View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Loking to swap.
- neutral safety switch making my car not start?
- Which do you think is better? Wilwood brakes or Baer brakes?
- anything "wrong" with Ebay seats?
- misfortune with my 00 si
- D15B8 Firing Order
- 98-00 civic
- Spoon Brake Rotors?
- 1997 HX Need Help
- heat shield
- need help with "D" engine swap..
- need info about the eg6
- Speedometer keeps going out!!
- no spark
- Quiet while still good performing exhaust
- GSR cams or others in my Si........
- 200k miles on hatch.. time to replace drums?
- Need Help!
- how do i make foglights yellow???
- what distributor to use? odb2 engine obd1 chassis
- Code 14 won't go away!! HELP!!!!!!!!!
- AC + Throttle Body
- wat stage clutch should i get for a sohc turbo
- How do you adjust?
- greddy bolt on turbo kit
- QUESTION ABOUT BRAKES ON EG
- QUESTION ABOUT SUSEPENSION ON EG
- Erratic RPMS, misfiring? clutch NOT slipping. WTF
- need help on my project
- R low beam wont come on
- picture thread?
- FS:Again 1992 HONDA DEL SOL SIR (RHD)
- starting car wiring
- Bent shift linkage?
- brake lights
- Anyone giving Carfax's?
- 92 Honda Civic Engine Idle Problem Help
- fuel pressure setting on ctr with fpr
- tell me what i did so my car wont start
- eg k20 lucky
- Ferrea sodium filled valves aka hollow stem valves
- setting cams at TDC? How do you know?
- I need your help
- D16 Engine Rebuild
- Is checking a CEL code the same on a 98 civic as a 91 CRX?
- ***need assistance, quick question***
- wishshield wiper problem, Can some1 help?
- Gearbox diagram
- Pics of White coupes/hatches with jdm corners or amber
- mESSED UP D16Y8 ENGINE ANYSUGGESTIONS??
- PORTING AND POLISHING SERVICES
- Steering column
- complete obd1 to obd2 change
- Which honda center caps fit the rota gt-3
- NEED HELP.. ecu wiring schematic
- D16y7 cam
- My story after buying konis for my EK from HT sponsor ExtremePowerOuters
- Engine swap
- Help please: d15b vtec-e vs d15z1
- exhaust compatibility question?
- B-20 W/ GSR head
- To get a camber kit or not?
- OBD1 GSR bottomend into a 00 SI question
- New 2006 civic
- I have information on thiefs in socal!
- removing intake resonator... worthless mod?
- Knuckle buster Fiamm horn install- done~!
- Problem after problem after problem.....
- ACG fuse keeps blowing out (searched)
- ABS & skidmarks
- Need A New Engine in my 1998 Honda Civic DX...ASAP (SO CALI)
- CTR seats
- exhaust question
- CAR GOT BROKEN INTO,LONG ISLAND NY
- Taking out the tint paint from tail lights
- 92 hatch problem
- Honda Civic Hatchback VX d15z1 - how much MPG can this thing get?
- Need some help!!! What intake.......This is my 3rd one...
- apexi safc question
- Need hlp Timing belt for Jdm d15
- ball joint INSTALL
- solid check engine light and car wont start
- Help w/ high-mileage 98 civic
- i hate cf hoods
- my buy of the year
- Update... for flucuating idle
- Easier axle nut removal without impact gun (Tip)
- for sale dc headers 4-2-1 carb legal fit b16 b18 b20 i had them on my gsr
- b16a SiR II motor in a sol?
- Will Auto Z6 harness work on Manual Z6?
- kyb gr-2 shocks for an integra on an eg?
- weres the ek9
- Anyone from the twin cities area
- del sol leak problem!!
- b18c5 into EK
- SWAP INFO?????
- SITE FOR HASPORT MOTOR MOUNTS
- Obd2-obd1
- New to the Honda scene, need an expert for explanations!
- Stretching JDM ITR rear seat bench skin on EK bench foam???
- aem fpr adjustments
- Transmission is becoming harder to shift
- How to get Caliper Bracket Bolt off?
- msd 3 bar map question!
- which computer and wiring harness do i need to get???
- Anyone got pics on a DIY ek sideskirt install on Eg, Ej
- what kinda tranny do I have
- pic request: 4 door EG's with foglights
- the dc dash doesnt fit in the ek does it?
- lets talk $ and cents
- USDM '95 CIVIC Coupe JDM H22A1 Hybrid, Engine backfires and sputters.
- is this a problem
- Motor Swap? 2000 EX....GSR/SI/RSX help!! Anyone with personal experiance?!
- d15b hatch problems with tranny
- questions about engines + extra horsepower?
- Brand New Civic
- 99-00 SI foglights
- how much power?
- Are civic front seat rails swappable with either side ?
- Dirty Headlight Housing
- does the 96-00 ek's have a clock?
- does the 96-00 ek have a clock?
- vafc w/p30
- Slight problem with EG swap 92-95 civic
- need some help from u techies
- D15 to D16 Swap
- acura el dash in black?
