View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Difference between a P32 and a P08 intake manifold?
- throttle body h22 to gsr
- quater mile times...
- My car falls asleep?
- port and polishn a ek 97 ex
- Info needed On Optional "RARE" oem eg6 sideskirts? any pix? or info . . .
- del sol shift linkage PLEASE HELP!!!!
- wiring diagram
- lips for del sol
- cel at red line in 3rd
- This winter was rough on underside of '99 EX sedan!
- 92-95 civic si wiring harness
- b20 vtec?
- Grinding/Humming sound when turning on
- low speed stutter/hesitation
- How do i add refrigerant to my civic?
- Air Conditioner Mount Part, where to get it at?
- quick question
- turbo exhaust?
- Need firing order for 95 Civic EX
- Power Windows and Power Mirror Not Working?
- 3k miles or 3 months?
- VSS WIRE HELP!!!!
- constant or switched 12v for power mirrors?
- ECU Question
- broken brake booster
- whats the best drop for an EK height wise
- Anybody used Posi Quiet brake pads?
- Excess heat???
- LOUD noise,idle jumping up n down...wats problem?
- engine trouble. b18b wont start/idle
- Door stuck
- QR steering rack for 96-00 civics?
- 92-96 or 98-00 HELP!
- Car idles really low but does not die?? Need help!!
- my tires rub <sadface>
- po420 ej8
- Knocking sound coming from driver side wheel??? Need help!!
- GSR Throttle Body??
- planning on buying a del Sol .. need pics
- I have low compression in my gsr motor
- 92 hatch turbo . need help with injector question
- What EK swap will pass bar?
- ecu plug wiring questions
- what size tires for rotas
- which tranny for turbo civic?
- help, problem with car, b18c1 ek hatch
- Getting a new rad, do full size 94-01 teg rads fit my EG?
- VSS harness wiring
- Best ECU?
- 4 bolt ITR
- what should i set my toe at??
- civic hb fit civic coupe
- auto swap question
- anybody want to buy a turbo kit for 1300
- Compensator Arm Nightmare!
- climate control help
- Del Sol Turbo...
- RHD conversion Shops in SOCAL????
- b16 timing question...
- do you think the RSX steering wheel would fit on my EG6?
- Del Sol Conversion... NEED HELP!
- DIY Prime Job...
- Itb's how much hp?
- What size rotors on a 94-97 del sol VTEC?
- HELP! brakes are really soft
- CRX si clutch on a eg si hatch?
- Trouble starting stock 94 coupe
- map sensor question for an ek?
- How to fix rounded head Bolts?? Need HELP!!
- need help about suspension
- Quality, Reliable Car Alarms?
- pic request: gunmetal 96-00 civic coupes
- How much is my car worth?
- Anyone knows 5wire oxygen sensor wire diagram? Thanks for the Help!
- compression testing. I already searched
- How much should I pay?
- Need help on power lock location plz
- QUESTION LS/vtec?
- 205/55/15 Too Big For "EK"?
- whats the best height drop for an EK
- Question ITR 5-lug
- EMISSIONS NIGHTMARE PLEASE HELP!!!
- eg6 vs. ek9
- pics of some 16"s on your rides......
- Alternator quick fixer or just replace?
- anyone use this exhaust?
- hp numbers
- First car...
- HELP::Remove a Starter
- B18B1 into 99 civic ex
- What engine swap should i get?
- HID NOOB!!!!!!!!
- b18a1 question.
- 93 CX / d15b7 / will a vx exhaust manifold pass smog with this?
- alternator issues HELP!!!
- RSR Exmag owner confirm this
- what exactly is it called ?
- WHAT LIPS YOU GUYS RUNNING?????
- itr pistons on a b16
- Thought the throwout bearing was bad and found this....
- Z6 FPR ON LS!!!!!!!
- Valve cover painting question
- **97 Ek Front**Mint**RED**00 GSR AirBAg**PIXx
- type r in a 2000 civic si
- type r motor in a 2000 civic si
- blox 21mm rear sway impressions....
- Steering wheel lock broken
- HELP! PLEASE!
- what ya think of my build
- My car wont start!!!!
- Del Sol Window Visors
- hyperduck tuning
- eg hatches prewired for vtec?
- quick question about wheels/clearing breaks
- how do i wire vtec in 93 civic dx
- Which side is the exhaust/intake?
- feel so much slower..
- what do you guys think?
- steelies weight?
- LS swap?
- suspension..
- Where to get a/c line for a K20A in an EG?
- d15b jdm vtec motor swap
- rear engine bracket confusion
- hmotorsonline.com shipping price??
- hate to do this, and i apologize in advance, but......................
- gsr sway bar on ek.
- Gauge Cluster lights don't work or fade in/out
- b16a2 swap, half of del sol cluster not working
- OEM Radio
- Vibration underneath car and exhuast got louder....
- What sort of parts are involved in a engine overhaul?
