View Full Version : Honda Civic / Del Sol (1992 - 2000)
- best mtf out there?
- how much bigger is a z6 throttle body compared to a z1?
- 92/95 ex/si tranny bearing sizes
- Wierd overheating problem
- Question about my tire wear?
- Quick question
- how much have u spent????
- will this stereo system hurt my lil civic alternator?
- r they the same?
- throttle body sticks closed sometimes
- alternator
- A/C unit removal
- tie rod help
- Main relay
- Blox muffler question
- lost the lower section to my dc header
- shifter to shift linkage problem
- Help, I have a question
- anyone runnin an ecu from phearable.net??
- help please. car wont start wen its cold.
- JDM ITR Header / 60mm Exhaust
- need help with obd2 gsr in a eg
- Need Some Inspiration
- Low offsett wheels on my 96 Civic hatch help
- 1 week to do something
- Car Bogs and Rpms drop???
- Problems passing MD Emissions! Help!
- Y8 Build, Any Suggestions?
- EXTENDED WHEEL STUDS
- 95 Civic LX - Running, touch gas NOT RUNNING??
- wow this is nuts
- moderate body work and paint?
- noob question about ek duckbill
- sunroof question
- Why is my sunroof scrathcing my roof??? (VIDEO inside)
- crank?????
- P0301/P1399 Cylinder 1misfire/manuf. ignition sys control or misfire
- k series in a em1
- car won't/has trouble going into reverse
- Cruise Control
- windshield banner question
- ek b18 R ecu question
- A real screwd up voltage issue. If you dare!
- EK PS problem after changed my rack end
- 00 EK w/ B18c1 Engine surges help
- Thinking about upgrading to integra rotors and calipers...is it worth it?
- I Found A Wrecked DEL SOL > What Fits My EG??
- D15B8/D15B Vtec Head timing belt help
- Camellia red pearl(purple) EG coupe
- removing stubborn b!tch pin?
- steering wheel change how to ?
- how can i adjust idle.
- Wiring VTEC to ecu (obd2)
- 2 Clean 98 civics V.s 07 civic
- Civic Si or Integra GSR???
- can no coolant cause idle surge
- b16 leak
- Do 92-95 Civic dx come stock with power steering?
- swapping from d15b8 to a d16z6
- E Brake light on during high rpm
- b16 idle help
- aftermarket camshaft identification? ADDED PICS!
- b16a3 complete swap worth?
- 99 si worth?
- rough idle, tried everything.
- b20 in 93 civic hatch vx
- Carbing 3 point. DC application -- in EM1
- Low idle, no power, CEL 9, b20/vtec chipped
- Turbo set up / motor swap help from one shell to another..
- Where to mount gps? 96-00 Civic
- Keyless entry remote transmitter not working. If you help me out you get a free gift
- Help inner tie rod
- Automatic Civic With Aftermarket Muffler?
- 92-95 hb seat options
- troubles doing a self check of my CEL...
- tire help
- tecna-fit
- clutch question
- Ls crank in a gsr
- buying an amp, wich one?
- b24vtec?
- stock temp guage problems
- Tie Rod Ends
- Jackal's DIY: Quick fix for busted door handle plastic
- d16y8 header?
- how much?/1994 eg
- Jackal's DIY: S2K Push Button Engine Start Switch in EJ1/EG
- HELP!!!!Transmission Problems.. Clutch? Pressure Plate???
- body work
- What engine and trim of car is this?
- Photoshop help! Rim color change!
- Best "Bolt on" for power, on a budget?
- Just got F&R sway bars. few Q's
- Carbon Fiber Wrap
- need help checc inside please
- what harness do i use for a obd1 h23 swap?
- Rebuilding CTR
- B&M fuel gauge/new filter and fuel gauge testing WTF.weird reading before/after??????
- Jackal's DIY: Cluster mod, change the directional color
- WTF is up with my temperature?!
- car wont go into gear need help
- What throttle cable for my LS swap?
- Advice on dead pedal
- axel broke....
- Air Breather? - New member -
- 93 civic fuel pump wont work
- HELP! Car dies at high RPM
- new from pa/97 hatch h23 swap
- New member with a 94 hatchback civic
- stock ek running rich and bogs
- What is the correct bolt for my 96 civic dx?
- Whats this Niche shock offset?
- b16a3 automatic swap
- aux lt
- apexi ws2 opinions
- HELP! Parking LIGHTS!!
- 98 civic help
- I crushed the nipple on my heater core...
- Need help on heater box/ fan box
- Sohc boost help
- does any one know the part # for civic hood insulator????
- GSR Rev Issue
- D16z6 Need a Cam Mark Refrence.. PLZ !
- d16z6 ON itb's * to tune or not to tune *
- boost d16y8 or swap an h22a
- WOT Rev Issues
- New guy with a Del Sol
- Please share your wisdom, not non-sense
- Solutions for "Civic Rear Door Won't Open"
- SANKEI 555 EG TIE ROD END
- Turbo Fuel Pump??
