View Full Version : Honda Civic / Del Sol (1992 - 2000)
- clutch question
- A/C Belt for swapped 97 ex
- b16 valve springs...?
- Where can I find axles to use for my h22 swapped EG hatch
- need a little bit of help and got sum questions!
- 1992 integra catalytic / 1994 dx
- New to the forums..have a few questions...
- OMNI Power or Crower valvetrain components
- V6 civic??????
- engine tapping
- 99 front end on a 97
- I need a carfax report Asap
- Need Help... Oil Pump...Bent valves
- will it work
- help with abs question
- Door jammed!!!!!!
- civic problem
- d15b wiring
- fuel gauge bad on new cluster?
- for a b16 swap
- Code 91 and vtec??
- Grade Logic and i-Vtec...
- e-brake adjustment quesion
- Tachometer hookup for measuring RPM's
- vtec spool valves
- Who has the best price on a complete omni head pkg for B-series?
- where to buy a cheap B7?
- auto to manual, reverse light???
- fuel filter change?
- HELP PLEASE.. . . rear hatch question.. .
- ek top fuel pillar bar
- lights on !!!
- what dizzy should i use??
- any civics in the tri-state area (new york only)
- Del Sol Trunk seal
- b18a help
- No Crank No Start...HELP!!!
- help with brake light harness
- (searched) Y7 to Y8...o2 sensor/cat questions.
- thermal exhaust
- GSR Tranny
- Nice Arse Lights... HID? Maybe...
- All Ek Hatchbacks with 16's i need your help pls..
- Tachometer Question
- how can i push caliper piston back in?
- tranny fluid - del sol
- check engine light
- b18c1
- anybody in here rocking an Ls|Vtec engine?
- EK Sedan suspension setup
- B20b into a 99 ex
- EG6 jdm rear seats in 6th Gen???
- eg amber corners GOOD OR BAD........
- Timing belt rubbing
- 99 Civic Turbo Overheating at idle...
- Which brake lines for a 99 cx with gsr rear disc brakes?
- pcv valve dilemma
- question about exhuast and gas mileage
- spoon ventuli plate for sale
- d16y7 OBD2a => OBD1 Question
- Auto to Manual Swap EG
- Wastegate popping problems
- ECU question
- 93 hb top spoiler
- should i bleed brakes @ all wheels?
- VTEC NOT WORKING
- How long will a swap take with 4 people?
- i need a motor
- Cruise Control Removal?
- Rod knock in a 98 EX...or is it? (bum bum bum!)
- Gaskets
- weird electrical problem
- My Project 92 Civic VX
- Swap into 99 EK
- TDC sensor
- 92-95 civic coupe, many parts for sale.
- Does ne one Know about engine swaps !
- How much does weight matter????
- How to install door visors civic ?
- Blinker problem
- MSD IGNITION
- BRAKE PROBLEM HELP ME ASAP!!!
- D15b Problem codes.
- help about Si Lip..
- FS Brand new Blitz Turbo Timer
- Video of the 600whp civic si
- Slump in floorboard
- Parking brake handle
- b16 burning too much oil?
- I need a lot of info...sorry!
- Floorboard replacement repair?
- y8 head gasket metal?
- Transmission swap?
- 92-95 HB
- EG window weather stripping is peeling
- Miata rims? Direct bolt on?
- Looking at buying 95 civic cx. No tach??
- eg hatch with 94 integra front end
- LS/Vtec Swap
- EK dash harness work in an EG??
- rpm's change at idle
- EG and DC motor mounts
- Axel Nuts reverse thread
- quick help needed
- OBD2 code 41
- Coolant Leak Issue.
- Car shut off today... Now wont start! (2000 Civic EX)
- stock exhaust bolt size....
- how to cover or hide blown airbags? i need help
- Where does the cd changer fit in a 98 civic.
- What happens when CEL comes on
- changing my caliper and pads ... everything went wrong for this nub
- Input Shaft Bearing - Thanks BauleyCivic!
- ls swap into my eh
- 96-98 civic projectors w/ retrofit any1 w/ these?
- posible to convert d15?? (93-95 del sol S) obd1 to obd2??
- Verifying the color of wires
- 1999 Civic EX rebuild manual transmission?
- left highbeams work, lows dont....
- Advance or retard
- what do i need to swap my rear drums to disc on my EG EX
- Most Miles on a Z6
- torque specs on b16 rod bolts and main caps
- Radiator brackets
- where is trhe 02 @ ?
- z6 swap engine problems
- Z6 head-Y7 block, which arp studs needed?
- fixing hydrolocked engine.
- Injector wiring
- help changing axle.
