View Full Version : Honda Civic / Del Sol (1992 - 2000)
- quick question, dont hate
- Radiator Probelm, please help ASAP...
- headlights?
- Fuse Box layout for a 96 civic hb dx
- wheel well liners.. are they necessary?
- help with my ball joint!
- WTB: Big Brake kit or New Rotors for Civic SI
- D-Series questions...
- need rota circuit 8s.
- del sol drop springs
- d15 or d16 turbo or B20 non vtec
- ITB's
- TD # on distributor?
- Chrome window profiles (don't known the english word!!!!!!)
- need to get my 89 civic dx hatch fast
- Help a mang out (NW IL, S WI, E IA)
- Quick exhaust question...
- clutch for d17a2
- fuel tank size
- Gauges Clusters
- rsx seats in eg
- GSR/Eibach or Tokico Blues/Inrax for my EG? Which one?
- civic CARB approved intake in my integra
- Quick! What color r Neuspeed Race springs?
- -------> (D16 Question) <-------
- USDM EP3 Back Seats for EK3
- new car, new mod
- steering wheel
- test
- Delsol trailing arm?
- Could a b20 take the abuse like a ls would on boostin?
- Looking for a 92-95 ex/si cluster.
- Accelerating problem.....
- Is my car hot or not??
- A JDM Type R Header will fit a B16 right?
- Idle Question!!! Need help !!!
- CTR steering wheel
- pics?
- Does Stock 2000 Si Lag?
- Timing Belt question
- B&M Short Shifter
- side moldings
- chipping stock 92 civic dx ecu???
- >>>>>>>>shifters
- for all u tranny rebuilding geeks
- 96-00 civic owners!! do our cars come with this...
- will an integra pedal assembly fit in civic hb?
- ECU tuning! help??!?!?!
- AEI Axles
- newb question i guess. or rather just uninformed
- weird noise when car is off?
- OT: HONDA-TECH decal?
- Update on my Ferio
- Did Honda make a 99+Midori Green Hatch???
- honda access door visors
- 4 door front clip fit on EK hatchback? simple question. thanks.
- drawbacks to keeping vtec cam ingauged all the time?
- do i have a ls tranny??
- does anybody know where to get headers for a 2003 lx civic coupe?
- del sol seats and height
- Does anyone have a pic cf dash kit in an EG?
- Silly Honda of Canada. . .
- b-series header
- 92 HB SI W/ B16a1 swap need parts....
- Camber kits for a 93 del sol ?
- Red Si EG pics
- size of tire sidewall????
- wat's it worth????
- Woot! My Custom-Made Rear Diffuser has arrived!!!
- D16y8 engine weight?
- 92-95 civic arm rest ?
- Internal wastegate question
- armrest get in the way of shifting?
- looky what i gotst in the mail today....
- Need help with tranny removal!!
- 5 lug conversion, e-brake problems
- eg steering problem?
- What I did after the attempted break-in
- CEL Code 43 Need help!!
- B18A1 stock spec
- OEM seats suck need options
- can't keep car at a rpm for long...whats going on??
- whats the eriks racing website?
- Oil leakage question
- Converting a non vtec wiring harness to a vtec harness
- EK Keyless Entry Question (Already Searched!)
- How easy to mess up a valve adjustment?
- taillight clear out
- Window won't work
- Emergency Question!!!<<<<
- b16b
- ek9
- small problem?
- Gauge Cluster Swap
- I can dispell the myth once and for all...
- Rear Defusers anyone got one?
- a/c and keyless entry question
- New Civic Project
- A/C
- I got scammed! *56k maybe*
- removed air conditioning, few ?s
- live sport lip kit
- Need your advice plz
- what yal think i'd be hittin?
- fuse problems.. checked, not blown, dashboard/center console and guage cluster
- Suspension question?
- new chic
- Keyless Entry on 97 Civic
- SOHC Vtec
- gsr lcas on ek?
- junkyard
- newbie here whats up ?
- need corners for eg bbad
- removing rack from pinion. help
- starting problems...
- What pistons should i use?
- Biggest stock honda injectors?
- a/c questions!
- This is a true HORROR story!!!!!!!!!!!
- honda delsol 1997 bumper
- Desperate for HP
- GSR Seats in Ek
- 92 Prelude Si Seats into 92 CX hatch..
- Coilovers?
- Which exhuast would be the best for my 00 Si
- What to Do about my Auto Ex
- 15 inch or 16 inch on delsol?
- New Radiator Install (write-up)
- tach reset
- converting problem*****let me know
- ODB II to OBDI - Which ECU Should I get
- roto-tech rotors??
- All you "v8" killers...
- How to remove valve cover?
