View Full Version : Honda Civic / Del Sol (1992 - 2000)
- If you remove the AC on your car will the defrost for the front window still work?
- Could you use any knock sensor for b16a
- d16y8 head question.. Last que I promise!
- 96 HX head fit my d15b2?
- Neuspeed Race Vs. Eibach Sportlines on 95 civic
- Danget, got more d series ques! Help!
- had a productive day..
- WARNING... Do not buy Nokya bulbs
- HID w/ Casper shields into EG6 head lights??
- Autolock Help
- si wheel weight?
- FRUSTRATION!!!
- 93 civic wont start?????
- any benefit to swapping a crx si head to my dx? i figured there would be some
- Aftermarket shocks for stock height?
- Adding power windows/locks to an EG...
- Why mod a VX?
- im missing a side skirt on my ej, can i use a 96 coupe one?
- sometimes not always, my car will bog like its missing a spark plug?
- clicking noise?
- COILOVERS..
- need help please car not running right cel 20 41 65
- Energy Suspension bushing kits
- *HELP*Measurement request: on Front lower tie bar bolts for EK
- help:rear brakes 97 civic dx
- Having AMP PROBLEMS
- orange eg spotted in FV,CA?
- question on IACV, please help!!!!!!!!!!
- 96 headlights ONLY on my 94 coupe, and the 96 seats too... questions.
- wiring from scratch
- civic ek problems
- I AM BAFFLED!!!!...... need help please.
- Repinning. How to disassemble plug?
- About an Armrest in EK
- HELP, Keys stuck.
- Best Solution For Damaged Core Support?
- any way this will work?
- turbo question
- I need some help in the 98208 area.
- invidia lip
- Jerky driving
- removing wheel lock
- Lowered Del Sol
- No Tilt steering to Tilt Steering
- wrecked EG
- Del sol or other EG H-bar pics installed?
- carbonfiber duckbill
- spring rates for a DD B18 swap EG
- Using 3-4-5 gears from a L3 JDM ZC tranny into a D16Z6 tranny + broken fork question ( pics )
- timing belt
- Tenzo Springs
- performance chip 4 93 dx
- B16A2 ECU or any B16 ECU for that matter.......
- z6 Crank Balancing?
- looking for a shop to drill out a screw...*SOCAL*
- Is the PCV hole causing idle problems???
- ITR intake manifold
- P28 ECU problem *urgent*
- Need a car fax..... can anyone help!!
- PCV valve Help
- ST sway bar kit question.
- who sells custom exhaust???
- best/cheapest ecu to use
- b18 dissy on b16?
- Y8 head on D15b block.. ?
- Right before VTEC Dip in power after installing BlOX mani.
- Camber probs....
- B16 Knock Sersor LocatioN
- rev limiter
- Recommend an Exhaust please!
- I need an obd1 o2 sensor pinout
- rust on rear quarter panel near taillights
- OEM Fog Light installation on 99-00 civic
- safc2 base line for single cam
- ek amber clock fitting ?
- RESET button after oil change?
- NEED HELP: MY DISTRIBUTER KEEPS BURNING OUT!!!
- Need Help Fast!
- 5th gen prelude cluster in a civic?
- At high RPM's my car sounds like it is backfiring but it is coming from under the hood
- Difficult stalling problem, 99 Civic LX
- pix of a turboed del sol (so sad gone now)
- wiring a tach?
- Pin for needle broke, gauge problem
- tps sensor questions
- Car slow / not starting in cold weather?
- flywheel bolts
- CUSCO LSD on ebay
- convention oil=sludge ?? is this true !
- 2000 Si transmission options
- swapping
- Rota slipstreams 15" 16" yes no maybe???
- Side skirt
- Quick question.... Please reply
- Reverse Indiglo Gauges ?
- Best Auto Swap?
- Removing seats belts (searched already)
- b20 vtec question
- Integra Dash Fitment Question - Searched, Specific
- turbo prepping?
- selling my 93 hatch in san diego
- 94 coupe, gsr rear disc conversion, don't trip I checked before I posted
- vtec controler
- Battery Light
- Xetronic HID
- Dumb noob question..
- will they still accept recalls for the eg civic?
- D16y8 AUTO tranny, replace axel seals????
- Wheel size and 5 lug conversion
- where does the headlight wiring come from?
- Bad slave cylinder? Noise coming from tranny...
- By pass the Starter Cut relay?
- Failed BAR ref today, does anybody have one of these???? Help? Gross polluter!!
- D16Y8 Having Redling troubles!! Need help
- im getting a ls motor but....
- Anyone here shipped their bumper before?
- yet another Vss/alternator/fuse problem
- What are best coilovers for a daily driven 97 civic?!
- Hondata s200 on a JDM ecu??????????????????
