View Full Version : Honda Civic / Del Sol (1992 - 2000)
- suspension question
- Towed At Midnight(Help Please)
- cant find DIY
- Need info on Roof Rack fitment - Thule / Yakima
- is it worth it?
- b18 swap not getting high rpm
- need h22 swap into eg6 infos
- 2000 GSR swap in 1995 Civic DX Hatch-HELP!!!!!
- PLEASE HELP, car problem
- Tried Everything, NEED HELP!
- Which integra axles for 22 swap?
- 99-00 cup holder in 96 dx?
- Help.
- How reliable honda is...
- 92 civic overheating. TRIED EVERYTHING!
- axle seal leak wtf? help
- will 99 civic ex disc brakes bolt up to a 93 del sol S????
- camber issues with eibach prokit?
- CEL and idle up and down
- Green plug behind fuel/temp on EG cluster?
- Getting head milled...ideas?
- Rota wheel alignment ring?
- Wheel bearing snap ring
- Removing or Replacing radio power antenna
- 94 Integra Locks in 96 HB?
- Weird Problem...
- shiny si wheels
- B16B ek hatch axles
- car shuts off again?!?
- koni coilovers, what's in the box ?
- New window motor
- Oil leak seems to have just gotten worse - where is it leaking from?
- state ref decibel test.
- timing help
- oil leak .. what is this? and what should i do?
- 08 Si seats in my 00 EM1
- PCV Valve causing CEL?
- mini me bogging issue
- JDM 5 lug swap axle issues
- gsr swap into eg question
- confused with my car
- Ferio Panels Help
- NEED help on installing new springs
- Rebuilding EG VTI CV’s….
- 99 civic ex and gsr ecu
- My Brand New Project.
- 1993 Honda del Sol with engine problems
- 2 step ?
- how long do outer tie rod ends last?
- quick need help speed sensor question
- CV Joint
- Where the hell did this come from?
- 2000 Civic DX Cluster Question ...
- NRG TYPE R REPLICAS
- Honda Civic New Dash Center Trim Radio Bezel
- Polished lip fat 5's? anyone got pix (already checked wheel n tire)
- when replacing a clutch...
- Need help Before wasting money
- HELP - Do i need a new axle?
- jumpy idle/motor trickles down?
- Weird Idle Problem
- radiator hose diameter
- NEED CRX HONDA SERVICE MANUAL
- Power Steering - Which One Is The Return Line?
- Aerodynamics/ram air question... more pressure at wiper cowl or under front lip?
- driver window prob...
- Problems with fitment of ITR front sway on EG.
- busted brake line, need help
- idk what to call this thread. a call for help??
- GOT Busted
- speedometer intermitantly stops working
- quick el sol??? pleas help
- Lookin for used car...
- Wat should i get
- missing something?
- A/C broke Help! 112 degrees here in Vegas!!!
- 2.5 cat back
- what do you guys think i could get for this ...
- D16z6 to D15b7 swap
- 1998 DX civic
- main relay????
- cruise control for civic ex 2000
- Help with installing A/C for 1998 civic
- question about possible damage to the main bearings d16y5
- does anyone know how to PM anyone
- A/C not working
- b16 idle problem (searched)
- Moody Windows! Could use some HELP
- Help me ID this center console, Please!
- fuel filter location
- Some help please!!!!!!!
- will my shocks blow?
- 97 hx with p28 computer
- Automatic Tranny issue
- What is the acg fuse for
- CEL help.
- how to take off handle for maunal window???
- LS Manual into a '00 Auto? - Help please.
- TPS sensor
- brakes locked up
- Calling all DIY CTR headlights owners
- KONI YELLOW? TOKICO ILLUMINAS?
- Hard starting
- tubo b18
- b16 lost motion assembly?
- Any ideas what these are........???
- Blew a heater hose yesterday on the freeway is headgasket blown?
- 00 civic si non interference?
- b series tranny on d series??????possible?
- leather eg seats???? OEM????
- new tire rod end?
- projector bulbs.
- Need help Del sol problem
- Rack and Pinion?
- What makes a camshaft loose?
- [95 CivIc Dx]Where can i put my cold air intake in my engine bay??(With Pictures)
- car still shutting off after it gets warm
- Catalytic Converters
- WTF! Tranny will not go in!
- no power to my ecu
- help with my speedometer!!!
- So I just blew the SHIT outta my b16
- Ebay H22 mounts into eg
- HELP - ebrake not working after rear disc conversion
- 95 CivIc Dx. My horn stop working tonight.What could be wrong??
- 96 obd2 knock sensor
- d15z1
- EJ1 Gas Light
- tranny problems...
- I would like to clean under my hood....
