View Full Version : Honda Civic / Del Sol (1992 - 2000)
- throttle body
- ER WOULD A D16 HEAD FIT ON A D15 BLOCK?
- Idealing below 1 RPM
- trottle booty =p
- Got some water in the motor, now car runs like shit. Help!
- em1 driverside window problem!
- Wheel Size?
- civic hx civic ex knuckle
- z6 head on a y7 block...
- what would be a good swap b18c5 or k20a2
- Pro link japan
- help
- dual wastegate wtf?
- Engine wire harness
- so this shit was stolen:(
- Flame shooting out intake??? WTF!!!
- 94 civic ex tranny grinding
- Changed ICM and coil WTF???
- trouble install aftermarket steering wheel on eg.
- speed sensor?
- PLEASE HELP
- D16 valve adjustment
- D16Y4 Head CC's
- New Skin?
- Power Steering swap question.
- Squeeky Hood
- What to do a D-15 SOHC VTEC
- have a state inspection tomorrow need help
- How can i monitor my A/F ratio without going $300 wideband!
- b16b or b18c1
- 93 civic ex coupe front spindle does it have abs on it??
- 00 civic cat conv ?s
- b series front torque mounts the same?
- help, radio and clock not working
- Stock injectors?
- Pic Request: Egs with 17" wheels
- grill insert swap possible between 00 EX/Si?
- Interior wiring HELP..... PLEASE..
- Pulled high RPM code
- what was the worst MOD you've done...
- Door panel re-wrap
- head unit wiring problem in a 95 civic sedan
- radiator hose
- were is the speed sensor located
- I know this isnt the place for this topic but they won't let me post on the Misc Help Section
- will a z6 crankshaft fit a y8 motor
- clicking when i turn, what do i need
- Help my car wont start!
- A good aftermarket steering wheel and how to install it for 97 civic ex coupe
- A few issues with my CIVIC
- JDM d15b
- tranny question
- HELP HELP AFTER DISTRIBUTOR O-RING REPLACEMENT!!!
- D16y8 head on a Hx Block???
- Is my timing belt about to break? **HELP**
- JDM Honda Access Trash Box
- EK9 Question..??
- Mini-Me help...
- Civic EG interior bump on floor on driver side
- HELP ASAP!!!!!!
- 1996 Honda Civic with 170k miles
- B16b timing belt cover same as b16a or b18c
- custom exhaust? need help
- what is ore prefered rim size?
- problem with clutching in...fluid/air problem??
- New to Honda-Tech and hondas
- would the y8 timeing belt work for a mini me swap with a y8 head and a d16y7 block
- d15y7, what can I do to make it fast?
- Eg coupe Auto to 5spd.
- "Help" Locating IAT sensor on b16a2
- good site for jdm engine swaps?
- '93 honda civic No Start
- What is the difference of OBD0 OBD1 OBD2 or whatever it is called???
- wat size injectors???
- Steering problem! NEED Help!
- Will a 96-00 exhaust for a hatch fit on a 4DR???
- ignition timing & mpg
- Comptech Intake Question
- question on civic strut springs
- ek edm type r climate control?
- Swap
- Anybody ever try to put the 97-01 prelude guage cluster in an eg?
- ready for a new tranny!
- Large seats for ek hatch
- side skirts
- 15x8 wheels on honda question
- Help!!! with interior lights.!
- 99-00 si shift linkage same as del sol vtec Dohc linkage?
- How much should a used 2000 SI prop valve cost?
- Idle, Overheating, Heater Problem (Searched)
- cx and dx b-pipe same??
- EF/EG Hasport B-Series Mount the same?
- Lost my gas cap on 94 civic ex
- fuel rail stud
- Inquiry: WW (replica or not) Flush mount wing for 2dr EG coupe?
- camshaft
- Apexi WS2 Louder then Greddy SP2??
- Weird MPG 93 Civic EX
- hp on hks hi power??
- Help on finding a hoon for my del sol......tryin for red....HELP
- Edelbrock header EDL-6642
- sup yall
- idling problem...driving me nuts...
- Distributer problem....
- neen help choosing turbo muffler
- A/C system bad?
- what do i need to connect my vtec?
- back pressure?
- clicking
- KNOCK SENSOR PROBLEMS PLEASE HELP (1999 EX)
- CEL code 8 - Is there such thing as CAM wobble?
- Dropping motor from the bottom, 96-00 EK stock motor
- no low end power or at 60mph
- Best stock b series with turbo?
- ek sideskirts on an eg?????
- Another Q On Lowering Civic.
- foglight plastic
- B16 TB question
- CTR Rear Seat Install ... Problem ...
- speedometer risig with engine RPM
- Vitara pistons with Eagle rods for D16Y8. Does the block need notching?
- how do u check if a jdm p30 is auto or manual?
- would a s2000 cluster......
