View Full Version : Honda Civic / Del Sol (1992 - 2000)
- si wheel offset
- eg w/b16 swap wont start
- Stage 5 clutch over doing it?
- Failed ca bar
- What lights can go at the bottom of the bumpers?
- 92 Si..Will not start
- EG's with B16 swap in California, need your help with laws!
- Power window motor question
- does Da rear disc setup fit ???
- Suggestions? 94 del sol si with vtec Knocking when i turn ..
- How to Idenifty a REAL SPOON Carbon Fiber lip?
- Idle Issues... Fix? (97 DX)
- My '94 tool
- which jumper harness?
- 93 civic hatch wiper problem
- My 96 Civic Hatch Gauge cluster lights do not light up...
- EG exhaust question
- aftermarket or stock jdm front grill with si logo
- I need help diagnosing a transmission problem.
- Seatbelts retract too slowly..
- bolt - ons question
- Can timing cause a knock?
- Will a 1999 si radio work in 1996 ex?
- My EG won't start! HELP!!!
- Mini-Me Swap (vtec help)
- Failed Emisson in Maryland. HELP
- When to swap out motor?
- Optional Audio console components question. PIC
- ??? about a halfshaft
- base maps
- Got a d16z6 overheating issue
- k9 al 532c alarm
- mini me build help appreciated
- 2000 Civic foglight screws
- Coolant leak
- Another EM1 checkin' in!
- for those of you using FLUIDYNE radiators
- heat not working
- speedometer not working help!!
- [FEELER] 00 si shell - how much is it worth?
- Gasket Sealing question
- B series swap mounts?
- EP3 seats in del sol?
- hardened shift linkage bushing
- OEM Steering Wheel Compatibility
- Installing blox rear LCA's on 1996 cx
- for the people that had thier car stolen in chicago!
- Turbo
- Ebay Lower Control arms any good?
- eg si hatch carpet in ek hatch???
- oil change interval 99% highway
- 99 CX weird problem/question
- EP3 seats in an EG - How difficult?
- Fan problem
- Honda guys/gals in Germany
- Trans Temp Sensor
- trunk wont close on da 4 door
- d17a1/a2 into an ek hatch
- Exhaust
- five lug conversion help. yes i did search
- throttle cable to use on y8 to z6 mani swap
- Sway bar
- Sigh, What happend today
- d16z6 or d16y8 w/z6 head??
- Chasis Mileage
- help: 96 civic hatch swap 99 b16 engine check # p0453
- Steering wheel?
- Help with idle problem
- Name or part # of Radiator fan blocking plate?
- Autometer guages...sensor help
- Ls swap into EK
- idle problem
- would a 97 wiring harness work on a 2000 si
- Would a DC2(non JDM front end) strut Bar fit a EG?
- coolant sensors
- Random jumpy idle lets hear your ideas
- Need Aftermarket Transmission mount
- 99 civic ex no start problem
- excuse my ignorance
- Any way to check if valve is bent...
- Fit: 4 lug Del sol si rims on EK Civic?
- ek conversion
- Input shaft bearing
- Led Gauge Face
- Climate Control Question
- should i get this?
- Car won't start
- Timing belt??? Please help!!!
- Will S2k seats bolt into my EK??
- oil level on gsr
- oil pan question?
- HELP ME photoshop these rim on my coupe please
- wierd problem
- Rear wheel bearing?
- Grounding battery when relocated to trunk of hatchback?
- 99 civic si (canadian)
- D16Y5 with a GSR TB and AEM Fuel Rail, now idling high?
- removing climate control trim
- whats the difference?
- tokico w/eibach vs. koni yellows w/ ground control
- half shaft???
- Distributor Questions, PLEASE HELP!
- shifter problem
- short shifter
- Local Help? Ohio
- STOLEN EG6 - San Jose
- 2000 si my cel code help
- 2000 si oil change filter location?
- head light bulbs ?
- what head bolts do i use
- I need a new Tranny!
- No ignition/fuel electrical gurus in here**need help**
- 94 hatch tailgate adjustment
- Boosting gone wrong
- vtec fluid
- clutch help
- 95 Civic Dash out = No Start
- Need Help, OBD1 Motor Into A OBD2 Car, CEL?
- 99-00 Civic SI Fog Light Install
- HELP!?!! Snapped EZ out in broken water pump bolt.
- New Yorkers: Passing inspection with JDM motor/ecu obd2
- header question
- how do i remove the piston from the rod?
- ?? High coolant preasure why???
