View Full Version : Honda Civic / Del Sol (1992 - 2000)
- How Do you install a turbo?
- Full rear window roll down
- eg swap
- 1993 delsol, Alternator removal issue
- Help with Skunk2 Intake Manifold and EVAP Purge Control Line!
- supercharging a automatic 94
- How much for a black dash and door panels?
- 99-00 swap
- b16 or b18 turbo newb pleases help
- how much inches to drop a ek hatch?
- A/C gas mileage, scientific proof...
- I feel retarded
- What is the best lowering kit for 94 civic lx?
- Do I have a blown head gasket? please help.
- Battery help 92 Civic
- Center console oem radio doesn't stay put
- D16 Automatic to Manual conversion
- Head compatability
- Fuel Pressure Regulator and Gauge . Q!
- CEL - P0131: What is it?
- How to disable the dimming setting of the oem clock
- EK steering wheel fitment?
- Turbo'd non Vtech Throwing Vtech Code?
- What Master Cylinder
- eg taillights?
- obd1 motor into obd2 chassis?
- b20vtec turbo
- Can someone confirm these AC parts for me.
- Stock VAFC settings for a Civic with 450's
- rear 5lug swap???? help plz
- Are 99 DX stock taillights, the SI red and white ones???
- gotta change piston rings..
- B16b Head on a b18b
- Bad injector causes blown cylinder???
- map sensor
- What to do with a d15b7
- Cabin Harness
- GREDDY TI-C EXHAUST EM1
- parking brake adjustment
- vtec wiring
- Civic 4 Sale
- are the hoods from a 92 hatchback smaller then a 92 honda sedan ?
- throttle response.
- Problem!
- question about p/s
- Question Civic 92-95 EG6 B18 swap?
- annoying clicking and no power windows
- b16 cam question
- Broken Latch on Hood how to pop????
- 1 fog light isn't working..
- d16y8
- gear box oil quantity
- midwest shops? anyone know of any.
- What is this piece(s) called? 96-00 Dash.
- Can I buy a single OEM sidemarker?
- maintenance light....solution?
- help b16 swap ques
- What motor does this cam gear go to?
- which headers 4 my civic.
- 1993 Civic Crankshaft
- wheel stubs removal
- d15b motor in 96 civic dx non vtec
- installing gauges help!
- B16a
- 94 civic CX ( blower motor not working)
- can anyone identify this exedy clutch by numbers
- EK with GSR little prob. LOOK INSIDE
- d16y7 sensor
- d15b???
- question???
- Anyone here ever try to get 50mpg+ in a Civic?
- Whats the name for the second din cd spot?
- Brake Conversions?
- a few questions with pictures
- What type of cams are these?
- f20b tranny ?
- Flood Damage?!?
- HID's in eg6 depot fogs??
- Civic Hx Idling High
- 92 cx hatch, Window problem
- NEED HELP BADDDDDD!!!
- type-r cluster in 92 eg
- New Head, Lots Of Blow By Now....
- Quick cooling question
- I have a B18A and I want to mate it with a hydro ls tranny and I have a few questions
- EG9 with B18C does not crank after a drive
- How to tell if B16A2 is from 96-97 Del Sol or 99-00 EM1 Si?
- need help
- Bad Thermostat causes Radiator Fan to not kick on? More Cooling related questions...
- Wing Mirror issue
- Shifting Problem
- head question
- OBD II emissions question
- steering problems... becomes way to light
- i'll have this extra motor soon..
- does lsd9000 it's bolt on on both gear box with final drive 4.26 and 4.4
- OBD2A or OBD2B ECU?
- i am about to do a tranny swap
- Anyone get me a price on these part number from Honda USA
- d16z6 AC system on a d16y7?
- how to retro fit projetors in ek civic head lights
- sk2 pro series intake manifold..
- h22 ecu
- 4x114 rims help plz!!!
- Cluster Wiring Plugs dash swap?
- Used Goo-Gone, now dash hazes. Solution?
- My 94 Civic DX and the D16Z6
- how bad ass is it?
- What color are these rims???
- Suspension
- Tein S-Tech or H&R Sport Springs???
- Oxygen Sensor!!!
- side mirror compatibility
- HELP... Dome light dosent come on w/ door open
- dim lights and stalling, i need a tune up???
- is this turbo kit good or bad
- B16b head on b18b possible or not?
- fan relay
- rear window question
- Door Open - No Light??????
- Civic chassis question
- FIN wheel curb help
- Inside an exhaust muffler?
- please help
- ARP TORQUE???
- d15b iacv help
- Honda Advanced MTF vs. GM Synchromesh FM
- Need an AC conversin question answered...
