View Full Version : Honda Civic / Del Sol (1992 - 2000)
- crank angle sensor....d16y7
- Newbe Needs Help: New Motor, Car is sluggish taking off?
- new memeber
- AK1 Motorsports Fail
- setting timing on 92 vx
- running power wire from the battery?
- www.tigerjapanese.com
- are these any good?
- CAR STOLEN **BOSTON** 4/12/08 B16A DX COUPE
- Bypassing Oil Pressure Sensor Problem..
- Jdmb16 into 93 lx tach no worky!?
- HONDA CIVIC EK HATCH QUESTION!!
- 98 honda civic body kit
- Door skins??
- dizzy ?
- Reliable Site?
- ***URGENT!*** How to fix timing?
- in-tank fuel filter?
- swap need help
- Crossmember same?
- Code 15 ignition output signal
- Help repair
- boost on stock rods?
- curse control on a ek civic
- 150,000 Mile Service interval?
- Prelude brake booster and Master cylinder fit 99em1?
- Just Joined here is my 94 Sol
- Quick question about Headers....
- which K&N air filter will fit the AEM SRI for 96 civic?
- Headliner
- Bent OEM wheel
- For a front bumper what do you like better?
- Door Panel help!!!!
- How to get metal debris off windsheild?
- ek/w 4x114 convertion. rotor replacement
- 92 CIVIC HATCH STOLEN HOWELL, NJ RUF 74N
- need some help..........
- Seafoam + RP <3
- Any one use restore lube?
- Need help on my type-r swap into 97hx.
- white smoke
- Quick question....pleas look
- knocking? or something else?
- funny noise?
- championship white in rattle cans?
- 92-95 Civic cabin/dash harness question/HELP!
- alternator? em1
- b20 swap help!
- Bought GSR Leathers, how do i put it together
- Those who've relocated their batteries.....
- Interesting Issue with VSS on B16a2 Swapped EG Hatch.
- Value of used D-Series engine parts?
- b16a3 check engine codes.
- i think i may be burning oil. what do i do to fi it.
- question about fuel problem
- 94 civic si...idle problems..
- Cheaper and better choice
- 92 CX pre-wired vtec?
- 92 CX interior question
- car won't start.
- How to wire 1.5 SOHC V-tech
- just a few questionsss
- ECU problem!!!!!!!
- tranny question
- Looking For Del Sol Parts
- jdm b16a obd0 running obd1 ecu help.
- jdm obd0 b16a running obd1 ecu
- P/W Conversion Q
- Car sometimes starts but its a prolonged start 92 civic dx please
- 92-95 fenders
- Del Sol B16a2
- Tire size?????????????
- exhaust question...
- Picture of a drivers side mount bracket integra and em1?
- Cluster lighting
- no fire, no spark, HELP ME PLEASE
- b16 idling weird
- how do i wire up the turn signals on my new m3 side mirrors
- homemade shift light in eg
- b20 block with b16 vtec head.
- b16 cam seals the same
- clutch switch location
- Factory recall or not?
- 00 Civic B18C1 Exhaust recommendations
- need advice!
- Interchangable parts for civics~~~
- spoon stroker kit
- how to install vtec on a 99 civic hb
- Hondata Dealer/Tuner in Chicago?
- em1 trunk question
- Project: EK9 facelift dash into an EG civic
- 00 em1 stolen :(
- Civic lambo doors?
- del sol
- strip motor mount
- civic swap, what would be better, want to boost 5 psi h22a4 or g23
- to rebuild or not to rebuild transmission
- 92-95 b18b1 ls motor upgrades
- question about tweeters in del sol
- vtec controller???
- OEM Honda Cd palyer wont play cd's Please help.
- ej8 gsr swapquestion............
- si side skirts for 4dr
- VX vs HX Tranny Gear ratios?
- 96-00 civic 2dr/4dr spare tire cover spacer thickness?
- CTR N1 crank pulley - belt size?
- FWD 13b in ek.. is this new?
- code 6
- Home made 5lug?
- simple question
- power window problem wiring!!!!!!!!
- Just bought a civic, a/c not workign
- Replacing stock steering wheel on a 99 civic!
- Skunk2 coilovers W/ Tokico Blues on civic 00 ex
- Has anyone heard of JDM UNLIMITED?
- cf products
- 94 DelSol D16z6 cranks but wont start please help!!
- Dim driver side headlight
- Partial throttle engine miss or "stumble"
- Got my new Engine but im confused... help needed!
