View Full Version : Honda Civic / Del Sol (1992 - 2000)
- h22a del sol
- Lost my wheel lock key!>!
- Doing Swap! Need HELP! Wiring Harness!
- nitrous B20vtec estimated track time?
- What setup is best for me?
- JDM recaro srd
- Color of Rotors????
- any coupes with cages ? post up !!
- Is this CX worth it?
- should i go with a JDM d15b or d16y8 for my turbo project?
- UNDER AXLE setup...where did my low end torque go ?
- 90-91 si wiring harness
- HOw to make your car doors make a satisfying thud when they close?
- Setting V-AFC
- test pipe problems!! help
- tranny ok? metal shavings and looseness...
- new header,cat and o2sensor placement question
- size of rear sway on stock 93 gsr teg?
- 3 wire to 3 wire CKP in EK running OBD1?
- please dont laugh
- just installed 2000 b16 in my 96 dx civic 'important'?
- what color red
- Exhaust Header installation (o2 sensor)
- some drifting clips
- FI guy who needs new supsension/brakes...
- Skunk2 ball joint boot
- Where do I get the premade Grill mesh stuff?
- Lockable/Detatchable steering hubs. Any recommendatons?
- Cusco Pillowball Mounts and Skunk2 Coilovers
- B18C Injector Question
- Lemoore!!!
- need help with B&M fuel pressure regulator
- I need headroom in my 2k Civic EX
- Engine question
- Civic is overheating :(
- h22a, h22a-s,h23a, whats the diff?
- EG and EK seat rails the same?
- how do u install a dc2 dash in an eg?????
- where can i get del sol fog lights?
- 90-91 Teg seats fit in EGs??
- Removing Climate control
- D16Z6 head on Y8 block does it bolt right on ??
- D16Z6 whats the Difference between this block and the Y8 block
- HELP WITH SRS LIGHT PLUG!!
- I need a wiring harness
- Need 99-00 Civic EX Climate Control With AC
- Removal of emission lines/canister on EG VX?
- AGX ??'s
- will stock EK civic (96-00) fit EG civic (92-95)?
- D16Y8 All-Motor Dyno
- Which LS Block is the best to do Ls/vtec?
- Dealership work/ T-belt-water pump = $700 parts/Labor?
- VTEC OR NOT VETEC THAT IS THE QUESTION?
- Hybrid Emissions
- rad question??????
- Seats
- trying to get rid of
- Will 02 or 02 si seats fit into the ek hatch
- HELP e brake doesnt line up
- Acura TL-S oil filter?
- Swaybar help
- ECU LIGHT?
- Speedometer Broken
- ITR Exhaust into a 93 coupe????
- Coilover sleeve question....
- Headers
- WILL THIS FIT?
- Snap on tools...can you get them or let me borrow one??
- Civic, Integra or CL???????????
- Del sol Rear sway
- Where do I find longer studs for the Intake Mani?
- Q on honda stock shifter
- Civic Side Marker Wiring?
- How much is my friends car worth. thanks..
- eg hatch 16x7 tire sizes?!?
- vibes ?
- Help finding a thread?
- Whatchya Think?...
- what do you guys think about mileage on eg hatches?
- so i'm NOT going to sell out...
- 99 civic radiator support for my 96 civic conversion to 99 civic?
- just ran my car in the 1320, fairly happy.
- d16Z6 with Y8 intake manifold?
- What Do I Do now???
- exhaust sounds weird.. really weird!
- My Car
- Pedal Question
- Air Breather?
- dumb dizzy question for d series......but i was wondering
- car won't start!!!!!!!
- Getting my car repainted again...Day 2 & 3...
- what times should i see out of my eg
- cam question!
- help wong out with his stereo problem:(
- Need fast fast help with glass on gauge cluster
- Vafc or Safc
- 96 civic dx / B16
- lowering springs on del sol
- What makes a D15b so great
- Anyone around DFW have a spare integra tranny mount for sale?
- Spoon N1 silencer
- ls+turbo vs. gsr+nos
- JDM Del Sol License Plate Filler Install ?'s
- SOHC Edelbrock manifold is installed.
- my set up is finished
- quick release steering hub
- intake air temp ?
- Just came back from the track
- clutch problems
- subframe reinforcement?
- 98 GS-R motor
- Thermostat Question
- Will rsx seats fit into my EK hatch
- Brake caliper paint? Which paint to use?
- You have a 96 Hatch with RM-Spec coilovers. What sway bar first?
- Buy the b18b or the b20b?
- all motor video of my 94 civic si hatch with jdm gsr motor
- Partial Gauge cluster Swap
- swap wiring
- Part Number For Map Sensor?
- ek shocks fit into eg?
- Del Sol Headlamps/Headlight Assemblies
- 97-01 JDM Prelude wheel?
- For those that need moldings...
- 96-98 civic type r center console
- how much is this hatch worth?
- EG# Question
- whens the next hybrid meet in so.cal?
- Remote Start on 5 speed... do i have it right?
- lowering springs or coilovers?
- Installing Greddy intercooler on my EG
- how to paint rims?
