View Full Version : Honda Civic / Del Sol (1992 - 2000)
- compression problem
- Blox dual bend and ES shifter bushings installed - extremely tight?
- 2000 civic crank but no start?
- Help out an OG
- 92 d15b7 running rich
- Hood won't open
- 99 civic ex primary o2 sensor connector location?
- EK+EM Owners: Post your OEM seats
- skunk2 pro 2 or 403's.....
- is there a difference in a 1994 gsr head to a newer 1998 gsr head?
- puting a head on a block
- were to i get amber geage cluster lights?
- need a catalytic converter for a 95 civic
- help with vtec solenoid
- Skunk2 Camber Kit
- erratic idle just sitting and when i let off the gas
- Mini-me doesnt rev past 5500?
- What should I do next?
- finally a member!
- vacuum test result ?
- my d16z6 vtec engage point?
- Are these two plugs interchangeable?
- distributor plug vtec/non-vtec ?
- Del Sol Manual Steering
- still no start
- OEM del sol muffler fit?
- taking out and changing an EK door locking mecanishm
- My home made rear seat delete, 94 EG hatch. With sub enclosiers, Clean, Pics
- Pissed...cant remove the damm stereo.
- can you buy a brand new block from honda?
- IMPORTANT: b20 vtec QUESTION!!!
- Just bought 92-95 JDM Cluster, turn car on and speedo sits at 40kmh, help
- 2000 civic ex limp mode
- 98 trans into 01 civic?
- Y8 In My EG HELP
- reinstalling power steering on 94 ex
- Turbo recommendation
- 4krpm idle lol
- timing a z6/b7 mini me with a y8 cam. haha
- My engine blew up and I need a new one.
- D16Z6 Rpm's Problem...
- I have eg92 d15b need a new clutch and flywheel...
- 94civic ex b18b1 idle problems
- 00' Civic Ex alt. not charging and #15 keeps blowing
- Speedometer/Tachometer Problem HELP!!!!
- eg coupe issues please help
- PS boot question
- Code one (o2 sensor) need help !!!
- Fog light install issue
- Nubeie State Ref BAR HELP... B18c1 in ek hatch
- b18c1 into ek hatchback need help please
- New project? $750 95 DC 4 door
- projects
- random things
- new to the game
- Right Hand Drive?
- Question on head resurfacing
- trading engine in my cars map sensor is on the firewall
- hey new 2 this site
- can i use a d15 tranny on a d16 motor auto
- swaybar fitment question?
- Car or gaming?
- cluster
- em1 evap/thermostat issue
- 1996 engine and tranny what else?
- Parts on order, getting list together for new mods!
- Car not starting
- Finishing the Job - Headgasket D15
- getting seats for my EG
- CTR Cluster in MPH??
- h22? might be boosting it,help!
- car starts to bog out wen it warms up
- Honda tec help me out with my swap
- Auto LS Swap Help
- EK rear seats
- idle problem please helpp!!!!!
- Best suspension setup?
- Hi im new
- 95 civic ABS light on
- does this fit my car?
- 93 civic (what is this wire)
- cant find the civtegra build!
- buddy club spec 2 del sol
- turbo help
- throttle body help
- HID problems, want to check relay
- Should i stick with my D16z6 or go with a h22? HELP ME PLEASE!! NEED ADVICE!
- Rhino lining my ej1?
- '94 civic ej1 brake problems
- 1991 integra oem seats fit on EG hatch??
- dc5 recaro in eg, which rails?
- eg6+h22a last to first!!!!!! ON-BOARD
- Post your Black EK with Takata Green rims.
- Thanksgiving emergancy!! EG died need help FAST!!!
- Newb to the Site Sayin Wassup
- Civic owners, Anyone has had this problem?
- 98 honda civic with d16y7
- just did a motor swap ecu fuse keeps popping
- How much can a stock D16Z6 tranmission hold up?
- 98 civic distributor cap and rotor install
- Future paint job opinion....
- Civic Coupe Rear Cut.
- 94 delsol
- question about upper strut bushings
- issue with heater
- 98 civic ac compressor
- d16y8 rebuild! advice wanted
- My Eg Makeover!
- sqeakin noise help...
- Civterga??
- ep3 in eg coupe question
- B16 engine and stock honda transmission
- Starting issue
- Rusted Rotor bolts on Acura Integra Brakes
- b18a1 into eg hatch
- 97 EK OBD2 Code Reader
- Thinking about changing exhaust
- i need a new battery. what kind can i use
- New guy just saying hi and help..lol..old dog learning new tricks
- 93 ej1
- Need help with rear disk conversion 97 hb
- Prob valve problem.. Right?
- Want to buy: 96-00 Civic Ex Catback
- Wheel noise..bad hub?
