View Full Version : Honda Civic / Del Sol (1992 - 2000)
- 95 civic barely starts, cuts out intermittently
- just got a ticket...............help ?
- lookin for some 14" HX rims
- 96 ek header
- DOES ANYONE USE LOJACK?
- have a heater core question
- 99 front lip on 97
- hola
- Trying to contact Drew --
- skunk 2
- b20z2 swap into Si questions
- effed up steering rack install
- blue mirrors replacements
- harness question
- yikes... release bearing drama
- to: turnsignal lady
- Weird Noise Please help
- hEAD LIGHT QUESTION
- noise question
- 99 civic ex fifth gear cruise
- hatch back electrical problems
- are obd2a and obd2b civic injectors the same?
- parts for sale
- 99 d16y7 in a 97 civic ex, wont start HELP
- distributor help
- short ram vs cold air
- OffTopic: Someone backed into me and look at my baby
- B16 Tranny problem.
- Throwing a Code
- What coilover setup for daily driver?
- Car seems a lil weak in the low rpms?
- Trany trouble
- PLEASE HELP having probs with my 96 civic ex
- help i cannot find the ecu plug to get codes on my 95 si
- EP3 seats into an EG
- tail lights help
- Back seat widths
- what is this on my headlights!?
- 95 civic vtec...no spark
- gsr swap question
- My D16 setup help
- JDM B16a Crankshaft sensor (Check Engine Light)
- 92 SI Dizzy Compatible with 92 DX???
- p08 and p28
- Anyone with carfax?
- EH RS*R ExMag Piping
- EJ8 Power Window wont roll all the way up (Stripped gear?)
- Largest rim and tire for a 2000 civic si
- What brake lines did you use with your WILWOOD calipers?
- Gap
- Parting out my 93 LX
- need help with swap got a few problems...
- p30 ecu with a sohc engine question ..
- 00 Civic SI Radio Question
- swaping in Cx Hatch
- Would a 90-93 teg axle seal correctly in a 97 type-r tranny???
- how to change distributor o-ring?
- Motor Swap Quick Question...
- Del sol oil pump
- 92-95 civic spindles the same as 94-01 integra spindles
- Please help! lol
- msd 6al problems in EH
- Help removing D-series manual Trans from engine
- D16Z6, Del Sol Mount Question
- Where can i find...
- Weight of SOHC head and intake manifold?
- Torque Lugnuts
- Trouble with shocks and lower arms
- What to get for power steering in a gsr swapped 93 civic ex?
- an issue i ran into this morning.....help me out please!?!?!?
- k series civics show pics of your clearence under your car please!!!!!!!
- brake rotor question
- 96 b18c swap.... 92 vx.... runs like absolute S**T
- one last lca question
- -=[ADD TO STICKY]=- .:'Civic Maintenance FAQ':.
- Clutch question??????
- foglight switch
- Car wont start, SAN DIEGO...Need Help.
- climate control
- automatic obd1 P75 ECU in a manual car
- HELP!!! Problems with d16Y8 swap into 93 del sol...
- What Swap with the best bang for the buck?
- Troubleshooting del sol s d15b 93 help me
- Help! Car dying!!
- Eg6 front bumper on Eg9
- My dilemma. The buy an EK hatch or coupe..
- engine swap/tranny conversion question?
- 1997 2 door ek9 tranny swap
- Has anyone bought from jdmcars.com??
- JHPusa.com-No name/ White Box coilovers
- My '94 Honda Del Sol rebuild...
- Oil Change Bolt Leak
- Clutch lines, or cluth itself shot?
- NEED HELP READ
- 99 civic swap
- Radiator fan stop working! Help?
- HKS Hi power carb legal?
- Vtec SOLENOID Leaking.....
- building b18c1 block?
- D16y7 Build project
- NEED HELP WITH PUTTING REAR HARNESS BACK IN!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- Wobbly wheel.. Anyone know what might be the cause?
- question about vtec not engaging(yes i searched)
- Mystery block identification
- can my stock b16 intake manifold be ported to match my 70mm throttle body?
- Non OEM headlights...
- 94 civic, I loose all of my radio presets when I turn off car
- Can I put cruise control in my non-cruise Civic?
- D-series transmissions suck?
- D16B8 Dizzy on D16Z6???
- Using catalytic convertor as a muffler
- Steering shakes
- help me on my tachometer
- NO VTEC - B16a Obd0 PR3. Should Be Working. How To Diagnose
- EP3 Steering Wheel in 96 del Sol?
- del sol fuel pump installation
- Rear disc conversion, bleeding brakes..
- Civic's D4 light keeps blinking
- EK[96-00] Sunroof in a EG [92-95]- Has anyone done this? Need some help!
- 92-96coupe swap
- LS swap question
- ECU Question
- 93 Civic intermittent stalls when warmed up
- Need help identifying part. Trying to also get rid of it
- B20B4
- b16
- what dous it stand for
- clutch decisions. 99 DX Hatch Mild built LS-T Competition clutch
- any oics of a Skunk 2 Racing muffler? How good does it tuck under the bumber and sound?