- Mini Me Swap - Success/Problems/etc?
- Itching to become a member (question as well)
- Which tires for my HX wheels
- i just bought 16x7s and peeps been sayin they wont fit my G5!
- tranny number??
- Rear-disc conversion on 92EG/DX questions.
- EG Si Sunroof problem
- Steering wheel shakes when decelerating.....
- Shudddering CVT transmission
- will a 92-95 hb catback fit a 96-00 hb???
- Tire Question
- **** how to remove FRONT windshield GLASS?
- h22 del sol
- Air bags and Modules?
- GREDDY SP
- b16a2 into a 95 dx hatch
- JRSC Belt splitting
- d16y7 cel codes question.
- Clutch Noise
- What are the most played out wheels for the 92-95 civics?
- *VIS HOOD PICS
- my "crash restoration/buildup"
- Power Steering on 99-00 Civic Hatch
- del sol Si and VTEC specs
- '98 Civic EX
- seats for civic: s2000 vs ebay
- HP gains for stock civic dx with header and cat back??
- how much FUEL PRESSURE?
- $8000 Integra Type R on Ebay, Scam? Beware
- Brake Sizes
- sportline springs on stock sturts
- Which shocks = "Luxury Sport" suspension?
- what you think about these seats
- anyone do a h22 in a crv yet?
- i need helpwith eibach prokit springs
- Wrecked my 93 sol, need left front suspention and 1 GsR blade wheel
- Best Year And Model
- Do tuned cam gears increase power with stock cams?
- newbie here: spec of del sol
- bent EG rear control arm HELP
- Brake Pad Help
- installing Neuspeed Race Springs, question about bumpstops????
- CBR954 ITB on a ZC
- check out this jacking..... LOL
- Oil for High Mileage D15
- f22 swap into 5g civic
- 2000 si b16 tranny i need service manual
- B16A was making over 400 hp more than 200 ft-lbs below 2,000 rpm peak torque rated at 350+ ft-lbs
- wanted !! hatch trunk / cargo cover for EG (94')
- OEM fog light harness smoking?
- Please help. Problem after installing clutch/flywheel
- letting my Hatch go!!!!!
- What type of engine is mine??
- Pictures of 96 GSR rims on Civic
- gsr sway bar on coupe..?
- Review:EM's pillar bar for EJ1
- Spoon Sports throttle body
- how long does falken azenis last?
- AEM EMS
- Apexi springs (not coilover) from a DC2 can fit on an EG?? help please..
- b16a2 in a eg hatch vs 1988-16v GTI golf
- What do you think my B16A2 will run 1/4 mile guys.
- New 1/4 time
- Any pics of 04 civics with rims???
- 92 b16 gsr motor?
- been upgrading my eg lately!!
- auto swap
- rims price$$$$$
- What are these parts ?
- prelude seats into civic
- B16- dome of piston has scratches?
- b18c Buy or Not
- Building my d16z6 for boost
- attn;salbaje!
- Integra Dash swap in EG!!!!!!
- CTR SRS steering wheel problem....
- any similar products to the Comptech Tie bar?
- Will a 92-95 hatch 5zigen fireball fit a 96-00 hatch?
- the guy that fitted OEM HID into his EK!!!!!!!!!
- 90 civic si hatch voltage regulator /electrical prob
- engine disaster
- sparco harness install help?
- d16y7 vtec yes/no?
- Mini Me Swap trouble!!!!
- bigger rims and tires
- odb??
- hyper blinker signal???
- Thieves Suck!!!
- Will a Thermostat/Fan Switch for a B16A fit in a D16z6 ?
- Get more oil pressure for free
- Okay, my first try posting picture
- B SERIES MOTORS....92-95 VS. 96+
- installed brake pads - Car won't move!!! Help!
- Pic request: Del Sol with rotas (slipstream, c8, c10, group n...)
- b16a2 in a pfdx hatch
- funny noise when starting....help...
- 1997 Honda Civic EX - Broken Antenna Fix??
- Need help
- Help!!!
- Ingalls camber kit install???
- Help with valve cover( snapped one of the bolts)
- sohc vtec timing belt
- HELP WITH TIE-ROD
- Fuse Probelm please help ASAP....
- Which suspension should I use?
- Integra radiator in a sol/civic. Top mounts
- Just Cut Shifter @ Top and Rethread = Short Shifter?
- quick question on my swap..help please
- Pics of the purple jelly bean
- K20 swap into eg? what are the downsides to this swap?
- Z6 Tranny Rebuild
- Everyday tire iron with Skunk2 lugs???
- valve cover gasket torque?
- high rpm auto
- climate control question EK 99-00 to a 96-98 peice
- h22 parts list for cx hatch swap
