View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Del Sol has fuel but no spark - ignition switch problem?
- 00 hatch/OBD1 GSR motor - Throwing codes #9 & #20
- 99 si from canada - Will JDM d16y8 swap run fine in my car?
- B16a3 still bogging after o2 replacement
- Del Sol Decals
- Radiator Hose GS-R swap and Del Sol radiator
- Alert to distributor wiring diagram error at Phearable and We-Todd-Did-Racing sites
- Gsr: White smoke when cold start
- s2000 cluster swap into ek
- Mini-me b7 block/z6 head/y8 IM - VTEC brick wall! HELP!
- 96 honda civic ignition switch replacement video or tutorial
- 98 EX stopped and now won't start!
- Civic EG emblem size?
- D15B2 head swap
- 97 HX rear brake conversion
- Another Turn Signal Issue
- 94 vx barely hits 200 miles on a full tank!!
- 93 EX coupe- key only works on ignition not doors.
- 98 Civic Dx/D15B swap - 02 SENSORS HELP!
- Questions about rebuilding D16Z6 with 120K miles
- HOW MUCH IS MY EJ1 WORTH
- 93 eg has brake shimmy
- eg civic wont spark?
- overfilled oil,drove 10m,thick smoke,drained but..
- eg cluster wiring question
- '00 SI Wiring Harness Plugs?****
- Dropped wingnut into VSS hole of tranny -- oops
- 2000 si with b18c5 block: What pistions to use?
- Is the Autozone b16 head gasket any good???
- Rear disc conversion on 92 CX, which M/C?
- 98 civic ex driver door wont open from inside or outside
- wire harness
- can i use my y5 harness on a y8
- Del Sol front bumper on civic DX
- looking for tranny
- Problem with GF's 97 civic EX radio.
- Oil pan gasket on 2000 Civic with b16 swap
- Help! D16Z6 Swap, AUTO Transmission
- hose question
- spark plug question
- Need help asap...zc d15?
- mine me problem!
- Aftermarket torque mounts
- OBDII b20b in a del sol?
- D16Y8 Engine Harness Help
- 94 Del Sol with b18c swap - How do I know what year my motor is?
- d15 mini me y8 mani
- Thermostat Issue?
- Fuel filter installation failure
- Misfire when CEL off / Runs Smooth when CEL #41 On...HELP!
- Alarm not working after conversion
- Will the A/C line from a 93 civic (SOHC) work in a 99 Civic Si (SOHC)?
- 97 EX/B16a2 swap/Auto-manual conversion - TACH NOT WORKING!
- Does spark plug replacement affect mpg?
- Possibly picking up a Del Sol.. worth the money?
- Steering wheel turns but tires don't
- Most comfortable bucket seats you've sat in
- 96 Civic/D15b7 swap - won't rev past 3500, tach won't work, CEL code 4, HELP!
- obd2 ls into 95 si
- MTV's True Life - I'm A Street Racer
- B18a1 in Ek Vacuum Lines ?
- 92 dx hatch - Need input on building K20z3/6-speed for boost
- Need new exhaust for B18b1
- Car shutting off/idling weird, randomly.
- b18b intake valve question
- 92-95 Interior Fitment help???
- 98 ex coupe - Gauge lights stopped working
- Sloshing steering rack when turning wheels with engine off?
- 99 Civic Si - key-in reminder stopped working
- 99 civic window problem
- Starter won't crank after mini me swap!
- Aftermarket oil pan fitment for jdm d15b??
- poor mans type r help!
- 97 dx coupe nrg short hub problems
- Lowering virgin EJ1 - How replace the stock shocks?
- No power to driver side underdash fuse panel
- Need help with swap Del Sol GSR
- engine block mount post removal
- norcarsol's 93 Del Sol build
- Does the dohc zc use a D-series clutch and tranny?
- del sol d16z6 build
- 94 del sol/B18c swap - White smoke coming from the oil fill cap
- 94 Si coupe Check Engine Light
- 98 HX running too cold
- need help! swapping motors, Ej with ls/v into ek cx, and y7 into EJ
- Will 96 d series vtec solenoid will work/fit on a z6 head?
- 96 civic setting monitors to ready?
