View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Help with oil
- 1997 civic hatch ek thoughts? plz help, I'm new
- HEELLPP!! brake lights/power windows etc
- side mirror, quick question
- w.t.b ek navigation system
- where can i get a rear windscreen with the wiper assembly for 96-00 ek4 sedan????
- overheating when ac is on
- D15B7 Head question
- Never ending hesitation problem in 96 CX
- 99 civic EM1 Faild Smog!!! (need help)
- infamous sticky pedal
- Water in my car!!
- When I press the gas the engine acts wired
- What do you do when the part where the bumper connects to the fender breaks off?
- Paint Help!
- Need info for obd2 b18b1 swap to a 99-00 ex
- Best spoiler for my EK?
- i got a new alarm, but cant get it to work right.
- Post your LOOPED P/S RACK SETUPS!!!
- What engine harness can i use?
- Yet another power windows/locks conversion question?!?
- Ebay Slim Fans
- Reckless Driving Ticket
- intake mani question...
- Which seats will fit my 94 Civic Si HB?
- Whats it worth?
- JDM Headlights
- after getting the car tuned it eats more gas!!! anyone have this issue also???
- I thought airbags were expensive! But it appears not!
- after tuning w/ p28 on chrome car idles a lil high or fluctuates...
- 88-91 civic Tein super streets on a 92-95 hatch?
- 97 Civic LX Code 335. HELP
- Got pulled over for no license plate
- How to Thread for brakes???
- Windshield wiper linkage and motor
- help 1992-95 jdm cluster!!! jdm cluster no yellow plug for for the lightings......
- b18 swap code6(ECT) and code14(IACV) HELP
- lsvtec turbo vs n/a b20vtec
- External Headgaskt Coolant Leak and Sputter
- Low idle then death issue
- ->question about a 96' L.S motor burning oil?
- two cynlinder misfires, new tunning done???
- What color do you think this is? (JDM Eg9 front)
- EK Front bumper question
- How do I bar my civic
- any ideas please
- Newb! From domestic to honda! lol
- temp guage going bananas!
- Brembo brakes or Spoon brakes 2000 civic hatch?
- Idle hunting and cel code 54?
- Looking for longer rubber exhaust hangers. Where?
- JDM S20 LSD tranny question
- limp mode with no check engine light?
- oem honda badges! help!
- Help: what make of side mirrors are these?
- Pop locks?
- honda badges?
- Spark plug wire wont go in, need some help
- 06 SI Steering Wheel on an EK?
- 96-98 to 99-00 conversion would you do this?
- how to test tps sensor?
- my car is not starting/and not cranking
- suggested wheel sizing. please help me out?
- 99-00 climate control on a 97 ?
- Retaining Salvaged Vehicle
- Del Sol Wheels
- bride seats
- extreme lag in first gear.. belts or tranny?
- Anyone know where I can get injector O-rings?!?
- Will a oil pan from a Ls fit on a b16??
- what header 4-1 or 4-2-1???
- timing
- Eratic Idle and Tach issues
- idle problem
- 99 Civic Si overheating
- RWD Civic Conversion
- whats this in my eg6 sir cluster ?
- combination of idles
- dare you to solve this problem
- Need your input about a weird problem
- mirrors
- Possible fuel pump problem.
- 93 Honda civic.
- eg8 lx, i want a moonroof, how much?
- My car sounds like a sewing machine
- help me identify my headstuds?? ARP??? idk
- broken steering wheel lock
- OEM B16 Manifold or 4-1 Header? Which one??
- Pic Request...
- installed type r into 95 which throttle bracket?
- turbo D16y8 build need advice
- My doors.
- full tune up still wont start right up tested starter
- clucking niose when i turn on the ac circulation button
- Car tuned to 93octane, but no 93 pumps around
- Downshift Grind
- 1996 honda civi cluster lights not working HELP!
- 5k rev limit
- whats this front bumper call??
- Need help with my Apexi Vafc!!!!!!!!
- 98 civic misfire problem
- WTF is this connector/plug/thing??
- Please HELP!! civic not holding an idle! Car idles ROUGH not erratic
- VTEC ISSUES
- 98 civic ex motor and tranny swap problems
- how do you remove the main shaft bearing?
- Couple of issues with my recent swap. FPR?
- I need help with some tech support pls.
- B20/EK O2 sensor
- ABS light
- fuel pump doesn't prime, distributor hot to touch?
- Leaky distributor
- EF wishbones the same as EG(del sol) wishbones?
- 5 lug
- steering wheel vibrates when i brake hard
- I Fu$%ed up my rear disk conversion PLEASE HELP
- after almost 5 years!
- Neeed Help Urgent On Skunk 2 Shock and Coilover
- eg hatch bra wont let me close my hood!
- brand new iat sensor
- AC Compressor ?
- convert jdm/obd1 motor to obd2?