- Plz help me hook up my ecu!!
- broken temp guage
- Socal or norcal honda dealership similar to hondaautomotiveparts.com online store
- A way to tell LSD v non-LSD transmission?
- Need quick help i searched. Obd1 motor into obd2 car
- Rear Sway bar question on 95 Honda Civic DX (Ej2) - Chassis mounting holes no thread!
- oil pressure in vtec?
- d15b7 block with a d16z6 head what timeing belt do i use
- Hotwire Ignition
- I want to keep cruise control!!!
- Too much preassure in my coolant system??? HELP! lots water in overflow after driving.
- best performance web sites
- Vortech supercharger rebuild?
- Need help! Transmission problem!
- eg civic front lip help!! pls!
- JDM eg6 gauge cluster problem
- d15b head on d16z6 block?
- help please
- bring back SPEEDMASTER WHEELS!
- lsvtec turbo wont work need help
- swap
- check engine light?!!
- Simple headlight question...
- what center consoles fit on 95 civic lx sedan?
- What wires are these?
- im searching and i cant find help me find!!!!
- Y8 Intake Mani install: Which sensor wires to extend?
- black interior
- aem pulleys
- drain the gas tank
- ls???
- New bumper for cheap
- high idle on a b18b swapped in a EK need help asap!!!!!!!
- what could cause 2 sister cylinders to have low compression?
- JDMcarboy good???
- 91 longblock in a 2000 civic. possible?
- no power!!
- Tranny disassembling help...
- H22A In an EK question
- Sudden Bumps when shifting slow .........
- CEL ?
- Can i use larger cat size than exhaust
- new here umh...small question...ecu choice help..
- JDM side markers
- Sunroof help!
- Apexi WS2 question
- radiator year, what will fit?????
- obd distributor question
- Rear BRACKET!!!!!
- Somebody Help, I'm freezing!
- Neccessary to reBORE or just a hone - severe ring leakage
- del Sol fuse diagram
- Engine problems HELP!!!!
- bauly civic
- funny sound coming from the front [tires]?
- fuel pressure problem w/ B20 in EK
- Why is my tranny doing this??????????
- (Searched) 2nd try starting??? headlight bulb choices?
- What is this part # in this diagram?
- what is the diffrence in b16a's
- Saw a blue EG t-boned on Geary in SF, Tuesday. Who was it?
- V-tec Solanoid.Work?
- battery light problem is stressing me out..please help
- how many 1999/2000 civic si's were made??
- jdm d15b vtec into 00 civic si (ex)
- Civic Upper Control Arms
- Anyone ever use a torque damper in a 92-95 civic w/ B-seires?????
- Steel threaded clutch lines question.
- gasket? what to choose for header? on b16 ..i dont know differences help
- help with rear lip
- where to get lca bushings pressed?
- transmission/bseries swap question (Searched, read faq, etc)
- Looking to buy a civic type r cluster tonight will it work
- D series Tranny problem (Electronic conector)
- H&R Springs
- (official)Post pics of your EG dropped on springs/shocks combo!
- Heat issue..
- thank you HT members for your help!!i fixed problem!!!
- what radiator hose do i buy???? b16a2 in 92 civic
- What do you think?
- Breather hose attachment on intake help
- RADIATOR HOSE HELP. 3RD POST OF THIS TOPIC
- civic clocks
- Maybe faq 2dr/4dr?????
- B18A1
- Brake booster swap
- Suspension upgrade?
- Integra Radiator into Civic..
- Brake master cylinder replacement
- Fuse diagram for in-car fuses
- weird oil leak under dizzy on d15b8???
- jdm b16a compression test
- Ninja ek from D2motorsport
- No power to anything after removing tranny for input shaft bearing? Tried everything
- Almost everything on my cluster isnt working!!! HELP!!!
- 99 hatch window issues. HELP car is torn apart
- 94 EX ABS removal question SEARCHED!
- CAR STOLEN IN SOCAL YELLOW EG B18C TURBO SLIPSTREAMS
- 96 civic front sway bar size
- Mini-me question
- obd port has no link 97 dx
- Fuel Rail Cap, is it necessary?
- What can I get for a 00 D16y8 motor and S40 Trans.
- check engine Error code 1 or 10??
- mini-me question for turbo
- d16Y8 timing ....
- omniman's 200whp dvd
- 99 integra ls seats in my 94 ej1 coupe?
- 4 door civic dash into a 2 door
- Theives
- need some info please
- Moroso super cheap on ebay....
- Wassup fellas i jus got a 97 civic 5 spd 4dr open for suggestions please
- n00b Eg question
- D15b
- ctr spoiler backyard adapters...
- suspension/lowerspring/mainly lca question
- Is this my Distributor???
- This just sucks. Help please.
- Greddy EVO2 Exhaust on an SI
- honda civic speed guage
