View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Motor Swap: About A/C, Radiator, and etc...plz help; TIA
- Any differences between the D16Y7 and D16Y8 bottom ends?
- need help finding brake lines
- HELP?Would you pay this much for a EG?HELP
- #$%!ing fuel filter!!
- What are my chances? d16y7 turbo vs d16z6 Zex
- NAKED CHICKS!!!!!
- how hard or hell possible?
- 92 EG hb sqeeking noise
- storm performance?
- 93 Del Slow rear disc brake conversion
- my EK got totalled once again...
- ??wat are helper springs for??
- I think i blew a fuse NEED help!!!
- Whats the difference between long block and short block engines?
- Civic Type R sideskirts on del sol?
- is anyone UNhappy with their Single cam turbo??
- bumper?
- messed up radiator install help! DOH!
- i know it doesn belong in here..... but..
- tein ss and volk te37 or b18c ? u tell me ?
- What A/C compresser do I need?
- removing the lower timing belt cover on a 96-98 civic
- Misshift symptoms
- ECU questions.
- What engine is this??? DOHC non vtec???
- Intake manifold?
- WATER TEMP GUAGE?
- Air Condition Help
- My B18C1 w/ Si tranny
- advice for a cat back N1, evo, rs-r, thermal....on 99 si
- sleeved block??
- EK Hatch N1 exhaust with 16's
- JDM Broadway mirror
- Need help need a good shop
- ::progress full coilovers:: NEED OPINIONS!
- falkin or performance tires on snow?
- Question about SRS light...
- ZC or D16a6 all motor bulid up??
- Will any axle back mount to any b-pipe?
- anyone with gsr supension on an ek? please post pics
- brake fluid leak
- Where's the Best Place to Get a Good Deal ?
- Removing moldings...how to pull door panel?
- headlight assembly
- #1 cylinder position sensor-code 9-just did swap. need tech help!
- Teg front brake calipers on 99 Civic?
- What is the best fuel pressure for intake and exhaust?
- this link makes me wanna get a bike
- New Suspension Small Clunk???
- which swap for the EGgo
- Show me the path of enlightenment...
- need somebody with an EG w/h22 swap
- first gen. jdm b16 o2 sensor?
- Did I avoid the rice? (very big picture, sorry)
- weekend projects: DIY vinyl and exhaust
- Nordskog GPS Speedometer
- Where are the window relays?
- Size of 90-93 Integra MCs?
- What spark plugs are you guys using with what setup?
- Check engine light not blinking with paper clip?
- Charcol Canister
- are my brakes messed?
- idle need help!!!!
- Help on buying EG hatch!!!!
- pics of car, how much should i drop?
- current state of my car w/ pics (56k ok....im running it)
- 80k Tuneup on 99LX
- DIY eg Audio Console
- my del sol won't start : (
- material
- Pic Request! Rota C8's on EK's
- Help me Hook up my O2 sensor
- My new 8lb flywheel and zoom clutch set...flywheel is sooo pretty....
- Goood price for a d16y8 block?
- How much will you pay for this car?
- Ordering Honda paint?
- Import Builders.com
- Finaly, 16" wheels on my Sol.. !
- how fast is a h22 sol?
- DX Intake Manifold to EX Intake Manifold
- Cant rev past 5000
- need new alarm, money is no object, what would you get???
- Xenon Headlights for sale 9003 9004 9005 9006 9007 65w (produces much more than 65w plain halogen)
- IAT sensor
- Terrible Rattling noise, could it be heat shield?
- best engine to use?
- brake trouble
- what you guys think of my car now??? :)
- this price good, clutch?
- rear type r lip
- eg hatch passenger side window
- Selling my car soon, need a quote from professionals (u guys)
- Changing Oil to Synthetic w/ 160,000mi.?
- OK Has anybody had good experiences with the Rear LCA shock bolt????
- 2000 EX Coupe
- tein SS coilovers for 00 Si
- 2003 si Seats
- What bulb for 97 EX turn signals?
- EG- Tire/wheels sizes and scrubbing
- custom 4-door civ, ran a 16.4 whada think?
- Project D16Y8 Nitrous....motor almost in. (56k beware!)
- alignment Q
- GSR Guage Cluster
- zex 105300 or 59300?
- PLease tell me what this prelude is worth.??!??~
- 99 Civic Clutch and Flywheel
- Pics of My EG at the track....
- Florida Honda's
- How to Paint my Side Moldings, door handles, and license plate holder????
- B16A2 into 96 EX....simple question
- SWAP SHOPS IN NC??
- WOW!!! Finally thought I'd share!!
- Wrecking yards in the Bay Area
- Why do some Amber Corners look different than others ????
- how much would it be???
- Well, you guys have H22's too, so I need your help too...
- DYI clear corner.....does anyone know how?
- Mini-Me: Auto dx tranny only shifts @ 6300 w/ P28 ecu- why!?
- ECU needed for auto to manual swap in 92-95 EX?
- F/S Thermal exhaust for 92-95 hatchies link
- Would the auto cluster fit on the manual car?
- Stud on hub assembly, How to get it out?
- ek hatchback guys..whatyd yah do about brake upgrade??
