View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Please help me understand my frankenstein car.
- Do I need valve clearance adjustment?
- Simple question regarding basic maintenance with brakes
- D16z6 or d15b vtec
- Will an EK overflow tank fit in EG?
- Buying a d16z6
- Stage 3 tuner series cam shafts
- Need some input settin up my civic as a dd
- 1998 Civic DX P1457
- 97 Civic Ex Control Arm Snapped?
- Brake Booster and Master Cylinder
- 95 Del Sol S SRS Light
- Civic or Integra parts... lol
- Car won't go into gear
- 99 EX stock except RDX injectors, turbo kit, chipped ECU- Las Vegas SMOG question
- 93 civic lx sedan -- Need recommendations for catback
- Need to isolate what this sound is.
- No Brake lights, horn, rear turn signal (driver's side), or cruise control
- intake manifold
- difference between leak down and compression test
- Help a/c problems b20 swap
- 97 civic/f20b swap - Will the f23a1 VSS work?
- converting from manual to power locks
- is this 94 civic worh 3800?
- is this 99 civic worth $4000?
- 2 Passenger side recaros?
- HO2S rewire
- B16B High Idle Problem.
- 2000 civic coupe MT cruise control issue
- Stock height
- wheel size help
- What tranny do I have? Cable? hydro?
- the horn died on my 94 hatch...
- steam coming out of coolant reservoir?
- SRS Light
- Clutch Master Cylinder Reservoir Hose
- 99 ex d16y8 mild build
- 1993 Civic DX will not start (new battery)
- 97 Civic DX - idle surging issue
- Civic RIMS refit
- dramatic drop in mileage!??
- Trouble starting my civic
- 99-00 Climate control on a 98.
- my del slow
- best struts and springs
- DC2 EK9 Recaro rails?
- Back in the honda game
- 1992 Honda Civic randomly dies
- 96 coupe drivers Motor Mount
- 1996 Civic D16y8 transmission swap
- Del sol bogging
- 00 Honda Civic winter storage
- Need Help, Door Trim Window Replacement. 94 civic (pics)
- Where to buy OEM aftermarket body components
- 97 Civic/d16z6 swap - Is a p2e the correct ECU?
- New Owner of a 95 Vx HB :D (new member) few questions.
- Bad Alternator or Dead Battery?
- 2000 Civic EX D16Y8 Head / Intake D16Y7 Block Idle Issues
- 99 Civic steering creak
- Ac belt
- Repair block tranny bolts
- 00' civic EX - CEL codes and hesitation problems
- EM1 electrical,, how tight should alternator belt be?
- What is the Alloy Wheel size in Honda Civic?
- Remove CD player and just have an iPod? Is it possible?
- Wet foul on a spark plug electrode tip?
- Car will not start after Fuel filter and distributor cap and rotor replacement
- Intermittent bogging on Gsr help help
- EJ8 Front end shaking
- 1994 Civic Ex B20B Swap HELP!
- car wants to die when i give it gas
- fuel problem
- 93 Civic Si Wierd Fender gap
- Snapped Shift Linkage Bolt, help please.
- Tune up time for 95 civic. Help me out?
- Timing belt advice...
- buying a thermostat what temp?
- 95 Del Sol steering
- Engine won't turnover
- Power Window Relay Part Number?
- HELP!! replaced harmonic balancer now more problems
- obd2b to obd1 computer swap
- Dizzy Question/Clarification
- Help s4PA+P2Y
- help 99 civic with 99 ls
- Suspension and rim setup
- Accidentally poured about 3 oz oil during wet test
- BAR d16a vtec in ek hatch?
- 1998 hx wont idle
- Back up light wires?? Help me out forum
- Using 91 Octane on a SOHC
- Clutch question
- Coolant leaking uder throttle body - help!
- What is this door panel adhesive?
- Killswitch and Relay wiring help
- mystery oil leak
- 97 tranny problem d16y8
- 2000 civic si trans install
- How should I handle this turn signal stalk repair?
- 99 Civic - cranks but won't start, no spark, fuel relay clicks
- Pep Boys Pro Stop calipers complete junk?
- neck diameter?
- Fluid capacity of EJ8 power steering rack?
- Stuck Axle, Passenger Side
- 96-98 civic coupe rear lip fit 96 hatch!?
- If my headlight gets a yellow haze, what if I Vinyl tinted it?
- Del Sol Trans Top Troubleshooting guide.
- 2000 Civic Si - CEL P1259
- 97 del Sol Steering swap
- no crank no start tried everything help!!
- Trim question (95 coupe)
- Radiator cooling fan not working and electrical problem
- CEL P1399 & Cylinder 1 missfire?
- ex motor into lx need 02 sensor help
- 93 del sol - D16Z6 worth rebuilding?
- Alternator fuse 15
- bad pressure test and misfire codes
- Honda civic headlights question
- 92 civic vx Help!!?? D15z1 harness
- oil leak help
- Will Enkei 92 clear Prelude vtec/ITR brake setup?
- EM1 rear disc swap on my 95 ex; brake booster & m/c troubleshooting
- Honda Civic EK4 Build from Hungary
- mud guards for 96 civic hatch?
