View Full Version : Honda Civic / Del Sol (1992 - 2000)
- price for tires
- ?How to intall EK9 power folding mirrors?
- Dremel and intake manifold
- Shock mount Nuts (vent)
- D series upgraded valvetrain ?
- what's been keeping me busy with my car....stripping!
- OEM FOGS
- WANTED: GSR LEATHER SEATS
- Integra Type R Brake Conversion Question
- pic request: 96-98 red hatch on bronze slips
- short ram why not just a filter?
- 99-00 Civic Si Transmissions
- Which fuse is the vehicle speed sensor fuse under the dash board for a 2000 si
- got eg hatch need help installing Camber kit..
- tach question
- 3rd gear grind after new clutch
- custom exhaust piping for an eg hatch...?
- 5 zigen axle back
- Noob question
- How is the fitment of a cf hood from fiber images?
- Removing stock airbox unit off a 03 civic?
- bore size?
- gsr cluster into a 92 hatch
- how long does it take to replace a lock cylinder???
- technical aspects of owning turbo d16y8 vs rebuilding B18B...
- where can i get a flange for a JDM header?
- 91 Honda Civic Hatchback work on a 92 Honda Civic Hatchback?
- type r replica strut bar on DX.. Question
- my ek ...just got painted.....
- Exhaust Bunper Heat Shield for civic
- what throttle body for my jdm h22a?
- cable clutch...
- Any good site
- gauge cluser ?
- sum pics of the aebs like yall wanted . . . sorry took so long
- Sway bar or no sway bar
- engine problem!!
- what rear strut bars are u eg guys using?
- Will my 18 Inch TSW's fit my 97 Civic?
- y7 throttle body on y8 manifold
- Sway bars for 96-00 civic
- EG Auto to Manual Trans. Mount
- White smoke and rough idle on Civic
- Where to get Es Ovals?
- question
- Help! sites to get type-r engine parts.
- Fuses for Ignitions
- brake pad problems
- Wiring 99-00 OEM Fogs into my 95 Civic with 00 front end conversion????
- S2000 muffler on EK
- suspension troubles
- 94 GSR swap in a 98EK how hard?
- DSM Fuel Pump
- anyone have any EK pics with black bumpers
- DC Sports cat back question???
- Springs/Shocks Or Full Coil Overs?
- Thanks GroundZero
- Do these aem pulleys do anything?
- CEL after VAFC install
- How much horsepower will stock civic motor handle?
- TB questions???
- JDM b16 into EG Hatch Auto
- how many of u guys run just the lower TB cover
- JDM sidemarker placement on EG???
- Squealing belts?
- Advice question - What should I do next?!
- ? on tanabe hyper medallion
- type of exuast?
- distributor install
- Timing belt and timing Marks
- EG Big Brake Photo Request!
- p28 ecu on d15b setup...
- Tein SS Coilover after install question
- Comptech ice box
- Ecu help
- NEED HELP PLEASE!
- Little problem with timing... dizzy
- driving with a misfire
- Installing the head 1.5L auto Problem?????
- primary o2 sensor high voltage ???????
- Civic Shift handle thread pattern
- rear wheel drive hb
- Car won't start help plz
- race gas 103 octane in stock motor?
- clip troubles with headlight install
- whats the point of jdm suspension parts?
- Shopping List..
- Where to buy OEM front and rear lip for 99-00 SI in EBP?
- Backseats??
- eg wheel suggestions?
- d manifolds
- JDM ITR 4-1 header
- How is it the rear LCA being is able to be changed to the ITR one without doing the 5-lug Convo
- any company that makes aftermarket 99-00 si endlinks?
- BEST Suspension for a Civic
- Looking to buy a RHD Civic HB......
- ok I need some help!!!!! OBD1 WIRING TO OBD0 COMPUTER
- traction bar came in today...
- please help - disappearing coolant in new jdm sir II b16a
- Which is the best swap???
- Gauge cluster question.
- 95 civic coupe with B20z what CAI setup
- Jun cams.. (Already did search)
- H & R Race springs VS Skunk 2 coilovers????
- 03 civic seat????
- How thick of motor oil is best for my new 30k d15b?
- D16Y8 head installation Question
- 99 B16A2, driven hard from day 1, worth it to build?
- What Brand Plugs?
- 2001 honda civic
- Question About My Exhaust????
- Any Input Here...Foglight Question....
- Engine weights.....
- Rain troubles ...
- oil preasure!? d16y8
- question a cx swap?
- vehicle speed sensor
- what is a mini me swap?
- K20?
- I needsa some help with my 94 EX
- looking for ctr parts for sale....
- intake silencer?
- Look at this 2000 SI!!!
