View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Blows oil from dipstick tube under boost
- HALP: 94 Hatch has been sitting for about a year... now its overheating!
- Who am I kidding? Its still USDM.. my build
- Buddy club spec II on SOHC ?
- Which mount is this???? ///b16a2
- P06 ECU runs like crap.
- d16z6 oil ?
- 93 DX Overheating - Help
- braided lines...suggestions/where to buy?
- *** eg video ***
- ELD help help
- help vtec no working
- What are our blocks made of?
- Help: where are some typical water leaks in eg/ej's
- help wit h series in an eg
- Replacing brake light help
- 95 civic wont start
- NEw exhaust for turbo SOHC d16y
- swap
- HELP with retrofit, First time doing one
- primer a car
- Ebay Headers
- Help with Replacing 98 civic singal combination
- need some suggestions..
- del sol stalls, loses acceleration on turns, electrics die
- will em1 rear seats fit in a EJ1 coupe?
- Fresh swap, clutch pedal hits the floor...!?
- 99-00 EK fogs
- looking for bearings
- d15b7 swapping for d16z6
- jdm fog lights
- ebay traction bars??
- Amber foglight switch and defroster?
- help identify mount!
- A6 and z6 differences
- what coilover sleeves do i get?
- new fish
- 96-00 civic interchangable parts
- srs & abs light(how to remove)
- 95 Honda Civic Ex
- HELP: no low beams!
- D-series block parts interchange????
- starter question
- lca bushing removal
- Not working Speedo/Trip/Cruise/Vtec B18c
- fuel gauge is very inaccurate?
- crank pulley tool
- Need help with welding and quarter panel repair
- d16y5 swap wont go over 4k rpms
- 2000 b18b1 into a 97 delsol swap please help? partslist?
- Coolent in my AICV
- d16 distributor question
- is there a differance between eg n ek front forks?
- should i...
- B16a2 or Lsw/b16tranny?
- head stud question
- Pics Request: Mugen Rear Splats/Spats/Valence
- Are these rods a total loss?
- start up idle problem....
- eg b swapped prblem [HELP]
- check engine question
- skunk2 intake manifold
- I cant get my wheels off...Help!
- 94 civic ex with d16z6
- Valet key - lock - thing
- Leather-wrapped SRS/Cruise Control steering wheel for EG?
- Question about 96 and 99 rear bumper for ek hatchback
- QUICK RELEASE HELP!
- gearbox popping out of 5th
- *** BATTERIES KEEP DYING. PLEASE HELP ****
- ej1 rear air diffuser
- car stalls....help
- Is a 2.25" collector really a 2" collector?
- *** fender rolling in riverside ***
- What part is this
- VX rims on ej1?
- How much do you think I could get for these?
- i think iam in trubble
- civic hatch
- Help with Integra mc/bb on EJ
- B20 lovers ONLY!!!!
- My Honda Owner's Creed, Live By it, Die By It
- Brake noise
- Aftermarket Radio stolen now Heater doesn't work?
- New to HTscene K20 installer Fullerton, CA?
- Pump my fuel injected motor inorder to start?
- ABS problem?
- CHECK ENGINE LIGHT need help!
- How loud exactly??
- help burning gas like no tommorrow on eg gsr swapped
- Correct way to wire JDM sidemarkers?
- how do i adjust my headlights? specs?
- Downgrading trans from SI to CX
- power steering pump rebuild?
- 96 civic tranny on a 92 civic
- Throttle cable
- ARP headstud question
- Vtec not working help anyone please
- 97 back prelude seat fit 97 hatch?
- gas light never comes on???
- eg coupe dash removal?
- rsx dash into an ek?
- New owner questions
- d16y7 with d16y8 ecu wiring nitemare
- eg lca fit EK
- quick question
- rota rb wheels
- rhd ek axel problem
- VAFC 1 on Civic EK4 B16A2
- EK Help
- Need help ignition won't turn on
- civic problems...HELP!
- 96 honda civic ek4 sir
- greddy evo exhuats fitment
- K20 into an ek hatch
- Suggestion on how to clean engine bay and valve cover
- Bump Stop For Ek Civic
- What do you think i should do next?
- Help! Car not starting after removing alarm!
- Rear Disc Conversion
- Mounts
- Rota zero plus 15 x 8 with red lip
- just opinions
- Will a d16a6 crank fit into a d16z6 engine with no mods!
- whats it worth?
- Radio Help
- How would this look??????????
- Question about sandblasting a motor.
- 98 EX Automatic Transmission questions
- New member
- 99 ek hatch motor problems.
- Which ECU to buy for b16 ???
