View Full Version : Honda Civic / Del Sol (1992 - 2000)
- B16 running 9.0:1 Compression: Compression Test & Leak Down Test Results
- Cooling issue
- 96 Civic EX - CEL code P0702
- Rough Clutch Engagement
- Complete loss of electrical power D16Z6
- Tachometer at 4k rpm when off
- B20b vtec
- 97 Civic LX Bogging under 3000rpm
- 94 Del Sol 1.5 Lt no start when warm
- jdm d15b vtec crankshaft - What engines have same crankshaft?
- Gsr tps voltage problems
- d16y7 Header replacement
- 96 Civic - Name of chassis bar that runs from b to c pillar?
- No spark, no voltage on TEC coil
- No start
- 96 Civic EX - d15b2 swap using P2P ECU - no spark
- Honda Civic HX Center Caps?
- B16 timing...Is it off?
- Clutch slips when motor is hot. 94 Civic VX
- Unable to burp radiator?
- 95 civic hatch dx - Climate Control cable question
- B16 3rd gear grind
- D15B7 to D15B Vtec, Economy loss?
- Throttle body/TPS problems
- 1995 eg6 w/b16 wont crank
- Re-Manufactured or new a/c compressor?
- Front-end Noises on Full Stop
- failed smog 97 civic ex all stock d16
- Climate Control Unit and other thing not working??
- 99 civic si - front lower engine mounts necessary?
- 1998 honda civic hatch. auto trans issue (solved)
- 94 Civic EX Intermitent Crank No Start
- wow! stiff yonaka engine mount made it LOUDER!
- 2000 Em1 Rack & Pinon Leak?
- Exhaust Help.. Bout to flip a Lid!!!!
- Strut tower bar
- header flange bigger then my test pipe flange??
- 96 Honda Civic won't start
- help identify this intake manifold
- 1998 Honda Civic LX D16Y8 radiator issues
- B16 Gear Grind
- 93 Honda Civic Dies While Running - CEL Code 43
- leaking trunk
- Run with service connector jump
- LCA bolts torque specs
- 92-00 Idle, what all can affect it.
- Valve cover breather?
- D15z6 Head swap
- Overheating problem
- D16Y7 chronic IACV disorder?
- Anybody good with wiring and/or electrical troubleshooting?
- 98 civic with y7/y8 mini me - Idle adjustment question
- OBD2B harness in OBD2A civic
- Are all eJ roof sizes the same
- EM1 window probelm
- what to do with my 92 eg sedan
- Honda civic 94 ex project/build
- 98 DX Civic Sedan cranks but doesn't start??
- 97 Civic + 98 acura integra motor = surging idle
- 94 Del Sol/B20B block/P8R-7 head/P75 ECU - TPS issue and diagnosis
- D16Y7 Oil Pan Loose, but can't completely remove!
- 92 civic dx cel code 9
- Re: automatic transmission shifts too quickly
- 1996 civic hatch b18b misfire
- EG / del Sol 12V ACC in engine bay?
- Passenger Window Seal (94 Hatchback)
- Increasing traction on Honda Civic EK9 with weight
- 00 Civic Dx coupe/D16Y7 - oil pressure warning light
- 95 Honda Civic DX stopped running while driving
- Built Del Sol - fx350 clutch isnt engaging!!
- 95 Civic DX - what engine?
- P06 chipping with d16y8 motor?
- D16y8 swap
- 99 Civic - Possible power lock motor issue, want a second opinion
- 99 Honda Civic overheating issues
- 98 Civic DX Coupe - Ignition wires fried. Civic won't start.
- d16y8 no crank but has power
- need help eg 1.5 motor and automatic tranny in ej
- 95 Civic - Planning JDM D15B VTEC-E swap - Can't find P08 for automatic tranny
- 2000 civic B swap exhaust
- demotivated to continue my ej6 build
- b16a2 compression test
- Honda civic 1997 engine up and down problem
- Mishimoto radiator too tall for '93 del Sol
- ITR Sway bar positioning
- Civic si 2000, many trouble codes!
