View Full Version : Honda Civic / Del Sol (1992 - 2000)
- question about my sound system
- half shaft question need an answer NOW
- high beam work but normal headlight does't work?
- Upgrading front brakes
- airbags for sale
- Si and ex gauge cluster (cheap si cluster out of ex model)
- Mildly Built EG2 (del sol b16a3) VS Mildly Built DC2 (GSR)
- WTB: vtec 2p connector, 1p connector vtec, iacv 2p connector. y7/78 head swap
- Spoon Sports intake/air cleaner problem...HELP!!!
- when everyone says dc 4-1 header...
- any bar sticker for 2000 up gsr to civic swap?
- b16a2 into 93 del sol
- girl question
- spring rates on maxspeed 88-00 civic coilover springs? k472 k372
- Steering problems
- engine noise when cold
- b16 fuel injectors how can you tell if there no good anymore
- b16 oil cooler?
- Lookin for a paint color
- Resurfaced Flywheel??
- ZC Engine codes
- cam install (lubricant)
- california salvage title to clean title?
- Someone Diagnose my misfire, please?
- HELP: will aftermarket cat-back exhaust for 96-00 hatch fit b-series swap without cat?
- ?? Change Clutch, Not pressure plate???
- Size Matters..
- 3 wire IACV connector with Y8 ECU?
- anyone have this problem
- hello? need advice or help.
- 14" Wheels fit on 99-00 Civic Si?
- Apexi World Sport EXHAUST system SOUND CLIPS.....??????
- 1.5 abuse
- delsol stuff
- car stolen/recovered......ignition help
- 99-00 auto d16y8 IM on d16y7
- JDM Front Clip Location Question
- Help with guages, parking light, transformer
- new motor in, wont run longer than 10 minutes.
- Does a 2002 Civic EX have red dash lights?
- msd ignition problems
- Are 02 coupe and sedans headlights the same?
- Whirring noise at idle
- Looking into buying a Civic - can anyone help me with ?'s
- How do you take off the exterior window trim?
- What is my 00 civic si worth?
- skunk manifold gsr what about iab?
- Where to buy Single guage pod
- Best Tranny For Street/RR Car
- Slipping Torque Converter?
- 92 A/C Condenser Fan Question..Push/Pull?
- Replacing a d15 headgasket... any comments before I put it back together?
- map sensor bypass valve and check
- Best Transmission For Turbo Car
- non high temp engine paint with hi temp clear? WILL THIS WORK?
- How are my spark plugs?
- question on brake pads
- Quick foglight question... everyone with foglights come in!!!
- what should i have my fuel pressure set at?
- Need help for 99 Civic LX
- wtb: 94-95 civic ex coupe, red preferred.
- B18C5 Intake Manifold for my B16A2
- how to contact Super Autobacs??
- Tyre wear help
- AN-R Header fitment eg
- to mill or not to mill?
- Repaired Bent Vavles...
- WTB: 96-up Civic, i have about $5000
- ZC Distributor wiring problems
- Seat for ek?
- hatch info
- need help please
- can't get timing right (searched)
- 97 F22 into 94 civic
- painting 2004 civic headlights ?s
- Calling all del sol owners with recaro seats
- crossing map wires HELP please
- d16z6 dizzy?
- Ls/vtec
- 92-95 Civic Suspension/
- Action Clutch torque ratings?
- Sound Deadener Question
- T1R exhaust system
- vss problem
- HELP!!! HELP!!! HELP!!!
- HELP my speedometer is going crazy
- Help! Water in my trunk...
- clutch prob or flywheel
- no power to distributor
- idle problem w'b18b in EJ8
- Is my clutch dying?
- where is the o2 on a 94 gsr
- Poor Mans R....Which Headgasket??
- g-tech pro performance meter
- B16a3 with unchipped p28?
- quick B20 question.
- help!! tach wire up need help today!
- 120 no higher
- energy suspension motor mount inserts
- can i get 200+ hp out of my 99 civic DX?
- ATTENTION H-T Help with vin numbers
- Are these vss sensors the same?
- Cat length and size on swapped eh2 (eg) hatch
- Jumped ECU, got code 67. What to do next?
- What intake should I use??
- what kind of cams to use?
- Stuck in 2nd gear HELP!
- ? about p05 and p06
- VIN question
- GSR...BLOX intake mani
- Does anyone rub with 205/60/15's on a 3" Dropped Ek.
- Installed side marker..sealant??
- cel code 43
- Which exhaust is best for a del Sol VTEC?
- too much spray??? ouch!!
- Yes I searched, cant find anything definitive.
- skunk2 intake manifold install problem, space btwn injector and manifold
- Timing Adjustment
- dies down
- Eg dies then starts...then dies...starts...HELP
- Car is too...COLD? WTF?
- emergency help with stock motor mounts(one snapped)
- FAQ: HOW-TO FIX WATER LEAK ON PASSENGER SIDE FLOOR
- qtr panel weather strips
- N1 owners, fitment problems?
