View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Noob Question, what is EG, EK and are there any other letters i should know?
- 00 Si Dash into a 00 DX, From Tan to Black, 2 door to 4 door parts
- Which OTHER shocks fit onto a 94 Civic Ex?
- cost of d16z6
- LS swap in to a EG?
- Omnipower Drag Coilovers, who has em?
- Cheap Headers for a B16
- '00 Civic EX radio harness...
- d16z6 pcm harness
- ek rear disk ?
- starter question
- How much should I pay for a four door SIR eg cluster???
- FUEL RAIL QUESTION???
- Civic 04 Projector Headlights??
- D15b Eg quarter mile
- need help 2
- my 95 cx won at nopi
- need help
- exhaust questions
- question about b20z
- car jacking at UCR
- 1/4 mile times 93 hatch with a 95 d16z6 slightly modded
- What is port matched? in terms of TB
- 95 ex motor
- Blew rod out of engine! Have a 97Ex D16Y8 can I use a D16Y7 Block?
- How Much Is My Car Worth????
- problem with iac valve
- car wont start
- Is this car worth the money? 95 civic cx hatch
- shifter stabilizer bushings
- 10 gauge wire good enough for grounding?
- Steering Question
- Need some diagnostic help...
- loud reverse gear?
- I got a question about turbos's
- maint. required light
- Another KORBACH FRAME LOCK REVIEW
- Aftermarket muffler with stock piping?
- coolant inside the car
- Car problems -- HELP!!
- 94 civic ex ignition switch?
- d16y8 need advice
- will a vtec pressure switch from a d16z6 work on a b16sirII jdm motor?
- 02sensor and gas milage
- LED 3rd Brake Light on Duckbill
- installing coilover ?
- is it possible?
- Someone help me axles problems!!!
- More on O2 sensors / lousy milage
- Ordering civic dash wire harness?
- tranny fluid
- Need Carfax JHMEC1343HS061603
- coilover or springs
- HELP b16a FROM HELL
- Having probs, any advice will help.
- japanese money
- Anyone in Denver,CO.?
- B20 block and Ls head what kinda results.(test)
- EG erxhaust on del sol...
- Please help!!
- D16Z6 SWAP INTO 94VX Please Help
- What parts would I need for a MT conversion?
- New pistons for a turbo?
- CTR Power Window Switches on Ex/Si Doors?
- Help installing JDM fog lights on my 98 civic
- electrical problem
- Skunk2 Short Shifter
- ? about 96-00 trannies comapred to 92-95 trannies
- HKS Hi Power to Spoon N1
- 6th gen Battery size ?
- What is best for my D16Z6 engine?
- clutch bolt fell out in jdm b18c - pics
- is this an EG aftermarket steering hub??
- used greddy vs. new ebay header?
- Cant get any codes off ecu?
- car pulls to the right
- Civic w/ integra dash dimmer keeps frying...
- power to engine....96 civic ex
- HONDA-TECH MEETING
- Del sol manual
- 92-95 civic iat sensor location?
- Mugen twin loop bite off.....
- idleing problem
- engine light on
- Brake Setups!
- Is there a difference between auto/manual jdm sohc vtec d15b cams?
- Axels
- Tranny question
- overheating issues
- Cant get my car into first gear...
- looking 4 a b16 or b18 motor
- Re-ringing JDM D15B
- Slotted vs. Cross-drilled Rotors
- car dumps coolant in over flow tank
- Exhaust rattle?
- SI intake for an EG with a b18c?????
- will del sol rear brakes fit on a 2000 civic coupe ex
- ignition timing **HELP**
- Help me figure out this rattle noise coming from the engine
- CTR Wing Install Question?
- EK auto->Manual question (ECU related)
- is there any way to bypass the vtec solenoid wiring in the ecu like the oil pressure switch? (search
- DX Hatch bogging out...what to do?
- oil passage dowell
- New K-series engine, the K20z1
- Check Engine Light
- integra fr/rr discs on 4 disc sol
- Better Intake MANIFOLD for D16Y8
- IM decisions-
- side molding ?
- [Question]Civic Suspension 6th Gen
- AEM air bypass on Injen intake
- Moded d15b 92 cx 200 mpg...does it seem right?
- Fuse Diagram for EG
- D16a6 Head -> D16y8/D16z6 Block -> D16a6 Tranny Cant they all fit together?
- Best tire size of 17 x 7.5
- Question, can you get NON cf duckbill wings?? like just normal black plastic?
- removeable steering wheel help
- Flywheel Tool?
- How much for EG interior pieces?
- Intake Manifold question
- 93 b18? into eg hatch
- Electrical Problem?
- quick 99 front end question
- 97 Civic Bra/Mask Question
- DSM injectors on b16 1st gen do I need injector clips?
