View Full Version : Honda Civic / Del Sol (1992 - 2000)
- itr cams in b16a
- tranny grinding
- WTB TURBO
- Decent Axles??
- d16a6 manifold on a d16y7 head
- 00 Si vs. 00 Ex
- **1/4 Panel Install with aftermarket panels.**
- STOLEN: 1992 Civic SI(Found stripped) Las Vegas, NV
- Question bout EG 5speed parts into an EK
- y8 intake mani on z6 head?
- IS THERE A FUSE FOR THE REVERSE LIGHTS???
- car wont start without a jump....
- Clutch Rattle
- Running Ligh Problem
- eg condensor...
- o2 sensor help
- K&N vs AEM- Short Ram
- amber corners
- can h22a "hang" with b-series...?
- relocating the sunroof button on a eg6
- Where can I find this part for my Civic EX? (rubber near bottom of window)
- New Exhaust
- will a 96-98 ek civic cluster fit into a 99-00 civic without modification?
- Exhaust Help, New to this stuf!
- Which Exhaust?
- COmpression Question
- JDM ek cluster problem
- no fire
- best shift point?
- st front sway bar install
- motor swap.
- Oil Burning issue B16a2 Help me out
- 99-00 civic si cluster
- Tranny Questions from a D16y7
- quick easy dizzy/rotor question???
- burning oil problem
- Wheel torque specs
- Clutch Pedal Noise. Need help.
- * automatic tranny nightmares *
- parking light problem
- EG rear perspex window
- spun out last nite, hit a cement island in a desserted intersection, would i know if my suspension i
- direct swap
- for the eg.. is the vx and si stock wiring the same?
- does anyone no if eg vtec wires the same for VX, SI
- 99 Civic Si engine harness question
- Which would be faster
- need help with my gauges
- Brake Clearance on a 96 EX?
- Redline limiter early?...
- How to increase a D16Z6 Head?
- Baltimore/ DC/ NOVA
- turbo help
- Found the culprit...Need Help!! ..::URGENT::.. Timing Q!
- d16z6 or b18a1 what should i do?
- dash part
- FWD...
- TTR PERFOMANCE
- 4X114 set up for 92 civic
- Where to buy 99 CTR Headlights (Geniune)
- Question about keyless entry.. 96 civic..
- OBD2 JDM GSR ECU have no knock sensor???
- Rear hatchback window trim (EG)
- odometer reset
- h22 or ls VetC
- Obd2 to Obd1
- why isnt we-todd-did-racing.com working anymore?
- boosting stock jdm b16
- Main Relay Question Already Searched
- gsr knock sensor wiring
- cambers for 94 civic
- D15. Turbo or swap it?
- structure of del sol ?
- JDM GSR motor redlining only at 7400 RPM.
- PCV removal reliable?
- 99-00 Si swap in 1995 civc 4 door lx and keeping AC help
- keep someone please ID this Lip for an EG
- alternator confusion..Please help..searched
- AARG!!
- 99 si running like crap
- e-brake cable change
- exhaust question
- need help ASAP. not getting spark, B16a in EG, canadadian model
- classic transmission problem?
- buildin my b20 vtek
- will my car pass inspection and emission in nyc?
- EG DUCKBILL FITMENT??
- B16A2. need some information
- integra type-r front end conversion
- trouble code 4 obd1
- throwing a code need help...
- HID retorfit, do i need shrouds for my projectors??
- axle question
- 99 SI OXYGEN SENSOR HELP
- very sloooow start up, car sometimes wont start
- is 68mm too big for my d16?
- WILL 225/45/16 FIT ON A STOCK 2000 CIVIC SI ?????
- Rear 02 Sensor Difficulties! HELP!
- Headers: 4-1 vs 4-2-1, Which one?
- Need help with the dimmer switch bypass
- Smog Trials
- shift linkage problem
- New A/C Compressor won't seal to hose!
- manifold help?
- Oil in distributor
- What type of ecu should I be running with a b20b4 swapped eg/s80 hydro?
- Just got a new cluster and the tach bounces all over the place.
- Speedo not working in a b20 swapped 94 eg... where to look first?
- b16a swap in 99 civic ex
- some electrical problems on a new car
- Center Radio Console Removal
- No pressure in clutch
- 4dr ek side skirts on 2dr eg?????
- My 92 hatch
- smoke from radiator cap please help
- wtf when i tried to log in it says user-bannned but my profile says
- how much are these things worth?
- Axle help
- Boost or not?
- all markerl lights are on wen i turn my headlights on need help asap
- 95 CX motor to a 94 si motor
- What ECU board type do i have?
- B16 obd2 oil pump on GSR
- whos used 92-95 civic shocks on there 96-00 civic???
- Repairing a snapped "bitch pin" on a S80 hydro tranny.
- H22 Power in Hatch?