- Vtec Swap
- HELP, Carbon and fuel/oil in cylinder 4 only, whats that mean?
- Noticed unpluged plugs and no bolts through mounts underneath my car. This bad?
- coolant/engine leak help..
- Brake upgrade : Will TypeR BOoster fit with RS master cycl?
- 01 JDM ITR 5 Lug Conversion, BENT TRAILING ARM..!!
- check engine light on for catalytic converter.....PLEASE HELP!!!
- 92 95 hatch central locking
- Dont KNow what goes there or what happen
- ebay fenders and bumper
- Suspension Differences between 99-00, or differences betweenLX-EX?
- Will the 94-01 Integra rack fit EK?
- exhaust question
- si, s2000, or rsx key in ek
- my 98 EJ6
- 2000 Civic Ex Coupe, gas pedal seems sticky
- half radiator help
- 93 SI - Power door conversion
- DIFFERENCES BETWEEN 99-00 EX AND 99-00 SI
- radio question
- car bogging when vtec kicks in.
- what jdm engines are legel
- Headers for B16 with GSR head on 96 EK
- Factory Rear Speaker Wires on '94 VX?
- D15B into a 94 EX...direct plug in?
- a little smoke
- spedo, vss, cluster?
- EG door visor install
- So it looks like I threw a rod...options inside
- 92 Si E-Brake Cable
- Removing sludge from engine?
- wheel offset...
- rear tie bar bolts.
- Exhaust Question
- Time For A New Clutch
- Ideas for EG Hatch Race car
- check this out
- JDM D15B
- Leaking oil from dizzy HELP!!!!
- Changing Transmission
- Would EK Center console w/ armrest fit in an EG Hatch.
- J1 tranny is it a b16 tranny?
- New here... need some assistance please.
- tps wiring
- Help: Tire rubbing
- d16z6 head onto a d16y7 / d16y5 / d16y8 block OR d16y8 head on a d15b7 / d16z6 block HEAD BOLTS STU
- Another idle problem
- help with mini me!!
- Question about the VX Oxygen sensor
- Need Help With Side Skirts
- TSX Seats in an EK
- Distributor timing
- D16y7 Motor Problem
- need some help with my head!
- Over reved???
- ek column/ignition light question.
- vx hatch o2 sensor??
- I smell gas in my oil... help
- throttle cable is loose? (need help)
- HELP: can anyone help me install my airbags? (so. cal/north OC)
- where can i find the tranny code? (searched)
- Battery relocation to the rear.
- Greddy SP2 Vs SP difference?
- HKS D16 cam, fit in a D15
- Anybody wanna help me out with a carfax report?
- Squealing =[
- can a loose timing belt kill power
- what are the torque specs on the oil pan, and oil pump, i searched
- looking for a complete engine!
- im puttin a b16a1 in my hatch and i had to get a timing belt so i got a 94 de sol si dohc and i was
- bad throw out bearing?
- I got a timing belt for a dohc de sol and i was puttin it on my b16 will that work
- is there a dohc si modle?
- Head problem
- Weird engine smoke not all the time??????? Please Help.
- does the 94 de sol si have vtec and is it a b16?
- Do 96-00 Tein S-Tech springs fit 92-95 Civics?
- Auto to manual DONE!!!! problem need a lil help please
- need info on d16y8 into eg hatch
- Sway bar question!
- Interior Drying Thoughts
- Wierd problem need to fix quickly
- What ECU for B16a2?
- JUST CHANGED WATER PUMP/TIMING BELT nothing changed
- just changed alt and now battery light is on
- bent or bad valves??
- Can I use the Emission Purge Valve on my CX manifold on my EX?
- Uberdata or Chrome???????
- Fuel pressure gauge need HELP!!!!
- Bad Valves???
- alcohol D16y7??
- Wiring harness help-jdm b16a sir 2 in a dx eg hatch
- My fender is messed up...which repair route to go?
- Cig Lighter not-working / Armrest Ebreak trim
- gsr help
- G35 coupes STOMP on CIVICS!
- Remove Door Pin?
- Grinding/Scraping Noise when Driving/Turning/ Low RPMs WTF IS WRONG WITH THIS CAR!!
- Ignition problem with d15b
- wtf is the big silver thing across the rear bench in an EK
- How to tell the difference between a bad head gasket or bad piston rings?
- Coolant leak, need help (pics) pls
- my 1/4 mile times last night
- Please help with brakes!
- cat abck burning up valves
- d16y2
- Which exhaust for EG w/ Comptech Rear Sway/Tie Bar Combo?
- ticking sound at start up?
- would this sound retarted?
- question on eg bumpers
- clutchhhhhh people
- engine light codes.
- i can get a cheap hatch, but hit in front, crushed shock tower...question inside
- HELP ::: car kept dying last night !?!?!??
- What to do with $?
- Soft Gring/ Pulsing Noise from front end - WTF could it be?
- Rim HUB bore too small????