- camber kit question?
- giovanna wheels?
- Need Engine QUICK Tampa Fl d16z6
- d15b7-mini-me vs. d16z6 D-SERIES!
- universal tanabe racing medallion muffler? anyone have pics?
- 225+ HP Del sol SOHC! lol wow..
- Do not purchase...
- CF hood gap problems
- How do I get Allowed to Post in the Classifieds Section?
- High Idle Problem...GSR TB on Z6 IM...Need explanation
- Can Someone Please Carfax This VIN For Me
- Coilover Question
- stiffness
- car super bouncy since energy suspension bushing install...
- Motiv8's 100% Rice-Free FERIO (lotta pics)
- LSVTEC vs GSR
- Are integra shifters different than civics?
- WARNING SOHC y8 intake manifold swap info you need to know
- 99 Civic EX Coupe - Passenger electronic door lock frelled...replacement parts?
- will replacing susp. bushings with new oem rubber make difference?
- do you think this is a good price?
- EK owners if you want a spoon cluster
- pic request !!!!!
- New Apex'i WS....wierd smell
- car won't start, but everything powers up
- CEL 17-VSS: Where do I start to troubleshoot/fix this?
- SOHC V-AFC
- Does anyone have any tips on removing camshaft caps?
- Anyone have pics of SI seats in an EK?
- EG Rear LCA...USDM and JDM are different??
- at work today
- WTF speed sensor is CACA
- tire pressure on falken ziex 512's?
- where is the coolant drain bolt?
- VIS Hood and duckbill fitment problems?
- Good online honda/acura parts store?
- question about jdm b16 motors
- Emissions question...???
- Got a new steering wheel.
- Install Auotmeter Gauges
- 2002 Celica seats in 1999 Civic????
- HID question for 99 CIVIC
- how to prep lip for paint?
- pillar bar in 92 civic
- misc. eg questions - need input
- Which shocks for longevity?
- 2kTypeRHatch's "aftermath" pics courtesy of SCPD
- Can I use a y8 (ex) head gasket on a 95 B7 (dx) head?
- my Check engine light is on..why???
- Anyone who has the Emissions sticker on a OBD1 Del Sol Dohc Vtec..
- need help finding vtec solenoid!!!!
- from ek to eg
- Question about swaybars......
- erratic idle and cel question
- Check engine light = missfire in cylinders, what else do i need to check
- "custom" turbo kit
- genuine spoon hood?
- where to buy a seibon carbon fiber front lip?
- Rust build up on wheel studs with spoon lug nuts?
- ECU and OBD1 OBD2 harnesses help
- CRX seats in my EK
- Code 15 Problem ?
- EG guys. I need help with my moonroof...
- TB for D series
- DIY intake, what bends do to purchase?
- ::blown rear shocks::
- what exhaust?
- Custom VX intake
- 93 Civic VX Motor Swap
- alternator problems!!!!!!!!!!!!!!!!!!!!! i dont get it
- Spoon Chip
- 99 si color code
- what u think i could get in a 99 Si
- Crazy interior water dripage while a/c is on
- whats wrong with my hb??
- 96 gsr wheels on ek hatch request
- Anyone in South Florida down to meet at moroso tonight?
- What's best for my installation?
- Install Walbro fuel pump? Already searched
- need help on 99-00 hb taillight conversion
- General cost of b16...
- Top Fuel Civic
- average cost of your B18B1 engine swaps
- is there such a thing as accurate guages????
- Check out my ride. Post some of yours. SI
- New digital Camera... virgin pix of my EH3
- ATTN: South Floridians...Its wednesday guess what that means.
- heres my once every 6 month pic thread...56k go die somewhere
- Main Relay location 93 Civic EX
- trial user
- y8 many on a 7y what has to be done
- Aftermarket Camshaft specs....?
- where to get carbonfiber duckbill for EK
- Why do people do this?
- FYI: J's Racing intakes (copy) on ebay for $42.99
- coilovers question...
- ctr lip question
- 92-95 Civic EX automatic owners, what RPM does it shift at? 6400 or 7200?
- p28 chip, p3o ecu, I know i'm retarded
- del sol vtec, prelude ecu
- Did Honda make the Civic Coupe in 92' ?
- difference b/w b series turbo kit and d series turbo kit
- EG Carbon Fiber Hatch
- fuel pump relay
- 2nd gear grind
- b18b with d-series transmission
- Polishing job?
- PLEASE HELP!! 93 cx 16 valev upgrade?
- Hey I have an IDEA lets have an integra dash forum!
- which clutch kit?? centerforce or sachs??
- Cheapest place to get a helms manual?
- P28/P30 what's the diff?
- General info q's on GAB struts
- '97 bumpers
- crack on d16 head?
- Which Way To Go With B20?
- one more integra dash question to add!
- Need help on my new car...
- Possible to put S2000 cluster in 00 SI?
- Skunk2 coilovers
- superwhite bulbs that wont blow out??
- Got a new car after 4 weeks of looking
- Car Stolen This Afternoon in Front of my Work
- Tein Install help/question??
- gauge cluster quest?
- single cam owners..give me reason to believe!!