- act clutch problems searched
- what throttle body gasket for obd1 jdm gsr????
- Intake hose to valve cover
- Grey/black goo in overflow tank
- Hey guys i need some help with a harness (searched)
- high compression GSR..reliable for daily?
- EP3 steering wheel in a 95 accord?
- d16z6 auto man in 5spd car..need help
- Transmission GURUS, need your help. No 4th gear, already searched
- Brain Fart!!!
- headers smoking
- i need a quick answer to a stupid question: ground wire
- searched to no avail....some interior swap questions
- Dirty Head & Intake Manifold... Any recommendations?
- d16y8 turbo CAM. wat is the rpm redline?
- td44 td68u
- do ap1 (s2000) rails fit or bolt on the ek chassis?
- 89 prelude seats in ek?
- Will it pass smog.
- VTM sensor?
- i need a shell please
- Help me find this part! (Headlight retaining clip)
- WHAT IS THIS !??!
- 96 civic lx door locks
- What intake manifold will fit?
- b18a block/b16 head swap question
- buddy club Spec IV cams
- Check engine light! help!
- serious b16 swap troubles
- i just ran a low 10!!!!!!!!!
- Downtown Daygo [someone jacked my intake yo]
- What axles?
- I got some noises and need help
- What would cause the SRS light to come on steady - 00'' si ???
- how to mount ecu 99-00 Civic?!????
- rear view mirror
- Stock Si CAT = Ex CAT?
- Car Stolen, recovered. Fix THIS, or say fuck Honda's? (PICS of damage)
- Photos of the Civic*56k warning*
- I have 15" enkei rims, I have a question regarding fitment
- Anyone ever found their stolen car with GPS?
- Thorwin some codes..
- eg ignition question
- wtb A/C Kit
- 99-00 si shocks
- Greddy Emanage
- LS 4 door Civic
- Tig welding tranny..?
- Used A/C Parts
- 99 si stereo into my 92
- is this an 02 sensor problem?
- Having compression/sparking problems. Please help.
- i need a 92 lx power steering hose
- axles wont come out of hub HEELLLLLLP!!!!!!!!!
- Is there a wings west lip kit for EG 4 door?
- Removing a/c compressor question.
- STOLEN HATCH!!! Cerritos
- Strapping down car on dyno. (missin 1 tow hook)
- 93 integra brakes on 96 honda civic
- 1 Muffler + Another Muffler + 14'' Resonator = Kill Power?
- oil in distributor cap
- Which EK sideskirt 2dr or 4dr
- rear drum swap
- GSR Throttle Body On B16a manifold?
- skunk 2 cat back problem
- Whats needed to install a header??
- stolen cars
- what parts can be for auto and manual
- Clicking in the fuse box when trying to start?
- EK and EG front lca's, interchangable?
- e final drives
- Right crank tool for 92 civic dx hatch?
- 98 Civic Wiring and dashboard diagram
- Female Racers ?....Post pics here
- What's the best place to buy ONE Volk wheel?
- Complete Engine/Body Wiring Harness - Del Sol Question
- HELP! CEL 70, anyone w/ experience PLZ
- koni shocks for ek - was I sent the wrong model??
- Car idle goes up and down after putting in a new bolt for motor mount. 1000-1500 then stops after a
- Window sashes...where to buy?
- slave cylinder
- Civic 98 trans problem.. with trans control unit
- h22a motor
- Converting motor from obd2a>obd2b?
- i have a blown head gasket
- questions on shocks/struts
- need help
- rotator cuff at base of steering wheel
- Could not wiring in your knock sensor cause other codes to come up?
- 2000 Civic SI Back Bumper
- Transaxle/drive axles help!! 00' honda civic EX with a 01' tranny EX
- coolest civic thread ever!
- 95 Hatch clutch pedal issue
- B16a2 Vtec
- d16z6 going to gsr swap need help on power steering and ac info.
- Swapped JDM B16A Throwing Map Sensor Code
- clicking at idle when car is warm
- Help From The Almighty Ones!!!!!!!!
- 2000 civic si help!!!!!!!!
- Is it a good idea to resurface a act flywheel?
- Does anyone have a DIY clutch swap for a B series tranny?
- swap problems
- Idle controlling
- EG gets VIOLATED Nor. CAL BAY AREA...
- Rear disk spindle problem(hub\bearing)
- Please Help!!!
- Need help with 92 civic
- How to install front lip
- B16a EG wont start - but just clicks when the key's turned... HELP!!!
- Aftermarket ECU's
- d15 bogging while suddenly accelerating(not cables)searched
- Spoon Head Gasket With CTR Pistons
- call to all bench racers need an estimate!!! also boost q
- 11 second b18b1
- Stolen grey eg in Triad area of NC
- code 41
- Window stuck and car stalls w/ a/c on
- CODE 9? 94 Civic EX??
- CAlifornia somg referee
- What about the teeth......?
- Idle Problems
- Rear Washer camber adjustment : UCA hitting wheel?
