View Full Version : Honda Civic / Del Sol (1992 - 2000)
- VTEC QUESTION
- Cel 43 Help.. **Searched**
- Have a D16 tranny with VIN...can anyone confirm model?
- Ek coupe exhaust question
- Possible fuel pump problem
- Problem with 97 Civic EX
- Car wont go into gear when on...replaced the clutch
- 95 SI INTAKE MANIFOLD
- my car color with this rim color?!
- EG Brakes
- 99-00 civic si parts interchangable????
- Overheating EG 100 Degree's Plus Outside : (
- Motor Mounts in 92-95 civic
- My new 94 CX
- screw in my tire :(
- ek with rota gt3 red..
- power door conversion ?
- how hard to remove and install ps?
- is del sol 4 or 5 lug...i need to know quickly
- OBD2 Distributor on a OBD1 Car
- TRansmission INFO -- JDM -- H22A
- srs light up in the cluster
- anyone have this problem with their Si?
- Front brake schimmy?
- Back fires going into second??
- Reverse guages
- ATTN: Anyone who has ever had their radiator support replaced...
- How to recognize B16B Tranny
- ACT CLUTCH LOW IDLE ????
- CODE-p0450-fuel tank pressure sensor
- best exhaust for a ek
- anyone a sohc specialist here in the socal area?
- car dies, won't start .. 5 minutes later everythings ok
- radiator fan question
- rpm adjusting
- EK clutch installation questions
- Help. Car is acting weird! 99 Civic. all stock.
- i have both...which one...b18b or b16
- car wont start (obd1 dohc zc0
- SRS Light?
- I used Brake Fluid to clean my flywheel
- rear disc trailing arm question
- wicked tuning..
- Tach???Electric/mechanical
- 95 civic
- Where to find BUILT auto transmissions
- Problem with civic 96 eingine dying while coming to stop
- 92-95 civic hb rear quarter panel plastics in 93-95 civic coupe?
- Calling all integra dashes into Si Hatch guys!!!
- D series tranny: Cable grears into hydro tranny
- tuning?
- Remove Si Logo from 00' civic si
- alignment question please help
- CRAZY HELMS!!
- Can someone please carfax this for me!
- OBD question
- oil pressure guage
- 94' hb SELL or TRADE FOR CRX !!!
- OEM spark plug wires or NGK blues?
- Honda Oil filters the best? And what oil?
- which AEM cold air for b18c/'99ek???
- Installing auto d16y8 intake mani on manual 5 spd car, HELP!
- PLACE HELP ME !!!!!
- D15B/D16Z6 ENGINE HARNESS
- Oil pressure gauge install
- 92 civic vti problem
- a/f gauge install question (searched)
- d16z vs. B16A powersteering pump...
- 93 JDM Del Sol trunk stuck open
- cluster Dead HELP ANYONE ASAP
- Didnt know where to post!!! New HONDA Owner!!!!!
- V-TEC Controller
- 91 b18 in a 93 civic hatch need some info
- DC strut bars and fitting
- D16Z6 Tranny Hydro or Cable?
- Anyone know if a S2000 steering wheel will fit a 92-95 civic?
- DIY Manual Window Regulator Replacement
- EK temp prob.....
- next mod?
- POLL: Suspension Upgrade or No?
- what size speakers on the 05 civic si hatchback?
- Scrappin' noise
- How about a K20A2?
- does Pulling acg fuse reset the ecu?
- d16z6 tranny on a d15b7?
- HELP!!!
- Been posted but again (EK oem sir front lip wanted)
- motor mounts
- I NEED HELP PUTTING A D15B8 ROCKER ASSEMBLY BACK TOGETHER!!!
- tapping noise from passenger front suspension
- how to put on a 99-00 front end a 97 civic Help
- broken T belt..
- CX/DX eg owners: how is driving w/o p/s?
- THrowing code P1457 help please !!
- New manifold fuel rail and pressure gauge take a look
- In over my head?!?
- dwl sol b series linkage HELP
- how do i remove the ebrake handle?
- Need help...
- Stripped oil plug.
- how to undo line that opens gas lid and rear glass hatch on my 93 hatch?
- heater core/wiring removed = gauge issues?
- Quick question on EK/EG mufflers
- Why Does My Exhaust Sound Raspy????
- B16B in a 00 ek hatch
- which flywheel/clutch combo for EF HB Si begginer driver?
- gauge cluster
- how/where to disconnect hydro clutch
- 2nd generation JDM B18C5 ?
- Wire questions...
- headers on stock exhaust
- ITR LSD, Civic Si ... One very quick question ...
- Too much oil causes bogging...
- factory antitheft radio codes
- got a header need help
- do i need to evacuate my ac system?
- hks turbo timer 1 in eg need help...
- Input Shaft Bearing Questions
- gauge display!!
- Help~~~Eg coupe/jdmb16sir2/ek 2.5" cat back..fitment issues.
- normal motor compression ratio test psi?!
- Black Smoke
- check engine light won't stay off
- need advice (accident)
- Power windows problems.
- loudness of ebay/aem short ram intakes
- clutch question !!!!!!!!!!!!!!
