View Full Version : Honda Civic / Del Sol (1992 - 2000)
- chrome p28 on sohc vtec not popping
- How do you wire power mirrors into a non-power car?
- car boggs at 4,600 rpm's
- NEED ECT PArt Numbers
- What to do about type k discontinued fog light switch
- question: ctr cams; whats the difference between exhaust and intake camshafts
- why would v-tec not hit?
- whats the best throttle body for my gsr in a eg?
- ls swap in a 92 cx
- D16y8 distributor difference between years?????
- What do you guys do when approaching a stop light? Downshift, stay in gear, neutral?
- show off your drop on your car.
- Anywhere I can order wiper arms for my 00 Civic si besides Honda
- eg6 power interior and AC
- 99 si front bumber
- Anyone know how to defrost a keylock?
- 99 si gsr swap
- Greddy Turbo Carb Sticker NEEDED!!!
- Fuse panel info
- 92-95 civic how many seats
- Overheating only on highway
- 98 CIVIC EX , B18C SWAP?
- heat problem
- Transmission Bearing issue
- LCA bolts on backorder. WTF?!
- what is chamfered bearing??
- Trying to swap...
- ctr climate control problem
- Fluctuating idle when warm
- another rear brakes question
- Referee ticket help PLEASE
- ek9 spoilel bracket
- question about a b16 crank pulley
- Hasport mounts
- Need help identifying my tranny
- DC2 clutch pedal work in a ek??
- Question on HX CVT rpm's
- p29s on b7 block? possible or not?
- Diy: Grip tape pedals.
- Bolt Size for Tie Bar - 1998 Civic DX Coupe.
- 93 head removel..
- Help with a Christmas present
- civic cruise fluctuates when it gets cold?
- D15B into '97 HX
- E-MOTOR ?????
- Anyone know how to "aim" headlamps on an eg civic?
- Heater core leak?
- help
- overheat and no heat
- shuts off
- gsr turbo smoking
- ls/vtec
- attention del sol drivers in MASS
- Wrapping a header...
- Fog light Relay
- basemap for OBD1 p28
- 1996 Civic EX, Electronics issues
- p28 auto
- Next step
- need help finding the name of this wing.
- need help
- How do you know how wide your rim is
- OEM bumpers + Foglight cutout?
- 4dr vent in a 2dr?
- C-Wings???
- Code P0420 : Mechanic says:
- p30 b16 jdm intake manifold - can you use it to pass Cali BAR?
- 1994 Civic Si HB- With rear disc brakes
- CTR exhaust cam vs B16 exhaust cam
- electrical prob????????
- b18b1 swap
- my car wont stay running
- low gas light wont come on
- Auto tranny not shifting!!! Please Help!!!
- DIY: How to convert your 10.3" brakes to 11.8" brakes - S2000 brake Upgrade
- Car Theft/Security - (Hopefull Sticky)
- musky smell after it rains
- what swap you think i should do?
- Diagnostic Plug for OBD2A
- where to buy a catalytic converter????????
- Another car won't start post.
- gsr final drive?
- Texas People
- type r vs b16
- EBAY OBX LSD?
- need to know the name of a part
- d16y8 tranny?...
- help
- B16A2 into a 94' Del Sol S, motor from a 92' Integra!!!WTF!!
- help plz
- i need to finish my 96 civic ex turbo
- V-tec vs. V-tec E
- STOLEN CIVIC EK IN SOCAL 12/5/07
- -del Sol VS SEMI-
- weird idle and backfireing problem... ???????
- ravelco security question
- Looking for this exhaust
- Help 98 Hatch-00 Conversion---Front End
- Another Gas Mileage problem 15mpg 150 to a full tank D16 motor
- weird bumper question??
- Help!!!
- B18B into 95ex.
- rear disk conversion
- 13" vx wheels
- ls/vtec
- What is the part number for a plug one step colder NGK plug than for a Y8.
- wat you think??????!!!!?!?!?!?99 Ek-lo ve
- d16z6 problems!!!help!!
- My door makes wired "pop" sound !?
- how do i install tachometer in my civic 99 ex coup
- Mal Effects of using a Z6 plug with Z6 gap in a Y8 head?
- POST PICS OF YOUR EK HATCH, COUPE, & SEDAN!
- I can't rev my em1 to redline... !?
- headlight sidemarker HELP!
- jdm thin side moldings for eg hatch or coupe...
- Buying a new car, need tips.
- Hissing from MAP sensor, vacuum leak? (B16A2)
- q about fog lights and springs
- what can i do to my engine for higher revs?
