92 CIVIC HATCH SI NO DASH LIGHTS OR REAR RUNNING LIGHT
dash lights went out the other day along with my rear running light and lisense plate lights....i found a blown fuse replaced it and turn the lights on and the fuse blown....then i check the rear bulbs and found 2 bulbs blown...replaced them then put a new fuse and turn the light on ....the fuse didnt blow but no light still... any ideas???
Re: 92 CIVIC HATCH SI NO DASH LIGHTS OR REAR RUNNING LIGHT
check to see if u have power at the fuse when headlight switch is on .
sometimes fuses are no good even if look good check continuity on the fuses
if all is fine with fuses then its the switch
^ same exact thing that happened to me..fixed the short haven't blown a fuse since..
Check the dimmer switch.. it might sound silly but you might have turned it and forgot to turn it back..
cor4ey
04-16-2010 03:53 AM
CRXsiproject
10-19-2005 12:15 AM
I8ayellowcrayon
21
09-01-2005 01:34 AM
