View Full Version : Honda Civic / Del Sol (1992 - 2000)
- does a ITR AEM COLD AIR fit an EG w/ B series motor??
- detailed instructions on how to chip a p28 and p30?
- Gas Smell
- EG Civic manual to automatic swap help?
- 99 civic HX
- Any Video's?
- Type R Wheels on EJ?
- D Series Header Install.
- What clutch?
- Diagrams for stock Civic rear seat install?
- Anyone have any experience?
- Need help where does the speed sensor wire go in the ECU
- stock redline on 00 ex motor
- Looking for an HT member that IM'd me...
- help identifying this TB!!!!!
- ac fan does not turn on and its freaking hot!
- DC struts/coilovers on a EK.. how do I make it work?
- running a little bit hot
- ITR exhaust on a coupe
- stock intake for hybrid hatch....
- EG springs on EK and vise versa?
- obd2 -> 1 with 450cc and vafc>>
- lambo doors on my eg, and pick between 2 different color schemes
- Is it true that a vtec delsol si is already equipped with a b16motor that cranks out 160hp? is that
- Best Junkyard Gems
- Five lug conversion from EK
- alignment and camber ??
- Harness question
- ::crappiest CF hood contest::
- ac compressor question?
- Tranny problems seem to be advancing... = \
- Can an EX cluster rev to 8,300?
- Starter question
- carbonfiber lip for del sol
- Prepping for my new EG9
- ECU Question for the swappers out there
- Front Crossmember for EG?
- Finally got pics of my beater
- DROPZONE SHOCKS AND COILOVERS GOOD??????
- Fuel pump question?
- manual windows hard to roll up and down
- Would it make a difference??
- Why God? Why????????
- Have any of you guys passed smog in Cali with a Greddy kit on a 96-98 civic?
- question about hondata ecu
- engine reliability
- B18b into VX eng, ecu, and tranny= price?
- Where to find a good Z6
- Got a Carbon Fiber Hood - HYBRIDS Read This Before Ordering any New VIS Hoods! 56K DIE DIE!!!
- picking a new EJ shell (body)
- DX throttle problem
- about to buy Wheel/suspension setup, need input.
- engine rev problem?
- B20 Mounts
- how to put on a 96+ hb steering wheel on my 89 hatch?
- CYLINDER SLEVES????????? HELP
- engine differences? sohc ZC, d16y8, d16z6
- Need your guys opinion.
- Look at what my girlfriend did !!!
- 92 DX problems HELP!!!!!!!!!
- Which rear Civic lip can I fit on my 94 hatch?
- Installing OEM metal headgasket..any need for copper spray etc?
- Looking for Racer X Motorsports Contact
- Does anyone know where to get good cwest replica front end?
- I'm new here....
- 14" Azenis and Steelies . . . worth it?
- will tuner lug nuts work on oem wheels?
- my wipers stick up when i turn them off?!
- carbon EK hatch
- Need help my climate vents blower doesn't work
- what kinna rear seats could i use in the back of an eg6 hatch?
- Anyone in Utah with EK hatch w/ cargo cover and wants a carbon fiber one?
- Parting out 99 D16Y8...test ad
- extending senors..which ones and how many for header and cat
- Getting the left axle off of the intermediate shaft (the waaaay easy way)
- B-Series Engine codes?
- Just finished installing A/C stuff; now have low idle probs....
- Diagnose this idle problem for me...
- Jdm Civic rear seats....
- What kinna clutch do you have
- Seat Rails
- Difference between 5Zigen FN01R and FN01R-C wheels
- KYB AGX question
- Fal Fan question...
- Parts Cleaning "bareblock, head including valvetrain, and pistons" what to use?
- Good cam for d16y8?
- Will struts from an 88 crx fit on an Eg??
- Cut-off with non-HID projectors?
- PLEASE HELP!b20 over heating,WHY???
- B18b1 in 96 cx
- Which engine series will pwn?
- Need help H22A or B18C1 not a Vs question
- Carbon Fiber Fenders
- 22mm Progress bar installed now I have ????
- does anyone have these moldings?
- 1996 Civic CX ?'s
- My new toy
- 5lug on EKs....
- how tight should the cv joint bolt be?
- need CODE for check engine light.
- Does anybody make a gauge pod for Del sol?
- Suspension knock
- EMERGENCY Help, Climate Control
- Torn trailing arm bushings
- another skunk2 camber kit story
- fixing rust!
- help on areospeed seats install
- Oem strut bar?
- wont turn over...
- WTF am I doing wrong?!? (Axle seals.)
- Who has removed PS on a D16Y8?
- Turbo cam for d16z6
- vx rims
- del sol tranny in a LS motor or SI tranny for boosting???
- help please now im going crazy!!!!!
- B18C EKs.. what intake do you run??
- Beaks kit on CX
- where can i get an AC kit for 93 Civic?
- Magnaflow???
- clutch problem
- how far can I lower on these rims and tires(do not flame)
- rattling TEINS...what to do?
- Mission accomplished
- ***Desperate help needed: 94 Civic Still Bogging [Chicago]***
- Attarco... Anyone used them?