- stolen mr em1 east rutherford, nj
- Should I choose ceramic sport or racing.....
- messed up speedo!
- oil???!!!!!!!!!!!!!!!!!!!!!!!!!
- Water Pump
- Possible Cluster Swap?
- Light problems
- damnit....my diff blew on my z6
- MSD dizzy
- built motor fire up noises scaring me
- Quesion bout integra's "T" braket or "L" braket!!
- ls black made vtec.. not lsvtec. .HELP
- signal to starter motor
- what would be the easiest way to replace rear struts? 99 civic si
- zc motor
- Need a D16Y8
- I NEED A FENDER
- Why does my Gsr motor feel like a single cam?
- Mushy Brakes
- rear lip, hatch to coupe
- Removing ABS off my '94 EJ1
- civic h22 idle air control valve
- 34 psi at idle normal?
- Just got an 92 vxc EG need some help guys.
- vtec doesnt engage?
- MVM pulley
- tap and die ?
- Would 99 si headlight fit perfect for my 00 ek?
- P1509 WTF?? IAC VALVE CIRCUIT MALFUNCTION???
- !$@%! I think my caliper is broken??
- 92 Civic Dx Won't Start. Please Help!!!
- vtec not engaging
- 11.5:1 Comp Ratio With Boost..
- Parking brake cable in swap
- cel help
- obd2 distributor pin location
- 04 si steering wheel on 92-95 civic
- Any website for a 97 honda civc repair manual
- Ek hatch interior question...
- Oil pressure
- 96ex problems..car wont start
- Need help with 2 things [Electronics]
- D16 Transmission makes grinding noise when shifting to 5th and reverse. Help
- zc block z6 head compression.
- EM1 Si ---> Brake lights not working!?!?!?!
- leaking valve stem
- CAR WON'T START NEED A LIL ADVICE 96ex
- leaking oil?
- clutch squeak?
- supercharger vs turbo
- 99 si bad gas mileage
- air condition help
- Burbley exhaust
- What just happened?!!!
- Foglight Help
- Time for new brakes
- im working on gsr del sol cant make any power besides idle.... workling on now!!
- Frozen Ebrake Cable
- 1996 honda civic with jdm b16 swap need some help
- Transmission question
- throttle plate sticking
- Buzzing IACV
- p0171, terrible gas mileage
- EK rear motor mount?
- motor mount stiffness ratings ?
- Timing belt, skipped couple teeth, help...
- is jdmsh!t.com a good shop to order from?
- Powersteering Y/N?
- b16b, b18cr, or jdm gsr, for my 2000 si?
- em1 electrical problems.......????????????
- OBD1 engine and OBD2 ecu??
- need a used motor for a 1998 honda civic ex....
- swapping a gsr. keeping same exhaust. will my exhaust sound change with the new engine?
- Time for a full tune up?
- Bodykits...bodykits....bodykits
- Early Redline.
- throttle cable = throttle body cam?
- em1 fogs into eg hatch???
- HELP NO SPARK ON B18C1
- Where to buy honda parts online?
- s2k cluster swap
- Really bad shaking between 55-70MPH
- reving cuts off at 6000
- having an engine delivered?
- 93Hatch b18c1 swap powersteering question
- oh s**** i stripped the flywheel thread
- right turn signal jump to left signal after turning
- hatch, coupe, 4 door sedan bumpers
- How to remove door windows on a 1995 Civic SI?
- D series transmission issue. Slipping/popping out of 5th gear
- Fuel Gauge Malfunction
- Help Me? ** Tranny Conversion
- 97 civic hatch CX brake question
- coolent leak??
- extending o2 wires
- help with ek swap
- My Jdm Zc pass smog??
- Removing tint??????///
- Quick question regarding an ITR intake manifold.
- ********** HOW DO I INSTALL THIS **************
- turbo?
- Eg Fog Light Question
- AC Problems
- boosted b16 idle problem
- $100 intake and $200 exhaust
- Let me see those honda's slash Acuras with fit (jazz) stocks
- neons
- ok not trying to drop a mill in my 98 but want a little more out of it
- will a cold air intake on a stocker make much of a difference???
- what r the biggest bang for your buck??? 98 civic ex (low budget)
- :::¿ Tips or Tricks ?::: ____ Best/Easiest way to remove 92-95 Gauge Cluster Trim ____
- DIY Front Lip Fix?
- clucth stuck and squeaks when pushed
- 97 Honda Hatch DX power window & lock converision?
- 93 Sol, new rear calipers, parking brake not working ???????????????
- ek brake problem please help!
- fitment of side skirts
- trying to put a 1995 automatic ls swap into my 98 civic need help on mounts and wireing
- NEED HELP WITH DIZZY ON B18c
