View Full Version : Honda Civic / Del Sol (1992 - 2000)
- 1993 Honda Civic --- Unknown Problem [yet]
- horsepower
- new guy, eg hatch
- Battery/alternator Issue * searched*
- Everyone With an EK open!!!
- Rapid Clicking Relay...After battery Died
- engine swap issues
- OBD1 V-Tec Wiring Diagram?
- how do you take out the windows on a honda with out breaking them?
- AEM intake filter ?
- Zc Motor!!
- lsvtec build oppinions
- read if you know about stuff
- New member but cirtainly no newb
- code 14
- Swap SMOG question
- EG(B18C1) trouble
- Just picked up some mudguards, Have a few questions..
- Turbo Question
- new here
- Tein basicdamper kit
- ***TIRE SIZE HELP***
- What is this part/missing part? (D16Z6)
- Sedan Seats?
- new dizzy. trouble installing. quick question.
- Problems after GSR swap
- 95 Civic
- lowering car without coilover wrenches
- pre turbo install
- axle help!?
- help me!!
- stiffest chassis
- Energy Suspension Bushing 89-95 civic/del sol rear lower control arm
- heater issue
- New Autotech Driveline WavetracŪ Differentials LSD Cars Wanted!
- will sohc flywheel bolts fit a h series?
- gsr swap, distributor wiring plug is different
- Integra Side Skirts on a EG
- Z6 Trans/ECU code???
- wire up a vtec on a motor swap
- b18a swap question?
- no power to fuel pump and no spark
- cluster and o2 sensor problems on jdm itr swap into 96 cx hatch...
- Question about CEL
- Stolen 1994 Civic Dx Southern California 500 dollar reward...
- HELP i want a eg civic either coupe or del sol.
- 99-00 Civic's with aftermarket head unit
- need help!!
- oil in my radiator resevor
- Can someone explain the JDM terms - EK/EJ/Etc?
- Axle back and Tranny swap QS
- 2000 civic b18b1 swap NEED HELP
- b20 swap
- how can i adjust my clutch
- stumped and need help
- need help!!!
- Window Regulator
- 2000 CX and 2000 DX
- cel code 0 ?????
- Oil Pan Baffles
- New Dizzy - No spark ?? HELP PLEASE!!
- b20 block b16 head turbo question!!
- rim leak
- mini me swap i guess help
- vtec oil pressure switch
- will 1996 gsr starter and alternator fit on a 2000 honda civic si
- California Enthusiasts, Please Respond, Trying to get a Yearly Smog Check
- head gasket work and then some
- jdm cluster light.....
- Greddy Sp2, cheapest place to get replacement gasket?
- Just about finished, what else can i do
- gsr in cx vacuum help
- Higher RPM's on a 5 spd vs Auto
- OK WHAT DO I DO NOW? fuel pressure regulator????????????
- need help with lug nuts....
- VTEC Solenoid Problem/Question
- D15B7 troubleshooting exercise and welcome post.
- Hood dampers
- B16A obd2 help
- Civic hatch axles, HELP!
- 96 usdm GSR swap
- Quick Question
- need help with rpm/ tach signal for gauge
- i have a question?
- pic request black ek9
- Anyone swap an Integra radiator into their EK?
- Check Engine Light 61
- Oil Leaks / Oil waste and Blue Smoke
- found this bumper in a garage....should i put it on .. or sell it.. not sure what it came off of ..
- skunk2 short shifter
- Fuel Pump help!!!!!!
- IS THERE AN OEM 92 to 95 CIVIC CD CHANGER?
- I need simple wiper help
- Oil in intake
- can i swap a iacv from a manual intake mani to an auto>?
- Swaping front end on 92-95 civic eg 4door
- changing distributor
- 97 Del Sol Power Mirrors not working?
- rz 0088 main relay
- ek for teg?
- emission problem
- which intake should i use with b18c5 swap??
- question on d6y8 intake manifold (searched)
- whats so bad about salvage title cars?
- Does anyone know where to find an older VDO tach?
- piston questions
- where does this plug go? pic
- speedometer
- So i got a ticket today,can i fight it?
- broken and striped bolt PLEASE HELP! NEED CAR FOR WORK!!!
- SI Cluster help
- help on gsr strut bar
- buddy club spec II question
- are these coolant lines in the right place? pics inside
- clutch has excessive slack. won't even go into gear from a stop.
- idling issue after headgasket replacement!!
- K Swap Newbie questions
- wheel offset
- Need An Exhaust. Any Ideas?
- Fuel and start problem?
- RPM Problems
- del sol mud flap part #
- overheating problem on my EG...need help?
- Question which motor?