- D16Z6 oil pump removal help
- civic si 00 instrument cluster light off
- 95 civic hatch - When headlights are on, the passenger brake light won't work
- 94 coupe - No Dash lights with headlights on
- Mini me (d15b7 block/z6 head/Y8 IM) - I need hose help!!
- Tension timing belt
- Where can I get a wiring diagram for a 95 civic?
- 93 eg hatch/b20 - White (possibly bluish) smoke in exhaust
- 96 civic temp gauge problem
- b18b1 swap running/starting problems
- 99 DX Hatch - A/C install, cluster swap, and hatch hydraulics questions
- How much for cf ctr spoiler?
- My exhaust headers - Need advice on cylinder volume numbers
- D16Z6: How to adjust timing without timing belt cover?
- What OEM Steering Wheels Can Fit In My EG Hatch Thats Smaller Than My OEM Wheel.
- feels like a misfire
- 93 Del sol Radiator Support /w PIXS
- 98 Civic coupe - Which jdm type r motor swap would be best?
- Code Cel 67 - 2000 HX
- 96+ d15b vtec OBDII into EG Hatch
- civic si newly chipped
- b20 head on ls?
- lca's from ek hatch fitments??? help
- 99 Civic CX - stereo components stolen in Vancouver WA/Portland OR area
- 00 Civic EX - 2 or 3 "pops" when starting off in first or neutral (bad axle?)
- clutch question!!
- rear disc brake problems. passenger side isnt working
- No heat... Help me i'm cold
- CTR wing Bolts BROKE in the CTR WING!!
- Question: Prelude steering wheel to EK?
- 94 white civic coupe STOLEN in Houston (pics included)
- Ignition timing with no tach
- Help wiring turn signals from steering column wiring 00 civic
- pm7 pistons in y8 block
- 96 hatch but si 2000 front end conversion
- p0420 wont go away after y8 exhaust conversion
- 99 DX/D16Z6 swap -- Alternator is not charging
- 95 civic coupe dx b18 swap-overheating
- 94 Civic/D16y7 - high pitched noise, sputtering, and speedometer doesn't work
- del sol won't crank
- 95 hatch auto has a manual ECU - shitty gas mileage
- brakes lights staying on?
- Strange noises at start-up - D16Z6
- Sunroof tilt problem.
- What bushings do I need for the very bottom of the shifter?
- How many miles do you get per gallon?
- Would a J35 engine fit in an EM1?
- 00 Civic Si - Oil Light At Idle
- How replace cracked exhaust manifold on 97 civic lx?
- Idle screw whistle after TB Spacer installation
- 00 Civic hatch - Can't get the Horn to work!
- h22a EG need answers please...
- 4dr front end on hatch
- 96 jdm d16b 3 stage vtec ?
- DIY: 1" prelude bb/mc in ek
- EK : Only when my lights are off, my left blinker blinks really fast
- H2B CIVIC SHIFT linkage?
- how do i replace shifter bushings ?
- keep blowing wheel bearing on passenger side help
- Burned up my Ecu... 92 civic w/ jdm gsr. pics
- B18CR Manifold swap in Germany - TPS connector different from B16a2?
- 99 Civic Ex with 98 GSR .. not sure what motor mounts and intake system to use
- 94 Civic EX Auto - Will any 92-95 Auto Trans work without ECU modification?
- Left tailight is dim when i hit the brake..
- Creaking on driver front wheel...
- won't go into gear when engine is on
- Need help - Hard time putting it into first and second gear
- British 99 coupe/swapped D16Y7 --> no ECU communication, spark, or fuel injection
- 93 Civic - Cluster only lighting up once in a while
- 1998 Civic LX - ATF Fluid & Filter Change
- d16y8 vtec and d16 non-vtec head, IM, and TB: What are the differences?
- marklamond.co.uk - Does he still convert non-Civic clusters to work in Civics?
- B16a2 and auto-to-manual swap in 97 Civic! Starter won't crank engine! (solved)
- How to mount a P28 ecu in a 92 eg hatch?
- 92 civic hatch/D15b7 + $100 B18 engine: Should I do the swap?
- Are vms racing spark plug wires any good?
- Will ANY D-series valve cover fit on my bone stock D15B7?
- b16/81mm cylinders: Will 81mm ctr high compression pistons fit?