- 10 Dollars (Help)
- to many miles
- AC Problem -- Refrigerant wont leave the can and go into the car
- Just to confirm, D16Z6 IM on D15B8?
- REALLY QUICK!! I need a pic of front sway bar mounting points.
- 99-00 EK fuse box?
- Skunk2 Short Shifter Hardware Question
- Tanabe SMR cracked.. NEED HELP!
- intake manifold
- Bent rim + inspection?
- A little help with ls vtec swap
- Help headlight problem!
- b20 block with b16 head and trans.
- Voltage problem HELP
- WHY IS THEIR A GAP
- how did you guys do your ac?
- B18 Piston question...
- Racing harness....how to install?
- 96 Civic Ex Axle ?
- Engine Replaced noe Burning Oil
- D15/D16 TIMING BELT
- NEED HELP. Need stock exhaust...NOVA
- questions about brake pads
- EG / IS 300 Fog Lights
- Gearbox Query
- install cabin filter
- HELP: DOING REAR DISC (SiR) CONVERSION into 92 hatch
- My ek has a few problems
- 00 Civic radio into EG, i searched i know
- my car wont start ... PLEASE HELP !!!
- cx turbo?
- Please tell me what you think.
- pics of red cars w/ white wheels (preferably 15's)
- What do ya'll think huuuuuuh???
- jdm itr cluster into a 96 civic cx.
- gsr brake conversion on 96 civic
- What do these codes mean
- Can i use my d16y8 crank sensor on a d16z6 block?? i need it for emissions reasons..
- pinging noise when i let of the gas. 92 gsr eg (vx)
- Question about B18 swapped Civics and A/C
- An honest EG Korbach Frame Locks review
- Does Using a/c affect engine temps?!??!
- what way to turn dixxy for advanced timing
- itr swap ?
- Will Hmotors swap shift linkages when purchasing an engine?
- Question about header???
- Anyone Running a Therman Exhaust?
- NEED A CHEAP QUIET MUFFLER ASAP
- cosmetic issue if anyone can help i'd really appreciate it
- Oil Question
- Is this mugen?
- 92 Civic hatch - TYPE R D brackets - NEED ANSWERING!
- AC problem.. lack of freon?
- Good bulbs for projector housing.....
- Trying to find that DIY APEX-i VAFC wire plug thread...
- Adjusting Ignition Timing on a 94 dx?
- Transmission Fluid
- Seat brackets.. for a 99 ek
- 92-95 Civic Production Numbers?
- Is it worth it...strut bar/tie bar combo..ebay
- VAFC vtec setting?
- need help ! engine swap
- Anyone datalogging on a p28, I need help please!
- sorry but i had to ask
- do it myself or a shop?
- bigger injecters? what else do i need to change?
- a few problems with my VX.
- oil light stays on for 5-6 sec. after start up
- push rod/clutch
- Will Vtec hit if you have a code 41
- disk brake conversion
- converting obd1 to obd2?? changeover , can i by just swithching the IM and dizzy??
- cluster isnt working
- Rev question
- Question about this 93 civic
- 99-00 Si Shocks on a 92-95 civic fitment?
- Idle Adjustment problem?
- *smoked* amber corners
- DUAL DIN COVER QUICK QUESTION
- making a b18a/b v-tec
- raising the sol?
- installing auto lock.... help
- Radiator cooling fan
- civic problem
- o2 sensor on catalytic converters?
- Part # Synchronizer speed # 4 (Hydro tranny S4C B16A Civic JDM 95)
- mimi me swap
- distributor wiring help
- noob noob question
- Inspection..............HELP!!
- New Clutch Install - Engagement moving up the pedal, quick question
- Fixing Code 20
- EM racing bars install??
- need civic hb radiator
- Does anybody know ???
- NA/super charger/turbo some on help me out im confused let me know some advanteges and disadvantegs
- Tranny question???!!!
- Would like to know your thoughts on my setup (semi mini-me)
- Anyone used a D16Y8 Intake manifold on a D16Z6
- Car running good or not 1320 times and compression checks provided
- MAIN REQ'D
- for the love of god please tell me which harness i need !
- SS Brake line install help... pics request
- im new and need help
- I've searched ... WTF is the blue box that says Interlock Control Assy. for???
- Question on carbon build-up on pistons
- No VTEC code 22
- 2dr tailights on a 3dr
- went to track tonight, please flame...
- f@#$ing cops
- My new WORST ENEMY!!!
- quick suspension question
- Need some ECU help - 02D01560-1500
- AUTO 2 MANUAL
- GSR block with b16 head
- New brakes, need shim on both pads?
- idle bouncing around after replacing head? come on engine gurus,
- 2000 B16a2 Swap Into 98 Civic DX
- eg9 ferio wing
- Car Won't Start........