- idle issues iacv fitv etc. explained
- IAC and IAB the same?
- Accord euro R VS JDM R swap for EG???????
- 95 Eg swap running odd
- clutch switch wire colors
- Obd1 jdm swap question
- (1) C926 [Option {+B}]/(Fuse 54 - Under Hood Fuse Box) ???
- What to have mechanic do?
- apexi n1 axle back...
- Knocking noise on my y8 :(
- Need some lube!!!!
- 98 Civic Cold Start Rapping
- Need whole Exhaust or just a gasket???
- bumper moldings
- XMAS GIFT/ NEW PROJECT !!!!!
- throttle body problems! help plz.
- what is this? (picks)
- 96 civic coupe
- Hesitation between idle and 3.5k
- 95 Civic Si: Car cuts out at about 4700 rpm and throws code 9
- Keyless/alarm in a DX
- help
- 92-93/94-95 glove box
- Help ASAP Fuel filter bottom bolt??? Remove Left or right
- need help asap car is not starting
- Keyless remote entry question
- 98 Hatch with OBD need Air temp sensor?
- interior question
- vibrant muffler vs spoon n1
- problem launching at the track [auto]
- Gold blox LCA's from the Fiance for Xmas
- C8SPORT COILOVERS?
- speedo is off by 8-10 mph.
- blown head gasket
- Switching interior cluster parts, does it work?
- No Start, Main relay clicking (new and old)
- can i put a 96 civic streeing wheel on my 92 civic?
- SWAP PROBLEMS???????
- 92 cx...(THINKING BOUT MINI-ME)
- speed healer calibration
- my wire tuck from el salvador
- How many miles do you have? 92-95
- will 05' Civic SI front seats fit my 94' civic coupe ex perfectly?
- OEM Hood Bra
- starting problems Help please
- Anybody here with a bone-stock EG hatch?
- JUst to be sure, EG6 parts in EJ2 Coupe?
- DEL SOL PAINT SIDESKIRTS? JDM YAY? NAY?
- del sol rear defog switch light stays on all the time?
- won't rev past 3500 on my Ej1
- LS trans or shift linkage problem? Need help ASAP
- gsr shifter doesnt fit ej1?
- Idle roams from 800 to 2200 rpm in 93 Civic ex VTEC 1.6L
- Help ! would this be ok ? ?
- How do I know if V-tec is working?
- lookin for a thread, can't find it....
- 96-98DELSOL GLOVEBOX FIT IN A 93-95 DEL SOL
- Headlight Rewire
- Ignition Fuse Maybe? Car won't start PLEASE HELP !!!!!!!!!
- Car wont start help please
- Help 1995 civic depressurze fuel?????
- boring a b16 with stock pistons
- 92 civic lx stereo wiring
- Oil pan gasket leak?
- New axle so shaky! what other axle can i use.
- Fuel Gauge Problem after gauges reinstalled
- Ls swap Help!!!!!!
- 94 civic a/c clutch problems
- Distributor and boost questions about putting Z6 or Y8 head on Y5 engine
- Problems with 94 Civic overheating
- sohc zc vtec turbo ?
- Sparco seat has some rippage..How should I fix/patch..?
- Need help with my car its acting wierd !
- ctr cams for b16a2
- few 97 ex problems
- Happy Holidays Everyone
- noise from suspension in EM1?
- foglight diameter size for 96-98 ek
- 99-00 civic chargespeed lip rep
- Considering getting an EM1
- B16a2 help
- Clear, Yellow, or no fog lights?
- how do you remove radio on 97 civic?
- cleaning sensitive engine components
- Gsr rear seats in an EK?
- B16 or B18
- D16Y8 OBD2b Dizzy to OBD2a Teg Dizzy help
- del sol front end swap?
- Whats better gsr 120,000 miles or d16z6 160,000 miles on e85 tuned 150whp
- vtec wires?
- 95 civic 1.5 no start??
- 2 problems with my eg..break and idle
- WET CARPET PROBLEM!!
- swap fo dummies 95 civic d16z6 to 97 d16y8
- Headlamp problems in ej1
- Lowering spring on stock shocks..
- 99 civic si misfiring on cylinder 3 and 4
- 93 b16 coupe ide surge issue
- how much oil
- civic running rich
- MAKING VTEC SOUND BOLDER!!!!
- Car locks
- Freaking impossible electrical problem???? WTF
- GSR tranny case crack.
- 95 Turn Signal Problems
- Caught the ****ing theives yesturday.
- Code 9 No.1 cylinder position sensor
- 94 eg coupe h22 no reving past 2 grand
- MAP Sensor code....car ran fine yesterday...please help got a big trip this weekend!
- b16a 1st gen build questions? help please! lots of good questions!
- Headlight - one doesn't work
- b20 with a pr4 ecu?
- Is there a way to quickly test vafc2?
- Are all EG gas tanks the same?
- help with my ek fuel issue
- 97 del sol fogs
- need new hood
- quick ? about cams...
- Ls seats in my ek