- gsr idle prob
- Identifying Gaskets(D15B7)
- b16 intermitent starting problem
- strange clunk from passenger side
- Tail light bulb keeps blowing
- left blinker acting up. (newbie)
- electical problem....
- Rear disc conversion question.
- car wont start all of a sudden....help?
- 99 RWD Civic F20C Powered
- 1996 honda civic 4dr. having problems with all 4 windows?
- A\C Removal
- Cheap In-Channel Vent Visors?
- 94 coupe build up
- ek recaro's on eg?
- ** MY OLD CX 0-110 MPH VIDEO **
- dual 12" subs in ek?
- cheap coil-overs have to changed FAST
- Adding power, besdies turbo or engine swap
- How much power is needed to run mid-high 12's
- Help HT I need your help locating a part
- Idling issues inside.
- B16 barrd?
- 93 Civic foglight install help
- d16 Driv-side Axle has 1/4in. gap
- finally got pics of my ej8
- B16a?
- replaced headgasket think thermostat is stuck
- 93 civic fuel pump/relay troubles....not sure...
- 94 prelude seats in a 93 CX?
- springOs
- stock vs aftermarket shift lever weight?
- need help identifying b16a short block
- Could a K20/EK beat an S2000?
- What is this wire?
- Quick axleback question
- quick timing belt question
- Need help with 1998 Hatchback underhood wire diagram
- stuck proportioning valve?
- what type of brake pads
- Y8 Head To Z6 Head
- 92-95 civic door handle??
- New Keys
- Installed a jdm civic ex transmission and now my shifter leans to the left!
- Civic Problems... Aboslutly Stumped!
- delsol suspension question
- oil change 2000 honda civic si
- exhaust
- 92 civic Si TIE RODS. I need answears. HELP!!!
- DIY Knock Sensor trick for emissions
- HELP!!!!!!!!!!!!!!!!!!!!!!
- 92 Gsr Hatch Wont Rev Past 3k
- Drivers door wont unlock????
- Buying a lip was a bad idea
- HELP! Has anyone ran into the problem with oil getting into the spark plug holes...
- Acl bearings
- Lowering EK - Torque Specs? How to pull the front?
- Driver-rear brake grind?
- flip up in sol
- can you do this?
- Cant decide on k20, B18C , B16 TURBO VOTE PLEASE!!!
- is it that easy to steal a civic
- gutted oem cat legal issues
- what ECU - JDM B18C with mods
- Amplified Antenna Upgrade
- ecu not reading
- 98 civic turns over but doesnt start
- My low beam headlight dont work on my EG...
- starting problems
- Brakes grabbing
- ATF in a manual?
- Civic Ignition timing problem
- Please help weird car issue!
- Ep3/Dc5 vs H22a Ej1?
- Weird Idle, how to use Multimeter?
- H22a in an eg hatch. axle question.
- Climate Controls do not work anymore or light up
- Strange knocking sound when braking
- Lookin into modding my civic
- IAT and IAB problem in Gsr swap to ej1..
- Effect of Automatic transmissions on 0-60 times?
- K20Z3 swap in EK. HELP!
- Turbo XS Knocklight working or not?
- P0304 Help!
- turbo help!!!
- wiring s2k cluster in eg coupe "searched"
- help with projectors
- Will they fit?
- Question about Del Sol exhaust on an EM1.
- P0336 99 EM1 PLEASE HELP!! Pullin my hair out!
- 4 lug itr rims in this model ? real or fake?
- Werd noise from motor
- What this noise coming from the wheel?
- civic sedan front end question
- HID lights question...
- eg climate control block off. is there one out there?
- b18b1 turbo build. PLEASE HELP!
- Full size radiator
- ELECTRICAL fault....earth..?????
- wiring up the horn
- Fawk!!!! Fawking sheit!!
- TO EVERYONE FROM CLEVELAND, OH
- Cooling issues with d16y7
- EG Daily Driver Swap?
- After replacing my head gasket
- whats the average 1/4 mile time for EKs with B18C1 swaps
- Head Gasket Replacement. '94 Civic DX with B16A swap
- OBD1 2 wire idie air to OBD2 3 wire
- 95 civic ls swap suging idle
- Brakes!!!
- need 96-98 civic keyless entry help
- Radiator question
- lost power during Spark test??? WTF
- Horn went off by itself when the car was parked
- window tint?
- Thermostat issue
- b20b does not pass 1000 rpm
- 95 Honda Civic Fuel Filter HELP!!
- braking problem.. plz help
- No steering returnability/ play in wheel
- Redoing my suspension for most comfortable ride
- Car "wanders" while driving
- How much will come out if i pull off my lower radiator hose?
- What Should I Do To My Car Next?
- '94 Civic DX Coupe - what is this cable? SEE PIC
- my b16a is a thermostat junkie!!!!!!!