- 94' Hatchback
- Short shifter vs. Stock shifter.
- aftermarket cluster?
- Honda Civic 96 VTi Loosing revs
- apexi world sport exhaust question
- D16Z6 Mount Broken TO DO or NOT TO DO
- Will a 96 LS rear sway bar fit 2000 4dr EK?
- OBD 0 into OBD I Vehicle (searched)
- 95 civic coupe b16a1
- Did I just ruin my rotors?? 92 CX
- a/c belt change?
- Is this hatch worth it?
- what is the part# for the headlight/fender rubber surround for 99-00 civic
- how much do k20 eg's run for??
- Question About CTR / EK9 SRS Steering Wheel ? Horn Plug?
- b18a1 swap into civic?
- where is the hose for this? Please help!!vtec
- Rear disc swap from a CRX Si?
- CTR wing?
- Just fixed my a/c system...Bad Switch?
- 95 Del Sol b16a3? Tranny Question??
- 96 civic ex w/b20b swap need some help
- HELP: Quiet exhaust for Del sol
- Trying to clear out a doubt (D15B)
- will a d15b8 oil pan work on a d15b7?
- Boost .... maybe??
- Help on Removing R-12 gas (can't get car to a/c shop)
- 1998 Civic EX
- need help with dohc zc swap, red-lining at 3.5k
- kamikaze headers
- De-Pin wires from connector
- Civic HX CEL Help!
- questons about changing a engine harneess help plz!!!!
- Black EG SI interior
- Fuel Pump problem?
- Where to buy ES Oval online?
- cup holder swap
- Door Does Not Open
- are EG and EK suspension interchangable?
- CEL O2 Sensor
- Clunking from rear of car over bumps
- Where to purchase Miracle Type (2) cross brace for EG Hatch
- Steering wheel removal question
- JDM NAVIGATION???>>
- EG and EK A/C question
- NY Inspection w/ Conversion Harnesses
- license plate bulbs
- 1st n 2nd get stuck, HELP!
- Skunk2 .. h22a ??
- HELP Me
- ls/vtec or h2b
- Replacing pilot bearing on a '93 Civic VX
- new civic owner
- Civic 92-95 EG6 driverside; driver side window crank handle
- HELP: D16Z6 with a S20 transmission = stock Si ???
- Main Relay
- what size is the inlet on the rsx muffler
- city light?
- when very rain driver underside carpet wet
- type r in a ej
- Do i need a vin # on my gsr tranny for state ref aka barring
- Weird headlight problem - diagram included
- head light tinting?
- Looking for d16y8 complete motor harness
- What is this part call???
- sup
- have a 95 sel sol that my motor is going out in and it has the d16 sohc in it
- D16Y8, problem getting it started, help confused
- headlight help! pics
- EK or EJ8
- RSX-S steering wheel fit in an EJ6?
- Would ek omnipower coilovers fit an eg without modification?
- still such a thing as a 3 puck
- sohc 92 civic lsd???
- prefered clutch usage???
- Civic quick release steering
- Transmission/Shift problem
- noob question d16y8 kinda bogging down...?
- shifting RIGHT?
- fast blinkers
- Help Me Please!
- wassup h-t
- Broken motor mount
- y7 header same length at y8 header?
- coolant leak through the upper radiator hose
- Civic w/ BMW Front Conversion
- what is actually illegal on a car?
- 2003 si rims on 2000si
- Looking for a 99-00 Civic Si front lip EBP
- Alright so my car broke down today the first day i drove it HELP PLEASE
- alternators?
- supercharger ? for ya guys
- 1993 Civic - How much?
- ctr cluster in EG6
- CRVTEC DONE!!!
- D15B7 vs D16Y7
- EK1 rear breaks
- EK CTR Headlights Q's Inside!
- Clutch sometimes whines after car being submerged in water. Is it dead?
- B-series swap questions
- What sould I do to supe up my d15b7?
- D16Y8, to go turbo or to get a Z6 and turbo
- jdm b16a wont start || help!!!
- help civic wont start
- should I retire my 95 EX Coupe, buy another or a 95/96 Integra coupe
- 2.0 gsr sleeved
- Buddy club racing spec shifter
- Upper Ball Joint
- WTF - RPM AND SPEEDO GOING CRAZY
- d16y7 with vtec dizzy?? Need quick response if at all possible
- got an obd1 with zc...fuel cutting at 3.5
- Myths / Questions about CTR Mirrors..
- Anyone know how to pull the a/c clutch pulley and bearing?
- obd0-obd1 conversion
- quick advise noob questions
- need help what is this called?
- after rain now my car is stalling
- Head
- B16 Clutch or Tranny issues
- Bosch Universal o2 Sensor Question
- steering rizzack
- Wanted to share some pics of my EG6
- 94 civic ex coupe power windows
- Burning Coolant like CRAZY! HELP!