- H22 in eg a/c bracket?
- JDM EG Cluster Problem. I Searched. Nothing To Do With Dimmer, SRS, Etc.
- Spoon Sports Air Filter.....
- Does A Upper Strut Bar Make Difference?
- New to the board, previous EH2 owner
- ECU Problem
- compression???
- Shift linkage problem
- My EG Swap
- just bought eg hatch
- Idle question
- GSR fronts into ek swaping only inside rails?
- Name this FRONT LIP!
- Unusual idle after doing my first head gasket replacement
- HELP! obd2 gsr swap. ex cluster rpm not workin
- Bypass Clutch switch
- removing oil off the ground
- Need Help. Just finished up a break swap but I have no brakes......
- No fuel?
- Just Got My 1996 Civic EX Coupe!
- where can i get spoon decals?
- Car cover for a 97 civic hatch
- P.I.T. Performance exhaust?
- I Need a carfax check
- SI and GSR snychros>>??
- What size SPEAKERS are stock in the 92-95 Civic HATCHBACKS????
- 38 Offset / 16" on a 96-00 Civic.....will it work?
- HCP Kit Question
- CAR DEAD!! Suggestions?? Please Help!!
- obd2 monitors, need some input
- just need to know an obd code
- HID problems
- can i use 95 integra ls brake booster and master cylinder in my 96 civic dx
- new head unit for 96 Civic DX 4dr.
- ok heres one for ya. solve this
- ECU swap...what i will need....
- how can you tell if a ecu is automatic or standard i have a p30
- NGK Wires F22 --> H22 ?? HELP
- civic front end
- Is it so bad in the U.S. ?
- VTi Cluster, Brightness
- replaced engine... 94 dx: idle problem any help?
- When you can get an access to post on cosmetics?
- switching inner tie rods, okae without adding washer?
- Installed Skunk2 manifold & hondata gasket, now motor runs rough
- delsol with 2 motors
- >>NEED HELP TO FIND CHEAP EK HACTH FERIO BUMPERS<<
- map
- honda seatbelt replacement FREE
- Need Help....Quick
- i need a vss pic from a b16.
- quick swaybar question
- Question about car in neutral
- shaking in b18 civic
- stage 3 burnout
- ek front end onto a eg front end, easy changeover?
- EG axel question
- very quick question
- how do you find an ECU code higher than double digits?
- Anyone installed a laptop other than to control an ECU?
- 98 D16Y fit in my 93 DelSol??
- How much does d16z6 S1 Tranny Weighs
- Question/Picture request for Lowered Civics w/ 17'' Rims
- need some advice on trading my car
- 93 civic front strut -> 90 crx ???
- belt sound
- my si was stolen last night
- look at this mini me...
- Can Someone Post Pics
- HELP: Engine cuts off at idle
- Sparco Harness Install?
- MAP Problem please help
- My car wont rev past 4000rpm. Any ideas anyone?
- New EG hood
- Would bigger injectors/fuel pump, high flow rail, regulator be good for my set up?
- Looking At a Del Sol DOHC VTEC
- eg6 climate control
- 99/00 SI prop valve picture
- Wheel offset
- turbocharger
- CTR pistons in an b18c5.. question
- OKAY I'M DOWN, 00 conversion, here i come.
- How do I change my transmission fluid?
- JDM SIR cluster
- Timing problem, or bent valve..
- Brake Pircing Question...
- EG Hatch + ITR 22mm rear sway + Beaks kit = Subframe damage?
- Anyone with aftermarket power door lock actuators. Question
- 98 civic questions
- Help, Return fuel line size?
- Where can I get "NEW" alternator?
- JDM P30<>USDM P30
- Is the JDM H22a streetlegal in the states?
- Del Sol model car?
- does anyone have a civic with a b16a engine swap?
- itr lsd/final gear fit ek4 ?
- Dimmer Switch
- brakes squeak
- Having problems with my MAP help!!!!
- Vtec engaging twice?
- quarter panel rust?
- d16z7 ? d16y8?
- civic ex 1998 trade for?
- 92 Civic Up and down reving...
- KYB GR-2 or Tokico "Blues"
- Quick question on continuity of wires.
- Doing a Great motor swap and build need help??????????
- EG HEADLIGHT TYC SEARCH?
- gsr tach into 92-95 civics
- which top radiator hose to use in an ek9 b20 swap
- GSR brake swap into EK hatch.
- 1ST TIME TO THE TRACK
- body filler
- body damage
- how long do you crank when starting?
- Brake hoses
- vx rear diffuser
- Any one looking to buy a 99-00 Si Cluster For $150.00 in SoCal?
- Dimentions for 2000 Civic EX coupe trunk?
- CIVIC 96-98 to a 99-00 conversion
- Stress on Aluminum?
- 99-00 EK Fog Light Bulbs?
- will an EF boss kit fit an EG?
- aluminum lower control arms
- step by step powersteering removal?