- 95 EJ1 has a D15Z1 not D16Z6 and it has issues
- D to b series swap
- Y7 to Y8 head swap - Automatic?
- 97 civic problem shifting into 1st
- 2000 civic ex keyless entry
- S4VA (CVT) and M4VA transmissions interchangeable?
- 93 sol roof leak?
- No start D16y8 Not spark related
- Oem Honda door visor
- will hood from an 95 EJ 2dr coupe fit my EG hatch
- clutch slave cylinder replacement question
- 1999 honda civic lx lower control arm ball joint removal URGENT!!!!
- 94 civic sedan - headlight help
- EF tranny into EG
- Locating C209 - A/C System Help
- Problems after tune up
- Rims for Del Sol, without wasting too much on gas...
- first start fails. second start OK...
- 95 Civic - Help with power windows
- Strange sucking/hissing noise
- Civic 99, y5 Block and y8 Head + Extras Help & Questions
- 95 civic ex coupe y8 easy swap
- 95 Del Sol bouncing idle
- Head Gasket Repair Questions (with related threads)
- AC GENIUSES
- 98 CRX Del Sol Muffler/ABS
- 98 Civic - Static PSI when A/C Compressor Clutch will not engage?
- 92 Civic: Question on the low volt side of the main relay
- em1 running sluggish after it warms up
- VSS Problem
- EG Power Steering noise (w/ video)
- 92 civic electrical gremlins
- Loud screeching when a/c
- IACV / FITV Seals/Gaskets
- Sporatic Starting Issues
- 99 civic ex does not want to start - What does this plug into?
- Car wont start
- sputtering at idle, car runs fine.....
- Brake bleeding on a Honda Civic 1.4 1999
- Thoughts on: plexiglas
- 98 civic Hatchback - want more power
- Spring/shock setup for an EJ maintaining stock ride height and NOT coilovers?
- 96 civic CX - rebuilt engine won't start
- Transmission noise on 94 civic
- Window switch problem on 96 ex sedan
- SEARS DMM FOR 9.99
- P1457 EVAP Code Help
- Replacement EG Hatch Spoiler with Brake light?
- 99 civic ex/auto...can I use manual starter?
- 98 Honda Civic ex not starting
- 75 Mini Cooper/y7-y8 mini-me - rywire tuck harnass issue. need help
- main relay pin 8 ground delay from ecu??
- civic clutch slave cylinder leaking (solved)
- 98 Civic EX - Parking light and City Light Issue
- 93 Civic coupe getting down to one key
- need help on identifying plug in engine bay in a 96 hatch
- Swapping seats!!
- Swap motor started 2 times!
- Electrical problems, IACV buzzing, no sparks...
- Car Overheating
- 96-00 tranny bracket bolt length?
- 93 Civic - Retrofit R12 AC system
- 93 del sol - Engine Mounts loose...
- Wiring issue please help (solved)
- intermittent miss, then stopped running, wont start (solved)
- Using EX automatic harness on EM1?
- 92-95 manual Steering column and rack and pinnion fit in 99 EM1
- a solution to low idle/backfiring when stopping and accelerating
- 00 Civic Ex - Installing rear view mirror back in?
- 99 Civic EX, auto - Crap Gas Mileage and I've Tried Everything
- 95 Civic - main relay look alike??? microchips
- Just changed flywheel and clutch - vibrating clutch pedal when depressed
- 97 Civic Power Door Swap Questions
- Civic LSi decal
- Hey guys n00bie here! If you feel like helping out. Press here!
- 1998 Honda Civic HX to GSR, or ITR, or LS swap
- Del Sol roof seals
- Yonaka intermediate shaft - set ring won't allow coupling to axle
- identify the plugs/cables under dash, 99 EM1
- putting d16z6 in 97 del sol - Will it fit right in?