- B20 Swap Illegal or legal in WA state
- 97 Civic rear running lights not working..
- Eg6 BIg or little problem
- 97 prelude seats in 97 hatch
- In over my head even before jumping in...
- Help more torque. and Hp B16
- can you feel the v-tec power on d-series
- Cluster Pinouts - Help! USDM Civic and JDM Delsol
- Tightening alternator belts
- my jdm h22a swap
- Electrical Schematic for P28?
- 98 civic, looking to put 99 climate control. possible?
- P28 ECU auto or manual?
- 94 Civic DX w/B16A swap: COLD AIR INTAKE VS AIR INTAKE
- PLEASE DELETE
- Water getting in Thru Sunroof
- SOHC VTEC issues. Help me out asap
- 96 cx to v-tec, not sure if v-tec is worken
- 99 dx motor into 92 civic SI
- B16a2 Lifter/follower adjustment.
- vtec diagram
- need help h22 wont start
- urgent help!
- *** TOPPING OUT @ 3,000 RPM *** PLEASE HELP.
- GSR swap in del sol, Mounts?
- motor options?
- Having some steering issues with my hatch
- auto to stick swap... help please
- Are EM1 power windows PLUG AND PLAY?!? Got pics.
- best thing to do with EXTREME blowbye
- y8 Block Milled 0.030" with vitara pistons? Piston to valve clearance?
- transmission problem?
- I need reliable fog lights
- Which Vision Corners?
- can you conect a switch for vtec d16y8
- Integra rear swap question
- Overheating Problem, please help, its my daily
- spoiler trunk plugs
- Ls Motor into eg questions?
- 96-00 hatch pin out D16
- d17 96 4door?
- difference between civics front bumper stiffeners
- y7 catalytic on y8 pass smog?
- noob question on the differnet type of engine (si, gsr) HELP
- 1997 hx windows problem help
- fog light bulb size?
- delsol b16a3 power loss/ high fuel consumption.
- Crazy Misfire NO CODES! Please help!
- d16z6 help plz
- getting lowering springs. any suggestions?
- Help me resurrect my coupe!!!
- LS Alt Question
- What engines will a D15B crank shaft work in?
- Wiring diagram
- Help...What is this? Pic inside......
- Mugen Universal seat rails
- VTEC question
- VTEC question
- 14" Fluidyne radiator. What fan to get?
- Left turn signal makes CEL lights blink
- 95 civic idle problem
- engine restore
- D16Y7 Intake manifold
- Where To Jack Up Front Of Car From...?
- d15b7 iacv fit on d16z6 im
- bad wheel bearing 97 civic with rear discs
- car exhaust smells little black smoke!
- del sol no start
- what kind of power would this make?
- What color could this be?
- 99 LX Check Engine Light
- [Please Help =\] 95 ej1 leaks into rear passenger carpet and pool in trunk
- Will this fit
- need help identifying b series rods and cranks
- 92-95 civic mil spec H22 conversion harness
- b16a (xsi) b16a sir2?
- need help with MUFFLER size
- IAC or cooling system?! Please help
- steelie question?
- best and worse websites to get engines from
- FOG LIGHTS COVERS
- timing dizzy
- New to Honda, possible owner of '95 Civic coupe
- Making a commuter vehicle...
- IACV question
- Rattleing front of car!
- suspension ? for my hatch
- Glazed flywheel
- Swap won't start
- 99 Civic Ex MT with new Viper 5901 and problems with Hazard lights
- need some data on EG6 and EJ2
- Oxygen Sensor Hell! Please Help
- Bad Cat?
- magnaflow converter?
- need help to figure out what master cylinder to use
- eg front on del sol
- 97 ex made 99 si ECU problems
- eg brakes
- Help Honda Civic Crankshaft bolt STUCK???
- eBay CAI carb legal
- From mustang 5.0 to Del sol 1.6 (new guy)
- new ride. 92 dx hatch, imported
- D series boost with A/C?
- EG Windshield squirters replacements.
- b18c1 type r rods and pistons!
- 95 civic coupe speedo problem
- new to honda-tech
- Blackworks LSV conversion kit
- KYB 2 Front GR-2 Gas Shocks 92-95 Honda Civic, are they good?
- b16 iac low voltage cel
- Random problems..RPM's reading 400 too high and im running rich* jdm d15b
- Steering Wheel Moves On It's Own?
- No FI signal from ECU? Help!
- 3 bolt heads snapped on my LCA
- Introduction-Selkertic
- some input, possably starting project
- Del sol pic request: Interior wiring
- 94 hatch...heater turns on but no air comes out...help