- CTR Interior Conversion Thread Help?
- 97 Civic coupe - What HID bulb size for my Headlight?
- 93 Del Sol Distributor - What turns the distributor rotor?
- TPS Sensor bad??
- Air coming out of oil filler
- D15B Wont rev past 3.5 rpms, low idle and more...(vid inside)
- how to convert to keyless start? Opinions welcomed!
- Hey H-T!! Suggestion for a better site =)
- Help identify 93 civic part - metal piece that lifts window up and down
- 93 Del Sol - Engine is misfiring during acceleration
- how to rebuild a sunroof
- 1999 DX starting issues
- i need all pointers, tips and information i can get on h22 swaps
- 1998 civic: Lights flickering prob
- 94 del sol si turns off while driving
- How can I tell if my 95 civic is an ex or dx?
- 95 civic has no 1500-3000 rpm
- 96-98 Depo Foglight Amp fuse or Relay help!
- 97 Civic coupe Front Windshield replacement - Expected price?
- Del Sol rust
- Autometer air/fuel gauge wire up
- 96 civic/98 jdm gsr - idles high and also bogs when first taking off
- Panel to tell when city, brake, reverse, signal, and corner lights burned out?
- 95 civic coupe dx b18 swap- interchangeable parts
- 97 Civic taillights won't work...STUMPED
- How To: S2000 cluster install in 92-95 Civic (pics)
- horn is going off randomly??
- 95 DX hesitating and surging in 1st and 2nd gear
- what exhaust to go with my b20v-t straight? hks? greddy? hmmm...
- humming sound at 65 mph
- 94 Civic HB/ZC motor - Changed headgasket, now car putters
- 92 civic dx sedan - What front bumpers will fit?
- 97 civic dx coupe/koni yellows with ground control coilovers - what bump stops?
- D15B7 Hesitant/Delayed Acceleration
- B18C idles at 1500 while rolling, 750 when stopped.
- Radiator Core Support question
- Pic request aerocatch hood pins on 96-98 civic
- What Stock Muffler's Fit/bolt on an EK hatchback?
- TURBO D16 WILL NOT REV
- car wont start...starter won't crank engine
- 92-95 civic horn wires
- Manual rack & pinion fitment for 95 Civic??
- Where find traction bar with front torque mount kit for Del Sol with h22?
- IACV problem...but not the IACV
- How to tell if a mugen wing is real
- 96-98 civic with 99-00 front bumper with a conversion??
- Will D16 transmission work with a D17 motor?
- 95 Civic AC System says R134A
- Just bought 98 Ex, Jumps in mid RPM
- ebay foglight help
- '94 Civic Ex lacks power on hills
- I have B20v with ITBs. Mech said no need for IACV to be hooked up. Need help
- d16y7 and d16y8 dizzy's
- Should i sell my built gsr motor and drop in a K series?
- 93 del sol- Why does my windshield but not side windows defog?
- **HIALEAH, MIAMI FLORIDA MY EK STOLEN**
- Fuse box tucked
- how to cut rev limit
- Em1/B20v with code 6 - won't go past 4k rpm
- (CA cat. conv.): where to get one?(95 b18c1)
- Passed California Smog - 2000 HX some tips for others
- 95 b18b1 - What throttle body is this? (no pics)
- Stock B16 low boost or cammed b16 n/a
- sir bumpers
- foglight crack need help
- 92 Civic EG - how to tune the twin carbs?
- obd1 alternator to obd2a alternator??
- Going from a d15b7 to a sohc zc non vtec! Water pipe difference?
- Difference in 93 D15B7 and 95 D15B7 or D16Z6 crankshafts?
- ls vtec arp rod bolt question
- Idle problem with mini me swap
- Fuel Injector Question/Problem
- 1996 del Sol accessory light wiring help please!
- How restore EG9 faded "foggy" window visors?
- Ek compatability with a swap in a del sol
- Transmission question
- ls vtec weird idle after driving
- Stage 4 Clutch!
- Would Del Sol catback fit on an eg hatch without modification?
- Hit VTEC and rev-limiter 1k early?
- Where can I buy these connectors for my spoiler and brake light?
- Seat question
- 94 del sol clock light
- Red Open Lug Nutz For SI stocks