- o2 sensor problem b18b1
- Cargo cover tabs
- Is this the correct T-Body gasket?
- motor swap ?
- stripped tension pulley bolt HELP!!!
- not the normal idle issue? please help!
- push button ignition
- rotor removal off of distributor HELP
- Need Ignition Key Cylinder Help
- where can i get a custom a/c on a civic hatchback?
- 96-98 Cluster any different from 99-00?
- ECU harness pins
- excessive pinging on my sohc 1.6 liter 4 cylinder civiclx
- Exhaust system
- EJ GAUGE CLUSTER FLUTTER?
- 92-95 Exhaust on 96 cx
- Yakima Roof Rack help for ek Coupe
- street legal?
- 92 civic dx integra rear disc conversion
- D15B7 with P28 ECU and EX trans???
- idle problem?95 civic
- d16z6 motor on d16y7 transmission ???
- My b16 isnt running good and I've been having a few issuses with it!!!!
- msd 2step dealy
- 99-00 CTR Cluster in USDM EK? Night time photos?
- em1 smoking under load
- transmission question
- test pipe on em1?
- 95 civic troubleshooting
- anyone ever done a h2b swap and still have a/c in their eg6???
- changing the exhaust note???
- hey u here about dyno day in holyoke
- Sol Belt Squeal on Startup help
- b16a2 obd 2 oxygen sensor help...
- intermittent high temp reading on B18C1...still
- jdm engine bay haness has no MAP plug what to do
- eg6 fuel pump wont kick on, replaced a list of crap and still no work
- will 99-00 si ac compressor fit an LS motor???????
- Im Confused...
- Car is acting weird..
- Recomendations for new Mufler
- side markers messed up my lights?
- 93 del sol si with H22 swap
- Honda Prelude to Honda Civic engine swap possible?
- 2000 civic si - smog question
- spark plug wire problem
- coilovers
- Debadge and light tint
- Quick Suspension Question Are DC and EG Hatch Compatable?
- Sputtering start..
- 1999 civic dx dash lights
- Question regarding harness bar for a 1998 EK Sedan
- Boost or Spray
- 98 Civic gauge cluster needles help
- how much do 99-00 civic oem fbp hood go for?
- ECU Tunes....
- What speed does a B18C1 top out at?
- 97 Civic will not run, post timing belt
- Car has problem starting!
- dropping gears
- HELP! car will not idle and runs rich!
- when does vtec engage
- Vtec not working on my LS-V
- Turn the key-lights turn on-ignition clicks but engine wont turn at all....
- Radiator Fan Not Coming On
- QUESTION!!!!!!!!
- how to remove stock EG exhaust tip?
- How do you remove rear plate garnish on the del sol????
- Chilton vs. Haynes repair manual
- can it start without the crank sensor?
- just swapped motor...dash lights dont work..
- Differnces between b20b and b20z?
- D16Y7 Probs. after overheat / head gasket
- Connecting Pipe
- Main relay fuse keeps blowing
- Will a 97 Integra power window motor...
- complete motor port and polished and turbo setup
- Somewhat noob question about interference and a timing belt failure
- del sol going crazy at 1500 rpm!!!! WTF?
- cooling fan WONT START!!!!!
- intake manifold on turbo set up
- Good Suspension For h22a hatch
- how many em1 were produce in the US?
- serpentine belt question
- b18c wont start
- Auto to manual interior wiring help....Please help
- LCA too short EK3 Civic Sedan Multimatic vi
- heIp BuiIding a B18a1 ls (need suggestions pIease)
- need help with a buy
- code 12
- Just got a civic and I need some help
- gsr strut on a 99 civic
- How to check whether i have ABS or not?
- Are Del Sol Pass air bags universal?
- 99-00 fog lights instruction
- no power in distributor
- anyone know where i can get a set of oem 2000 hood bra??? tried searching
- b16b but no vtec
- which sohc tranny is the best?
- 1997 wiring converted to2000
- Best way to get a black interior?
- b20 fuel pressure
- ek/d16y7 A/C issues
- 92-95 Civic Front Lower Control Arms
- Delete post.
- yet another idle issue
- Help, completely dead, can't jumpstart
- 92 EG6 LCA?
- I need helping naming this piece to my car.
- Help! eg6 headlight problems
- 99 civic b16a2 swap radiator problem...please help me.
- does anyone know where you can get new condensor block offs?
- trying to fix up my Civic
- little help?
- 2000 civic ex!!!!
- Time for a new Fuel PUMP?
- B16a (obo 0) into 1999 CTR RHD Questions
- amber dash lights?
- help on swaping a gsr into ek
- ls vtec conversion, i need help
- question about my engine problem
- Radio problems.need help
- headgasket question... plz help...
- question about my new axles?
- ANOTHER ANNOYING OVERHEATING CAR!
- VTEC QUESTION!
- Selling 2000 honda civic ex