- 99-00 EX catalytic converter = 99-00 Si??
- **Dist. Question
- Trouble With Headlight Bulbs
- Clear Coat problems
- type r del sol?
- JDM Rear Interior Install Questions??
- What's the web page where they show Diagrams of parts?
- Clutch pedal acting weird!
- n00b question :-( for fellow EK owners
- i need a diagram of wiring harness 99 civic ex
- gsr intermediate shaft in a 92 hatch?
- idle problem...
- replica 99 si lip
- won't start...
- B16A2 for sale
- ***Carbon fiber lips request on 96-98 civic sedan***
- Rotting Center Pipe = Loss in performance??
- Do anyone know where I can fine a full pillar pod for a 02 - 03 Civic SI
- 96 guage cluster into 93
- Exhaust question????
- Ugggg axles making noise (I THINK)
- i dont understand this? i beat an eclipse but he had way more ponies than i did??
- d series cam question-some tech
- Carbon Fiber Fuel Door Plates for 92-95 hatch-Now available
- anyone running the greddy emanage help!!!!!
- civic & integra shizit
- Never use 20W50
- 2003 Civic LX, I need instructions on rear bumper/stop light...
- jdm eg6 cluster..??
- JRSC D16z6
- Oil Light flickers, comes on and off, stays on constantly and then shuts off after a turn...
- which tranny? please help!!!!
- Just blew my stock engine have some questions.
- WAFFLES's Grey Goose.
- Need more power
- Does a d16y8 distributor fit a d16z6?
- Difference in D-series alt.????
- About to take a 1000 mile trip from the dirty south to Toronto Canada
- Advantage/Disadvantage in using thin oil.
- auto tranny, no cold air?
- Removing Power Steering In 98 DX?
- Bought shortblock,does it need anything before i put the head back on?
- EDFC With Tein SS? Yes Or No?
- civic vs ITR mugen twin loop
- hood lock experiences...?
- Tein EDFC on a 99 civic hatchback????
- how low are green and yellow neuspeeds on an EK body?
- spring dimension needed, stock springs.
- Seat rails.
- Anyone do an RSX-s in there Eg yet
- oil line on d16y7
- switchin it up
- for you jdm freaks
- rota c'8s weight?
- Did i make a mistake. CX underdrive pulley on a d16z6 motor. I need you help gurus.
- I think i got raped
- My NEW Civic 2k ex WHERE DO I START??
- Just Bought DC Spor 4-2-1 Headers
- code 10 IAT sensor
- Sold My car --Did I get hosed?
- d16y8
- Looking for Spoon steering wheel for an EG
- climate control wont lite up in EH
- Honda or Volkswagen??? Why not both?
- 1 and 2 don't work on a/c
- Closed loop and O2 sensor?
- Parts needed for 99si swap into 99 ek?
- Good Websites to find a 93-95 Civic Hatch
- aem big brake on dx?
- Help identify this tranny with LSD????
- trying to find x brace for the rear of civic(rare)
- red rotors
- 93 honda civic CX help need info
- thinking about buying this hatchback need feedback please
- PLEASE HELP ME!!!!!!!!!!!!!!!!!!!!!!!!!
- Where did you guys put your msd box/coil?
- Pics of 195/50/15 tires
- throttle body spacers??????
- EG's with B18B's look here
- CA State pre-smog results: High hydrocarbon deposits:a.k.a. unburnt fuel...
- OK is there a difference with a AUTO JDM B16. and a MANUAL JDM B16?
- place racing auto to manual tranny mount??
- Hot wire on the Ignition?
- cant decide which paint color
- Would this cause ECU damage?
- Need some tranny help?
- fuse
- Where do i....
- help with d16y8 mani
- Vibrant short shifters any good?
- Anyone near Chino Hills,CA. please read
- Three Questions about building a d16z6?
- No Limit Motorsports
- auto tranny?
- I have to know...
- thinking about going RWD or AWD
- Engine wiring problem/ confusion
- The dreaded exhaust question.....
- post pics of eg hatches only
- b18's comparison
- GSR front tie bar on civic
- help me find something here on H-t guys!!
- Just Read about Cornering in Archives...
- no o2 sensor on gsr header/will gsr catalytic converter work?
- Head gasket?
- anyone put Civic Cp. or Integra exhaust on a EG???
- Asylum Motorsports...Yea or Nea?
- Brake questions
- Pics of Apex-i World Sport exhaust on 99-00 Civics
- "Suick Change" stut assy.. ..what do I need?
- looking for the best Gasket Seal.
- Ron's Clean EG (56k beware)
- mysterious noise and loss of power
- 99-00 civic OEM foglights
- Part number request
- Quick final question about VX wiring harness with GSR in her!
- what would cause the ECU to pull timing?
- STOLEN 93 red hatch stolen from my Apt. LOUISIANA
- hydraulic lines?
- Kyokugon lugnut socket stripped !!!!!!how do i get them off ?
- What ecu do i have?
- P06 or p2E ecu?
- does anyone have this link?
- Fields Vtec controller setup
- how to remove and install throttle cable?
