View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Turbo Kit Needed
- looking for mud flaps
- Whats the differance between headlights??
- Some idle issues
- mugen rnr's?
- Getting window back into front weatherstripping track...
- Ground Clearence
- D16Z6 swap in my 92 cx hatch
- What parts for mini me?
- Has anyone reflared brake hardlines?
- Check out my [DIY] Sidemarker EG action! its nice!
- I need local help in the southern CA area!!
- adjusting cam gear
- 1992 honda civic hb with 20k miles.
- msd blew out
- removing all body panels for paint, how hard?
- 92 HB w/ b16a axle question
- JDM Black taillights off ebay?
- Problem with the rear doors getting stuck in 4door civic.
- Misfire problem, obd2
- Civic Si
- 2000 Civic Si Turbo! Will it pass smog???
- Need help with Ek
- ek center console and armrest in a eg
- Buddy club ECU management system?
- Cluster/CC lights
- help pulling 97 ex door panels
- HX exhaust vs EX exhaust fitment issues?
- window wont go up cause of stripping near window & it was robbed...
- Need feedback and opinions on springs.
- Do EM1 Sparco brackets fit the EKs?
- 3 1/2 Digit LCD
- ------Exhaust Systems------
- fuel cut off switch
- Erratic suspension handling, how to fine tune? Need your advice!
- A company put an alarm in now lights dont work
- Hey help me Identify my harnesses
- How long can I drive titanium retainers?
- OBD1 pinouts for IACV, B16a
- Strange knock on cold start
- rear disk swap e-brake cable help!
- buddy club wheels decals?
- ECU removal problem.
- KeyHole Disassembly
- new 1/4 mile time (finally satisfied)
- Problem with dim projector headlights....can someone help??
- -Newbie clutch question
- zc swap instructions yes i serched
- WTB: either 99-00 civic or 99-01 teg dash
- ek: no power steering?
- GATHERS TAPE DECK 92-95 CIVIC INSTALL??
- OBD 1.....Why?
- How big of a drop?
- install ignition wires
- looking for a B16A
- Recent problem in civic fixed...does this make sense to you?
- How many amps is the stock civic Si alternator? Please need help
- will low oil turn on CEL?
- what would be needed - did search
- where can i get aircraft stripper?
- I think I'm going to get a visit from the car thief fairy
- D15B(sohc vtec) head on a D15B7 non-vtec
- distributor cap
- Hey guys im new to this site and i need help doing my gsr dash in my eg
- stud on a hub!!!
- Mini-me... bye bye :,(
- K20 swapped eg, how do i get it to pass emmisions??
- DC seats in a EG coupe?
- need help on ls swap in 95 eg cx
- Need a new hood for my 93 sol.
- Sorry Off Topic..But
- ECU codes 9, 41, 43 on civicEX 92 running rich
- Strut bar clearance issues ?? Pics
- p28 in 88 hatch. obd 0 to 1 conversion. Idle issue.
- spark plugs swimming and coverd in oil??? huh????
- HB 1992 1995 Civic FITS WHAT GSR INTEGRA DASH OR ACURA DASH
- ingen intake ?????????????????????????????????????????????????? ????????????????
- Pic Request.EK's w/ lips
- buying a tranny from a company?
- i broke a bolt. what do i do
- will a 4dr civic's tail light fit on a hatchbacks?
- fuse cover "clip"
- y8 tranny on b16
- where can i find me some eagle rods and AN-R header
- d16z6
- No Vtec
- ek passenger airbag removal
- Getting LS-Vtec soon, opinions?
- rsr exmag...Loud?
- got a ca smog ref ticket and won't pass... avenues of approach
- type-r Cluster in a 00 hb
- will itr axleback fit my 00 ek w/ctr lip? (already searched)
- Went to the track last night, giving honda-tech a chance to make me feel worse
- Cams
- question for anyone with 01+ civic ex
- Injector Question- RC Injectors - Saturated require resistor pack??
- AC
- STILL can't post in appearance so....
- Spring Compressor Does Not Fit
- question
- DIZZZY help
- automatic civic
- Best transmission for my d16z6 soch 94 civic?
- Question for those with OEM foglights on 2000 Civic
- EK specific online club?
- Is there hope for a faster D-series...
- 98HX w/ B16A Won't start, no spark
- 99-00 Si engine wiring harness.......shot in the dark and yes I have searched
- quick answer needed about heads...
- Need to know if parts will work
- Hey what happen to the Silver Civic that crash on the 5frwy in Palmdale last night?
- I need a Schematic
- engine trouble
- iacv help please
- Sound from Power Steering
- Audio/AC center control console swap
- Hurricanes, Trees, Kill Switches and my Crank Pulley???
- instrument cluster for '97 civic dx
- Anyone else have a 2005 Civic EX Special Edition??
- what is the max RPM on a DX
- new info on CODE 43 fuel supply system
- JDM B16A into 92 Civic Hatch, Distributor wont work what do I use
- Help! 12 volts TO AND FROM A17 at ECU
- Vinyl Paint
- y8 exhaust manifold over an average header
- how do the EM1 strut bar studs stay in?
