View Full Version : Honda Civic / Del Sol (1992 - 2000)
- What are some OEM shifters can I use with my D16Z6?
- b18c1 running hot why
- Can I use this wiring harness?
- **y7 harness on a B18c1**
- ***B and D series Reverse Sensor Question***
- D16y8 head swap question
- Catback for my 00 Civic EX
- Something Smoldering and radiator fan not working!!
- Type R Build (em1)
- Need Help! RPM fluctuating (video)
- throwing out white smoke... loss of power
- 96 Civic coupe - Turn signal does not work when brake pedal pushed
- power window conversion
- obd1-obd2 help
- 98 civic ex/h23 h22 head motor - Can't put transmission in gear
- Can I drive on a bad Input Shaft Bearing?
- 94 del sol/B16 with 165-175 psi cylinder compressions - Is this good?
- How do I identify my shift linkage?
- manual rack & pinion
- Source for mounting bracket/rails for Recaro SRD into '94 del Sol
- turbo lag?? and surge
- got my baby stolen (Northern VA ~10 min outside of Washington DC)
- Cant link up my OBD2 (link error)
- Engine cleaning
- EK swap .. no battery light ?
- d16a6 w/p29s w/EK HX y5 stock will it work
- 93 hatch/ls swap - Engine won't crank. please help!
- 2000 Civic SE - Auto transmission help
- 93 Civic hatch - starter won't crank! Please help!
- 97 Civic - How to wire up the harness to the motor?
- 00 Civic/OBD2 b18 swap/p28 ECU - crank sensor code 4
- White smoke from exhaust
- '96-'00 Transmission Compatibility?
- 95 Civic Dx/B16 swap - running rough
- 99 Civic Si - Integra intake fitment question
- $160 civic nose mask - good deal?
- built sohc turbo or stock gsr
- del sol 3rd tail light always on?
- 00 Civic LX - Where should I buy a new exhaust manifold?
- Car died in mcdons drive through
- Idle Problem Persists
- Jdm Itr (dc2) seats into an ek
- 95 EG bushing replacement
- 98 ek d16y8 wont start, it cranks but wont start
- Are 96-98 ej8 rear bumpers the same as the 99-00 rear bumpers
- Will y8 injectors fit on a b18c1?
- How do I install Yonaka seats in my EK Hatch?
- Coilover Install For Dummies
- EJ9/D14a4 - What is the correct fuel injector connector firing order?
- 93-97 Del Sol/sohc - Will all D-series clutches fit on the s20 transmission?
- 93 Del Sol S: Will 91 Civic master cylinder work with 94+ Integra non-abs booster?
- b16 code 7(tps). new tps, still a code
- Help! E-brake getting stuck in Canada cold weather
- Car not "re-learning" base idle -93 Civic VX
- b16 high idle
- Backup fuse keeps blowing -93 Civic VX
- eg hatch - Can i adjust my steering wheel? Can I install a cluster with a tach?
- headlight probleme on 93 eg
- oil drain plug won't come off
- Depin ECU jumper
- EG/B18b1 - Engine stalls after degreasing and washing engine
- EK drivers side window doesent work
- how do you make a vx lean burn all the time?
- 99 sohc VTEC makes rattling noise after it's warmed up (video)
- Quick Rear Disc Conversion Question
- Need Some Help. A/C button in EK9 Climate control doesn't work
- Squeaky noise from coming the transmission when i step in the clutch
- JDM D15B w/vtec Cel code help
- car killing gas & not filling up much like it used to
- EM1 won't start
- Misfire just before rev limiter and hesitation after Seafoam
- 99 Civic Si - heater doesn't work after stereo was stolen
- EG pre-purchase inspection checklist?
- How to adjust my idle lower?
- ej8 b16a swap - How do I reinstall power steering?
- Distributor Rotor screw Question
- Size of nuts that connect cat to header??
- 95 Civic ex harmonic puller
- 94 Del Sol - Help with bleeding radiator!
- 97 Civic DX hatch - climate control lights don't work
- Car lock system to prevent car jackers?
- obd2 JDM LS throwing o2 sensor CEL code
- 93 Civic EX - latch for hood broken
- 93 Civic EX - fuel smell in the cabin
- 95 civic - no hp, won't climb a hill
- 93 hatch/jdm d15b - should i run a cat or not?
