View Full Version : Honda Civic / Del Sol (1992 - 2000)
- need help and info on doing b18b obd2 swap to 98 civic and keeping it obd2
- Knock Sensor?
- clutch replacement help
- 0bd1 gsr harness.....WILL IT FIT A H22 0bd1 EG? if so what wires will it need to make it work?
- Is there such a thing as rear wheel alignment?
- d16z6 in 95 cx milage questions.
- Question on stock wing on EG and also squeaking coming from springs!!!
- Ek stock colors??
- CAT/Muffler disconnected
- SRS error codes 1-1, 9-2 and 1-1.
- problem
- which flywheel?
- What would u do to match up a black integra dash to an EG civic.
- Is it safe to drive hoodless?
- 92 Civic CX
- Air Fuel Gauge on Stock Five Wire O2
- ABS, better off with or w/o?
- B16a wiring question.. NEED HELP ASAP!
- Buildup on muffler tip
- How to use a Valve Grinding stick on a Head ??
- Sparco Speed bolts?
- integra radiator swap into a 94 civic
- Sway Bar Links for 2000 Si
- Looking to buy a Civic...
- oxygen sensor
- Which engine?
- Timeslip Analysis
- car fax please?...
- WOAH MAJOR PROBLEm with my swap.. help please?
- HELP!! 99si cluster into eg
- Anyone know where i can get some 282mm 4x100 brake discs from!??!
- i NeeD help taking off the shift linkage!!!
- b16b in ek
- 10 long - 1 short... i need SRS code?? anyone have it??
- Civic 2000 Front End.
- Upshift indicator
- washer to hold down integra seat????
- civic 96-98 bumpers
- obdI ecu pins vs. obdII ecu pins??
- Looking for people that have done a H23/22 EK swap.
- looking to trade for an EG6
- Questions on my 94 Sol
- Stripped motor mount holes in block, compensated by using longer bolts, found strange greese on bolt
- very hard to get into gear.. help! (searched)
- rattle?
- losing oil when revving hard on EK civic hatch.
- Finally happened, my car is gone.
- Anyone ever put a y8 head onto a z6 block?
- How-To change alternator for a 99 Civic EX?
- help with headers B16
- problem with distributor!!!!!!!!!!
- 97 turbo d16
- Turbo cam results in D16Z6?
- water gets in my reverse lights every time i wash it.
- side molding... im new to this stuff
- DropZone Struts/Shocks any good?
- help, someone diagnose this ::VID INSIDE::
- backfiring?
- Will 14" Mugen MR-5's fit over 10.3" gsr brakes?
- 93 Civic VX hatch
- eg names
- need help... dohc zc obd0 in a obd1 del sol... wont stay running.
- ANY WEBSITES FOR H22 EG SWAP
- D15B7 Radiator leak question
- some basic information...
- rsx type s turbo
- DPFI to MPFI Conversion, new problem, I searched
- what do i do? to make 2dr bumper, fit in 4dr??
- do a civic 94 2dr front bumper fit a 95 4dr ??
- Recently bought 2000 SI
- will a ek side skirt? fit a 4dr, 95 civic ?
- Help Growling noise coming from head
- burning oil
- help with headlight bulb upgrade?
- eg/del sol fenders
- not hittin vtec
- soch pleasure
- Fuel Gauge pegged at full
- What Is Needed For a Mini-Me Swap For An EK?
- Fuel line to fuel filter leaking.
- Brake problem, need opinions.
- can check this list of all the sources of vacuum in a d16y8 motor?
- What do I need for install of type R lsd into a 98 civic.
- Bogging in VTEC?
- TX:DOHC ZC won't pass emissions HELP.
- b16a and b18c have the same timing belts
- clutch help PLEASE
- CEL Does not come on when I turn the Key
- the quest for more gas mileage
- acquiring a obd2 3-stage d15b?
- Pistons
- lookin for h22eg swap
- eg swaps
- Exhaust not flaming yet :(
- i need help!! (fast idle)
- gauge cluster
- Stolen Gray EG in Triad Area of NC!!!
- Honda ATF
- Is there a quality alternative to JDM CTR lights?
- Is my car an import?!?
- engine dampers work?
- DA seats in a EK?
- HELP! Vibration and Floating feel
- Popping sound coming from driver side front ???
- Carbon Fiber hood lifting?
- Where can i get Euro Type R 4 lug rotors???? or can i ??????
- difference between early and later pr4 ecus?
- how do i clean my headlights?
- B18C1 in EJ1 Help
- Primary Oxygen Sensor - Heater Circuit Malfunction
- Intake manifold question
- DIZZY SWAP NOW CAR WONT START?
- Timing
- fuel hardline feedline question
- CEL for "catalyst system" comes on and goes off...??!!
- 2000 Honda HX question
- car starts when it wants
- HID Retro Fit?!?!?!
- shift cables routing
- Opinions on this car?????
- reverse lights dont work
- Emission Question, need some advice!!!!!
