View Full Version : Honda Civic / Del Sol (1992 - 2000)
- special axles
- CEL help
- Need Turbo and A/C PLEASE HELP
- b16 swap problems
- CEL PROBLEM
- D15b8 Head question???
- gauge cluster/ fuse questions
- VX throwing codes 9 and 48
- 92 civic w/b16 starting up problem, any ideas?
- Have faith in honda..i did and i have a customer for life.
- clutch advice needed
- Prep Work (H22 to EK Hatch)
- heater blows no air
- question on d16y8 swap.
- d16y8 swap idles jumping like crazy
- 98 civic 2 dr window motor swap
- 96 civic with gsr swap keep getting codes P1454 ,P1452 , P0505 help!
- Is this true?
- hid ballast differences??
- how to wire a 92 cx o2 sensor to a 4 wire 02 sensor??
- code 45
- exhaust help needed
- Ripples / Waves on shock towers
- Verification Needed. P2N and P2M.
- 2000 Civic Si Transmission
- install nrg quick release=no horn? help
- Tuning Question
- B16A Redline
- 95 civic stolen in NJ
- Radiator support
- Can some one please clarify
- which brake fluid?
- Normal Idle when Cold And Hot
- Check Engine Light Trippin Out
- OBD1 automatic GSR wiring problems
- Headgasket leaking?? (pics)
- newb kinda
- ls swap into eg help/
- quick problem any answers?
- header question
- CONSOLE help please 92 Hatch
- p28 ?
- Finding out the age of an engine?
- CaR wOnt sTART!!! HELP
- Suspension problm any ideas?
- Throttle body question/TPS
- New Hear Wanna Get Some Answers
- A little help with this one?
- What is different about the VX engine?
- HOW DO I WIRE ? DIZZY
- IS DENATURE ALCOHOL GOOD TO PASS SMOG CHECK?
- Please Help! Brake Pedal wayyy to stiff
- s2k seats? Worth what?
- will a ek (97 honda civic) dash fit in to a eg (95 honda civic)
- thermostat Question "please help"
- D16Y8 Q
- Will front 94-01 integra brake lines work on my ek
- B20 Weak??
- how hard to reach 200hp?
- 92 civic hatch stalls at lights?
- Radiator Fan no-longer kicking on after swap, and tps out of range.
- greddy turbo kit for 99-00 si b16 may fit others.
- just testing waters for my 2000 si
- Yet another timing post?
- need help with a ls vtec problem
- Removing lower grill on 99-00 bumper
- does anyone have an em1 si spoilor forsale?
- Starting another Build
- 97 coupe rear tray plastic rattle fix????
- no vtec and flickering oil light on freshly built gsr???
- COME LOOK! 92 b series hatch for sale!
- quick question..
- trunk leak in 95 del sol
- Buddy Club short shifter
- Dealership and Timing Belt/Pump Replacement
- BC Spec II Exhaust
- Manual transmision fill/check plug
- Wire tuck, Sohc civic coupe.
- CTR door panel, CTR pedal assembly question
- 200whp possible??
- Engine Check Light Problem
- Help looking for 99-00 OEM Si lip ???
- Need some motor mounts/Energy suspension motor mount inserts or innovate billet aluminum solid mount
- will dc springs fit on an ek
- good turbo exhaust
- timing belt broke
- timing blet broke
- Wiring in a Resistor Box... Help please
- Jdm Cheappppppppppp!!!!!!!!
- CARBON FIBER HOOD
- 2000 civic ex catalytic converter problem
- i need help with tie bar
- 94 teal civic d16 y7-y8 head turboed need tuned?
- Sway bar question??
- Any one have pictures of 06-07 civic seats in an Eg?
- gsr oil squirters
- looking for a upgrade
- honda main/rod color bearings
- curiousity
- Rear lower suspension question
- Question about h22 swap
- h22a type s in a em1
- my first car project, 99 si
- AMBER CORNERLIGHTS ??
- ex/si gauge cluster auto
- Just another reason not to buy"ebay"products
- ef ignition interchangeable with eg?
- Another B16 swap ???
- Unorthodox pulley question...
- over heating(i think)
- obx intake manifold question
- Mixing 2 different types of Coolant?
- b16a oil temp and pressure
- Help: Car sputters only at low rpms in gear
- d16z6 engine rebuild need help
- Quick question on B-pillar bar??
- ?????ALARM for my civic with MANUAL locks?????
- What is your water temp while running? When does your fan kick on?
- 95 civic eg coupe back seats fitment
- 92 integra rear disc brake conversion on 98 DX?