- Swapping out old radiator with a jdm DC2 or EG6...will it fit on a USDM EG Hatch?
- need help!! is this the right car for me?
- EXHAUST ?S
- HELP, OVERHEATING...IM STUMPED. civic cooling system just a topic post noob, 5th H-badge
- How to clean idle valve control
- Car jumping when first taking off.
- front license plate question
- NEVER DONE A SWAP BEFORE. **HELP!**
- Problem with battery when the weather is cold
- motor violently shakes, dies after plugging iacv hole in TB help
- B16 gear box oil
- A how to for removing the TPS?
- spark plug of cyl 3&4 smell like gas and are wet car wont start
- Toda B's in b16a2, searched already, still need answers....
- Running on 3 cylinders not sure why????
- jdm fog light install.....
- motor swaps
- Question about throttle cable and bracket?
- Just bought her yesterday let me know what you think
- It just died!!!Help me Honda Tech!!!
- hot engine, hot valve cover, hot manifold, will i be safe?
- good deal?
- overheating problem HELP!!!
- 92-95 civic 4 door brake question?
- When headlights are on. I have no driver brake light.
- Question about stock injectors?
- 1992 civic d12 no pick up ..what should i do
- OEM 99-00 Raybrig HID plug and play
- IAT wires...
- 96-98 air cond console/centre console - how to remove?
- 96-98 SIR Coupe Bumpers.
- speedometer is not working
- Car sputters ,bog and drops in idle.. b18C
- Sway bar brands pretty much all the same?
- a/c lines and oxygen sensor
- wheel rsx steering wheel fit 99 si steering rack?
- Too Rich ,Failed the EPA test....
- Help me identify these injectors
- Can anyone help me find depo headlights for the EG?
- my gauge cluster took a crap today...
- H22 SWAP IN '00 CIVIC
- Question Bout stereo in a civic!
- CAR WONT START OMFG
- Transmission swap from 5 spd to auto
- Timing mount bracket?
- new law ???????
- fuel pump wont STOP priming
- book on auto to manual swap
- Which ecu do i have
- SI Cluster Problem??
- del sol fog lights
- Will these rims fit on a 97 civic?
- saying hi all, new to the site...
- I need to replace my fuel filter...
- Importing RHD cars from overseas
- EG Engine Build Question
- Top Speed?
- Crank pulley ?
- VSS Interchangeable??
- Stock Civic Prop Valve Diagram
- clutch? hydraulic? no pressure help!!!
- 93 Civic Service Engine soon light Wire
- Break Conversion for 95 Civic ex (Searched)
- I need some help
- Black stuff from exhaust?
- Clutch slipping need comformation
- Looking for Del-Sol pictures
- 93 civic R134 conversion
- How can you manually roll up an auto power window?
- b16a3 problem
- AC Compressor Question
- belt squeek?...can someone help please?
- advice on rebuild
- FITV - b16a2
- problem starting my car
- a/c compressor??
- need help!!!
- CEL CODE 43 HELP QUICK PLZ!!!!
- JDMCARBOY.COM
- JDM GSR vtec solenoid question
- can someone help me real quick....
- radiator question
- help identifying this sound
- maf sencor???
- Question about slim fan wiring
- tri Y headers would you buy?
- dropzone coilover kits
- Fuel Pump problem
- Havign problems with 95 civic
- Axel/Drive shaft compatibility issues
- Rear Disc Conversion???
- gsr in 99 si throttle cable problem
- d15b
- spitting motor..PLZ help!!
- no fuel into the engine help please?
- Weird brake issues... I need help
- will an eg6 cat back fit my sol sir
- Using CTR ECU on a ITR Motor?
- Car won't start
- B16B CTR motor in a EG, I NEED HELP
- sir lip question
- Swap a D16Z6 for a D16Y7?
- Undertaking 97 GSR swap into a 97 DX
- B16a2 tech
- Third brake light??
- 92 Si Cranks, No start
- integra front end
- 00 Si or 93 Lx
- Help: Broken wire
- 92 eg h22 swap
- Double Din in 00 Civic?
- Crank Pulley
- B16A2 with CTR EK9 Pistons for Daily drive
- b16 Tranny is making noise
- Coolant Bypass Hose
- How to get 70mpg highway and 55mpg in town.
- swap info?
- 0BD1 TO 0B0 BLOCK???
- si front control arms and swaybar
- bad alarm remote?
- Will Tower Bars from An EF fit an EG?
- Will Tokico Blue EF Suspension Fit An EG?
- civic 19 ex cam shaft
- will open end extended lugnuts rust?
- 94 ls odometer/trip gage not working
- auto/manuel axle question help