- chrome painted calipers and drums??.......
- Question: car is slammed and rubbing a grove in the middle of tire
- rear drums, spindle and everything else
- air intake question
- where can eye by a vtecE controller?
- integra obd2 harness into 96 civic question
- Nitros oxide
- unusual main relay situation
- my eg is leaning
- Craaap, head lift and overheat!
- I GIVE UP!!! help please.. I will paypal $25 for the answer
- Blew my motor last night. Now Im puttin a new onw in tomorrow but need opinions
- leather integra seats for four door civic? does it work? (rear seats)
- A EG radiator and fan into an EK?
- need a knowledgable honda dude, y7/a6 IM swap
- What motors will fit in a 92 civic hatch CX?
- low voltage, car won't start, no power, help please.
- del sol front end!!
- 93 honda DX ignition switch problem
- oil usage problem
- cable reel behind steering wheel.... WTF!!!!!!!!!!!
- Starting Issues: is ECU the problem?
- 95 CIVIC 99 EK AC QUESTION
- D16Z6 crank pulley same as D16Y7?
- Zex on d16z6
- Headlights dont come on
- Question about 94 B18b in 93 DX hatch
- Ecu obd2 to obd1
- oregon tuning
- Headlight problem
- 05 rsx seats in ek coupe.
- WTF camber issues and 18"s on a civic
- can i extend my rpm???
- lower seat position
- can someone please help me get my b20/vtec to start
- help with excessive tire wear...
- Is this piece broken? Fuse box cover
- b16a in EK hatch failed emission twice..
- gsr cd player and radio in civic anyone done this?
- GSR CTR or Skunk 2 S1 Camshaft?
- d16y8 piston?
- civic pulley?
- 92 civic lx problems
- minor build plans
- oem cd player
- swaping f23a1 in ej
- 99 half shaft
- Transmission bolt size quick question
- Turbo Ek help
- JDM D15B Gas Problems?!
- Please help me with my problem... :(
- suspension setup
- Taking off driver side mount on motor?
- vtec
- High Mileage 1999 Civic Si Problems?
- use my
- 96 Civic wont start d16y8
- y6 bottom end y8 head swap crank sensor help!
- driving without p/s?
- Fuel Pressure??
- Putting a cable tranny in a 92 Civic CX
- Hello everyone, just another new guy on the block.
- stripped oil pan drain bolt......
- B-series Engine question
- b16b throttle position sensor voltage output wire
- gsr gauges into civic wont fit into dash
- interior LED dome light dissapointed.....
- water coming in?
- 98 civic main wiring connector?//
- too much oil?
- F****ing wires
- wtf! AC causing water to condense and leak into passenger floorboard??
- What to use to clean ek headlights that are clouded (faded)?
- Need a part number please
- Front/Rear Lip Questions
- Problem with the a/c....
- jdm fog light switch
- 93 hatchback has d15. want to swap 89 d16a in. what harness and ECU?
- Shear bolts for ignigition
- I NEED HELP MY CAR WILL NOT MAKE ANY POWER
- Setting up Apexi SAFC
- civic eg hatchback... with ls/vtec exhaust question.. need help
- autocross suspension ideas...
- Help decide civic or integra
- sinlge cam. needs 2 b warm
- 92 hatch runnin weird
- Weird Qustion hope someone knows
- Looking for more out of my b16
- what would you pay for a 92 civic cx PICS!
- Clicking in suspension when I turn
- help with a caliper !!!!!
- Neo AFC and Nitrous
- Overheat HeLp!!!
- Need Help With walbro pump
- 2002 civic ex/si problem
- OBD1 Computer and Secondary O2 Sensor Question:
- Cooling Fan Issue
- speaker installation
- P07 Pinouts
- curious....b18c1 question
- Weird squeaking sound when my a/c is on..
- quick tuning question
- Help: Passenger Seat Belt Replacement
- window removal
- car wont start and no interior power
- Help me whit my project........
- Hatch rear wiper delete?
- SEIBON carbon fiber hood help...
- IAB wiring driving me CRAZY!!
- TRANNY DIFF ISSUES
- rewiring o2 sensor
- How do i get here???
- D16y8 vs D16z6
- Boosting my B16a Advice needed
- Rattling noise when Vtec?
- 6th gen front LCA on 5th gen??
- What parts from other cars are compaitble with a 93 hatch cx
- fitting stock itr airbox onto ek4 ?
- teg seats
- b16a2 into 98 ex 3dr
- B series throttle body on a D series motor
- IACV symptoms? mine jerks when i give it gas at low RPM
