View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Turbo EM1 (SI) norm qr mile times.......
- Throwing code 20 ELD
- CEL codes 2 (i think) and 22 (searched)
- Oil pump noise at startup, 2000si
- Car goes right after putting wheels back on?
- WTB: oem d15 intake manifold, headers, fuel rail
- K&N Filter Question
- I must have missed this.
- Whistling noise heard inside Cabin at WOT
- Need Help, P08 O2 Sensor One Wire
- Fuel pump not turning on,,,
- excess space between strut collar and spring
- radio code for my Del Sol?????
- Life time warranty on seatbelts?! for reals?
- Quieting down my exhaust setup???
- COLD Weather and Shifting problems
- wtb: civic si tail lights
- driver side civic si headlight for sale
- Hmm, Could porting the head wrong cause it to smoke?
- JDM shit type r lip.. for 96-98 civics
- Transmission fluid...
- Gm/chrystler trans fluid in a Honda?? ? ?
- HELP! need cam caps from a b16 head
- popping in and out of vtec.
- problem (clutch or tranny?)
- JDM yellow Light BULB H4 .......... LEGAL IN CALFORINA?:???????? TRUE OR UNTRUE?????
- HELP Radiator Problem!!
- K20A3
- Last saturday on the NJ turnpike
- Need Help Finding Rear Lip.....
- Road Racing......
- s20 tranny, blown or?
- How many hoses?
- Mini Me Problems
- power window problem!!!!
- b16 in 93 eg swap help needed
- How to Install OEM 99 Civic Fog Lights.....
- heater not blowing hot air? what the????
- should I....B18A..?For $200
- code 13 BARO Sensor????
- rear disk swap Question
- ek stolen and found cleaner?thieves detail cars?
- d16z6 smokes @ 5500... old eng? or simple fix?
- JDM D22?
- high idle and check engine light
- 00 dizzy v-tec...will it fit on a 2000 civic dx non-vtec??
- thermostat d15b7
- NO Speedo and NO VTEC, tried everything, HELP
- which would you buy?
- intake manny swap-worth it
- axel help!!! will any b-series axel work on my 1990 integra
- lowering question
- Hello
- 96 ex, d16y8
- Clear Bra?
- What potential is there for a JDM D15B in a 94 Civic hatch?
- Pro Honda Dot 4 Brake Fluid
- b18a1 help on passing in Cali smog or bar
- Stuck between decision of either the B16 OR B18b in my eg, which is better swap
- Is my D15B a REAL JDM motor or are the letters ground off?
- Trying to cure my burning oil problem
- Oil from the Air Filter=Damage?
- steering wheel
- Del Sol: I want a Comptech Ice Box!!!
- Roll Bar question
- Axle question.
- 99ek civic bumper on a 96 ek civic 4dr/
- 94 CIVIC HB/ 95 CIVIC COUPE LCA??
- unknownly fast del sol
- squeeking when turning and over bumps.
- 92-95 civic coupe-AUTO. B20 swap
- any 1/4 mile times for d16z6 with mild upgrades???
- vi-rs?
- 92-95 Civic Feels Widebody kit
- I think i blew my clutch actually i am almost 100 % sure i did
- jdm d15b cooling problems
- Adjusting headlights on 2002 civic
- hood not latching.
- would accord ground control coilovers fit my EG?
- d series PS pump on a b series
- will EF sedan axcels fits to B16A2 EG ???
- quick question about tail hook thing
- metal cover on tranny question
- Headlight wont stay on
- a/c leak....but can hold a vacuum????
- Driver Side Headlight
- oxygen sensor stuck old header old header not fit in car
- NEED HELP! 98 b18c1 into a 97 CX
- Slight gap between axle - tranny = Bad? Pics Inside!!
- Spedometer is not working and redlines at 5500...Vtec is not working either!!!
- noise from shifting
- new goodies are on there way to my house right now :-)
- Rear quarter panel
- 30000 mile engine replacements
- clutch problem
- WHATS THIS?? HELP!!
- 92-95 honda civic intake manifold problem?
- converting ek to odb1
- What would you do with $3500?
- Need help, opening DEL SOL trunk, (keys Locked in it)
- help on 96 civic dx
- usdm b18c1 question
- 2000 Civic SI or Type R strut tower bar install question
- Help, popping noise and hesitation
- tow ?
- 2:48:31 pm . . . . . . GOOD NEWS! . . . . . . :D
- IACV
- 2000 civic wont start!
- Help - I think my dealer is full of it
- help!....rsr exhaust into 96 civic hb....with b16/jdm header
- Importing a car?
- Question about not starting up
- 99-00 si grille fitment Q!
- EK cluster in EG POSSIBLE?
- 16 valve head on a d15b8 motor with 8 valve head
- anyone switch from ctr to skunk2 stage 1 cams?
- 1995 Civic DX, Suggested Tires?