- Code 91 (Fuel Tank Preasure Sensor)
- i searched....y7 bottom z6 head...mini me...94 ex civic coupe
- 95 civic disc swap question
- coilovers .
- 1995 Civic Lx - - - Quick Start When Cooled Down - - - Hard Start When Hot
- shift trouble
- Camber Problem
- Reprogram ECU with JDM?
- Idle does NOT go DOWN!
- distributor coil
- 1995 HOnda Civic Dx Floor Mats
- wtf.........alternator belt wont stop screamn.....
- Weird Revving? Idle?
- noob question
- Clutch fluid problems?
- Speedometer Issues
- Power to Manual Steering ?
- h22 non LSD tranny
- cel question...........
- 2000 cx hatch can u install ac and ps
- What you guys think?
- BUMPER???
- brakes
- vtec timer on d16y8 sorry bout that
- stock exhaust / muffler question for 93 civic cx
- b18c3 cams!!!
- vtec timer on 93 civic with d19y8 motor
- stock D16Y7 numbers??!! hp- tq
- Tire width and height questions.
- h22 manifold in eg
- Question about a service manual
- TPS HELP
- o2 censor cel...........
- 93 desl dol parts
- HX stock wideband!!! whats up with this?????
- 97 civic no BRAKES !!
- alternator problem
- gsr ej8 swap boging at 4000rpm........
- Engine Problems - d16a6 head/d15b7 block
- Pulsating lights and voltage
- b18c or k20a
- Need a fuse size.
- What is the stock throttle body size for a d15b8?
- help gsr problems
- P28 with type-r programming
- type r badge??
- I got a shaking, vibrating issue?
- ek rear suspension in eg question searched
- Full nose mask
- Stock rebuild, suggestions please..
- help
- 91 crx seats into 93 eg hatch?
- noise at timing belt area
- Exhaust Manifold
- no start
- f22c1
- 98 civic fixed with Honda parts.
- Skunk2 struts on a 1999 civic si. Any good?
- what throttle type is my B16a2
- Need help!
- scs service connector
- P0420..
- D-Series And B-series Mounts Qusetion
- What motor mounts needed in a 96 civic??
- some electrical issues
- 98 civic door wont open from either side of the car
- Anyone know if the honda civic 05 stock cd player will fit?
- Mount Inserts....
- what can be this cause?
- 92-95 civic Rhd help
- Anyone know how to open a hood on a 1994 eg if the cord broke
- cluster question
- ecu repair
- CEL code number 24????
- wiring o2 sensor to the ecu??
- Plexiglass rear windows
- del sol piping size?
- camshaft regrinding
- How do I set the timing on my B16A2?
- B20 in an ej
- is wire tuck worth it
- Starter
- questions on tranny?
- Adjustable camber (front & rear)
- crack in my oil pressure sending unit bung!
- Quick yes or no Question!
- How To Wire Distributer(MSD)
- sorry for this question...
- ecu question...
- Spring LMA's
- h22 dont know if i will pass emissions
- motor swap in ek9
- JDM Mugen TL exhaust help.
- How many pulses does VSS produce per its single revolution? (d15b2)
- A/C (quick question)
- How to seal off water from leaking into the trunk ???
- Fitment and Quality of these lights
- Rear Spindle Dia 1.180" which trailing arm is this from?
- Voltmeter gauge installed,still not workin..
- Nittolegends game
- p06 auto ECU
- Side mount question...b18b
- exhaust manifold question
- D16y7 Mini Me or B18a ?
- complete b16 swap
- Dimmer Switch issues/Diagram wanted
- Which intake manifold is better the b16a or the b16b?
- B16 thermostat HELP
- 1992-2000 axles
- doing a motor swap in a 96 ek. need help with mounts
- 99-00 SI front sway bar into 99 EX
- fuse keeps blowing...cant find any help
- can i make my dx have power windows??
- EG intake question
- h22a in eg issue help please
- After changing cams,should change map sensor?
- EG civic EX cluster into DX EG
- I am trying to make AC work in my car. I need help!!!
- ek9 climate control to 99 usdm civic?
- EM1 Spoiler Where Do YOu GET THIS!!! PLEASE TELL
- putting a z6 intake mani on a d15b7 ?
- engine light on..
- 2000 Honda Civic Power Mirrors not working
- D16z6 TURBO! or H22
- can i put my ls t-bracket in my eg with my b18?
- 94 B18c hasport mounts dont fit
- 98 Civic Air Compressor bolt torque specifications
- Removing shifter linkage - plz help
- Fix it Ticket
