View Full Version : Honda Civic / Del Sol (1992 - 2000)
- no vtec runnning rich
- B16a not running right Help!!
- Hasport Mounts (Missing a part)
- Mobil 1 vs Castrol Titanium, Valvoline Synpower
- Need help! NO DASH LIGHTS! 95 civic ex d16z6
- Ignition problem. Can't tell what it could be. Details inside.
- Del Sol head light diagram
- Pulling the engine without the trans
- 1996 honda ex with JDM b16a SirII swap running OBD2A P2T ECU
- Matching of IACV
- Ek Driver rear window installation ?'s
- key stuck in ignition
- Sound deadening writeup?
- Squeeking noise at idle and when i turn my car off
- D16z6 rev limiter at 5500rpm not poping vtec need help!!!!!!!!!!!!
- NEEEED HELP ASAP ANYONE PLEASE!!!!!!!!
- 2000 Ek Hatch build- Done, but far from it!
- b16a2 ctr or itr cams
- del sol stalled - won't start MYSTERY!
- sohc valve cover question! Help!
- 99-00 Fog Lights Bulb
- no spark b16 swap
- No start
- replacing knock sensor on a b16
- Hatchback & Coupe oem fuel / brake lines?
- EG with JDM GSR Swap question
- Huge problem - axle broken off in transmission
- Another random stall thread
- Heatshield Bolts - thread type?
- Windshield wiper on back hatch window?
- Power windows and locks in CX
- Broke Oil Pressure Switch
- Knocking/slugish acceleration.
- 2/3/4 door, outer door molding compatability?
- Rust repair
- How do I install A/C in my Civic CX?
- D16Z6 oil pan removing
- Civic wont start after long drives.
- Temp gauge circuit diagram for 93 civic
- 1998 honda civic dx manual lock not working
- any good manuals for replacing the trans
- Fake J's Racing whale penis intake non-carbon fiber. Where to get it?
- What are the main reasons wheel bearings go bad?
- Oil Analysis - Opinions/Input
- Grumbly/rough downshifting
- EK QUESTIONS about cluster swap, blown dash lights fuse, and water leak
- D16y5 96 Civic hx spark plug wiring diagram?
- Clunking/clicking noise?
- Honda 98 Civic - P0117 P0118 broken radiator
- srs MES problem
- what is this wire in my 93 Del sol?
- 1995 Civic smog help!
- 98 civic hx/d16y5 - chip it or cam it?..
- 99 ej6 with obd1 b18b won't start-has fuel and spark
- 93 del Sol Si brake upgrade
- y7 tranny to y8 tranny same axles?
- WHERE?!?!?!?!
- What do you all think of my doc to organize and prioritize my build?
- Where do I find a synchronizing piston for a D16Z6
- 98 EX b16a idle problems
- b16 vtec solenoid question
- hw much should i pay labor for cv axles, wheel bearings and brake caliper?
- Where do I get clips for the side molding of a 96 ek hatch?
- A/C blows cold air SOMETIMES, but not all the time
- 95 Civic won't fully fill up. Filler neck?
- 99 Civic with 83K miles - Is there any other maintenance I should do?
- replacing piston
- 92 civic b18 IAt sensor help
- Removed alarm car doesn't stay running. (2 stray wires under dash fuse panel)
- 93 Del Sol: CEL 20 Electrical Load Detector
- Anyone have Corbeau TRS seats installed in an EK?
- Do NGK ZFR5FIX-11 Iridium IX Spark Plugs need to be gapped?
- Rocker arm torque specs?
- 1999 Civic - Bumper and innerfender removal
- 96 ex coupe wont pass smog in first gear but does fine in 2nd. Need help!!
- Clock resets itself everytime 95 civic si is started
- The Monster's DD 95 Civic 4door build thread
- timing a z6 head on y7 bottom end
- D16Z6 Tensioner! Need help removing/replacing.