- v-tec head on non v-tec block
- Fuel and temp gauge stuck at max
- 99 Hatch engine swap
- is it ok to run open cat on my car!!!!
- Throttle Body Question
- 2k dx civic dizzy into 96 dx civic
- shocks from 95 ej on 00 SI??
- wierd ass idle
- quick ? on radiator core
- DIY Intake vs. Ebay Intake? Which is better?
- got car tune and went to fontana track
- 7.5" rotas on a eg?
- What honda models came with the hydraulic tranny?
- looking for a swaybar, 96-98, recomend? gsr on civic?
- Do you know where I can get halo projectors headlights for a civic 04 ex?
- Q on 00 d16y8 with 96-98 harness
- fucked up my second gear
- Scratch on my dash
- AC/Heat problem turns on at high speeds....HELP!
- civic intake manifold question
- hey you eg guys! want to trade for an ek?
- d16z6 question?
- 99-00 fog lights
- Civic Clutch Install
- Zenkei lug nuts after 1 month...
- clutch or tranmission?
- Question about catback on 92 civic hb
- 92-95 cpe/hb bumper,hood,fender's on a sedan???
- heater core help b18c
- first dyno since my swap
- gsr swap or stay sohc turbo?
- hx rims... do they clear gsr brakes???
- Panel for audio console?
- Question on Which Year is best¿
- [question] Removing Door Moldings (Safely)
- 92 hatch suspension upgrades.
- floor bars & front seat pillar bar
- Need throttle linkage bracket asap!
- Headlights are jacked
- Short Shifter Install
- Help Leaking ;/
- LOOKIN FOR HEADERS!(new/used)
- PLEASE HELP: electric power steering (k20 ek)
- can anyone install clutches for eg civics in the bay area?
- what steering wheel hub
- Got INT dash in check it out and need some help
- Question about heat wrap..
- knock sensor
- need fuse diagram for 93 del sol
- Civic Clutches
- D16Y8 Intake manifold on D16Z6 head Help
- 96 ek civic hb cargo cover?
- Who's short throw is shorter dc sports, or skunk2's?
- need help wit power window conversion
- THANKS FOR THE VAFC HELP.. THE INSTRUCTIONS LEAVE YOU LIKE WTF...
- do it compression test but i see low
- Clutch Installation
- problems with vtec
- Just did a swap, now its smoking...
- y8 intake manifold swap quick question
- 96-97 front bumper
- Will the rear section from a gsr fit my eg coupe??
- converting auto to stick????
- jdm question???
- 5 lug on a eg???
- For Those Running OEM HIDs... HELP!!
- JimFab Traction Bars + EK hatch + usdm 5 lug conversion..?
- 95 Civic and N20
- WICKED IND. CAMS FOR SALE AND RC INJECTORS
- EG coupe... HARD STARTING!!!
- Has anyone done this to an EG6 Gauge Cluster
- mini me swap question?
- D17 Straight Cable and suspension
- What trailing arm is the same? Sedan = Coupe as well?
- Anyone know code 51?
- Question about swaping an 90'integra motor into 5th gen
- Re-Centering steering wheel
- my car stalls out after i fill up
- what kind of suspension should i get for daily driven car?
- can someone possibly show me a pic of an EJ8 w/mugen front lip ?
- 99-00 Civic Si Taillights
- this is a good deal...I think
- Coilover Question?
- Clutch Fluid disappearing!
- need help with this green plug near the dizzy.
- have exhaust prob!!!!
- sideskirt installation, help!!
- The Police got me
- SAFC 2 WIRING HELP PLEASE FAST HELP :)
- Denso Iridium Power vs. NGK Iridium IX
- 95 Del sol HELMS??
- Ebay LCA feedback topic
- B16a idle problem help!
- ;....putting in integra jdm lights?
- VTEC Point on 2004 EX?
- your favorite ecu
- How'd you wire your ls engine in your 99 civic dx?
- compression test ?
- headlight/taillight help!!!
- BRAKE NOISE
- Water leaking from the hatch, please help!
- Fuel cell question!!! What do i need???
- cometic head gasket
- CEL #43, Fuel supply system... Causes?
- weird stuff with speedo?
- air/fuel problem
- valve cover?
- Integra Interior in Civic ???
- CODE 135, O2 Sensor Heater Circuit Malfunction, what do I do?
- ineed some quick answers serious problem
- Quick question!
- Horn..
- Cheap turbo for a 95 civic ex
- Idle question?
- suggestions on car
- How do i remove the original shift knob for the 96 civic ?
- Swaps...
- Quaife Fast ratio steering racks are now available...
- gsr intake air temp sensor location
- PS question
- Diy yellow fogs...turned out amber
- Woundering if 97-01 Prelude side view mirrors will fit on my Si...
- how much do u guys thing this 1999 si is worth?
- NEED help SETTING UP VAFC NOT TUNING ANYONE?????????