- 98 Civic DX - Speaker Wire Problem
- 97 Civic Ex crank NO START
- Tune-Up 1996 Civic LX
- NGK FAKE WIRES!?????????
- Just did my swap now I get code p1337
- Window problems (solved)
- need help. 2000 civic dx codes
- B16A Surge 1500-2000 RPM
- help please, car cranks but won't start
- 93 Civic hatchback - Rear LCA’s. Same Left and Right?
- Em1 No Start Short electrical?? HELP
- 00 Civic - passenger power window doesn't roll up all the way
- Shift bushings
- Diy 92-95 sedan power actautor & window assembly in 92-95 hatch
- Cylinder Head Identification
- Non-OEM Replacement Fenders?
- what exhaust will fit a 95 civic si?
- Need Advice On Which Brand of Head Gasket
- Tire Confusion - please help!
- D16y5/y8/z6 hybrid engine - no VTEC and compression test results
- How do I install an Ek climate control into my EJ8? HELP!
- D16y7 in 97 Civic Hatchback no start condition.
- 1.4 1997 civic
- Stupid antenna problem (solved)
- Soggy carpets? Help me end this nightmare!
- 92 Cx Build Thread
- 98 DX Dust, Leaves, Pollen, etc blowing out the vents
- Bought a Bunny
- Squeak when pushing in or taking out clutch
- 253k new for me car AC issues
- 96 civic CX - D16Y7 Rebuild Won't Start
- 2000 Honda Civic SiR - speedometer stuck at 30km/h
- D16Z6 - Is my head still good?
- 99 civic sputtering on take off- died on road- now cranks but wont start
- 96 civic sedan - Are 2dr and 4dr ek sunroof & sliders interchangeable?
- Total Em1 Parts List with Pics
- Head Gasket Won't Seal
- honda civic 2000 ex clutch kit
- VIN LOCATION ON A 99-00 CIVIC SI
- Aftermarket stereo climate control issues (solved)
- D4 blinking, speedometer not moving
- Transmission issues 98 Civic EX
- 95 civic dx d15b7 runs bad after headgasket/timing
- 98 Civic Dx Clutch Pedal / Ignition Problem
- tranny or throw out bearing
- 99 Civic EX - hesitating
- Clutch and Oil Problems
- help!! with ek hatch that has sat for 7 years doesnt start
- Mystery box with blinking red and green light
- shift linkage bushing
- engine cranks but doesnt start. there is fuel, spark and compression
- Engine swap
- D16Y8 Comp Cams 105300 - Rough Idle
- Throttle Body gasket
- Likely Impending Head Gasket...Seeking Info
- possible head gasket?
- Would like some opinions about this body damage
- 95 EG racing seat info please
- Hazard lights not working but I got the turn signals to work.
- 94 eg rear disk conv help
- D16z6 Ignition Timing HELP (solved)
- Will it fit???
- Where to buy EG hatch door mouldings??
- 95 civic cooling fan problems
- '94 Civic CX Exhuast
- Intermittent Electrical Issue 94 DX
- 92 Civic Steering Woe's (Need help)
- 99-00 Civic DX Coupe - Transplanting OEM Keyless Entry
- D16y7 ticking.
- Civic 1998 Moonroof opens but won't close
- 1996 Civic with 1381 obd code
- Hunting idle after pressing throttle
- FULL FUEL TANK MPG???
- What tie rods do I need?
- 1997 EX CEL and other engine issues
- D16y7 block with d16z6 vs d16y8 head?
- Spindle nut question
- rhd eg6 - what motor and how do I make it run?
- B16A2 Stock head gasket hp
- ITR Master Cylinder upgrade question
- 1998 Honda Civic HX trunk lid
- Creaking and Shuddering During Braking... What Could It Be?
- 97 hx head trouble
- Can inop radiator fan cause iacv not to work properly?