- cut splice injectors. obd2-obd1
- help..car wont start
- DA seats?
- Does anyone know how to install prothane motor mount inserts?
- eh hatch doesn't crank, main relay doesn't click, check engine doesn't come on.
- Coolant Leaking help
- Ticking after New Valve.
- B16 swap info
- BROKEN BOLT on exhaust manifold help.
- b16a3 ek not starting
- TPS HELP
- Salvaged car
- EJ8 help!
- Radiator fan won't turn on, new thermostat, new ect switch, autometer reads 250!
- Random Speedo Issue
- high offset on ek?
- turning my lights off
- inner tie rods on a manual rack, can they be replaced?
- vaccum leak (idle problem) please help
- Relocating washer jets on 5th gen civics!
- manual or automatic
- MIni-Me headgasket
- Noises coming from 2000 Civic EX. Please diagnose
- EG Motor Swap need some help choosin!
- Rear Lower Control Arms
- HELP: '88 1.5L civic alternator on a 92 1.5L engine?
- Ek4 complete interior how much to ask?
- suspension assistance needed
- I need a catalytic converter!!
- HELP fuse digram!
- need help bout my engine
- High tension wires
- Overheating
- tranny got stock on 1 gear help!!
- Replacing my Piston Rings(d16yz)
- Please help me with my overheating problem
- 200hp question help plz
- Fitment Question
- Anyone use Ebay Quick Release Steering Wheel Package?
- Need some Auto-Shop References for d15 Valve Adjustment
- what computer should i use
- timing belt replacement
- clutch master cylinder.
- 99 civic si pistons
- D16Z6 Replacement
- Chipped P28 back to normal?
- CALLING ALL 96-00 Civic Tein Flex owners!
- clearance issues with comptech sway and N1 exhaust. tanabe fit?
- y7 > z6 - parts
- Nasty Electrical Problems!!!
- Gday from australia
- clutch question
- Trunk emblem 95 eg
- B18C1
- What Muffler is this?
- HID Question
- New throttle body= high Idle
- 1996 Civic CX hb with b16a1 swap, what catalytic convertor?
- Possible to fix?
- Another Engine Under my Belt
- oilpresure gauge
- NewB question. What you guys think about this color/combo?
- Headgasket instructions....?
- I just purchased this Auto Zone Radiator and..
- test1
- 99-00 Headlight with air duct?
- picts
- B20b running rich.
- swapping heads, small problem (wiring)
- quick question about dropzone shocks...
- 92-95 Honda civic.. Coupe and Hatch exhuast..
- Tune with apexi afc neo
- b series header question....any advice will help
- My first really slow turbo Build, no response on forced induction,
- Integra Dash Install Wiring Trouble....Please Help
- GS-R IACV vs. Ek Civic manual IACV (mounted on Intake manifold)
- Em1 Cam swap bulid up.
- Element drifter x?
- CLUSTER WONT LIGHT UP!!!
- New owner with LOTS OF PIX
- AUTOMATICS
- Need Help: 96 Civic hatcback - Trunk Doesn't stay close
- Added too much oil accidentally, should I be concerned?
- WILL 93 CIVIC EG HATCH DOORS FIT COUPE.
- b16 type r cam, camshaft
- head gasket ?
- new build problems???
- EG Fog Lights
- Anyone Ever Tried a DIY Lip
- 00 conversion
- Eg hatch/coupe tail lights
- NEED HELP ON FOG LIGHTS!!!!!!
- need head gasket replaced - recommend shops in Rochester, NY
- civic si rims
- broken cam help!
- Whats wrong with my civic?
- battery always has to be jumped
- B18C1 Tranny
- Stupid Exhaust Q
- vehicle speed sensor
- Whats the difference between
- will an ITR hood and front bumper fit IN a hatch for transporting
- IACV
- car will not drive
- hx to gsr harness
- help!!
- a d15b swap for a 94 civic?
- WIRING PROBLEMS!!!
- idle problem
- ecu chip question?
- Oil pan fitment question
- thermostat temps!
- >> 3rd Brake Bulb Larger Than Bulb Hole!? [2k CX Hatch] <<
- tapping on cold starts!!
- computer ground out true/false?
- cleaning VSS ?
- b16a2 swap question
- intellectual input needed
- want to chip my ecu
- Need Feedback on RHD conversion????
- got a p28 throwing code 40???
- i need some advice?
- STUPIDEST question EVER...but can someone please answer it for me.
- turbo
- Electronics Problem?
- Getting sick of sucking water outta my hatch...
- mixing up valve seats
- manifold pics