- 96 Civic/GSR swap - Are pre- and post-cat O2 sensors the same?
- 99 Si - Where is the best place to get a new front bumper?
- 93 Civic EX/D15 swap - How do I gain 30 HP from this engine?
- Crappy idle on normal temp..
- 93 civic lx sedan - looking for opinions on engine swap and wire tuck
- 1993 civic coupe heating problems
- 92 civic eg, heat problem :(
- Transmission problem - grinding noise in neutral, goes away when clutch pedal pressed
- d16y7 and d16y8 valve cover gasket
- 97 dx motor thoughts
- what aftermarket cams are these??!?
- 93 civic b18c swap COLD START DIES
- My $500 Del Sol project
- Jdm h23 bluetopvtec doesnt run hard?
- ckf trick failed
- Will a D17 pressure plate fit on a 96 D-series civic?
- 99 Si - Will any 96-00 coupe axle back exhaust bolt right up?
- 97 EK coupe Build Thread lots of pics
- EG Engine Coolant Temp (ECT) sensor location?
- 96 hatch with d16 - Turbo the d16 or do h22 swap?
- Will the EG B16/ITR hybrid intake properly fit in my Del Sol?
- DIY fuel pump strainer/pre-filter replacement
- Low power, rough Idle
- 95 eg coupe mini-me with D16Y5 head?
- 1998 Civic EX is over heating
- B18b swapped 92 hatch with CEL codes 10, 21, & 41 and also low mpg
- D16Y8 - Timing belt replacement?
- [Civic 92-95] USDM Fuel & Temp Gauge - Question
- 94 civic dx idle issue?
- 94 ex w/h22 boost 10lbs - won't start
- d16z6 bogging
- Has anyone here painted their carpet?
- 94 Civic si/b20 with gsr head -- Can I bolt on any LS headers?
- 1995 civic ex time to buy new shocks?
- Would a b18a1 be a good swap in my 97 Civic Dx?
- Question On Installing RSX Seats in 1998 Coupe
- d15b7 swap.Idle hunt.Help!!
- Need help or wiring diagram for 98 Civic stereo
- b16a2 del sol on EG
- 96 civic ex non vtec swap question
- 98 civic ex powersteering bracket
- Apexi RSM ECU Extension
- Removing steering column cover on a 1997 Civic
- radiator help
- Check out this civic
- b20 golden eagle sleeves in a b18c block???
- 92 Civic hatchback Si - starter won't crank engine
- 94 civic build help
- Replacing 95 coupe d16z6 throttle cable - What will fit?
- How to install 5-bolt pattern steering wheel in an EK?
- 98 Civic LX - Automatic Transmission Shift Problems & CEL
- 96 dx - What's the best inexpensive motor swap?
- Will the stock EG fuel pump work fine with an H22 swap?
- Hatch won't start - no electrical power
- d16z6 and d16y8: Are the pistons the same?
- Stalling & starting problems: Ignition? Relay? Fuel pump?
- Need help with broken male connector for radio
- What is the best clutch for 98 civic dx?
- Water meth injection
- Looking for opinions on buying 93 hatch, swapping in an LS, and boosting it
- Would 01 itr cams fit in my b16a3?
- odb1 b18 in a 98 civic hatch
- After new B20 swap, tranny seems stuck in neutral
- d16z6 low end sputter
- How would I make a longboard rack on the trunk lid of my Del Sol?
- 94 civic lx shuts off while warming up then drives fine rest of the day??
- Turn key and all power cuts off -- Short Circuit? Alarm? ECU? (solved)
- EX headers on my DX engine
- 94 Civic Cx/D16Z6 power loss - Do I need a valve adjustment, fuel filter, fuel pump?
- 97 Civic hatch/667 whp turbo - WEAK SPARK MYSTERY (solved)
- 00 Civic DX auto -- Idle problem re-arose...
- HELP!: error code 14 strange Inital Start-up, and rpm bogg down
- will my d series throttle body work on my b18b1
- K-Tuned Billet Oil Filter
- Cranking but won't start
- Del Sol/h22 swap questions about ECU and high rpm and clutch problems
- B16 civic..What would i need to run in the 13s at the track
- noob question ls/v on ek...how to wire vtec on stock harness
- Need help with 00 Si brake swap into 94 Si hatch
- Failed smog test - High HC & NOx at 15mph but not 25mph
- 93 Civic Hatch/D15b non-vtec swap - What ECU is best?