- di5b
- QUHELP!!! Pleas
- non power door locks to power door locks
- Will Prelude Clutch assembly, fit a 96 EK?
- tanabe hyper medalion axel back exhaust
- WILL TYPE R SHIFT LINKAGE FIT A 99 SI ...?
- I was just wondering.....
- STOLEN EG, MILWAUKEE, WISCONSIN
- motor question
- oxygen sensor?
- Shifter moves when you let off the gas
- Wheel vibration like no other.........searched
- z6 intake manifold on a y7 head?.....searched
- whats up with everyone in this forum?do you guys even know how to work on motors?
- Will an Civic Si gauge cluster hook up to an H22 ECU?
- I Need help Installing the "Air-Fuel Gauge"
- ZC CAM ON A Y7 HEAD
- CTR crank pulley ?
- Low Voltage Issues
- EK rear lower control arm question. yes i searched
- Whats going on with my timing? Please help!
- are these gauges rice?
- heater only works when you unlock the doors?
- how does this bad boy look
- sending unit on the gas tank????
- Fixing dents?
- Where should I buy my tires?
- WIERD TAIL LIGHTS PROBLEM ??? :(
- How high of a comp. ratio could a stock ls block handle?
- carbon fiber hood skeleton question
- timing question with the aem cam gears poor mans type r.help.
- Mufflers?
- Problems with OBD2 to OBD1 conversion
- Calling all B18c 2 Ek/ej swappers!!!
- installed new flywheel but when i start it, it turns right off
- Weight Saving by carbon fiber??
- difference between 99-00 and 96-98 headlights???
- 99 civic -- power steering & brakes off and on, help!
- clutch problems! need help ASAP
- Engine Sounding Like A Diesel When Accelerating
- 5 lug conversion on a del sol
- vtec problems
- help with engine cuting out PLEASE HELP!
- Flooded By Katrina
- do i neesd extended studs?
- A/C install on a 99 EK
- sensor problem/motor cuts
- Swap Question
- 96 civic subframe mounting point.. nut won't thread?
- CTR 32 mm axle wheel bearing replacement questions
- Help with smoging EG/b18c1
- whats a good site
- loose rattling noise...
- Anti Freeze smell, could this be my head gasket?
- Cooling Fan Problems - Please help!
- need help with b18 swap Wiring
- civic transmission oil change
- Del Sol/Civic
- 97 DX
- '99 SI rear wheel bearing
- Code 23. Knock sensor - Help Shut it offfffff Thread
- civics?
- my car 98 civic b16 for sale
- 98 civic b16 for sale
- 4door visor install help!!! please anyone!!!
- 55 shot on a d16
- rear wiper removal plug
- For everyone who want obd2 engine into a obd1 car......
- need a good shop, delaware valley...
- oil on plugs help asap
- Where to order Lexan Plexi glass from? (search engine dead)
- header question
- C.E.L : Code 21
- ive had it with no search, can i put Legend GS calipers on my civic?
- EJ D15, Overheatin + White Smoke + Low Idle. HELP!!!!!!
- Need help guys suspension question..........
- 2000 Civic EX Drain Plug, what size is the bolt?
- Del sol Head light
- Swapping seats help!!
- 94 GSR B18C1 OBD1 into 97 EK Civic Hatchback OBDII with OBD 2 ECU
- Cam Shafts Skunk2 or buddy what one is better
- dohc zc need help.
- Totally Irrelevant
- Alternator Belt
- Rewiring Alternator
- b16 swap complete, CEL problems
- Timing belt
- do you think this retro fit would work?
- del sol or del slow haah
- A/C---HEATER stops blowing WHY? HELP.
- Turbo vs Super
- TIR b-pipe, JDM 4-1 header, RS-R ex-magic muffler... what will it sound like?
- B18C1 into Del Sol Si WIRING HARNESS >:O
- Swapping an '99-'00 Si cluster in an EG civic...
- Need Throttle idle help.
- Whats the compression ratio of a jdm d15b?
- F%#^ ME!
- ***HELP***
- 4wd civic conversion
- Small aftermarket tach integrated into stock cluster?
- Autometer Tach Help
- Will Rims/Tires Rub?
- Kenji or Phearable ecu?
- where can i find a cusco 6 point for my ek
- how much?
- PS. Should I remove the whole thing?
- What b18c-2-EK mounts to use?
- Steering Rack recommendation
- Civic Upgrade Help
- Anyone else have/getting "fender dimples"
- stupid question about power steering pump compatability
- Valve cover screw snapped. Need help!
- no lights go on
- D16Y8 Backfiring
- ek side skirts??
- Anybody know the length aftermarket steering wheel screws?
- weird noise when i start car?
- is not the main relay
- timing belt???
- b16 build-up questions... need help
- Is 2.25" midsections really a 1.75"?
- having problems after timing belt and cam install
- firewall diagram
- Is this how you bleed the brakes?
- whats a good rpm to set vtec?
- No spark issues (search is down)
