View Full Version : Honda Civic / Del Sol (1992 - 2000)
- New to Honda-tech But not to da Honda Game!
- is it normal to have black carbon buildups on top of pistons???
- Needen some input
- What gauges match the factory 99-2000 si cluster gauges
- i think i need a different ecu
- ||nubbz||( new here)
- clutch pedal sinks to the floor on my 95 civic hatch, need advice!!
- Just Bought an EK what Oil?
- silver ej8 what kind and color rims should i put on it??? pics inside
- 92 sedan removed power steering, having some problems
- overheating with ac on?
- need help check engine light p0202 car wont start
- Apexi N1 B pipe will stock axelback bolt up? NEED HELP ASAP!
- Just looking for feed back on an Idea for my EG
- Cradle shift question/Alignment question
- b series swap question HEPL!!!!
- CEL Help & Possible Head Gasket Problem
- Need minime wiring help asap
- "diesel" sounding noise since water pump was changed
- Can i pass emissions with o2 simulator????????
- idle problems
- EP SEATS???
- HELP!!! D15B. Need to make 'Carb' legal!
- cable b16 gears in an hydro ls case
- 94 Civic Vibration
- looking to polish my ASR subframe brace
- 2000 ex trans swap
- base maps
- The difference between Short ram and Cold air
- What REALLY goes on when you bring your car in for service??
- VTEC issue
- hiding my brake lines?????good idea or bad?
- Si/Ex shift lever...
- code 43 help
- b16 swap into a 98 ek hatch exhaust problem
- My newly lowered VX
- Blown Headgasket?!?! Opinions needed!!
- New to the Forum
- Big brakes for 99 si ?
- integra 94-01 gas tank swap into civic 92-95
- throwing cel code #45 on 96 DX, need help
- Hondata Intake Mani gasket!?!
- what do u guys think of my ride?
- A/C problems
- 95 civic ej1 car wont stay on
- non abs hubs on abs car?
- 95 civic d16a GA emissions problem
- Rear-Ended; New Bumper?
- srs light
- bad idle???
- New to Honda-tech But not the honda Game!
- Acura EL C.Control into EK
- clutch not releasing
- Tape-on side moldings
- EG6 JDM Duck bill
- help power window off track
- GSR cams
- Wing and Rear Lip Install...Help
- ENGINE EK HELP D16y?
- 96 HX, no ac?
- Will the codes make it so VTEC wont engage?
- Car died and won't start?
- Honda delsol weather strips. Please Help!!!
- WHAT OIL
- What color should I paint my EK? 56k!!
- type r motor in a eg parts..
- Brake light (tailight)
- New guy
- 92 hatch with auto swap and h22a install
- Outside diameter of CV joint -- Help!
- Hondata into a CX
- LX Cluster in DX Civic ?
- Mystery plug?
- Quick question: Which header should I get OBX, megan racing, SRS? under 200 budget.
- Tuning a 1996 Honda del Sol
- B18C IAB wiring into EG Civic problem
- DOHC ZC OBD0 to OBD1
- honda hatch back dx mod help
- ignition and steering column question! HELP!
- b16a2 pics!!!!!!!!
- d16y7 vs d16z6
- my a/c kicks on and off, it blows ice cold, is it normal?
- Hybrid B
- help me id this part
- airbag question
- Anyone living in Virginia wanna make a buck and help me out with my car???
- turbo civic overheating?
- will i need to be tuned when running itr cams in b16a3 with I/H/E???
- h22 in ek
- need help its a lil more than a miss
- d16y8 into a 97 dx hatch
- A/C making weird sounds
- Ever delt with these guys before?
- HELP windshield wash not working?
- MSD HELP PLS
- Help with CO emissions
- mini me swap surging
- I'm confused, please show me what oil pan I need!
- JDM Lowering Springs 92-00
- safc throttle problem
- Auto VS Manual
- fuse blown, any particular idea of what might have happened?
- Rewire reverse light on a convertion?
- Question on Part Removal
- Need ECU Help With D16Y8 Swapped EG Hatch
- skunk 2 inlet manifold question?
- engine vin...help
- Low Voltage at the injector clips!!
- 99 civ.ignition switch recall/info help...
- Was my gas mileage a fluke?
- 95 civic headlights
- B20b in a 92-95 civic
- quick wire question
- Engine oil going dark after 30miles
- Car stalls during idle. Help!
- 95 civic power and lighted mirrors
- 99 Civic CX A/C issue-It's hot out!
- EG Ignition Question??
- Ecu Help (P2E)
- Del sol swaps help
- Issues with 97 civic
- alarms....