- eg foglights
- Del sol b18b1 won't start
- NEED HELP wiring O2 sensor into 96 Civic EX/jdm OBD2a B16A swap
- screws broke off in distrubutor
- need pinouts: 92-95 civic shock tower
- rattling sound from axle (part question)
- 96 Civic/b16b swap - 3P to 4P alternator connector conversion?
- '92 civic wont start - no spark, need help troubleshooting
- EJ1 Backfires On Start-up
- Cant remove torque mounts on ej6
- 2000 hatch build!
- Mayfly's build thread
- EM1/JDM type R swap - white/greyish smoke at idle after revving
- Air Conditioner Screeches
- Del Sol interior Project threads anywhere?
- 99si w/b18c swap need new primary o2 sensor
- D15B7 weak spark issue
- battery being drain
- 97 Del Sol: Need help locating interior door panel
- 95 Del Sol - Tach Stuck At 1500 RPM ALWAYS....
- 92 Civic VX - No start
- What is this called? -See pic of steering wheel plastic covers with the light
- 1998 ex B16a2 swap vtec problems
- Thmanx's R-DOT B18C5 project
- 98 civic failed smog - CA
- del sol b16a3 idle problem...AGAIN
- Wheel Pushed Back on Passenger Side
- ecu sohc v-tech
- How do I fit 90-93 GSR seats in a eg hatch?
- D16y8 Hondata questions
- Help! OBD not reading O2 sensor...new wire or new computer?
- 97 Civic Si/B16a2 swap/B18c1 ECU - Can't Read engine codes
- 2000 Civic Weak AC?
- AC Compressor Issues
- cracked rings? quickest way to fix??
- Help! D15b7 mini me z6 head
- b16a cold start high idle, surging off cold idle-NOT FITV or IAC problem
- 92 civic brake light and horn fuse blowing when i step down on brakes
- exhaust hanger size for holes 8mm or 12..
- 96 Civic alarm system problems -- Flashers on. I did not turn them on.
- D16Z6 Leaking oil
- need help engine smoking ??
- 00 Civic DX manual -- ECU REPLACEMENT
- 00 Acura EL/B16a2 swap - LOW idle problems
- Will a transmission out of a vtec work in a non-vtec 1.6l engine?
- Thinking about buying a timing light - What features should I look for?
- 98 Civic - Fuel cut problem?
- Axle is loose on the trans end
- transmission issue
- Reduce those annoying knocking/tapping noises
- Crank sensor missing in engine swap?
- P0420 code after I replaced exhaust manifold and cat
- Will a Y8 throttle body with a y8 tps sensor work on a z6 engine?
- gsr or ls block build?
- What Honda catalytic converters fit civic?
- How pull codes from a P28 ECU?
- em1 electrical issue - power locks stop working after a few times
- 2000 si speedo/alternator questions
- question ?
- Please help, car shuts down when gas is pressed
- EG civic cx wont turn over...HELP!!!!!
- camshaft stuck valve adjustment??
- 1993 Civic ex leaking passenger axle.
- Needle Jumping When Car Starts
- Need review of Spoon Sports street exhaust
- 99 Civic : Snapped bottom starter bolt
- civic wont start everytime
- power door locks inop
- prove me wrong
- D15B2 Head Milling
- HX 5 wire o2 sensor help
- Fit lip on 97 civic
- 98 ek with 96 gsr - high idle problem
- How do u test a fan control switch?
- Need input on installing power steering in my Del Sol
- 94 Civic Emissions problem
- wiring problems cel 9 ecu pinouts
- 00 Civic Si , Misfires,Dies When Pulling 4th plug out, Oil Behind Manifold =
- 97 ek lil problem need help PLEASE
- Stumble Issue 94 Civic Hatch
- crank position sensor problem
- MY Civic cranks but it doesnt turn over
- 97 civic trans problems
- Jdm 36mm brake swap ek hatch
- *****HELP: Trouble turning over after several hours of being off. Details Inside*****
- 92 civic b20b4 swap converted to obd1 dies every time I slow down
- Are non-vtec Y7 rocker arms, springs, retainers, etc compatible with a vtec head?