- Easy question on swaybars
- swaybar swap question
- em1 to em1 swap
- wtf battery light? popping headlight bulbs
- LED for Gauge Cluster?????
- Help with tps code
- Any Suggestions
- What JDM means to the japanese
- Is it normal -front end shutter on civic 96
- Help with parts
- help me with my wiring: interior and engine bay stuff
- Oil Cooler Question!
- PCV box
- Looking 4 JDM ashtray
- d16 bore
- S2000 cluster in EJ1??
- o2 sensor help!!!
- "the code is rooted deeply" stubborn a
- D-Series Exhaust pipe size
- wtb a stock 2000 white hatchback 5speed in cali
- Weird noise, need help!!!!
- Need help on LS Swap
- WTF? Car for sale on craigslist, dude posts link to yahoo pictures and
- Password "Super Yellow" Bulbs
- ecu reset problem
- What type of paint would hold up on suspension parts (LCA, hub, UCA, fork, etc)
- A harness question
- How do you install 550cc injectors into a B16a2?
- my new setup for my baby
- No spark....help please
- Transaxel removel and time: On my side?
- Which Tranny to use Z6 or Y7?
- A/C/ problem!!
- HOW COLD CAN IT GO?
- having problem with bulbs not lasting
- Cluster question.
- Oil pressure and Water Temp Gauge installation
- 2000 Civic Si Catalytic Converter Help!!
- VAFC
- Did i store my engine good?
- intake problem (nifty diagram included)
- battery re-location,get kit or no?
- The end for my EG?
- need help with ls swap
- DA rear disc swap
- Ricey McRicerton help me please!!!!!!!!!!
- Car Bogging But Running
- 98 DX Tranny
- Custom interior
- Speedometer Problems
- Del sol clock/radio problem
- was reoh no fdjizm with his timing again!!!
- Hydo-Charger. everyone check this out, link inside.
- Honda-tech.com login password problem?
- ls Vtec ecu question
- engine mount need help EK 98
- converted from auto to 5spd but now just cranks(97 civic ex)
- Bogging down D15B8, burns oil, runs rough, intake sounds funny....?
- whats the deal??
- HELP WANTED: Someone local please show me how to do a valve adjustment. Maybe timing belt?
- TW: CTR trans on b16a2
- spark plugs for turbo sohc vtec ???
- 62mm TB on a lightly modified D16Z6?
- engine harness
- Finally Have the money for swap..Need Direction
- Car stalled while driving, need help!
- Replace Rear Wheel Bearing and not Hub?
- b16 for $1800 need input !?!?!?!?
- MA State Emissions on a B16 - Which cams would pass? ITR? Skunk2 S1?
- b18c5/6 fuel rail & fpr on b16a
- hi Everyone
- Car turns over but doesnt want to start!!
- new suspension setup
- Throttle Bodies.......
- radio code for 2000 SI
- Exhaust Question about tanabe hyper medallion or apexi ws2
- Paint Schemes
- What catback exahust should I run on my 94 EJ DX Coupe?
- How to check the year of the Engine
- Difference between GReddy EVO2 and EVO exhaust?
- What are these for ?
- Pay Omage to HT
- ITR simply quit and now won't start?? Need some advice...
- 93 Civic VX Wiring
- Fuse Box Relocation Questions (Searched)
- how much to reinstall a/c to my 93 civic cx.
- What Headgasket should i use
- Bolt size for rear T bracket?
- Help With USDM B16A2 Swap
- Turbo project
- Exhaust for 2000 SI w/ turbo
- Air Condision Help
- Picked up my first eg.......bone stock 94 CX!
- head gasket?
- do they make this lip for 99ek
- d16z6 bored 20 over or d16y8 for turbo
- vtec pressure switch
- 97 Civic HX - Fuel Gauge
- disc brake conversiton on civic ex
- lights acting funny ..wut you think??
- clunky ride
- ek 96-98 front end quick question....
- Need help connecting OEM door lock switch to aftermarket actuators
- Question about installing a/c on civic w/ LS motor
- ok so i ordered depo fogs and have a (Q)99-00 civic yellow
- would the knock sensor cause vtec not to work??
- 95 Ex fog light electrical problem!
- Need some info about compatibility.
- looking for cleaning the stainless header...
- Resistors? How to wire?
- kit // lip
- 92-04 civic clutch the same?
- ek tweeters
- Civic Lowering?
- gsr hatch questions
- would the ff-squad ckf (crank angle sensor) bypass trick work to pass emissions in CT?
- JDM Sidemarkers
- code 9...
- Civic hard to start when gas low?
- Looking for motor...please help
- dyno b16a yesterday
- Tokico HP's "blues" with Tein S.techs
- thin line
- Quick questions about GSR swap
- WTB: 1999-2000 Civic Si LEATHER SEATS
- tranny problem