- LSD question
- Fact or just a trend 99-00
- Glow needle swap
- Custom spring rate for GC sleeves on Tokico HP's for 00 civic
- OEM Coolant Hose Kit - 92 vx D15Z1
- Found what looks like a piece of belt under my hood(pics)
- EG Bseries T bracket issues
- Swap Integra front brakes in Ek Civic
- Del Sol d16z6 auto to B16a auto mounts
- Idle Drop Help
- Cleaned IACV yesterday, now Speedo doesn't work? Cel 17
- Heater problems !
- Temp gauge sensor cover chipped
- Distributor, which component controls RPM signal
- Front exhaust pipe
- Headlights won't come on/corners and tail lights won't come off!!
- 4-4 ABS Code interpretation - 1995 european Civic (MB1)
- Would integra dash kit fit my civic
- shifting gears while car is off = bad?
- 98 civic fuel gauge stuck
- em1 00 with gsr sawp wont pass up 4k rpm
- oil light staying on!
- 2000 civic fuel pressure regulator help
- Simpler OEM intake tube/box for y8?
- 93 civic dx check engine light
- 2000 honda civic d16y7 head bolts snap
- Del Sol: disable dim clock
- 2000 Honda Civic LX flashing check engine light
- Replacing engine mounts 98 Civic LX
- tps problem?
- D15B In and out of Power
- Lots of oil in coolant, head problem vs crack in block?
- 99itr rear shock +LCA on 2000 ej6 coupe ?
- check light picks & chooses 4 on & off
- diagnosing front end noise 2000 Civic EX
- 2000 civic SI - intermediate Tach drop out
- seat mount question
- EK Hasport mount problem
- Hatch with b20vtec swap axel rubbing fork?
- 95 Civic D15B Vtec-Not Starting
- need help!!! with specs on d16y7
- Oil AND bubbles in Radiator, start issues, stalls.
- Trouble Starting every so often
- Car cranks, but won't start
- Shifter Position
- 1997 Civic Overheating
- radiator boiling
- '92 civic, midas diagnosis, would appreciate what you guys think of the quote ($)
- 95 civic lx 5 speed, few questions
- NEED HELP (mini me swap) y7/z6 - what harness to use.
- 98 Hatch Trunk Area...
- 98 ek Civic gauge swap?
- 98 Civic lx to EX exhaust
- a3 crank in b8 w/b8 rods???
- honda civic 1994 rev limiter
- A/C Issues - Intermittent Cooling
- '92 civic LX, 1.6L 5-speed manual- Brake issue
- Weird Overheating Question (98 civic lx)
- Slow acceleration between gears
- 95 civic horn
- 96 Civic DX front lip
- rhdjapan.com anybody ever deal with them
- WTF is this?
- best way to lower your car yourself?
- Clutch Judder - Only When Cold
- A/C wiring question(s)
- 93 civic lx setup help, exhaust, coilovers, etc FIRST CAR!!!
- Coolant leak under the hood?
- 1996 Civic Coupe EX Window issues
- my dash cluster died while driving. need help please!!!
- A/C questions
- 95 Civic stays running with key turned off
- 2000 SI wheels wont fit on my 2000 LX
- 1998 Civic HX wet trunk
- Oil dipstick tube removal. Please help!
- temp guage will not come off cold....
- Need help on EM1 Engine
- 98 civic ex swap help
- 1996 Honda Civic Ex Stock Engine Overheating
- Major oil leak
- crankshaft sensor help
- Reverse and license plate lights won't work.
- 92 eg hatch. Can't get it to run. Any suggestions.
- 94 Civic Lx - Need Idle Help
- where to buy a crank bolt?
- 1999 Civic Ex - Idle, Buckling, hesitation P0505
- 97 hatch open loop issues
- 94 Civic Hatch
- Help wiring in killswitch
- 92' D15B7, no crank.
- headlight help asap
- signal lights
- CV Axle possibly?
- help with jdm zc
- 99 civic dx no spark
- EG6 1995 Auto to manual swap won't start
- 92vx distributor cap/rotor or whole dist.?
- ball joint to lca problem
- 92 VX h/b -stalls while driving-HAS dash lights
- 96 ek b20v not getting fuel
- Will a 49 state cat cause a CEL on a cali emission car?
- 1995 Civic revs to 6k rpm on start (video)
- 1993 VX R.I.P. (Rusted in Pieces)
- code 71 random misfire cylinder 1 need help!!
- 95 Civic EX ABS brake pedal goes to floor, minimal braking power
- Idle issue after changing coolant.
- Broken Valve Cover Bolt Holes
- rich afr during cruise and little stutter during idle help!
- 1992 honda civic will not crank
- Mini-Me Intake and vtec question.
- 96 Civic hatch minime timing belt
- Dash clock in a 94 dx
- 94 Civic Lx - Idle issues
- Does anybody know anything about the Domani?
- Auto d16 to manuel b16 issue
- Itr, gsr engine swap ca bard question
- blow 40amp light fuse, engine doesn't idle, coincidence?
- 96 Honda Civic- Brake bleeding troubles
- z6 head
- How to remove Hatch off 95' Hatchback.
- 93 civic brakes
- Help! Eg si sunroof visor removal!
- Del Sol climate control gauge pod
- 94 Civic EX - replaced HG and now valves rattling, bogging, losing horsepower
- All kinds of Problems
- Rpm surge 95 del sol
