View Full Version : Honda Civic / Del Sol (1992 - 2000)
- wiring harness bseries eg hatch question.
- looking 4 2000 si front end conversion
- 1st gear laggg like a bitchhhh
- Can someone tell me the procedures to replacing a cv boot ?
- compressoin #'s ??????
- b18b ecu???
- 2000 si
- question about ctr headlight legality?
- NGK plugs
- Rolling up power windows without the switch? Possible?
- coupe front end onto a sedan chassis?
- Worse or better than oe cap&rotor kit ?
- How Do you change Side Mirror?
- Axle problem
- GSR Swap
- What kind of Performance tunning can i do, FOR NO COST (Honda Civic 96 DX)
- oil
- fuel injectors
- HELP!! i need your advice Civic Swap.
- boosted b18 question
- how low should i go??
- ARP Headstud installation question on D16Z6
- Gauge cluster question....
- Adjusting trunk fitment.
- Tranny shift problem
- HELP! o2 sensor broken by a crash
- Question about a few parts from an rsx onto my del sol
- b20 with inspection
- Short Circuit?
- whining at 3000rpms
- WILL 96' 328 wheels fit my 5 lugged EK???
- whats the differance?
- whree can i find a stock cluster for a 94 civic vx?
- tranny help(throwout bearing??)
- How much would.....
- Low RPM's on VAFC running chipped p28
- Which is faster? Coupe or Hatch.
- Signaling problem!!
- Saving cruise control?
- MSD distributor
- Stock Intake tube & filter question
- Need help with ECU codes - Thanks
- Cruise control cut off
- where can i order a k&n air filter for my cai
- Some pics
- Need a second opinion on solution to engine prop.
- Sunroof Problem...
- Kamikaze Header Questions?
- obx twin loop on EK hatchback
- another civic gone.
- Price on motor
- Question about AEM fuel filter.
- fuse for fuel pump.
- smoking
- flowtech WarlocK exhaust on a civic?
- Question about O2, please, need a post on it!
- Need checklist
- d16a water pump question...gmb?
- car wont start: removed ECU to run a knock sensor wire
- Which injector goes to which wire?
- What happened to Jdmshit.com?
- ek tach on eg civic?
- o2 Sensor question.
- glitch around 1500rpm during light throttle. ideas?
- Chipping P28
- sunroof plugs on EG's.....post em
- civic ecu
- D16A6 DOCH ENGINE: FROM WHERE IT CAME FROM??????????
- Suburbian Thieves
- turbo civic :)
- What Should I Do?
- Door Ding removal and paint....
- all motor ls vtec
- Poll on what motor to build next
- Less Del Sols than Civics?
- no power to head unit
- MUGEN
- b series swap using a modified CX harness, help!
- Places to put a VAFC
- ECU WIRE HARNESS HELP
- eg vs ek vtec motor
- installation serivce? SOCAL
- DOES ANYONE KNOW WHAT OHM FUEL GAUGE TO GET FOR A 1993 CIVIC ?
- 97 dx coupe w/b16a2 complete just a couple questions?????
- cat back cx
- OBD0 problems in OBD1 car
- Timing Belt noisy
- PGMFI RELAY
- motor not running good help ??
- Looking for friends of Ignitecivic
- Integra brake swap onto EG, no BRAKES!?
- Water Pump Question
- Check engine light
- New motor swap or built block with b16 tranny?
- How to Mount Motor on Engine stand?
- my sisters AUTO TRANNY leaking antifreeze...possibly problems?
- Tranny going bad possibly..???
- I got a problem
- Retro Fit HIDs?
- ObdO Block Convert to Obd1
- Can some one help with a stero question for a 98 dx hatch
- B16a2 + Throttle
- Where can I get a cheap or knock off of the Hondata IM gasket?
- 5Zigen Muffler able to pass smog?
- Anyone have 1992 - 1995 B16A Civic Workshop Manual
- Cant get car started... PLEASE HELP..
- stock shocks.... what brand are they ???
- Engine Conversion Question - GSR into an EG
- ..HUBS...HUBS.HUBS........HUBS
- How much to get broken bolts off from my D16Z6 head?
- rpm's on highway?
- Opinion on GSR brake swap (what BB/mc???)
- mugen rims
- Y7 fuel rail fit on a y8 IM?
- Checking interest: possible write-up on EG/EH/EJ sunroof/moonroof removal
- mini me question
- Need Pics of Del Sol...PLEASE!!
- Black Leather steering wheel for an EG ---- where can these be found?
- i need help
- Civic MB6 '98 headlights
- Are d16y8 and d16z6 valves the same?
- mini me question
- oil pumps...