- Check engine Code 6
- help me out with a cost question (d-series)
- How to check Racing Harts for Authenticity
- surging idle, whether its warm or cold engine from 1k to 2k constant
- Tires for 16" Rota Slipstream
- OBX Cam Gear
- 96 EX Keyless entry (already searched)
- USDM head on a JDM block?
- is there any HID kit for jdm bulbs H4H?
- What does this mean when purchasing wheels....OFFSET????
- d16 delso tranny bolt up to d15 93 hatch?
- DX Tb on EX manifold
- code 14 (searched)
- 80A battery fuse...???
- P28...is this NORMAL???
- Cold whine from engine bay
- what would be better for FI, a d16z6 or a minime?
- first say of wntr quarter and a keyed car
- hot motor?
- Vacum line
- Tranny went out, please help.
- tryin to finish my swap...last min problems help me out
- car dies when starting
- airbag replacement tray ?
- whats the difference between a 96-98 and 99-00 floor harness?
- Valve Job how much $$
- Smoke plumes when vtec engages
- tranny and engine??
- Traction Bar Question
- Cat Converter is too expensive- options?
- i need help!!!
- WHERE IS THE AIR/FUEL ON A P28 ECU
- Tire Recommendation
- dumb ida? or ok ida?
- What size lug?
- Clicking Sound in front Axle - Risk?
- wheel bearing ?
- VTEC Controller questions
- alternator ??? ob1 and ob2
- Rattle/Vibration Noise w/ Short Shifter and Exhaust Install
- where can i find a...
- what can i do to get more power out of my b16a
- E Type Service on 2001 Civic DXG - Is it all what it's cracked up to be?
- my new project. -2oo0- 4door ek
- EG passenger side mirror whacked-out
- Idle Problems (IACV, Throttle Cable...)
- Obdo to Obd1 ls Swap
- question about my set up
- i totalled my ek!!
- rad. fan or oil pan
- N/A or BOOST?
- Good lowering
- b16 swap: clutch won't engage
- opinions on 350mm semi-round wheel?
- Wiring Horn with Momo Steering Wheel and Steering Wheel Release Kit???
- quick question bout parts
- '94 Civic Dx radiator losing water?
- Magnaflow Catback On An EG(95) Hatch?...
- just got my 1992 civic hachback
- rear brake upgrade kits
- fuel economy
- head lights
- How do you know when its time for a new clutch?
- Floor brace/bar pics?
- Question about Lower Control Arms?
- "short shifter"
- something wrong with my car. help please
- what went wrong??
- Washington people
- HKS HiPower Full-Catback Exhaust Review...pics & vids inside
- 93 94 Civic only start on three cylinders! HELP!
- motor mount point
- What seats can i put in side my eg hatch?
- Has anyone converted there Del Sol to manual windows ?
- 4" Dropped~!!! Whatchathink?
- Best performance CLUTCH & FLYWHEEL
- delsol lip.. = 92-95 civic or 96-00 civic? which one fits best?
- Possible ground problems on obd2 to obd1 change over!! bad sparks on some ground wires around the en
- A/C problem after swap
- car is poping
- how to remove starter soleniod
- VAFC trouble
- Need help...People with Del Sol's....
- 97 Honda civic axle replacement success.
- cant get the del sol to run
- help on my delsol please...
- blew my d16z6 today... time for a new one.."low mileage japanese" replacement?
- missfiring?
- looking for a engine
- egine dission
- Alittle Help Avoiding Theft
- EG Gauge dual gauge bezel (NON CF)
- Eibach Pro-kit lowering spring question...
- 5G Civics with 16x7 or 15x7 wheels
- junkyard performance. questions
- d series tranny codes
- test
- Does the VSS affect the odometer?
- anyone know of anywhere to get an uprated clutch asap for a b16 dohc civic
- my wheels didnt fit whats the deal? they came off a legend 89 i think
- do i need a booster on a rear disc coversion?
- Engine lifting points
- Will a 99EX Master Cylinder fit on my 93 DX brake booster?
- Apex1 AxleBack or Rear section Where to buy online?
- do u think a b18c5 will beat me b18
- Will a Canadian 00' civic SIR (SI in US) front brakes fit onto my 97' civic h/b DX?
- i ran through axles in 1 week..PLease read
- Oil for my STD
- white smoke?
- PASSWORD JDM fenders. fitment issues?
- perfect suspension
- power window conversion?
- engine
- rod/stroke ratio's needed
- my doors won't open!
- ls vtec
- Can anyone burn a p72 chip that disables the knock sensor for me??
- hood dont go down
- LS/GSR Swaybars on EG8
- OBD2, JDM p72 Pinouts (SiR-G)
- whats the most bhp a b16 will take standard/factory
- Pressure plate bolts
- oil dip stick. between 2 dots or at the top dot?
- I NEED HELP!!
- kyb agx w/ H&R race springs any good???
- My 94 Dx
- attempted wheel theft - tucson, az
- more mods needed
- DX sunroof installaion question
- roof radio antenna problem
- forced induction
