View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Jdm headlights
- LS Vtec Turbo??
- 96-98 jdm sir bumpers on 2000 civic
- AC fuse keeping blowing after compressor replacement.....95 Del Sol b16
- Noise Problems! Engine is loud, could it be my intake.
- 96-98 Civic door Handle Removal HELP
- Help with windows
- moving to colorado, suspension and tire ques
- What flywheel
- Swap Videos
- Z6 Manifold vs. Megan racing header
- removing drive axle
- TL HIDs?
- Simple Question about a b18b stock
- wiring harness ques
- please quick help
- Trouble Starting After Engine is Warm
- Itr ecu on a b16a2
- reset ecu
- Coilovers
- different computers
- best tranny fluid?
- Installing a/c into non equipped ek hatch?
- Weird dizzy wiring problem? b20 swap obd2 to obd1
- Burning oil, black smoke, low comp.
- Heres a good one Ideas?
- fuel pump problem HELP ME PLEASE!!!!
- My car has become slow and gay when it was once fast and cool. HELP!
- New Head
- which turbo?
- need help no power to ecu and fuel pump
- Energy Suspension shifter bushings question.
- Did a search but cuoldnt find reliable enough answer-z6 dizzy fit on 93 dx
- Skunk2 mega power
- OBD1 motor in OBD2 Civic only reving to 4000rpm
- dow identify d16 block ?
- b20b mounts..
- struts
- d16z6..putting on a y8 header and b18b tb?
- stop the squeaking!!!!!!!!
- Timing belt question (cam)
- vtec question about ecu's
- loud whirling noise coming from the rear
- I swapped engines now my car wont start. Help needed idk what to do.
- spoon or wwrs?
- b18 shift linkage
- Honda Civic 96 power lock problem
- spoon calipers on 4x100
- skunk intake manifold
- Please can anyone help me??
- Header/stud help please
- Problem, and confused which it is?
- NEED INFO................LS VTECH AXLES
- y8/a6 mini me headstuds?
- Putting an integra b16a/turbo into a 93 civic/1.5, I need help, my first honda/swap!!!
- Temperature meter rising????
- piston rings question!!
- Oil leaking out of my head
- foglights question
- EG shifter into EJ1
- Steering wheels...
- Clutch issues
- guage cluster does not work
- rocket m22 cams
- vtec engagement
- can neone giveme addvice!!!!!!!!!!!!!!!!
- Idle issues on a D16
- VAFC Question.
- B16 Turbo
- jdm eg visors
- interior
- b16 head/gsr block head studs
- 93 ex won't role over
- need help rewiring my radiator plug?
- p28 ecu idle??
- Charges No Longer Needed to SEIZE (and Destroy) Street-Racing Cars in Canada:
- wiring problem....PLEASE READ!!!!
- 97' civic keyless entry? will it work without stock radio?
- some body help me
- code 2
- WSII exhaust HELP!!!
- B16b tach signal wire on ignition disdributor? wire color?
- CTR Suspsension in 1999 civic ex coupe
- civic front bumper
- bodykits?
- overheating
- blown head gasket question
- if i.......
- no a/c
- tranny fluid change Q.
- o2 sensor keeps going bad
- d16 having problems reving past 3krpm
- Need help
- Ek4 problems..
- 00 si motor swap
- Urgent repair Question
- noises coming when in higher rpms.
- god im confused
- ecu upgrade on my del sol dohc vtec
- My b18cr V.S. GTO 5.7
- 93 civic coupe with H22A, Transmission replacment
- 96 civic non power window problem
- all motor ls/vtec
- Idle problems!
- how much does this go for
- HELP ! civic si 1999 Interior lights(cluster,ac lights and gauge keep shutting off)
- Don't have adjuster dial set up for 1 of my shocks
- Headers to test pipe
- exhaust falling completely off a hb? possible???
- -->Running like crap after compression test..? Please Help!<--
- hondata s300 question....
- should i do this swap
- how can i wire my jdm headlights?
- Need Help: EG with H22-R, No RPM Signal
- swap in 93 sedan
- black interior and JDM amber climate control... (lacking instructions)*
- B20B Turbo vs K20A2
- Timing Adjust
- will 17's fit on a EG with a 1.5 inch drop?
- *HELP* Another PASS inspection OBDII car OBDI ECU
- NEED HELP WITH SEATS!!!!!!
- Box connected to air filter
- Help: Throttle Cable for B series in 1994 civic
- how to register a real EG6 RHD in Florida
- the car will start an the u can hit the gas and the car dies???? any help!!!!
- Power Door/Locks Conversion
- Speedometer does not work
- pwr window help
- 97 EK 00 B18c need to keep a/c & p/s
- Estimated Price for Registering Your Car?
- ls/b20 swap headers..?