- help settle this fight at work
- 92 hatchback GSR motor question.
- Look what I was able to put my hands on b16a/b16b hybrid
- doing ls vtec hybrid what is the difference bewteen a ls crank and gsr crankshaft wich is better to
- KYB AGX's or Tokico Illumina?
- Fluctuating Idle
- radiator fitment
- Integra interior in Eg coupe
- d15b7 with d16y7 head questions
- question about O2 sensors and a Apexi
- kyb agx with H&R sport riding rough?
- 99 civic motor jumping up 2-3 inches literally help>>>>
- 2nd engine swap.. can't get it in gear.
- o2 sensor 4 wire 1 wire question
- no intake 4 98 cx motor
- MUGEN MF-8
- Question
- LS and GSR crankshaft?
- get more rpms
- about Ecus in a b16A
- NEED HEADLIGHT SIZE FOR 92 HATCH!!!
- Interesting Info...
- Headlight bulb
- d16y8 to b16a
- valve question
- Car is running super lean.Anyone have any input to help me out?
- Nor-Cal Dyno shoot out/meet @ dynospotracing.com MOVIED 12/17/05 sat
- trouble starting cold but not when warmed up
- How to remove this TPS off the TB?
- EG Civic with JDM GSR with I/H/E i have $500 bucks to spend on my final! performance mod what shoul
- Blown engine? Blown clutch? Blown SOMETHING??
- Need soem radiator fan help :(
- How do you guys drive your slammed rides?
- Need some help on the bushings in my civic.
- HX intake mani. question
- question about adjusting the glove box
- Braided steel lines, permanent fix for radiator hoses?
- ek interior question...
- quick question.........anybody familar with the MDX?
- brake shimmy
- color match for interior
- I hate thieves!*
- where to find pre-molded carpet
- Del sol/ civic question
- right hand drive
- Acura oem parts delivered in 24hrs
- Questions about SRS components
- Converting auto to manual ECU
- question about duckbill spoiler....
- Radiator Fan/Climate control doesn't work
- QUAIFE LSD SHIMS OR NOT?
- Help On Silencing My Exhaust
- Exhaust Help.. something subtle to replace my fart can.
- Valve terrain input
- Getting started?
- clock keeps restarting
- cat-back
- keep blowing REAR Defrost fuse????????????
- REAR DEFROST CABLES POPPED OFF - NEED HELP
- del sol w/ integra front slip goin ls vtec
- i need an exhaust system for my del sol
- how to put in lsd tranny in sohc
- C.A.I intake coupler question.
- pcv valve...
- 1/4 time on b16a in EG
- plannin to swap d16 have tranny questions
- odd vtec problem
- magnaflow exhaust?
- Quaiffe install needed this weekend in South Ga $$
- 1993 V6 Civic!
- Main Relay
- Help on B16a compression and how it effects turbo performance
- steering wheel ?
- Strange engine flickering just occured help?!
- Using tranny after sitting for extensive time...
- audio console instructions
- aem 1010 box
- 2000 RPMS!!!!!
- i need help
- del sol newbie.. tokico?
- Check Engine Light- 93 del sol si - need some input
- the b throttle body on the d series
- largest offset, without going silly, work equip 03
- __feedback on CF Spoiler on EG at JDMCARBOY__
- Tanabe Super Medallion Racing Exhaust
- D15 head???
- vibration is so bad help
- buying a ls swap
- 97sohc vtec into eg
- What rpm to launch ur b20
- OIL check help?!
- which turbo kits?
- Header Question
- Need HELP ASAP
- Help! Bulb size and color?
- anyone know how to put ITR suspension on EK
- low speed hesitation
- question abut changing gauge cluster
- I hear a field sfc-vtec can be wired to a non vtec, is this true and how?
- Rim and tire size question
- putting b16 block in ek hatch??
- 96 Civic problem
- B16A into Civic EG6
- Energysuspension for EDM/JDM EG6
- Civic coupe exhasut fitment
- JDM VTi Spec wanted
- eg gsr exhaust kit?
- EG rear engine bracket problem
- Best brake upgrade for my EG civic?
- Steering wheel won't lock?
- d17 motor
- stolen silver ek hatch in arizona
- POST PICS of your dumpd JDM ride!
- master cylinder upgrade
- v6
- CD Changer Audio Problem
- turbo
- ecu code 11
- which clutch should i get??
- Time for another exciting episode of "Name that sensor plug".
- B18C9
- smog...
- Does anyone have this rubber plug from an O2 sensor?
- Rocker Arm Assembly Bolt Broken... Need Help!
- How to remove radio?
- Who sells windshield moldings and other moldings??
- b16 tranny question, need help, PLEASE!!!