- power window problem need help
- The Honda brake pedal squeak, where do I put the lube? :)
- diff between 96-98 or 99-00 front end's
- what cars did the d16z6 come in?
- Help! What is this part called? It won't stop leaking gasoline.
- LS vs d16
- i need a helms..please read
- Horn & wipers dont work, fuse diagram?
- Request: D16 Tanabe Hyper Medallion audio clip.
- ECU code #5
- Socal meet tonight at 6pm..... Irvine Tapioca express........10/9!
- Overheating prob. Suggestions?
- Parts / Civic factory & aftermarket sources ?
- I NEED HELP FAST!
- Iridium Spark Plugs
- ZC swap into my eg
- Brembo front rotors dont fit (93 ex coupe)
- DSM 450CC Quick Question!
- Hood Cooling and Hood Locks
- Shops To Go In San Diego ?
- rota rims 15 or 16 on eg?
- d15b exhaust manifold question
- dash question
- who has done it and what are the results. (LS?VTEC)
- Korbach Frame Locks - review that doesn't sound like an infomercial
- EH8 spoon mirrors?
- did 96 up civics come with a black dash?
- D series Linkage
- GS-R head worth getting?
- throwin 2 codes after da swap is done.. HELP!!!
- ES hyper flex kit??
- How to wire up Aftermarket horn?
- manually lifting power window
- Everything was going great....
- Check out this air horn....
- location of thermostat on b16a2
- how much tranny fluid?
- A/C condensor
- speedometer and vtec... and vss
- question about 92-95 civic hb w/ 95 b18c1 (exhaust piping)
- 03 Civic EX Rear Defroster problem...
- Man...F*ing wrecked my car last night
- help throwing a code
- whoever did this?help needed thanks
- Welcome me aboard the Honda Family? =[
- 93 Del Sol Automatic reverse problems
- Depo lights? Whoever has installed them please read, NEED HELP
- RX7 turbo mated to B16A...is it possible
- My new shitbeater (pics)
- CF buckets?
- I need webites
- anyone wana teach me how to swap out my springs..
- state ref MIL failed (searched)
- 99-00 blue Si w/spoon mirrors
- B18a/b or B18c
- looking for turbo kit 99 - 00 si
- Acura steering wheel on 1992-1995 HONDA HB SI
- Mirror Components
- where is the best place to buy a engine in LA
- why are ls dohc good for boost
- clicking coming from front left wheel when i drive
- $ 100 Reward to find well known racer to get numbers for Korbach Frame Locks
- 93 civic ex problem.
- Anyone near Central PA want to paint my hatch?
- RPMS Stick 3-4k in first..then second
- Can bondo easily be removed?
- opinions on greddy EVO system?
- good brake/rotor setup?
- I'm might want to buy an EG6, but have a few questions first.
- Can someone do a carfax please
- Del Sol sideskirts fit a civic hatch!??!?!?
- what next for me?
- dizzy is fired sooo!!!!
- problem with enjo motor mount
- need help with power steering problem.
- oem airboxes
- way crazy idle issue
- question about blackjax
- What would you pay for a '92 Si?
- What's that noise?
- what starters will work with a b16?
- HELP GET im gasket off plz!
- Are the cx/dx cluster gauges interchangeable with the si/vx clusters? 92-95
- How to fix ecu immoblizer in 2001 GSR
- hood latch help 94 ej
- Problem with turn signal...
- o2 bung on cat in 94 d16z6
- im stripping my car tonight.. and I NEED HELP!!
- shit 4sale 4 92-95...
- Throw out bearing Q & A?!?!
- If I wanted to post a 350 small block in my Eg hatch. Who makes a mount kit?
- Tire Question, need a FAST respone PLZ!!
- Is this a EK gauge or a EG gauge? pic inside
- recommended first mods?
- Listen to my rant about exhausts
- Help me figure out the correct ECU setup for my civic
- any idea on where to get just a f20b head?
- JDM SIDE MODELING FOR EG
- Will 14" steelies fit over 99si front brakes?
- Ok im your lab rat.... Seafoamed my turbo GSR.......
- Throw out bearing question...
- Need help!!!!i have a smell trouble
- vtec
- How to De-rice your car post?
- b16 dissy on b18b?
- help! car idleing up and down
- civic type r spoiler
- passing smog inspection
- Intake as good or maybe better than J's Racing Intake
- Eibach Dampers! ! !
- bumper removal
- So.. Some lady rearended me..
- turbo-kit
- p28 ecu pinout
- NEWB question
- B18 swap fuel pump question
- 92 eg door panels WTB
- I need to find the location of a vin number in my car!
- >>>VISION TYPE DC CF MIRRORS ON AN EG<<<
- Tips when buying a replacement rack???
- how much should the timing belt move?
- Need help getting interior parts from Junkyard, Can any of you guys help?
- Remove excess oil and coolant from cylinders, along with other engine cleaning questions
- B16a3 vs. d16z