- soft clutch pedal
- cel stays on car wont start
- 98 ek has no spark or power to the fuel pump
- Adjusting Clutch Pedal Catch Point
- rear disc hub and rear drum hub, difference??
- How install skunk2 prosearies intake manifold on Civic HX?
- Need wire diagrams for P28 ECU plugs
- What momo steering wheel is this (see pic)?
- 95 Civic cooling fan start up problem
- Eg/H22a4 swap - dead cylinder 1
- 96 Civic EX: continual no-crank problems
- '94 Del Sol Squeaks on 2nd
- First gear shaking problem
- Help: d16y8 Stock intake/airbox plugs
- How to remove knuckle and replace wheel bearing on a 94 Civic HB DX?
- stage 2 cams help?
- ROUGH IDLE; ALMOST STALLS, Weird noise from exhaust
- Removing/installing blower motor
- 99 ex with a ls/v swap - VA emissions fail
- prelude seats in civic?
- 94 cx/B18B1 engine/00 si B16 trans - 3.5K-4K RPM at 70 mph
- Chasebays CM1 Harness install in a EG. {Q's}
- 98 ex rough idle and stalling no CEL
- Rain=passenger floorboard puddle
- ANY QUIET PERFORMANCE EXHAUST BRANDS OUT THERE?
- 1995 del sol roll bar
- 00 civic wheel stud stripped!!
- third gear grinding
- d15b7 piston rings
- quest for fuel economy
- Automatique tranny issues
- apexi ws2 hangs low, cutting resinator too loud?
- So hype right now lol ^_^
- car dies when not warmed up
- Need some tips in converting 96 civic front end
- oil cooler
- Civic CX 99 B16A IACV Problem !!!
- EG8 - stalling problem
- 95 Civic auto - what mod should I do first?
- check engine light ???
- Revs below 1000 Civic 96 ex
- rear upper control arms.. eg and ek the same?
- ej/ek mpg overhaul
- d16z6 fuel pressure
- Fiber head gasket?
- Lower motor and transmission mounts... swap-able?
- ukdm civic vti-s wont start
- AC issues and only 3&4 work on HVAC
- 93 Civic A/C system overhaul
- used AC compressor, how can I tell if it's good or not?
- How to remove the a/c controls from a 93 DelSol
- Help with LCA bolts
- Jdm Gsr Coolant in oil.
- How swap 99-00 Climate Control into 96-98 Civic?
- can d16 throttlebody fit d15.
- 97 Civic EX - To get learning experience, what do you recommend I do next?
- 93 civic limp mode no idea. Help!
- Ebrake handle comes up but comes back down on its own.
- 96 DX EK A/C at 30 PSI but blowing warm air
- 97 civic o2 sensor Question...Help?
- 98 Civic - weird power mirror and locks and speaker problems
- stiff ride, so bumpy, HELP!!
- 1999 Si wont start after OBD2a to OBD2b conversion! Help.
- Issues with replacing rear drums
- 95 civic, won't start... Again...
- civic lx exhaust manifold/cat replacement
- fuel pump wont prime
- 98 Civic - Questions about V-TEC to Non-V-TEC engine swap
- How do I clean up the engine bay on a $0 budget
- can a d15b distributor function right on a d16z6 engine?
- windshield washers for carbon hood
- 92-95 turn signals went out..all of em
- 95 del Sol -- Tach going crazy, any ideas? (VIDEO)
- CEL and car idle jumps from 800-1500 rpm
- Clunking noise from front side
- Have you purchase from rockauto.com?
- weird compression problem
- SiR Spoiler - What is it?
- 92 si too loud
- 99 Civic LX - skunk2 intake manifold needs a different IACV
- What distributor do I use for my 93 hatch
- D15Z1/D16Z6 mini me?
- which valves open at TDC?
- going b20 vtec any sugestions?
