View Full Version : Honda Civic / Del Sol (1992 - 2000)
- TRADES
- Gas leak
- fuction 7 lca and sway bars
- headlights
- Rolling forward odometer
- engine oil pressure
- a/c recharge help needed
- How much lower with vision one touch rails on my recaros?
- swap has 4 extra plugs
- I NEED HELP WITH THE VIN IN MY NEW EG DASH
- CRVtec
- fog lights installed what happened?
- Very Rough Idling.............Ive tried everything!!!!!
- b18 swap into ej1 searched....
- hood pins
- Need Help on Alternator Change?
- Pressure plate collapse?
- I CANT GET MY CAR TO START PLEASE HELP URGENT
- H&R sports on my eg
- boosted d or b series?
- boosted d or b swap?
- wings!!
- engine harness question
- which camber kits are interchangeable
- Quick opinions. Coilovers for my EK
- Tanabe or HKS?
- Complete LS/VTEC swap guide into EG Hatch??
- engine code 5.
- koyo kicked my a$$
- Need some help. 92 Si swap with 94 B18B
- Leaking oil
- Vtec solenoid bolts.
- vin # location???
- i got code 6
- LOOK REAL GOOD DEAL
- dash weight
- orderlongBLOCK
- B20Z - Low Compression, Low Coolant Pressure, Coolant Loss = Headgasket?
- Random ? easy answered
- P0505 Problem, after engine replacement
- searched but have tranny questions
- 98 civic swapping from b16 to b18
- 99" obd2b y8 swap into 97 dx hatch which ecu and harness to use??
- quick question about my injector
- Cd player
- 4 lug to 5 lug?
- drivers headlight not working...not a burnt bulb
- 96 ex itr knock sensor
- Help repairing windshield wiper lever
- D16Z6 block with non vtec head... will this work?
- car toruble!
- Any advatage at all for getting your rotors machined black or watever?
- Powersteering elimination kit
- Honda Civic dx 95 help A.S.A.P please..
- CAR WONT START NEED HELP
- Intake Manifold.
- Honda Civic 95 sedan dx problem need help A.S.A.P..please
- H2B... Is it worth the money?
- Knock sensor schematic....
- New Rally Video....D15 Fury!!!
- Bench Bleeding M/C?
- STILL NO POWER!!!!!
- Help! Do I do what my mechanic is suggesting?!
- MSD Pro billet dizzy on b16a
- stock seat belt on recaro???
- brake problem
- Cruise question
- B16 Trouble
- 105,000 Mile Service
- Anyone order from exospeed?
- Is this Civic worth it?
- spark plug question
- how would you install a distributor?
- installing upper control arms, 00 civic coupe
- Wheel size and dyno
- ITR vs. EX Front Sway Bar??
- Rear View Mirror Problem
- Need a intake manifold hose diagram...
- Some questions with a rear disc swap???
- What brand Head gasket?
- idle problems
- timing belt help
- Which tranny for supercharger?
- How much for a fender??
- Passenger Seat Shakes
- My Civic Re-build
- b16b with nitrous, what plugs would you reccomend?
- WEIRD THUMPING NOISE
- EG8 Speedo problem
- 97 civic ex wire tuck
- Are Shift Glow Gauges good/accurate?
- question on h2b swap
- Fuel pressure question
- how to put a 1996 civic hatchback front end on a 1992 civic hatch help me please
- advancing or retarding your distrubitor?
- Del Sol Intermittent Start Problem Think its ignition switch
- oil pickup replacement
- Proportional valve..... no such thing as 40/40 ..... only 40/60 ... ?? HELP
- H22
- Transmission Fluid - 1995 Honda Civic
- 1st car
- Skunk2 Pro 1 stage 1 set up (help me please)
- Which part do I need?
- DA ebrake cables on EG?
- changing oil myself
- lost wheel lock. anyway to get them off?
- Need info on part
- Does a p30 ac bracket fit a jdm gsr block?
- need bigtime help with this build up...newbie to the import world
- Factory Oil Change Worth It?
- D series turbo vs B18B swap
- Swaybar bushings & endlinks
- strut/shock/spring assembled units.
- Tranny Issues
- Power Window Switch? (searched)
- h/f2d
- // How can I remove this ???
- b series AC ?'s
- NEED HELP
- b series AC ?'s
- Y80 transmissoin help
- 94 B18C in 95 Civic Si Z6
- EMULATING KNOCK SENSOR SIGNAL/IGNITION PROBLEMS
- 2000 FBP Civic EM1, How much to offer?
- b16a p28 vs. p61 vs. pr3
- o2 sensor?
- Caliper pin from 93 Civic SI brakes same as 96 Integra??