- Is there a gasket for the coolant outlet cover?
- Car bogs down while accelerating then dies as I slow down....
- Main relay?
- heater and idle help please
- Ignition switch going bad?
- 98 hatch/tuned 01 b18c1 with turbo - Hard start/stalling problem when cold
- DEPO and EK9 stanley side maker installation. Any difference?
- *an Arthas get a va***m diagram for a D16Y7?!?!?
- 97 Civic has large left-right freeplay in both front wheels - Inner tie rod issue?
- Re-Doing A Headliner, What Adhesive to Use?
- Anybody Know where to get replacmnt disk for exedy hyper single stage 3
- pics of Eks with neg camber/wide/flush fitment/broken rear end etc
- Idle problem after cleaning IACV
- '97 Civic LX - Ground Wire Between ECM and EVAP Purge Control Solenoid
- What Wheels you Running on your ek BRG pics and Specs
- looking in to buying a 96 hatch
- GSR Swap Code 9
- What specific CEL codes prevent vtec from engaging?
- will ITR front upper control arm fit on 92-95 civic??
- 93 Del Sol Si - Any good aftermarket washers for transmission drain and fill bolts?
- 94 Civic hatch - need help fixing CD player wire harness
- Noise/Vibration on curves (LHD-Driver Side)
- Which block is the easyest
- metal grinding when trying to start
- brake piston "coming out on its own"
- Overfilling gas causes leaks by LCAs ?
- Brians 93 Del Sol Build
- 95 ex front sway bar on 97 ek? searched
- which parts interchange with JDM d15b vtec?
- 96 dx/d16y8 swap/5-speed - Need IACV help!
- 99 motor in 96 ex. CEL code 4 ckp. Can anyone help?
- H22a1 external dizzy wiring 94 civic
- DIY 93 si power to manual steering rack conversion (pics)
- Where is the "homemade sleeves" thread???
- Non-existent dome light
- Can tuning fix a surging problem?
- Civic Dx Rear Door Question
- temperature gauge cluster on ek
- eg b18a1 at/mt swap starting problem
- hydraulic vs. cable transmission axles.
- Buying motorswap online
- gsr axle replacement help
- My Del Sol is a GROSS POLLUTER!! Need Help!!
- 2000 civic question regarding struts
- H23a Civic Bogs After Warm.
- CEL problem - How Bypass EGR for 97 HX Civic?
- O2 sensor relocation. Did I do good or bad?!
- Will a 91 alternator fit a 92-94 d15?
- Honda Automotive Parts for JDM Civic
- D15b7 automatic not accelerating when pushing the gas when its cold
- Intermittent hesitation Please Help Me
- removing crank pully on d15 with auto tranny
- Del Sol - How access space below rear window?
- What CEL code is being thrown?
- 96 Civic CX wont idle, surges
- d15/z6 mini me swap idle problem
- 99 gsr swap in eg...extra plugs???
- changing head gasket on b18c - need tips and torque numbers
- what are the symptoms of a faulty coolant temp sensor
- D15B8 head is noisy at low rpms - Should I be concerned?
- Electrical problem!!!
- 93 del sol/newly swapped 5 spd 97 D16y7 has high and fluctuating idle problem
- Over-heating problems with Y8
- Tach working funny. Any ideas?
- turns over but wont fire
- Name That T Bracket ! (( Curious ))
- What intake for GSR manifold on EG w/ ABS?
- Swapping 97 LS non-vtec into 97 Civic DX
- Gauge Cluster Bulb
- Integra LS transmission is stuck in 5th gear
- What is this plug for and where does it go? (pics)
- Heater problem
- 96 Civic coupe - Parking lights fuse keeps blowing
- PIC REQUEST: B&M short shifter with Energy Suspension Bushings
- d16y8 head/y7 block turbo build. Whate headgasket do U recommend???
- what do i do bout 3 wire iacv to a 2 wire iacv
- EG under dash fuse box: What is the purpose of the c923 or c927 plugs?
- 99-2000 civic SI trim help
- 94 si hatch/itr throttle body/skunk2 mani - Throttle cable too short
- Code 43 on 95 Civic
- steering wheel feels kinda loose
- 99 ex (y8) won't run
- What shifting method works better to maximize gas mileage?
