View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Life expectancy of a brake booster
- 96-98 Lip
- Help, what kind of camshafts are these? D-series pictures inside
- Question about y8 intake manifold
- Required Engine Harness for 1999 Civic Si motor in 92-95 Civic
- difference between Drag DR 16 rims and Rota GT3's...
- AEM CAI HYBRID
- clutch noise and smell
- integra and civic knuckles are they the same?
- fluctuating gauge cluster
- exhaust interchangability
- HI new B here got a Question.
- del sol roof rattle?
- Front Axle Q's
- what do you think about this price?????
- power tools to change my axle, where to buy?
- crashed EG.....worth it to fix it or not???
- motor flush
- best tranny 4 singlecam nitrous
- CEL but code blinks infinitely - why?
- How long should a cylinder hold compressed air
- [DIY] Antennae block off plate (56k be careful)
- Questions about integra rear suspention swaps.
- So I have a caulk situation.....
- how much est hp ?
- how much should i be spending in putting a swap in a civic?
- for those that have done auto to manual conversion
- wiring my b20b4
- Fuel cuts out at 5500 RPM, right when VTEC is about to hit, wtf?
- Crack in the Muffler..
- need help b18c
- Horn Does Not Work
- going stock again ?
- for those who has a b16 turbo,what kind of oil do you use
- alignment question...
- where do i jack up the car from the front?
- VTEC solinoid torque specs
- tire size
- what kinda civic is this and where can i get the front end?
- installing fog lights
- Goin rhd
- what is in the 93 civic
- COTTER PINS
- How do i remove the CAM GEARS CAMSHAFTS! PIN KEEPS BREAKING
- turbo help
- Low end Power? what will help me
- My Ek, welcome me to HT
- good deal???
- which is better?
- HELP! Dashlight and other interior lights went out?
- starting the car in cold weather...
- d16z6
- Turbo Timer Harness
- Beaks subrame prace + 18mm swaybar.
- mileages
- Roll Bar in a del Sol
- V-Con shcematic?
- question about EK reinforcement plate
- obd conversions
- 99-00 Civic Foglights in 92-95 Civic Coupe?
- Muffler bearings question
- Targa top seals
- not sure where to post?
- replacing rear bumper and liscense plate garnish
- Valve Cover Gasket
- d15z to d16z swap(ecu)?
- hood question
- water in the motor
- Difference between OBD2a & OBD2b?
- hey
- hey everyone
- 93 coupe CKP (crank position problem) code 4
- Manifold flange profiles
- Installing ASR Sway bar/Tie bar combo?
- Very Noobish Question About Front Grille
- ne got a h22 linkage cable?
- power window door conversion
- Will I have any problems running a 45mm off set w/ 215 40 17 on a 99Si?
- fuel question
- 2 WIRE IACV TRIGGER QUESTION. ???
- Lighting help.
- Water Leak?
- How to PASS INSPECTION?
- will a hatch hood fit a sedan?
- cams question
- pressure plate finger question
- bonnet release cable snapped!
- b18c1 motor
- ctr steering wheel momo adapter
- anyone know a good place to buy 70mm mufflers?
- 2000 civic dx sohc
- strut braces
- need help...no lights in dash,climate control
- Oil Burn Smell
- EK sat nav unit
- Tach........????
- quick clutch compatibility question
- SIR Digital Climate Control
- LS/Vtec
- What swap can fit in my car
- del sol for a turbo integra?
- 00 Si / SiR steering wheel removal
- d series all motor?
- Paint My Civic Coupe Sideskirt? or leave them be?!
- removing stock 99 civic sideskirts??? need to paint these suckers asap!
- NEed a clutch! suggestions?
- falken azenis rt615 WORTH BUYING?
- HELP 92 civic hb converted to 99 civic hb front end
- camber problem
- 99-00 civic doors fit 97-98
- 99ex and 99si harness
- atleast the motor is nice..sigh =/
- Cheap reliable swap
- ctr ecu?
- random question
- mix match
- Timming Belt Replacement
- Weird VSS problems and the mythic god fuse...
- how much for 5Zigen JASMA headers?
- replacement muffler size help need to know size of current system greddy evo on 00 si
- del sol a/c not working
- Engine Removal Question.
- oil pump location
- 92-95 head
- 94-97 dc2 front end conversion on my eg
- d16z6 b0ttom block and d16y8 head will it work ?
- quick hatch question
- whats the requirements for a swap?