- HELP! I need 99 civic engine harness diagram please
- 5G Steering rack swap
- 94 gsr rear disc on 95 civic
- Integra Front End
- CTR 96-98 rear lip different than 99-00?
- power steering question
- quick release steering wheel hub
- HELP WIRING
- Installing Type R Grille
- cam gears!
- speed and tach not working
- helllllp plzzzzzz !!!!!!
- Help.. Which one should i buy
- My EG sol build
- Code 9 cylinder sensor and Code 22 VTEC pressure valve....
- rear disc brake conversion
- Rear Disc Swap
- windshield wipers not working...HELP!!!
- Leftover wiring after swap?
- Opinions wanted- ls/vtec or k20
- 99 civic no power and back fires out intake
- Naked Vacuum Line?
- Ex-Honda Challenge car
- strange idle
- help
- is this my OBD2 indentify?
- 96-98 Civic Fog Lights
- online stockists for skunk2 camber kit balljoints for ek civic
- fog lights
- Valve lash help.
- Headers cat and catback diameter questions
- Replace CV Joints or get brand new axels.
- CD/DVD Player
- rattling noises
- ZC vs Z6
- Dead battery on 98 civic leads to much frustration PLEASE HELP
- Eg Hatch Build
- muffler question
- ground wire questions?
- step on brake pedal rpms raise help
- vtec solenoid wires?
- weird ABS problem.
- Is it just me, or if the theft COMPLETELY out of control
- b16a obd1 engine harness? (noob question)
- Stolen Honda Civic
- turboed delsol 4 sale
- Dumb Q
- engine swap help?
- Jap To UK Imports
- AUTO TO MANUAL CONVERSION ON A B16A EG9
- a question about which clutch i need
- Manufacturer Control Ignition System or Misfire
- D16Y8 Head good enough??
- losing fluid in the hydralic clutch cylinder
- boosted d15b7
- D Series tranny's?
- i know i know.. its been discussed.. but i have another question on a ebay turbo
- MY CAR WONT START???
- carpet replacment??
- car shuts off.
- Coolant leak near headgasket with pix help plz
- Problem with pwr locks after alarm install
- brake bleeding procedure
- 1992 VX wiring trouble.
- Distributor Bolt Positions
- what makes a IACV go bad? How to I make my car idle again!
- Another 93 cx hatch gone
- what ecu to use with D15b vtec block w/d16y8 head???
- PL help with which motor should i buy....
- B and D series dizzy question
- Help! Del Sol wont start after cap and roter replacement
- striped threads on oil drain plug.need help
- b7 to z6 help
- skunk2 mani, and 68 mm tb issues
- ?'s about installing an itr transmission into a stock 99 si
- Knock sensor
- Stupid question...
- TIRE question 205/60/15
- ***Extremely Weird Clutch Problem***
- EG U joint
- Intake Manifold question
- turbo d series?
- will a d15b7 oil pan fit on a d16y5
- will a dx auto trans work on an ex?
- door locks freeze
- i need help desperately!!! b16a3 into ek (1999 civic ex)
- heater Core and others..
- rear lip
- what is the stock flywheel weight for a 99 civic si with original b16?
- do short shifters kill transmissions???
- p30 ecu swap
- need benen products for my eg
- fuel parts identity crisis! b16 swap in a hatch....Help needed!
- Help please
- Your opinions/experience with eBays fog lights for 92-95 Civics...
- Check engine light?
- Removable steering wheels and hub lock
- eg cluster
- paint shop in SOCAL
- H22 Project
- EG: CX/DX/LX D15 valvecovers interchangable?
- help me
- 92-95 civic parts needed
- stuck parking brake (e-brake) cable
- d16y8 injectors the same as b18a??? already searched
- rsx aspec rims on eg?????
- need help with security for 2000 honda civic si
- Engine swaps
- How to Combat Car Theft
- 95 del sol fuse diagram
- car won't hold idle...what's the deal???..need car running ASAP
- fishy guy trying to sell me a gsr motor, might be stolen
- Help With Dash
- 92-95 Civic Need Parts
- which mounts to go with for a turbo b16
- d16 dizzy same as d15??
- oil leaking into spark plug tube, seals already raplace but still happen
- (Useless topic) NEw key just wanted to share
- side markers
- Found: 2000 EBP Civic Si
- need hlp how to add pressure to clutch
- TURBO ???
- weird brake issue (searched)
- Brakes
- Removing power steering?
- Clutch Question
- DA seats into 98 ex?
- Rear Quarter Panels
- need help with Suspension.....
- Manufactured in Canada?
- '94 civic automatic tranny not moving d15b7 help a brotha out!!