- Steering Question?
- i need to go faster!!!!!!
- gauge seals?
- To you EG civics with the b16...
- camber/wobble questions...
- z6 fuel rail on y8?
- 2005 stock security system... respectable or a joke?
- Will Acura TL Rear Leather Seats Fit in a 1992 VX HB?
- Installing new door speakers... help
- girlfriend's civic is making noises can you diagnose please?!!
- horn? 96-97 type r non srs steering wheel in eg
- major problems after new engine install
- 91 1.5 Distributor on a 95 civic 1.5, Will it work?
- 99-00 civic ex to si distributor wiring
- Hydrolocked NEED HELP PLEASE.. SEARCHED ALREADY
- D16y7 owners got a quick question????
- car keeps overheating
- mounting tire by hand?
- Exploded Pictures
- Are 96-00 LCAs interchangable?
- No sticker on the inside of the hood.
- Daily Driver vehicle: What clutch?
- Old gas?
- For Those Switching to Double Core Radiators (Single Wide Core)
- EK Civic Sleeper
- ARP extended wheel studs or Skunk2 extended wheel studs?
- ? on obd2a to obd1 harness...
- downpipe yessir!!
- Whats some good springs
- HELP!! Can't get crank bolt off.
- Droping the hatch
- CHEAP AIR TOOLS!!!
- 95 civic headlight question
- O2 sensor and knock sensor?
- Soft Clutch Petal
- D15B SOHC VTEC
- Suspension Difference?
- Exhaust problem
- replacing distributor cap and rotor, will timing change?
- CEL stays on in a Civic w/ a b18b
- What is your top pick for cams and valve train setups?
- Another EM1 Si gone... damn i hate jersey
- car does move when in gear?
- Acura 01'-04' TL, RL, CL 5 Lug into a Civic can it be done?
- BEST CIVIC ENGINE SWAP FOR THE $$$$
- Need opinion for Headers please
- exhaust melting rear lip
- Sunroof help? please help!
- leaking gas out of exhaust.....
- question about my d16
- B16A S4C tranny GSR 5th gear
- intake manifold swap y7 to y8. which gasket?
- Need Help Please!! JDM H22a
- Horn hook up
- 16s = nonstop rubbing?
- Low-beams DEAD *PLEASE READ* DRIVING IN THE DARK SUCKS!
- Grounding the block, alternator, intake manifold...
- Can I replace just the endlink on my sway bar?
- Help!!!
- What should I do with this civic?
- exhaust problem
- mitsubishi td04, 11b Turbo ON a B Series Engine
- OBD-1 Conversion Harness
- loose rear view mirror
- b16 swap question
- EM1 Wheel Stud thread pitch?
- Need an undercar pic of an apexi n1 exhaust....PLZZZZ
- What is this plug? what does it do?
- clutch or tranny problem?
- Mysterious Connector On 1992 Hatch Driverside Shock Tower
- Whats wrong with my 95 civic
- EK hatch and Couple exhuast lengths the same?
- VTEC head or B16 tranny
- climate control help
- Having Problems
- bad spark knock on mini me... HELP
- Stock sleeves or Darton repair sleeves??
- Si (USDM) vs Type R (JDM) EK Front Lips
- What did I do to my clutch? Need help
- vibration under accelleration
- S.T.R product
- goodnight dashboard
- 99 civic Cd relocation
- CTR Cluster lights.....
- Need some HELP ASAP!!!!!
- DISTRIBUTOR order, plz help
- What do I do With My old motor?
- d15b vtec guys, need some help
- A small quick question.
- Noise from Transmission - Throw Out Bearing or Pilot Bearing?
- vtec is working fine, no speed from it
- i ran a 10.1 in a 1/8 mile is that bad
- 00 gauge cluster on an ek
- OIL for b16a2
- harmonic balencer crank pulley??????????
- Whiteline Automotive GROUP 4 COILOVERS
- cam swap
- EVAP P1457 - Did troubleshooting....where is Purge Control Solonoid Valve?
- b16 swap into 97' hatch
- Civic Dash Lights!!!!
- Is it possible to have high and low beams stay on at the same time?
- help wit wiring please
- Hate to sound dumb here, but where is the fan switch and Temp Sensor for the dash located in my d15?
- bypass FITV amd IACV....
- Paint removal/plastic
- LS hatch
- EK sideskirts on Del SOL?
- engine codes
- how to wire jdm fog lights?
- Auto to manual swap for EK.... NOT MY CAR.
- ECU Pinout Diagram needed for '00 Si Edelbrock Turbo Install
- Balance brand new flywheel?
- EG headlight compatability(There are pics)
- HELP CAN A D16Z6 AUTO TRANNY FIT A D16Y8 ENGINE AND CAR?
- need help for my 99 si
- I NEED HELP ON MY 94 CIVIC HATCH WITH THE MOTOR SWAP!
- pit crew motorsports
- B20 parts
- Easiest way to remove the gray trim.
- Dx (d16y7) and Ex (d16y8) 97 civic coupè brakes/suspension the same?
- What are all these wires? and how to clean this up?
- new paint job for my ek..
- EK suspension help