- 1.5 tranmission vs. 1.6 block
- Del sol DOHC VTEC swapped for d15b7 hooking up AC and PS questions
- Help me out.
- Taillights.. 96-98 and 99-00
- Cheap aftermarket Fuel filter
- What the???? gull wing doors on a stock civic?
- it only helps if people see it
- B18B head stud thread patern?????
- wtf
- EG Steering Rack Swap - PS to Manual HELP?
- abs and non abs rotor question
- 96 civic rear strut
- jdm headlights
- EJ8 - Topic: ECU
- What foglights are these?
- Problem taking out outside door handle on 98 Coupe
- 99 civic
- Wheel Stud Replacement
- HELP WITH POWER WINDOWS - 95 DX 3DR.
- Overheating at idle!?!?!?!
- what sensor is this
- Do I need the prop valve from the 99-00 sir for ITR 5 lug ...or can it be ITR with k swap?
- anyone ever put hid kit on an eg/ej1 factory fog light
- looking for a shop in central fl. to rebuild 2000 si tranny
- Swapping 99-00 climate control into 96-98 civic
- Engine not getting spark.....Ideas???
- quick question
- TURBO A D16Y7
- Cam Question?
- d16y8
- cheap web sites for honda parts
- ********* Cleaning IACV - How to *********
- something weird is going on with my brakes...
- head swap
- NEEDD IMPORTANT HELP FAST
- what do u think??
- Can you drill 4X114 type-r wheels to 4x100?
- which turbo kit would u get?
- need help 98 b18c1 swap into 94 civic vx
- Squeeling sound from front passanger wheel well?
- b16b, friend pulled wire off dizzy cap while running and then reconected it, wont start
- civic 99 DX/EX enginre wiring harness converstion to H22
- 40k mile on odo, 113k on car, Problems?
- window visor
- turbo
- Cluster Question
- rpm help
- type r lsd
- Catalytic Converter Problem, ecu code 67!!!
- hid in ek headlights
- How much doesn't the EK weight?
- got a problem
- Best Oil to Use?
- instaling cuisse control in del sol vti
- NEED HELP
- i need motor mounts
- Stalling at lights/after revving
- Ground Controls for agx shocks, what other shocks can i get?
- fuel tank straps
- weird whirring / rubbing / humming coming from rear wells on hard turns?
- reseting the ecu?
- What air intake is this? AEM hybrid GSR or AEM ITR?
- d16 vtec turbo or b18 ls?
- WTF random loss of Vtec! help please
- what is the 93 honda del sol fuse diagrams?
- 93 civic hatch problem
- What OBO is my 93 honda del sol
- fuel filter location
- quick release questions
- Do EG Seat rails fit 99-00 SI Seats??
- Pics requested of custom rear strut bar Thanx
- Worth it? 97 Hatch
- Can I use a civic coupe exhaust on my hatch? SEARCHED
- What year is this GSR Throttle Body?
- Injector noise /// T-O bearing noise. A way to fix, or a quieter brand.
- oil pickup in the oil pan
- Fuel Pump Replacement 98 Civic EX 190 or 255 ?
- Need a couple pieces
- 95 coupe w/gsr what radiator hoses do i need
- Bore Size, Fitment Help (jdm To Uk)
- 99-2000 civic si?
- 99 si interior conversion problem
- tranny
- troubles
- ctr headlight Bulbs?
- DISTRIBUTOR WIRE BURNT...HELP!!!!!
- help pulling the motor
- Differences between 99-2000 b16 and the older b16s?
- power steering pipe
- help b16a2 will no start
- 92-95 civic VX wheels question
- ecu p28/p30
- Eg hatch rear seats?
- valves
- All motor d16
- EG / DC suspension components the same ?
- B20 with gsr head
- sputtering problem help!!!
- jumping connector to find engine code....not working
- What is the best flywheel for the street
- Coolant temp impact on oil pressure
- Help with turn signals
- 2007 civic type r spy pics
- obd0 dizzy on obd1
- Obd2 to Obd1
- I need info on brake pads
- engine codes????
- CEL problems
- daily driven 98 hatch
- car overheating and idles drop.
- 92 eg b16a2 swapped V-tec doesn't work
- what sensor is this?
- serious problem with brake pedal pressure before and after upgrade
- Need Help Please Car will not start!!!!!!!
- code 24???
- Antenna removal on 2000 Civic DX
- b-16 swap running bad
- NOW WTH IS GOIN ON WITH MY CAR?!! HELP!!
- check engine code 1128, 1106 help!
- Piston rings?
- D16Y8 manifold
- Tranny Mount Bracket
- sputtering problem please help!!!