- Stuttering under 3k RPM
- Best motor oil to use
- Broken Upper Strut Bar Stud, need some help
- mugen lip without pockets
- Can bad axle cause alignment problems?
- Remove lower dash cover panel?
- Help! Stolen 93 EG! License No. 3EAB062
- Intermittent prob in my 93 4dr ex... help me out
- Steering rack compatibility
- What is the best engine swap for me to do?
- New Del Sol Build- Swap questions
- Power Window Regualtor Question
- Need Help
- will a 5th gen prelude steering wheel fit my 98 civic sedan
- wtb-oem ex/si lip!!!!!!!
- t1r test pipe
- koni/GC horrible noise over humps
- Need help with minime asap
- What's this?
- windsheild wiper problem
- Can someone explain this.
- ??? rpm stock???
- Question about CF trunk lids: HELP
- MOTOR SWAP GSR into 96 civic
- fuel pump going bad???
- Parts to Do the swap
- new projects - need advice, please
- some pics as promised - headers + valve cover + lip
- 95 civic ex gauge cluster
- What mirror is this?
- LS motor swap.
- Ek fogs on an eg bumper
- Antenna block off
- obd2 b16 convert to obd1
- Front Brake upgrade choices for EG
- right blinker and right stop lights dnt wrk
- Civic scraping noise in Reverse gear
- Need some help, cracked exhaust manifold
- Need pics of eg stock black interior
- 2000 Civic Ex Performance/Maintenance
- O2 sensor question
- 12 volt wire cut
- City Lights: What kind of bulb
- i need evap system canister diagram
- TB help.
- problem with rear bracket
- h22 vtec specs
- spare bolts for b series motor??
- serious suspension problem!!
- oil in spark plug #1-2 not 3-4
- weird civic driving problems
- '00 Civic - Motor Bogs Then Sudden Renewed Power ?
- no power on new motor
- LS will Idle, but wont drive...
- front sway bar from em1 si in 97 civic ex?
- [HELP!] '98 civic, heat/radiator problems
- SOHC HELP!!!!!!!!!!!!!!!!!!1
- 98 integra camber fit 93 civic? tires wobble?
- Didn't want to start.
- 2 Problems, 1 Car: Shut off, and pulling hard right when braking.
- Choosing the right HB
- 98 Civic EX idling difficulty !!Help!!
- best turbo for the job
- Car alarm issue
- gas gauge problem
- Code 3 Help
- mixing trans fluids?
- Help with poor mans type r swap!
- gsr swap, evap wiring?
- O2 sensors
- **cluster / gas pump doesnt turn on ***
- Does oil expire?
- 92 civic bad gas
- 92 civic lx 1.5 5SPEED CONVERSION
- EG cat-back exhaust on an EK ... can it work?
- Tri-y header vs Rmf header
- knocking sound
- Will an AEM Intake fit a B18
- Happy 4th
- New to HT
- Header stud question
- 93 eg wont start
- few a/c removal Q?
- FLOATING GAS GAUGE??
- gsr going turbo 1 question.
- question about 96 "civic" and "cx" badge
- I'm stumped- alternator belt broke, and car shut off
- Cheapest Performance CV Axles For a 94 D15B Civic?
- looking to attend any car meets in cali
- Calling are Green 96-00 civic pics and what you got :)
- 92 civic dx 1.5 auto tranny shifting issues!!! HELP!!!!!!!!!!!!!!
- Clutch Disk
- Fuel pump dead??
- Timing
- 92-95 civic non p/s crossmember same as integra?
- What makes the gsr brakes better then an eg ex brakes
- my car is making a weird and annoying clinking sound!!
- 225's
- 94 hatchback eg cel code
- gauges in gsr dash
- Evap wire. B16a going into 97 civic ex auto.
- WHP estimation
- z6 block y8 head
- b16a engine code
- Yakima Q Stretch Kit Question: 99' 2 door coupe
- Any tips to make new lip hug bumper better?
- Input shaft bearing and Seal Replacement
- Coilovers or Lowering Springs
- Removing side panels from 98 sedan?!
- 8 TDC - top dead centre sensor... were is it?
- CEL Help
- 92 b 18a swap in 1996 civic hatch
- which cat back exhaust is best???
- 99 si with b18c. runs great at first then when it warms up it runs like poop
- jdm vs. usdm
- Any idea how to repair rolled QP and fenders????
- Doughnut Gasket Question
- question about oil weight
- Alternators and Starters
- installing manual shifter into auto eg
- '99 Civic LX Exhaust
- Can factory a/c be installed in 95 civic easily..
- need help in installing steering wheel
- bar swap complication
- HELP H22 ek idle!!
- stupid question i know
- Ek wing