- USDM/JDM EG Headlights
- autopartswarehouse.com
- 1993 Delsol SI
- B2C pillar bars for EG - they did exist, help me find one
- single cam tranny's
- is f22 rear bracket same as h22 rear bracket for eg swap?
- anyone?
- I need new brakes.....but which ones?
- No spark! Now I'm out of ideas and desperate.
- ******************please help as noone seems to be able to help in the hybrid forum***
- good sites?
- will 92-95 civic d16 mounts fit in an 96 with a y8???
- Just Happened: Stolen EG coupe in VA. B20/Vtec Boosted.
- What's better? Coupe or Sedan?
- Why the hell wont the bolt go through the rear motor mount?
- D16z6! got some questions...need input!!! :)
- OEM WHEEL LOCKS!
- lights dim after swap??
- alot of k24a1 questions pics inside
- EGT/WideBand
- o2 sensor help
- Installing Civic coupe doors. Super heavy, how to go about it with just 2 people?
- blinker not blinking.........
- i kP0301 No. 1 Cylinder Misfire
- 99-00 turbo headers which brand is best for good price
- our imports gettingg crushed by the court!! look at this
- ****NEED TO KNOW ASAP***** PLEAZ!!!!!!!!!!!!!!!!!! BIDDING ON A CLUSTER, NEED HELP QUICK
- I need brakes...but what kind?
- What is a Mimic or mini mi...It's a civic Vx and Ex combine....?
- How much should I sell this wing for?
- look
- Hot air when outside vent open???
- ***Trying to identify SOHC head Vtec or Non Vtec D15b***
- ls-vtec problems runs way to rich
- f23a1 swap in 93 civic sedan
- 96-00 HONDA CIVIC MSD CAP DISTRIBUTOR EXTERNAL COIL... Are they a good idea?
- Need help with my new head gasket!!
- squeaking brakes
- NEED HELP installing the turbo on my d16y7
- spoon n1 exhaust
- please help asap
- Thinking about a swap
- Strange Auto to Manual Question.
- 95 civic
- 99-00 Civic Hatchback Front Bumper ???
- bogging on acceleration
- Replacing clutch slave cylinder... how to?
- ??? oil cooler installation
- how to remove side moldings?
- d16y8 snapped timing belt!!! bent valves?
- 95dx valve cover gasket
- Getting B20B Vtec to pass smog @ state referee station
- will gsr headers fit on a ls??
- my b16 hatch build thread
- Is this A/C Pipe/Line repairable or junk it?
- which d-series hydro tranny has the loggest gears DX CX EX?
- CTR BUILD ??????
- Help! GSR Swap
- no fuel pump, injectors, spark. main relay works. keep blowing sp fuse
- question.....
- 2 issues; Rattle when AC is on, and E-brake light turns on when I accelarate hard
- VTEC Not Working? No CEL just a Stuck Speedometer Needle
- Why are Body Kits bad?
- QUESTION ????
- spare tire...
- Code 0 problem
- question on what ECU should i use. for b20
- fast check engine then dead help..
- weird turbo set up...
- mini meeh question
- engine oil 5-30 or 5-20
- removig stock headlight cover on 92 eg6?
- tire pressure?
- I got a k20 crankshaft
- Shock / Coilover install question.
- from a coupe to a hatch
- SOCAL Residents Beware!!!!!!!!
- question about a throttle cable. 95 gsr motor in a 97 ek
- Ek foglights
- suspension for a 93 dx
- code 45 too rich or too lean
- EG HATCH CARGO LIGHT WIRING
- what else could it be?
- No more gas money!!! WTF!?!?!?
- a/f ratio question
- Are fuel tanks between CX and DX interchangeable
- wat is the torque on putting the bottom end back
- 92-95 Head Light Improvements
- Lower splash air dam dynamics?
- 99 Honda Civic LX --- HELP
- ITR Cams?
- Stolen #'s
- gsr head and b16 block
- Aftermarket Crank Pulley/Stock alternator Pulley Belt....Questions
- convert p06 to vtec is it possible?????
- si eg help!!!
- fuel filter
- groning noises and metal chinging noises - ek hatch
- spoon style rims
- IACV, FITV, and gas mileage :( help me and I'll love u 4ever
- 97 HB w/ b16a2 CEL #9 out of the blue?!
- Blinker not workin.......
- Service thing on cluster
- Inserting a mesh grill.
- heat wrap
- Early signs of the wearing out clutch?
- denso o2 sensor?
- My 1998 EK hatch w/B16b Spoon, Bride, Takata, Cusco etc etc
- need help with alternator problem...
- clicking on start up?
- performance exhaust and header on gsr
- 10w-30 in Si instead of 5w-30?
- Just did GSR swap and tranny side axle is 2 inch short??? CONFUSED!!!!
- antenna
- Raido problems
- Plz Check my work Wireing !!!!!
- will an oem exhaust from the cat back fit an ej8???
- Brakes???? Please help
- signs of detonation... how bad?