- d16z6 to jdm d15b
- best tein kit?
- smoke comes out of exhaust
- crankshaft pulley bolt help!!!!
- Whats the best way to blow $1000?
- Water pump won’t come off.
- Just dropped my car off today to get it painted white.
- what axels do you use?
- 99-00 Civic Si rear rotors & 94-01 Integra GSR rear rotors
- wich engine is better for this car? h22 or h23
- b18c1 swap- funky shit happening
- stand alone?
- gurgling fuel pump
- HCP ek 18c mounts. Cable tranny in a EK????????couple of questions
- !!!!!HELP!!!!!TRANSAXLE BOLTS STUCK!!!!!!!!
- What kind of exhaust system ist this ? Fujitsubo Legalis Viable
- gasket help please!
- i need to know how to make a vtec controller!!!!!!! PLEASE HELP
- code for 96+ ex tranny
- rotas 15 vs. 16
- ripples in fenders... body damage?
- Stunna Sparco question
- verify this---some 1993 civic si's with lsd?
- What could cause timing marks the be misalined
- Picture of a Carbon Fiber TypeR style lip for an EG???
- fields vtec controller wiring help.
- Where to put ground wire kit!
- just put on exhaust smell bad
- 61mm z6 IM and 61.5mm B20 TB on a D16y8 head? Gains?
- Need Help
- sway bar ???s
- times on my new B16 EG coupe
- FOR SALE H22
- d16z6 performing like crap.
- Callin IVAN
- Swaybars for EG6 dx
- Post question
- need help with coil overs
- Swap question- Del Sol SOHC 1.6 vtec can I just drop it into a crx without mounts?
- Adjusting Idle
- trunk lid for 92-95 civic
- KONI Red or KYB AGX
- type of fuel injectors to buy?
- where to get sparco steering wheel and hub?
- springs?
- NEED VALVE LASH PROCEDURE 99 CIVIC
- Anyone know a good place to buy a Skunk2 camber kit at?
- r/s ratio on a b20
- EK Power steering/sway bar conversion how to.
- need left front upper control arm plus good balljoint
- Where can I buy?
- Wheel studs......
- PLEASE HELP NEEDED, BUTTERFLIES AND KNOCK SENSOR WIRING
- how to get my factory cd player out?????
- springs?
- 99EX Coupe...Removal of interior panels and back seat?
- Car worth more with swap?
- how much del sol wheels weight?
- Code 45 and 90 ??
- D15B VTEC into 95 CX?
- all motor or turbo???
- honda junkyard
- anyone know what size rims and tires fit and look good on 96 civic hatchback?
- Size of B18B TB?
- Beaks wants to charge me $95 for a pair of Si endlinks
- Going to buy a 96 hatch... what to look for?
- can someone help me with my power door locks?
- Y3 tranny?
- Need a pic fast of the pullies/belts on a 94 Civic engine
- OMG.. i'm banned
- Transmition oil change
- Help b18b running way too rich!!!!
- how can i tell apart a d16z6 (si) tranny from a CX
- Are there shorter rear lower control arms for 1996-2000 Civics?
- would a header really help a d16y8?
- My EK was just stolen
- max revs
- Autolamps H4 Hylow Philips Ultinon HID kit w/99-00 OEM CTR headlamps (no 56k)
- how can you tell if a b16a2 has lsd
- Subframe bolt torque
- wheel hub assembly question...
- replace input shaft bearing or find another s20 (z6 or si) tranny
- EX Headers
- How to? Replace rear hub assembly (wheel bearing) on 92 Si with rear discs?
- Are new ground wires worth it?
- hood pins??? (newb)
- Is a block from a 92-95 civic ex the same as a block from a 96-00 ex?
- camber kit
- studs
- dash
- Spark Plug wires keep popping out
- EK bumper QUESTions
- service interval of rad hoses??
- Stripped the strut tower nut that intakes mount to....suggestions?
- Differences between 96-98 and 99-00 Hatchback?
- 1/4 & 1/8 Times For a SOHC stock 94 EX
- Driving Gear struts anyone use them?
- Apexi N1 Coilovers
- Blown tranny, need help/info...
- i got owned (again)
- Climate control bulb size for EK
- i need pics of buddy club wheels
- Valve cover queston....
- Anybody have experience with these (St Corsa) camgears? It's guaranteed not to slip
- sf bay D series cars, skunk2 mani dyno deal?!
- Getting my car painted again...day 1...
- what is wrong with my signal lights??help!
- POST PICS OF YOUR EXHAUST SYSTEM ON A EG HATCH....
- Needing of pictures, (motormount+autotranny) ek-auto for junk yard
- J's racing air duct for EG civic
- 5Zigen Fireball/5Zigen Border Speed which better?
- I Need Help Plaese, transmission problems
- I need help on installing Ractive G1000 7 color Tach.
- newmember
- Will a Spoon N1 for an itr work on a 00 si
- INSTALL: CTR side marker template... HelP!
- exhaust gaskets ?
- Looking for Peeps in San Antonio, Tx., and Prescott, Az.