- Helm manual question
- 92 timming belt
- How can you tell if the motor is obd0 ,obd1 or obd2??? Need help.
- no grip on steering wheels
- civic 96 dx
- can someone please help me out with a question ?
- Would OmniPower Ek Coilovers fit on an EG???
- 93 EG HB problem w/ rear toe
- insurance 3 door vs. 2 door
- Quick question
- 95 Sedan DX, can I add cruise control?
- aftermarket adjustable front upper arms...
- tunning question
- y7 to y8 manifold swap
- need a new muffler for my old greddy evo catback system need help with size brand and price
- Honda Steering Wheels
- Power Steering problem... Would appreciate help.
- high compression pistons on D16Y8
- guage cluster not working
- PIC REQUEST: SiR lip vs cf lip vs any others!
- d15b
- coilover Question
- ***Went turbo smoking out of top of valve cover and dip stick****
- just oredered obd1 ecu
- Idle Problem 98 EJ B20
- help 92 dx hatch no fuel coming out of the injectors
- a qwik question??????????(eg+dc)
- caming d16 without cams.... ?
- Code 13 Occasionally pops up, ?????
- hood gap??
- need some torque specs
- shift linkage still attached to tranny...
- Noise
- 99 Honda Civic Si Guage Cluster
- b20 vtec setup
- another sad story
- 92 Honda Civic was stolen lastnight
- HELP!!
- JDM tailights
- B18C5 in 93 del Sol
- Seafoam?
- 98 civic ex mini swap
- Lazy Tachometer
- Trial Membership.....
- climate control bulb sizes?
- back again. this time e-brake question.
- do i need the this part(2000 si)
- ASR subframe CTR sway w/ what front sway?
- Distributor Leak
- Pennzoil tranny fluid?
- Manual or automatic? (Picture inside)
- Lights won't come on
- Dimensions of EG
- motor swaps
- Fire balls
- would this be worth it??
- Tranny HELP PLEASE!! Tranny fluid???
- clutch problems
- DIY: Details pics and instructions, how to change your clutch 96-00 civic
- EK 99-00 Fogs
- Help finding brake booster
- "Heated Oxygen Sensor" on a 94 civic
- H22a or Type R
- another teg dash swap question...I DID SEARCH
- turbo kits
- ARP head stud installation
- where are the back speaker wires on my 92 dx hatch?
- Will a z6 alt. fit a dohc zc motor???
- D16Y7 Timing qustion** QUICK HELP**
- Del Sol carbon fiber trunk, tail garnish & front fenders
- need help naming a part.
- SRS Mishaps
- crower rods?
- what kind of primer to use
- Del Sol Shell
- Replacement Proportion Valve for and EG?
- Looking for reputable SOCAL shop to do HID retrofit!?!
- 1.6 EL tie rod ends
- SRS LIGHTTT!???...whyis that???
- FS:GE intake manifold (B16/ls)
- wow
- vacuum leak
- looking for y8 ecu and harness in va
- Question?
- EM1 track times
- cold idle problum
- cam on d16??
- Automatic -------> Manual
- Looking for cheap coilover system
- Whats this EG EK EK9 EK4 SIR CTR?
- Would you or would you not?
- Question about roll cage for an ek hatch
- B16 Axles and intermediate shaft
- Tranny Issues, 92 civic si hatch
- State Referee Certification
- Happy Bar + Harness seat/Belts etc
- Almost stolen...TAKEN FROM AZHT.NET
- custom tail lights
- CEL code 1 o2 sensor....changed and cel came back
- car isnt at 100% potential
- Difference between a 96-98 civic keytumbler to a 99-00?
- help!!!!!! car wont start
- ctr mirror or original spoon mirror?
- idle surge, d16z6
- how much for a del sol shell
- removing passenger side axle?
- How long will these last?????
- Which Brake MC To Order?
- Metal shaving in block coolant drain bolt
- zc motor and lsd tranny 5 speed
- For those breaking rear strut bolts.
- where can i buy this part of the foglight for eg (pic inside)
- obd1 or obd2
- sold my turbo db8, picked up 96 ek
- dash lights on eg hatch on and off
- Simple question from a 92-95 civic
- carbon buildup on top of pistons, best way to remove?
- Power steering into Civic DX?
- oil catch can question
- does anyone know how to get the new nissan maxima headlight color on a Eg civic?
- civic automatic shifter bulb?
- Specific Tuning Question...
