98 Civic/B18b swap dies? while driving.
well, i start driving to work this morning and all of a sudden the engine cuts off, then i down shift to 4th gear then the engine cuts back on. off and on it will cut off then all i do is keep down shifting then the car turns back on. so if any one here has an idea of what the hell is going on please help.
Re: car dies? while driving.
1998 civic ek hatch, with b18b motor. new fuel pump , my friend says may be ignition problem but cant seem to find where the main relay is and is ig 1 under the fuse box a main relay or just ignition fuse?
I had a similar problem once was due to bad ground wire.
Ignition coil sounds like a possible one.
I'd say it sounds electrical, but I'm no mechanic.
Re: 98 Civic/B18b swap dies? while driving.
The ICM is inside the distributor and tells the coil when to release its high voltage spark. Have an auto parts store test it. A bad ICM is a common cause of stalling.