- GSR seats in an 02 Civic Coupe??
- clamp load - clutch
- what do i need to get for a gsr swap?
- 94@up cluster on a 92si hatch?
- need help diagnosing problem
- what tires ?
- Flippin Airbag
- EBay Rear camber kit (not the washer ones)
- Idle rpm's dipping
- what ecu do i need for a d15b 3-stage v-tec?
- hondata manifold gasket
- sunroof wiring help?
- is anyone from tacoma wa?
- B16A 92-95 (SiR-II) help.
- LS tranny, and Flywheel..
- Dizzy and TDC question
- tuning question, advance/retard
- LS a/c braket for a B16A SIR II
- sir question
- help me
- i need a good clutch and pressure plate for my civic. SI TOP, LS BOTTOM, SI TRANSMISSION<>
- Question about an ITR TB on my B16
- y0! who would win this race?
- what can cause the flywheel to worp
- problem with intake..
- Zenki Lug Nuts
- f20b or b18c?
- Question about accessory fuse locations
- SPOON YELLOW???
- crower cam camshaft skunk2 zex
- anyone got rims+tires for sale?
- Please help
- tranny
- Will skunk2 camgears be a good upgrade on my d15b?
- wat is the best tranny for a b series
- Is the aem v2 cai better than the original aem cai?
- TSB 92-050
- Windshield Fix
- b16 civic hatch for sale
- Mid Spoilers (searched)
- Clicking noise driver side dash
- May issue of stuff magazine..spotted an EG..
- Idle Problems on Del Sol D16z6
- Support a Fellow HT member...
- get rid of powersteerng my ek or get the bracket and pump??
- 15" civic steelies
- Found a 96 CX 5-speed silver hatch for sale in Texas
- Bolts Question
- wat is the best b series trans
- front lca thread stripped. HELP!
- H&R springs question -->
- Stock DX brakes? Good enough for my street car?
- oil coming thru dizzy
- Suddenly my car wont start! Please some one help!
- after valve lash, power lossed
- dry ice...
- Motor/swap question
- help!!! what ecu do i need?
- eg brakes quick question?
- NEED A D16Y8!!!!!!!!!!
- It's good to be back on board.
- Thats right...need advice about going from MANUAL to AUTO
- Will my 99 Civic, with cold air intake pass smog?
- can someone decode this paint code into its name
- What would you do? EG6 with new piston rings...
- FS: Spoon Hood/ Spoon F+Lip
- Mini-Me User - I Need Your Advise
- ek locks..
- springs making noise!
- Horn Trouble!
- want to see 6x9's in your eg hatch
- What's MC and how do you bleed brakes for a 98 honda Civic?
- looking for a b16a
- Prelude brakes on a EK
- I need advice quick!!
- Will 92-95 shocks fit on my 96 hatch?
- a REAL BAD tranny problem need help asap please!!!
- Tire Question
- Need help finding a part*
- Splinedrives in stock whenever you need em for $60 bucks, but I got a question
- ecu pinouts
- Possible Air In My Brakes...............Please Help w 98 Honda Civic
- Which MC and Brake Booster do I need?
- Exhaust question
- Evap Purge Control Solenoid Valve Help (Searched Archives - still feel dumb)
- will a 92-95 header fit into 96-98 header?
- Would a chipped p28 work well with a d15b?
- apexi jdm gt spec header
- Jdm D15B swap checklist
- Piston Rings HeLp!
- i hate deer
- would a 4 door dash fit 2 door hatch????
- What Engine for 1999 Civic Si?
- need del Sol turn signal housing ASAP
- CIVIC HOOD
- Import Auto Salvage.com Is Officially Godlike...
- Vouch for EK4door
- help......
- '99EK foglights on 95EG
- Rear Upper Strut
- 1989 240sx Seats into 1996 Civic Hatch
- VIN tags on tranny?
- tranny bolts...where do i get these?
- manual ECU for auto to manual conversion?
- Need Instructions...clear head lights..
- Another BADASS creation brought to you by K20EG's mounts......
- broken IACV??
- rota rb's on a eg ?
- Door panels rattling
- Tranny question
- b series shift linkage on a d?
- in your opinion....
- Anyone have an A/C harness?????
- A 92 si hatc is it possible to get one for 1k?
- Post SECURITY options for everyones Rides here...
- buying o2 sensor........
- si cluster in ek
- having problems with 92 hatch, HELP!!!!!! so what do i do now?
- Will Integra GSR leather seats fit?
- WhERE TO BUY A MOTOR
- Center Caps for Ls Webs?
- K20 Swap into a EK
- p28 pinout.
- another hatch stolen
- Spark plug wires are a bitch..
- Theft repair question..