- Water in exhaust.....NOOB help
- Civic Overheats Occasionally
- Tech help needed for a site noob!!
- motor swap help!
- gsr swap into a 93 ex coupe
- honda oem parts sellers
- LED dash lights?
- Tech specs and hoe to identify Sir2 cams?
- Brighter Interior Light for 94 Civic Hatch?
- obd0 motor in obd1 car??? help?
- idk whats wrong with my hatch
- My EG build in process.
- z6 mini-me swap help =(
- Honda Civic SI For Sale 8000 98k
- Need help.... Car won't run longer than 5 seconds...
- 1994 Civic dash lights inoperable
- How to retap the block
- Remove drain bolt from engine block...
- cel code trouble / d16z6
- heater problems
- ecu catching fire because of bad vtec wireing?
- B20 cams?
- P2P-A83 auto ECU to manual conversion..
- D-series tranny n axles
- b20 swap help
- Noob help!!!!!!!
- Knocking. W/ Video
- how do i test the radiator fan
- Before I replace the ECU...
- is it bad that my car runs too cold??
- Some questions about lower torque mounts.
- Enkei RPF1. What size on EK4?
- Don't know what to expect really...
- JDM D15B with p29 pistons
- How to hook up ASR sway bar?
- Hard start and code 16
- Coolant hose exploded
- breaks not working would like help please
- putting a tach in my delsol
- kind of new to the H world
- Quiz: Identify this loose connector!
- Courtneys' 94 Sol - Rags to ritches build
- Del sol/eg conversion with pics sloooowwwww process, be patient
- Injector + Clips Order
- How to install ignition lock assembly? Heellpppp
- GRS Tranny, B16a, Eg HELP
- b series flywheel question
- checklist
- car overheats! (b16a)
- civicride93
- new to the whole honda thing need help
- wondering what ecu I use and harness?
- OBD1 OBD2 Conversion harness
- How do you hook a laptop to your engine or ecu?
- Cluster Issue. help identify my wiring and WHAT im gonna do!
- ITR Front and back seats in a 97 hatch?
- super loud v-tec
- pic request gutted civic coupes
- 99-00 dash swap problem need help asap
- WARNING: eBay headers suck @$$.
- I'm an idiot!
- Help! Fixed most of the fornt end and car still vibrating badly
- looking for info 92 d15b7 block w/ 96 d16y8 head
- gauges?
- Problem : How to connect a 60mm catback on a 2.5 header manifold ?
- B Series Valve Covers????
- How much for used OEM 00 Si Suspension?
- Steering Wheel Problem
- spoon twinblock on 96 dx
- comptech ice box for ek9
- What should my vtec feel like...with video
- 93 Hatch Rear Bumper Beam
- trouble starting 00 honda civic si
- V-TEC Controler (What Best place to put in EG)
- Leaking ABS system!
- b16a2 w/jrsc build GSR Pistons? LS crank?
- Hunting Idle with no CEL
- Bad fume from header area.
- b18c1/c5 into EM1
- no heat!
- no heat!
- Whats the easiest way????????
- Looking for quicker steering
- Racing seat bolts, need help asap
- My custom Cluster
- Front of the car wobbles up and down when driving slow?
- stolen parts help?
- Smog question.
- Seat Question into 2000 Si
- EJ1 heater sometimes not workin got mind of its own
- Suspension Techniques Sway bars
- b16 conversition
- Just bought a Civic
- Need HELP! How to disconnect the shifter link to tranny
- Help adjusting camber kit
- Should I run this ECU
- wat intake manifold to user on a h22 eg turbo
- got oil change done, now alternator light
- new motor
- What the hell?! A mysterious bolt from nowhere?
- EJ1 Door Replaced with EG6 need help.
- Recommend del sol bumper
- exhaust fitment
- Need help with 00 Si seats!!!!!!!!!!!
- turns over but doesnt start
- gauge cluster illuminates, why don't the needles?
- Engine swap? What to or best
- dohc zc swap help
- Will a 97 civic dx headgasket fit a 93 civic dx?
- cold start idle
- Stupid ques
- ES shifter bushings Difference? Red and Black
- Fuel injectors for b16?
- rear end swap from acura to civic
- Mechanic Search
- Does any one know...
- b16a swap in a 00 ex 4dr what axles do i use
- What seats fit in my EK?
- Exhaust Question
- Car is not runnin gright wrong ecu
- help: 96 civic fan did not turn on.
- shift knob
- EM1 problem
- PLEASE HELP!!! leaking fuel filter
- code 9