- ek shift linkage question
- gas gauge
- knock sensor question
- Grinding Noise from Front of Car Help Please
- gsr and aftermarket exhaust fitment
- b16a2 idle problem
- d series broken shift fork
- Need 'How-to" installing EK CLOCK
- motor build help
- Another Idle question
- B-series 6speed transmission
- Engine, good or bad?
- Hayden Oil Cooler
- HELP: removing side kick panels on 96-98 civic
- Yellow or Clear fog lights? for Civic 92 HB
- EG power folding mirrors
- Oxygen sensor placement question, researched.
- d16z6 idol
- 1995 civic only gets 200miles on a full tank..need help!!!! eating gas
- del sol edm aux light projectors
- Speed Sensor?
- maintance????
- Blown Engine, any Business in Seattle that sell JDM Engines?
- VX/EX OEM Front Spoiler question.
- windows wont go up.....
- 94 gsr throwing 23 (knock sensor) and 43 (fuel supply...
- NEED SOME MAJOR HELP!!
- Where Or How Can I convert My 94 Civic Ferio into 5 lug...
- Speed Sensor Fuse
- eg with b16a
- WTB your EK broken cluster
- PUBLIC SERVICE ANNOUNCMENT - B-Series in EK = P7J A/C Bracket...
- Any lips available to increase downforce?
- Any thoughts on AutoTap by B&B electronics...OBDII diagnostic tool
- Are these the proper steps to check my timing belt?
- '97 EX, no MAF adapter on intake
- modded EJ1 side skirts
- body kit
- ALL eg SEDAN owners.... how does your car handle & your setup ? ? ?
- Decided Swap D15y8 for H22a (delsol Si 1997)
- which spark plug do you guys prefere?
- WTB - Water Pump and Timing Belt
- help me now!!!!!!
- Auto to manual conversion for a 93 ex
- for trade
- DIY/How-To write up, should I do it?
- help! my clutch is too soft.
- EG6 and EH2
- Help car acting funny!!
- Need Basic Smog Information... Any info would help..
- I need help
- s2000 seats swap !
- Diff. b/w OBD1 & OBD2 for B18C1 95/96
- INFO ABOUT OBX LSD
- Check Engine Light after Head Replacement
- any suggestions on fitting 95gsr backseats into a 2000 4 door civic lx?
- Help Please
- JDM SIRII caliper replacment (searched)
- Nology Vs MSD Vs NGK
- 98 Civic Acceleration Hesitation
- Del Sol JDM gauge cluster swap
- wings west rs side skirts for eg hatch
- Is a mini-me worth the money?
- Spongy brake feel after bleeding
- swap prep?
- spoon cluster
- Wire Tuck
- d series indentification
- WHATS this clacking noise?? HELP!
- Is this a good buy??
- T-stat housing: Which ones have fan switch on them?
- CODE 22 Need some Help
- AC Problem 93 Del Sol
- white smoke coming out of valve cover breather??
- b18 swap wont start
- Valve question- B series
- third brake light
- dash trimming
- Tuning AEM CAM
- Need Wheel Bearing Replace Tonight - <SO CAL> WILL PAY !!! ANYBODY HELP ???
- EG fog light install "how to"
- low idle issues
- Fogs...
- HELP !!
- NEED HELP! Dizzy problems/not starting
- STUPID ME....DID STUPID SHIT...HAHA
- Quick release steering wheel? How to install? Need help!!
- clutch acting up..
- New here...and i come to you with a problem already...
- Quick ignition Q.
- Rear glass wire antenna in '99 EX sedan real weak?
- vtec ecu
- SRS light flicker
- engine
- eliminating one of my o2 sesor
- need some advice on boosting a D16Y8
- new turbo with blown oil seals?
- directional tires, which way towards the front?
- How hard is it to fit rsx-s seats into a civic?
- Swapping in D16Y8 into 96 DX hatch?
- Oil drain plug torque?
- civic vx o2 question
- after market wheels and gas mileage?
- can an o2 sensor cause this?
- Quick 96-98 Driverside Fender Question
- need to fin dout axle nut size for 92-95 eg
- Accel 300+ Digital Ignitions
- block heater wiring
- mechanic shop help
- pic request - 4 door civic - 92-95
- Need some advice on a 91 civic DX.
- AMP
- power locks?
- rearquarter rust on my eg...
- WTB: 93-95 civic coupe fog bezel!??i just
- Help where to get denji headlights? need 2 replace ASAP!
- Do DIY rear camber with BOLT & WASHERs work?
- 3 Angle Valve Job and Guide Work?
- civic suspension HELP KYB struts & ground control coilovers
- Seat Swapping into 96-00 hatch
- s20 trans install
- F*cked up my wiring again! HELP!
- ------do stock tires look good on si rims-------------
- Exhaust for 92-95 hatch interchangeable with 96-00 hatch?
- Steering wheel trouble!!!!!!!!!
- clutch and steering problem
- rollcage question
- power steering.... power window
- 5lug conversion small problem, gear box bolt/nut! Help please!
- del Sol car cover
- Question about 1996 Honda Civic CX/DX Engine Bay Harness!
- aftermarket intake + stock intake tube?
- Engine Harness
