Tired D16Z. How to stop dizzy oil leak
- Koni "yellow" with H & R race springs users
- 98 Civic Hatch Engine Questions
- Full COLor Change???
- *** HELP: Turn Signals Not Working ***
- SOHC swap question?
- ef fork arm on a delsol?
- '00 Si rear suspension/brakes on EG Civic 4 door...
- Im buying a car from a friend...Is it legal?
- my eg2
- DIY - AVCR or VAFC Mounting to Rear View Mirror revisited
- How many styles of EK shift knob?
- new clutch
- Help!!! Eg Front Brake Questions.
- Need to jack up my car?
- D15b drop....questions
- hondaautomotiveparts.com
- help with smog
- Do i need a resonator??
- What is HX trim??
- EG power rack with bad tie rod bushings...
- Question about retro HID
- free play in my steering wheel, tie rods replaced. what can be the problem?
- Megan or DC Header??? What should i buy!?
- Can I Upgrade?
- weak vtec?
- whats the difference?
- Manual Window Handcrank '97 Honda Civic
- How many horses? I really need some help!
- ebc greenstuff!! or hawk/axxis pads?
- the PVC valve...
- Rear Disc Parking Brake Question (not about which cables)
- george the moderator...
- Stuck in Neutral
- Problem with Vtec
- Estimate 0-60 mph??
- ebay headers
- B16 Died!
- angel eyes for my Del Sol
- GSR Cams in B16
- WTB: Megan or DC Header?
- Exhaust??
- EG With EK Front End?
- HELP! car won't start
- fuel gauge does not work
- wired idle problem.
- SplitFire wires
- Why would a topic get locked?
- NEED! Civic EK 96-98 JDM Type-R Front Lip Spoiler
- where to get lines to connect GSR master cylinder to prop valve?
- Brakebooster and master cylinder difference between ej1(d16z) - SiR(B16A)
- Strange bogging sound from engine at low rpm
- how to do an automatic to 5-speed transmission conversion
- Light problem
- Del Sol tranny swap
- Si 99 00 Did it come in pheonix Yellow?
- How to identify if a B18C engine in Civic
- retro fit head lights what is it?
- my swap, what am i looking for?
- heylo people
- Tech Ques: D16Z6 or D16Y8 Vtec head in 98 hatch?
- I need help with what to do to my 98 civic...
- Help identify Motor plz!!!!
- Road Killed a Skunk last night. Car smells horrible! How to rid smell?
- car is legit and motor is not what happends
- Mini-me in a 92 vx hatch
- What parts are inner changeable
- Rear Disk Swap
- quick windshield question
- Axels intechangable?
- is it safe to run 100W H3 bulbs in oem foglights?
- shifting problems
- Quasi DIY for LED modification of Interior Lighting.
- dizzy question
- Rims or More Power
- pics of my EG. first time pics in alabama
- gsr brake swap - positive camber in the rear
- ek w/ ls turbo?
- EK power doors
- Returning car back to stock. Have some questions.
- Tapping coming from engine?
- rear disc swap/4door=ok?
- need to buy
- Any shops in the bay area that can do the ex power window conversion on EGs?
- Need Help Finding 2.5-3" tip n1 exhaust
- How Can U Tell The Diff. Between A 2dr & 4dr EG Rad Support?
- eg or ek
- what is a p08-1
- plz take a look at my main relay, do i need to solder this point? pic
- fuel system problem b16A/B18c1
- Mirror help...again
- car bucking
- Brakes are locking up...
- HEADER????
- B16A2 oilpan question
- quikk question
- DRLs on my Del Sol
- Girlfriends Honda Civic 1996 Vti Coupe
- gas smell but no leaks
- p07->p28
- Were to buy a D16Y8
- b16a1(y1) tranny into eg...what axles would I be able to use?
- EK foglights problem......need electrical help
- B16a Turbo or B18c1 NA
- Add vtech to LS
- removing side view mirror glass.....
- vtec breaking up
- bottom molding
- NGK spark plugs?
- 93 si clutch problems
- side mirror del sol...
- STI Style Hood
- STOLEN EG COUPE MILWAUKEE, WISCONSIN
- How to drop your motor w/ pics
- Seats?
- Removed spark plugs and found Oil
- 93 civic ex? restore or sell???
- 2000 civic si h22 turbo for sale!
